Solved low fps on my ryzen 5 3400g
tristen jankowski
3
24
i have ryzen 5 3400g with 8gb ram 3200mhz and i get 30-40fps on apex legends even in 720p low pls somebody help my i have updated my drivers too i need help pls im pissed
i even saw benchmarks with the same specs on youtube but i dont get the same fps they get
i really need help
thank you
So others can assist you
Include the make and model of the Power Supply Unit if this is a Desktop.
What drivers and where did they come from?
Have you tried resetting the network back to a factory state?
Do you have anything over clocked?
Set the power scheme to Balanced?
Hibernation: Enabled
If you do not need it or use it disable Hibernation
Using an Admin Command Prompt
powercfg.exe /hibernate off
RAM 8.00GB Single-Channel Unknown @ 1599MHz (16-18-18-36)
Suggest getting a matching RAM to have the system running Dual Channel and not Single Channel. Which can also sometimes cut the speed of the ram in half as well which is why you should always use RAM in pairs.
Physical Memory
Memory Usage: 47 %
Total Physical: 5.95 GB
Available Physical: 3.13 GB
As you can see almost 50% is being used and allocated by the system.
Reactions: tristen jankowski
Physical Memory
Memory Usage: 47 %
i have auto updated all the drivers and checked all the driver updates from device manager
i have nothing over clocked its all auto in bios settings
my ram speed is showing 3200mhz whreas here it says 1599 mhz
Pissed, Why? I'm surprised you can even play that much with onboard graphics.... and nothing overclocked? You have to set your RAM speed in Bios to 3200
Buy another 8gig stick of matching RAM....must be dual channel for best results.
Check your PSU and then buy a GPU card. Anything is better than onboard
Don't expect to play games on this till you get the right parts.
If you do not upgrade your GPU and RAM then you will never play games of any quality, candy crush for sure though.....lol
Reactions: veeg
