Ok so, I've checked all the connections and they all seem to be firmly connected, I've removed my RAM, gave it a clean off incase of any dust on the pins and reconnected.
I've changed the power plan to balanced.
I'm not 100% about the drivers, I did install AMD chipset drivers but I noticed they seemed to make my system more unstable? I've given them a go a few times but always seemed to make it more unstable.
If it is any help in diagnosing the problem, when it started 6 months ago and the pc would not detect my screen at all, the pc was working fine. As in, I would turn the pc on and I could log on. I knew I could successfully log on as when I do my mouse always changes colour to what I have it set to in the Razer software and it always did so, it just wouldn't show an image. I can also confirm that the fans on the GPU continue to spin during a crash, both now and then.
I have included below the information from the software that you requested.
MiniToolBox by Farbar Version: 13-05-2022
Ran by danie (administrator) on 03-10-2024 at 14:25:44
Running from "F:\Downloads"
Microsoft Windows 11 Home (X64)
Model: X570 I AORUS PRO WIFI Manufacturer: Gigabyte Technology Co., Ltd.
Boot Mode: Normal
Application errors:
Error: (10/03/2024 02:07:44 PM) (Source: Application Error) (EventID: 1000) (User: NT AUTHORITY)
Description: Faulting application name: CorsairCpuIdService.exe, version: 5.18.106.0, time stamp: 0x66b4883c
Faulting module name: ntdll.dll, version: 10.0.22621.4111, time stamp: 0x518e67bb
Exception code: 0xc00000fd
Fault offset: 0x000000000003d518
Faulting process id: 0x0x3d54
Faulting application start time: 0x0x1db159539f4f5ab
Faulting application path: C:\Program Files\Corsair\Corsair iCUE5 Software\CorsairCpuIdService.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: ca20ebe4-5383-45e5-92b7-518a2ece0dbb
Faulting package full name:
Error: (10/03/2024 02:07:32 PM) (Source: CertEnroll) (EventID: 86) (User: NT AUTHORITY)
Description: Event-ID 86
Error: (10/03/2024 02:07:31 PM) (Source: CertEnroll) (EventID: 86) (User: NT AUTHORITY)
Error: (10/03/2024 01:35:06 AM) (Source: VSS) (EventID: 8193) (User: )
Description: Volume Shadow Copy Service error: Unexpected error calling routine CoCreateInstance. hr = 0x8007045b, A system shutdown is in progress.
Error: (10/03/2024 01:35:06 AM) (Source: VSS) (EventID: 13) (User: )
Description: Volume Shadow Copy Service information: The COM Server with CLSID {4e14fba2-2e22-11d1-9964-00c04fbbb345} and name CEventSystem cannot be started. [0x8007045b, A system shutdown is in progress.
Error: (10/02/2024 09:30:02 PM) (Source: CertEnroll) (EventID: 86) (User: NT AUTHORITY)
Error: (10/02/2024 02:31:50 PM) (Source: CertEnroll) (EventID: 86) (User: NT AUTHORITY)
Error: (10/02/2024 02:31:49 PM) (Source: CertEnroll) (EventID: 86) (User: NT AUTHORITY)
Error: (10/02/2024 01:40:47 AM) (Source: Application Error) (EventID: 1000) (User: DANSPC)
Description: Faulting application name: Widgets.exe, version: 524.24900.90.0, time stamp: 0x66e5e1e3
Faulting module name: Geolocation.dll, version: 10.0.22621.3672, time stamp: 0x8d1850a1
Exception code: 0xc0000005
Fault offset: 0x0000000000012981
Faulting process id: 0x0x2ea8
Faulting application start time: 0x0x1db1451c9710b78
Faulting application path: C:\Program Files\WindowsApps\MicrosoftWindows.Client.WebExperience_524.24900.80.0_x64__cw5n1h2txyewy\Dashboard\Widgets.exe
Faulting module path: C:\Windows\System32\Geolocation.dll
Report Id: 3ae1fa71-4300-4394-9d9a-948910a5c7ae
Faulting package full name: MicrosoftWindows.Client.WebExperience_524.24900.80.0_x64__cw5n1h2txyewy
Faulting package-relative application ID: Widgets
System errors:
Error: (10/03/2024 02:16:03 PM) (Source: Microsoft-Windows-TPM-WMI) (EventID: 1796) (User: NT AUTHORITY)
Description: The Secure Boot update failed to update a Secure Boot variable with error -2147020471. For more information, please see
https://go.microsoft.com/fwlink/?linkid=2169931
Error: (10/03/2024 02:07:47 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The Corsair CpuIdService service terminated unexpectedly. It has done this 1 time(s).
Error: (10/03/2024 02:07:24 PM) (Source: Microsoft-Windows-TPM-WMI) (EventID: 1796) (User: NT AUTHORITY)
Error: (10/02/2024 09:30:04 PM) (Source: Microsoft-Windows-TPM-WMI) (EventID: 1796) (User: NT AUTHORITY)
Error: (10/02/2024 09:29:50 PM) (Source: volmgr) (EventID: 161) (User: )
Description: Dump file creation failed due to error during dump creation.
Error: (10/02/2024 09:29:57 PM) (Source: EventLog) (EventID: 6008) (User: )
Description: The previous system shutdown at 9:27:46 PM on 10/2/2024 was unexpected.
Error: (10/02/2024 09:23:21 PM) (Source: nvlddmkm) (EventID: 153) (User: )
Description: Event-ID 153
Error: (10/02/2024 06:00:01 PM) (Source: Microsoft-Windows-TPM-WMI) (EventID: 1796) (User: NT AUTHORITY)
Error: (10/02/2024 02:40:38 PM) (Source: Microsoft-Windows-TPM-WMI) (EventID: 1796) (User: NT AUTHORITY)
Windows Defender:
Date: 2024-10-01 15:36:24
Description:
Microsoft Defender Antivirus scan has been stopped before completion.
Scan Type: Antimalware
Scan Parameters: Quick Scan
Date: 2024-09-30 15:11:50
Description:
Date: 2024-09-26 15:17:32
Description:
Date: 2024-09-14 15:09:59
Description:
Date: 2024-08-28 14:26:12
Description:
CodeIntegrity Errors:
Date: 2024-10-03 14:07:54
Description:
Code Integrity determined that a process (\Device\HarddiskVolume4\Users\danie\AppData\Local\Discord\app-1.0.9165\Discord.exe) attempted to load \Device\HarddiskVolume4\ProgramData\obs-studio-hook\graphics-hook64.dll that did not meet the Microsoft signing level requirements.
Date: 2024-10-01 14:49:22
Description:
Code Integrity determined that a process (\Device\HarddiskVolume4\Users\danie\AppData\Local\Discord\app-1.0.9164\Discord.exe) attempted to load \Device\HarddiskVolume4\ProgramData\obs-studio-hook\graphics-hook64.dll that did not meet the Microsoft signing level requirements.
7-Zip 24.08 (x64) (HKLM\...\7-Zip) (Version: 24.08 - Igor Pavlov)
Alan Wake 2 (HKLM-x32\...\Alan Wake 2_is1) (Version: - )
Assassin's Creed Mirage (HKLM-x32\...\Uplay Install 6100) (Version: - Ubisoft)
Car Mechanic Simulator 2021 (HKLM-x32\...\Car Mechanic Simulator 2021_is1) (Version: - )
CCleaner (HKLM\...\CCleaner) (Version: 6.28 - Piriform)
Core Temp 1.18.1 (HKLM\...\{086D343F-8E78-4AFC-81AC-D6D414AFD8AC}_is1) (Version: 1.18.1 - ALCPU)
Corsair iCUE5 Software (HKLM\...\{A9B0B2D7-8C59-4413-A2FB-99EDBE65A608}) (Version: 5.18.106 - Corsair)
CPUID CPU-Z 2.09 (HKLM\...\CPUID CPU-Z_is1) (Version: 2.09 - CPUID, Inc.)
Documentation Manager (HKLM\...\{94DE47AB-3149-4877-8547-DDA27945A1F2}) (Version: 23.70.2.3 - Intel Corporation) Hidden
Dustborn (HKLM-x32\...\Dustborn_is1) (Version: - )
EA app (HKLM\...\{C2622085-ABD2-49E5-8AB9-D3D6A642C091}) (Version: 13.297.0.5810 - Electronic Arts) Hidden
EA app (HKLM-x32\...\{4566c3be-2b12-4de0-9f0f-72bd6e3b1c4d}) (Version: 13.297.0.5810 - Electronic Arts)
ENE Video Capture Box HAL (HKLM\...\{A096611D-BA11-4A1A-8D09-0A0462D7C8F2}) (Version: 1.0.5.15 - Ene Tech.) Hidden
ENE Video Capture Box HAL (HKLM-x32\...\{974259bf-3ed1-4cd6-9ed1-40c7f601a786}) (Version: 1.0.5.15 - Ene Tech.) Hidden
ENE_AIC_Marvell_HAL (HKLM\...\{085E2365-0A70-4230-B664-02D5E4FE7E9C}) (Version: 1.0.7.0 - ENE TECHNOLOGY INC.) Hidden
ENE_AIC_Marvell_HAL (HKLM-x32\...\{887e18fb-6bc3-4cd4-b34e-32d9ff71bbae}) (Version: 1.0.7.0 - ENE TECHNOLOGY INC.) Hidden
ENE_DRAM_RGB_AIO (HKLM\...\{5B5CE185-F845-487D-824D-9D02A8B778FB}) (Version: 1.0.9.1 - Ene Tech.) Hidden
ENE_DRAM_RGB_AIO (HKLM-x32\...\{661c7ac8-4c45-4772-ba1d-090085dde688}) (Version: 1.0.9.1 - Ene Tech.) Hidden
ENE_EHD_M2_HAL (HKLM\...\{37A48B7F-D4EA-4863-844E-A284E2AA3C5D}) (Version: 1.0.12.2 - ENE TECHNOLOGY INC.) Hidden
ENE_EHD_M2_HAL (HKLM-x32\...\{3f5a70c6-60da-4ae9-8072-a51aa4dc08ee}) (Version: 1.0.12.2 - ENE TECHNOLOGY INC.) Hidden
ENE_External_Device_HAL (HKLM\...\{2B8E611F-0B51-4FAC-87BB-AF50D82E7DDA}) (Version: 1.0.12.7 - ENE Tech) Hidden
ENE_External_Device_HAL (HKLM-x32\...\{a7b1cf47-d8f0-423d-9494-568195f1c864}) (Version: 1.0.12.7 - ENE Tech) Hidden
ENE_MousePad_HAL (HKLM\...\{9E97178A-ADB8-4778-BE60-7E28E2A72721}) (Version: 1.0.1.8 - ENE TECHNOLOGY INC.) Hidden
ENE_MousePad_HAL (HKLM-x32\...\{bf256b46-8ff7-48be-ab7f-5661e9a0651f}) (Version: 1.0.1.8 - ENE TECHNOLOGY INC.) Hidden
ENE_X_AIC_HAL (HKLM\...\{CF703694-01C6-4062-B797-84DB215662BC}) (Version: 1.0.6.3 - ENE TECHNOLOGY INC.) Hidden
ENE_X_AIC_HAL (HKLM-x32\...\{c662a481-d76a-4188-95d2-6eb4ffd55542}) (Version: 1.0.6.3 - ENE TECHNOLOGY INC.) Hidden
Epic Games Launcher (HKLM-x32\...\{B85FAA6E-A9AA-4655-9029-E1A4EDC05E1A}) (Version: 1.3.93.0 - Epic Games, Inc.)
Epic Games Launcher Prerequisites (x64) (HKLM\...\{F9C5C994-F6B9-4D75-B3E7-AD01B84073E9}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Epic Online Services (HKLM-x32\...\{57A956AB-4BCC-45C6-9B40-957E4E125568}) (Version: 2.0.44.0 - Epic Games, Inc.)
Euro Truck Simulator 2 (HKLM\...\Steam App 227300) (Version: - SCS Software)
Euro Truck Simulator 2 (HKLM-x32\...\Euro Truck Simulator 2_is1) (Version: - )
Gas Station Simulator (HKLM-x32\...\Gas Station Simulator_is1) (Version: - )
GOG GALAXY (HKLM-x32\...\{7258BA11-600C-430E-A759-27E2C691A335}_is1) (Version: 2.0.73.27 - GOG.com)
Hard Disk Sentinel (HKLM-x32\...\Hard Disk Sentinel_is1) (Version: 6.20 - Janos Mathe)
House Flipper 2 (HKLM-x32\...\House Flipper 2_is1) (Version: - )
HWiNFO® 64 (HKLM\...\HWiNFO® 64_is1) (Version: 8.12 - Martin Malik, REALiX s.r.o.)
Intel Driver && Support Assistant (HKLM-x32\...\{FD1F89D7-58B0-4AEA-995D-72D07C5302A4}) (Version: 24.5.40.11 - Intel) Hidden
Intel(R) Computing Improvement Program (HKLM\...\{89E7E64C-A30C-4D24-9D12-B354CA2335DE}) (Version: 2.4.10888 - Intel Corporation)
Intel(R) Wireless Bluetooth(R) (HKLM-x32\...\{00003070-0230-1033-84C8-B8D95FA3C8C3}) (Version: 23.70.3.1 - Intel Corporation)
Intel® Driver & Support Assistant (HKLM-x32\...\{43826762-6E01-46B8-81D5-79BA90ABED2F}) (Version: 24.5.40.11 - Intel)
Intel® Software Installer (HKLM-x32\...\{2f7b77cf-9080-41ab-b879-938730a33f60}) (Version: 23.70.2.3 - Intel Corporation) Hidden
Launcher Prerequisites (x64) (HKLM-x32\...\{43a03b9c-4770-409c-a999-587b60700b63}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
L-Connect (HKLM-x32\...\{69720AC4-DC3C-4F1A-972E-4F56579126D0}_is1) (Version: 1.00.00 - L-Connect)
Malwarebytes version 5.1.10.127 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 5.1.10.127 - Malwarebytes)
MediaHuman YouTube to MP3 Converter 3.9.9.90 (HKLM-x32\...\MediaHuman YouTube to MP3 Converter_is1) (Version: 3.9.9.90 - MediaHuman)
Microsoft Update Health Tools (HKLM\...\{C6FD611E-7EFE-488C-A0E0-974C09EF6473}) (Version: 5.72.0.0 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
MSI Afterburner 4.6.5 (HKLM-x32\...\Afterburner) (Version: 4.6.5 - MSI Co., LTD)
NVIDIA FrameView SDK 1.4.9615.33661400 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_FrameViewSdk) (Version: 1.4.9615.33661400 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.28.0.417 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.28.0.417 - NVIDIA Corporation)
NVIDIA Graphics Driver 561.09 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 561.09 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.4.0.1 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.4.0.1 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.23.1019 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.23.1019 - NVIDIA Corporation)
NVIDIA USBC Driver 1.52.831.832 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_USBC) (Version: 1.52.831.832 - NVIDIA Corporation)
NZXT CAM 4.68.3 (HKLM\...\ac0666ae-ee66-5310-ac01-9d6348133b2d) (Version: 4.68.3 - NZXT, Inc.)
OBS Studio (HKLM-x32\...\OBS Studio) (Version: 30.1.2 - OBS Project)
OpenAL (HKLM-x32\...\OpenAL) (Version: - )
Patriot Viper M2 SSD RGB (HKLM\...\{8B4C0A3D-C135-4E1F-98D8-3926494B4D61}) (Version: 1.1.0.1 - Patriot Memory) Hidden
Patriot Viper M2 SSD RGB (HKLM-x32\...\{07236f40-ec25-4646-8cb6-b6aaf1597324}) (Version: 1.1.0.1 - Patriot Memory) Hidden
Plague Inc Evolved (HKLM-x32\...\Plague Inc Evolved_is1) (Version: v.1.19.1.0.build.9770563 - Decepticon)
Police Simulator: Patrol Officers (HKLM-x32\...\Police Simulator: Patrol Officers_is1) (Version: - )
PowerWash Simulator (HKLM-x32\...\PowerWash Simulator_is1) (Version: - )
RAD Video Tools (HKLM-x32\...\RADVideo) (Version: - RAD Game Tools, Inc.)
Razer Synapse (HKLM-x32\...\Razer Synapse) (Version: 3.9.0806.081316 - Razer Inc.)
Resistance: Fall of Man (HKLM-x32\...\Resistance: Fall of Man_is1) (Version: - )
RGB Fusion (HKLM-x32\...\{FFA8F1FA-3C2C-4A94-AC0B-0DF47272C25F}) (Version: 3.24.0318.1 - Gigabyte)
Sound Editor (HKLM-x32\...\Sound Editor) (Version: 2.1.0.1 - TheVisitorX)
Speccy (HKLM\...\Speccy) (Version: 1.33 - Piriform)
Starfield (HKLM-x32\...\Starfield_is1) (Version: - )
TechPowerUp GPU-Z (HKLM-x32\...\{8B0F211E-5846-4FB2-B0B9-4EB31546FDF9}}_is1) (Version: 2.59.0 - TechPowerUp)
Train Sim World® 5 (HKLM\...\Steam App 2967990) (Version: - Dovetail Games)
TreeSize Free V4.7.3 (64 bit) (HKLM\...\TreeSize Free_is1) (Version: 4.7.3 - JAM Software)
Tropico 6 (HKLM-x32\...\Tropico 6_is1) (Version: - )
Ubisoft Connect (HKLM-x32\...\Uplay) (Version: 151.2.11050 - Ubisoft)
Verbatim_SureFireGaming_Product (HKLM\...\{35CB65C6-A7E3-4EE7-AD40-738D70A72164}) (Version: 1.0.3.11 - Verbatim) Hidden
Verbatim_SureFireGaming_Product (HKLM-x32\...\{d601832a-0d94-46ce-9b19-78e8a5887313}) (Version: 1.0.3.11 - Verbatim) Hidden
WD P40 Game Drive (HKLM\...\{EE55DBAE-ECDD-4ADD-AAB5-23DE848B0996}) (Version: 1.0.2.18 - Western Digital Corporation) Hidden
WD P40 Game Drive (HKLM-x32\...\{72b1a866-fc31-4381-bff3-fa6cd8823777}) (Version: 1.0.2.18 - Western Digital Corporation) Hidden
WinRAR 7.00 (64-bit) (HKLM\...\WinRAR archiver) (Version: 7.00.0 - win.rar GmbH)
Wondershare Helper Compact 2.5.3 (HKLM-x32\...\{5363CE84-5F09-48A1-8B6C-6BB590FFEDF2}_is1) (Version: 2.5.3 - Wondershare)
WWE 2K24 (HKLM-x32\...\WWE 2K24_is1) (Version: - )
Packages:
Copilot -> C:\Program Files\WindowsApps\Microsoft.Copilot_1.0.4.0_neutral__8wekyb3d8bbwe [2024-10-01] (Microsoft Corporation)
Lively Wallpaper -> C:\Program Files\WindowsApps\12030rocksdanister.LivelyWallpaper_1.0.144.0_x64__97hta09mmv6hy [2024-10-02] (rocksdanister) [Startup Task]
Microsoft Advertising SDK for XAML -> C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.1811.1.0_x64__8wekyb3d8bbwe [2024-05-13] (Microsoft Corporation) [MS Ad]
Microsoft Advertising SDK for XAML -> C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.1811.1.0_x86__8wekyb3d8bbwe [2024-05-13] (Microsoft Corporation) [MS Ad]
Microsoft.WindowsAppRuntime.CBS -> C:\Windows\SystemApps\Microsoft.WindowsAppRuntime.CBS_8wekyb3d8bbwe [2024-06-13] (Microsoft Corporation)
ms-resource://MicrosoftCorporationII.QuickAssist/resources/APP_WINDOW_NAME -> C:\Program Files\WindowsApps\MicrosoftCorporationII.QuickAssist_2.0.32.0_x64__8wekyb3d8bbwe [2024-10-01] (Microsoft Corp.)
ms-resource://MicrosoftWindows.CrossDevice/CrossDevice.Core/Resources/PackageName -> C:\Program Files\WindowsApps\MicrosoftWindows.CrossDevice_1.24082.53.0_x64__cw5n1h2txyewy [2024-10-01] (Microsoft Windows) [Startup Task]
ms-resource:AppStoreName -> C:\Program Files\WindowsApps\Microsoft.RawImageExtension_2.3.2051.0_x64__8wekyb3d8bbwe [2024-08-07] (Microsoft Corporation)
ms-resource:AppStoreName -> C:\Program Files\WindowsApps\Microsoft.Windows.DevHome_0.1800.640.0_x64__8wekyb3d8bbwe [2024-10-02] (Microsoft Corporation)
ms-resource:AppStoreName -> C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2024.11070.31001.0_x64__8wekyb3d8bbwe [2024-08-07] (Microsoft Corporation) [Startup Task]
ms-resource:AppxManifest_DisplayName -> C:\Windows\SystemApps\Microsoft.Windows.PrintQueueActionCenter_cw5n1h2txyewy [2024-04-25] (Microsoft Corporation)
ms-resource:Clipchamp/AppName -> C:\Program Files\WindowsApps\Clipchamp.Clipchamp_3.1.11720.0_neutral__yxz26nhyzhsrt [2024-10-01] (Microsoft Corp.)
NVIDIA Control Panel -> C:\Program Files\WindowsApps\NVIDIACorp.NVIDIAControlPanel_8.1.966.0_x64__56jybvy8sckqj [2024-10-01] (NVIDIA Corp.)
Outlook for Windows -> C:\Program Files\WindowsApps\Microsoft.OutlookForWindows_1.2024.925.200_x64__8wekyb3d8bbwe [2024-10-01] (Microsoft Corporation)
Realtek Audio Control -> C:\Program Files\WindowsApps\RealtekSemiconductorCorp.RealtekAudioControl_1.1.137.0_x64__dt26b99r8h8gj [2024-09-19] (Realtek Semiconductor Corp)
Torrex Lite - Torrent Downloader -> C:\Program Files\WindowsApps\BooStudioLLC.TorrexLite-TorrentDownloader_1.4.46.0_x64__b6e429xa66pga [2024-10-01] (Finebits OÜ) [Startup Task]
TranslucentTB -> C:\Program Files\WindowsApps\28017CharlesMilette.TranslucentTB_2024.1.0.0_x64__v826wp6bftszj [2024-05-22] (Charles Milette) [Startup Task]
Ultimate Photo Editor -> C:\Program Files\WindowsApps\35450PhotoCoolApps.UltimatePhotoEditor_2.1.4.0_x64__61cxy7b35vdsg [2024-10-01] (Photo Cool Apps)
Video To Mp3 Converter,Video Trimmer -> C:\Program Files\WindowsApps\39492FruitCandy.VideoToMp3ConverterVideoTrimmer_1.1.7.0_x64__xnewyr70hrxjw [2024-09-19] (Fruit Candy) [MS Ad]
Widgets Platform Runtime -> C:\Program Files\WindowsApps\Microsoft.WidgetsPlatformRuntime_1.4.0.0_x64__8wekyb3d8bbwe [2024-09-06] (Microsoft Corporation)
WinAppRuntime.Main.1.5 -> C:\Program Files\WindowsApps\MicrosoftCorporationII.WinAppRuntime.Main.1.5_5001.214.1843.0_x64__8wekyb3d8bbwe [2024-08-15] (Microsoft Corp.)
WinAppRuntime.Singleton -> C:\Program Files\WindowsApps\MicrosoftCorporationII.WinAppRuntime.Singleton_6000.266.2241.0_x64__8wekyb3d8bbwe [2024-10-02] (Microsoft Corp.)
WinDbg -> C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2409.17001.0_x64__8wekyb3d8bbwe [2024-09-19] (Microsoft Corporation)
Windows Feature Experience Pack -> C:\Windows\SystemApps\LKG\MicrosoftWindows.LKG.AccountsService_cw5n1h2txyewy [2024-09-14] (Microsoft Windows)
Windows Feature Experience Pack -> C:\Windows\SystemApps\LKG\MicrosoftWindows.LKG.DesktopSpotlight_cw5n1h2txyewy [2024-09-14] (Microsoft Windows)
Windows Feature Experience Pack -> C:\Windows\SystemApps\LKG\MicrosoftWindows.LKG.IrisService_cw5n1h2txyewy [2024-09-14] (Microsoft Windows)
Windows Feature Experience Pack -> C:\Windows\SystemApps\MicrosoftWindows.Client.Core_cw5n1h2txyewy [2024-09-14] (Microsoft Windows)
Windows Feature Experience Pack -> C:\Windows\SystemApps\MicrosoftWindows.Client.FileExp_cw5n1h2txyewy [2024-09-14] (Microsoft Windows)
WindowsAppRuntime.1.3 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.3_3000.934.1904.0_x64__8wekyb3d8bbwe [2024-04-18] (Microsoft Corporation)
WindowsAppRuntime.1.3 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.3_3000.934.1904.0_x86__8wekyb3d8bbwe [2024-04-18] (Microsoft Corporation)
WindowsAppRuntime.1.4 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.4_4000.1309.2056.0_x64__8wekyb3d8bbwe [2024-09-10] (Microsoft Corporation)
WindowsAppRuntime.1.4 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.4_4000.1309.2056.0_x86__8wekyb3d8bbwe [2024-09-10] (Microsoft Corporation)
WindowsAppRuntime.1.5 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.5_5001.159.55.0_x64__8wekyb3d8bbwe [2024-06-12] (Microsoft Corporation)
WindowsAppRuntime.1.5 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.5_5001.178.1908.0_x64__8wekyb3d8bbwe [2024-07-10] (Microsoft Corporation)
WindowsAppRuntime.1.5 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.5_5001.214.1843.0_x64__8wekyb3d8bbwe [2024-08-15] (Microsoft Corporation)
WindowsAppRuntime.1.5 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.5_5001.214.1843.0_x86__8wekyb3d8bbwe [2024-08-15] (Microsoft Corporation)
WindowsAppRuntime.1.6 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.6_6000.266.2241.0_x64__8wekyb3d8bbwe [2024-10-02] (Microsoft Corporation)
WindowsAppRuntime.1.6 -> C:\Program Files\WindowsApps\Microsoft.WindowsAppRuntime.1.6_6000.266.2241.0_x86__8wekyb3d8bbwe [2024-10-02] (Microsoft Corporation)
WinRAR -> C:\Program Files\WinRAR [2024-04-18] (0)
XLSX Editor: Sheet Reader -> C:\Program Files\WindowsApps\29982SibistLtd.XLSXEditorXLSReader_1.0.5.0_x86__rd00eeepyhwr8 [2024-06-14] (Match 3 games studio)
Percentage of memory in use: 37%
Total physical RAM: 16306.45 MB
Available physical RAM: 10121.03 MB
Total Virtual: 38834.45 MB
Available Virtual: 29691.48 MB
1 Drive c: (Operating System and Apps) (Fixed) (Total:244.14 GB) (Free:103.52 GB) NTFS
2 Drive d: (DYING, DO NOT USE) (Fixed) (Total:111.12 GB) (Free:35.46 GB) NTFS
3 Drive e: (Music) (Fixed) (Total:976.56 GB) (Free:622.92 GB) NTFS
4 Drive f: (Documents, Saves & Backups) (Fixed) (Total:886.44 GB) (Free:235.8 GB) NTFS
5 Drive g: (Train Sim World 5) (Fixed) (Total:931.5 GB) (Free:222.99 GB) NTFS
6 Drive j: (Games) (Fixed) (Total:708.42 GB) (Free:260.5 GB) NTFS
User accounts for \\DANSPC
Administrator danie DefaultAccount
Guest WDAGUtilityAccount
**** End of log ****
