Low Render Distance In All Games
tochgl_
24
I have been having an issue where I have low render distance in all games. I have a rtx 2060 super, ryzen 5 3600, asus b450m a csm botherboard, crucial ballistix gaming memory 16gb ddr4-3200, evga 600 w1 power supply, and a wi fi adapter. I have replaced the gpu, cpu, motherboard, storage, and ram, and nothing has changed. The only things I haven't replaced are the power supply, wi fi adapter, and case. The only thing I could think may be causing this is the flash drive I used to install windows, which doesn't seem likely, or the monitor I am using, which is an old gateway monitor fpd2485w which uses dvi-d.
Not a gamer myself so not much help when it comes to FPS but over the years through helping people I have found that when it comes to online gaming there are two things that hinder gaming, a poor internet connection and browser security plug ins, sort them and you are usually good to go.
Something for you to do to see how your present set up handles video when not online gaming;
Use the free versions at the following links;
Check your FPS etc with SUPERPOSITION
Not a good choice of PSU, from the budget range and not intended to be used when there is anything more than an entry level GPU present, Which power supply do you need?
wi fi adapter.
Not ideal for gaming and the best way to check if the wireless signal is the problem is to use an Ethernet connection which is in fact what should be used when online gaming.
First released in 2007 so surprising to see that it still works at all, the video in the FPS testing will show you how good the screen quality is.
