So basically I had issues with my laptop and I fixed them, but my display stopped working(probably a loose display cable or something) and I plugged in a monitor with the same Hz as the laptop(60). Thing is when I play demanding games or such I don't get the 60 fps that is showing in game and it isn't playing smoothly as it should.
What do you think the problem is? I am sure that they both are 60 Hz, maybe the cable has something to do with it?
Normal work is OK, tho and some lower demanding games.
