Low ping/High FPS and still lagging/stuttering in game.
Dicco
29
Hey guys.
I am really hopeless right now. I tried so many things.. My computer is about 3 years old. It always ran perfectly since i am only playing games like league of legends. Now there was one event that changed everything. I upgraded my pc to 2 ram sticks (16gb). Since then my computer didnt know from which partion id should boot. i was caught in an autamtic repair loop at the start. i fixed it by resetting the system and putting my windows back on my ssd (not my hard drive). everything worked smoothly until i tried playing league of legends.. there was crazy stuttering at the start of games (jumping character) and if i want to move my champ with my mouse it feels choppyy and slow. This drives me crazy. I tried changing to my old ram stick (8gb) but that makes no difference. All my drivers seem up to date as well.. i have no idea what i can do to fix this.. please i need your ideas. thanks in advance :)
And sorry for this long post!
My hardware Specs:
Gigabyte Radeon RX 580 Gaming (8 GB)
MSI B450M Pro-VDH Plus (AM4, AMD B450, mATX)
Intenso High Performance (120 GB, 2.5")
AMD Ryzen 5 2600 (AM4, 3.40 GHz, 6 -Core)
Patriot Viper 4 PAT (1 x 8GB, DDR4-2133, DIMM 288 pin) // old Ram
Patriot Viper Steel (2 x 8GB, DDR4-3000, DIMM 288 pin) // new Ram
The only other change to mycomputer that i made was, that i am using bluetooth headphones now.
My task manager shows perfectly normal cpu/gpu/ram usage while playing the game. There is only the energy consumption thats red (using a lot of power). my ingame stats are perfect as well / 200 fps / 20 ping / i get a downloadspeed of 40 mb/s and a ping of 20 if i check my stats outside of the game.
do you have any idea what my problem could be?
Are you using RAM sticks which are compatible with your system?
Did you clean install Windows or just use reset?
Have you run Windows update until there’s nothing left to update?
Have you tried deleting the game using Revo Uninstaller & then reinstalling it?
thx for your reply. they should be compatible. my bios recognizes the ram sticks and before i bought them i got in touch with it support of the retailer. i reset my computer complety (deleting all files and everything). there is nothing left to update sadly. i will try to delete the game by using revo uninstaller now
If you restore the original RAM stick does the game work?
I would’ve used Crucial’s RAM checker beforehand which would find compatible RAM sticks for your system. The retailer may only have a general knowledge of PCs - unless they only sell PC components.
A clean install is done via installation media rather than running Windows reset. A clean install is more thorough & better than a reset.
