Monitor, keyboard and mouse won’t work
TomGoakes
21
Hi guys I recently changed something in my bios to enable performance boost override when I saved and restarted my pc it turns on buy my mouse keyboard and monitor doesn’t work. Can someone please help me.
Ok if you cant use your keyboard or mouse to get into the bios and set it back to default, unplug the pc from the wall socket and remove the motherboard battery for half an hour, then refit it. This will reset the motherboard to default values. The motherboard battery is the cr2032 button battery.
