Low GPU usage and CPU at 100% in all games
auraexcon
25
Hello everyone,
I've been having this issue for like 6 months now where my GPU runs only at 50-60% while my CPU is maxed out 100% while playing any game.
My Specs:-
i5 8600K
RTX 3070 8GB
8x2 3200mhz (Running at 2666mhz)
Gigabyte B360M
Corsair HX750
I previously had a GTX 1060 paired with the same specs above and was still having the same issue so I bought the 3070 about 2 months ago and was hoping the issue would get fixed but it didn't.
Here are a few examples of the issue:-
RDR 2 High GPU Usage:- YouTube
RDR 2 Low GPU Usage:- YouTube
Cyberpunk High GPU:- YouTube
Cyberpunk Low GPU:- YouTube
One thing I have noticed is that this problem only occurs in areas of games with higher overall textures.
I didn't have this problem for the past 3 years I had this pc. It just suddenly started one day and I have no idea what could be the cause of this. I have tried almost every software related fix and found no success.
Any help is very much appreciated.
Step 1:
Checkmark following boxes:
Flush DNS
Reset FF proxy Settings
Reset Ie Proxy Settings
Report IE Proxy Settings
Report FF Proxy Settings
List content of Hosts
List IP configuration
List Winsock Entries
List last 10 Event Viewer log
List Installed Programs
List Devices (problems only)
Click Go and Attach the log in your reply.
Step 2:Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
Step 3: Autoruns Scan.
