Motherboard compatible with a thunderbolt expansion ?
LEVII
23
Hello everyone, a friend of mine who stopped playing music gave me his apollo twin x duo sound card which only works in thunderbolt 3, only I don't think my motherboard has a thunderbolt port. I would like to know if buying a thunderbolt expansion will be compatible with my motherboard which is an asus strix z270f gaming
Can you give me more explanation please ?
I downloaded the software, do you need a screenshot to check ?
You run the software then you post the link. here.
Nothing in the file is on any help or use to hackers.
Which thunderbolt expasion card are you looking at buying
Do you have a link
