My computer is running very slow
lopuxxl
3
25
  1. It all started when windows update started and I was shutting down my pc. After that i couldn't turn it on so I bought a new ssd, installed windows to it.when I turned it on my pc started running very slow.
    my specs:
    motherboard ga-h87-hd3
    processor intel i5-4570 @ 3.20Ghz
    gpu gigabyte 1060 windforce oc 2
    ram 8 ddr3
  2. ssd kingston 240gb
Hello lopuxxl,
Can you post the brand and model name or number of your power supply for us if you will.
the brand or model names isn't writen on it and i've lost the box but it's 600w
600W sounds great not having any information label on the PSU suggests that it is not a good brand, this means that it is most unlikely to be able to produce anywhere 600W or the required amps on the +12V so cannot be guaranteed to be 100% safe for use with your hardware, do what you can to try and find the info for us, if you bought it online, post the link etc, meanwhile;
My apologies lopuxxl for some reason I either missed or did not receive notification of your reply #6 :(
Only thing that I am seeing in Speccy is the fact that you have multiple AV programs installed, this is a recipe for disaster, the programs will conflict as they fight for resources and this will not only slow down your computer but can ultimately leave you with no AV protection at all,
If your Avast or MBAM AV protection paid for products, please make a note of their product key numbers and then uninstall them using the tools here and here once done, allow Windows Defender to check for updates, do a full scan of the computer then post back with an update for us.
Antivirus
Avast Antivirus
Antivirus: Disabled
Windows Defender
Antivirus: Disabled
Malwarebytes
Antivirus: Enabled
Reactions: gus
Any update for us lopuxxl? If unreplied to within 48hrs this thread will be closed.
