Hi! New to the forums, joined because I'm having an issue with my monitors. I recently (yesterday) switched to a new case since my old one was pretty banged up and the USB ports on the front didn't work, new case is a Kolink Observatory Lite Mesh if that's any use. The audio of both my monitors was fine up until I changed my case. They both always showed up in the audio as their respective monitors, and I've had them connected to my graphics card using 2 HDMI to DisplayPort adapters (I have one HDMI port on my graphics card, but I save it for plugging my Oculus in - yes, I did try plugging my monitor directly into the HDMI and it didn't fix my issue). I had to take apart my PC to put it in the new case so I'm not sure if I just put something in wrong or what, but it worked before with my old case and I don't see how changing my case would make it so my monitors output audio isn't detected. My graphics card is a Radeon RX 550 Series and I'm running Windows 10. If there's anything else you need to know, ask and I'll let you know. Thanks!
