-Corsair RM750
-AMD R7 5800X
-Silicon Power NVMe M2 gen3x4 2280 SSD
-ID Cooling SE 214 XT ARGB Cooler
-Gigabyte Radeon RX 6800 XT
-B550 MAG Tomahawk
-G Skills DDR4 3600 8gb x2
-Asus VG27A
-Windows 11 Home
I can't get any microphones to work with my PC; so far I've tried two gaming headsets and a lapel microphone. I've tried the rear I/O audio port on my motherboard and the mic input port on the front panel of my case. The rear port doesn't register that a mic is connected. The front panel says the mic is connected, and registers audio input during testing (100% of volume), but it doesn't pick up my voice when I try to use software.
Any thing I can try? I don't think its a bad mic because I had the same problem with two gaming headsets.
-AMD R7 5800X
-B550 MAG Tomahawk
-Asus VG27A
-Windows 11 Home
