Yes, there is something else I would really like your help on not sure if this would be the correct thread to post it on but here goes.
I have 2 ips monitors set up to run on one cpu, the main one is plugged into the DVI port whilst the other is plugged into a vga port. What happens is sometimes the second monitor just blows out the colors and make it looks whiteish. I used to had use the NVIDIA control panel to adjust this and it would work but NVIDIA controls in the system tray doesn't appear any longer.
Is there a way for me to get the monitor running properly permanently?
Thanks in advance for your help
