Hi, I am facing an issue with my PC. I am trying to use my LG 43 inch 4K TV (UK6360PTE) as pc monitor but failed to do so. TV has hdmi port but my pc has vga and no hdmi. I have used a converter but didn't worked, no display at all. Talked with lg customer care they told - pc motherboard must be a hdmi motherboard otherwise it will not work even no converter will work. My pc technician told me hdmi graphics card will work. Now the problem is should I convert the non hdmi motherboard to a hdmi motherboard or hdmi graphics card will solve the problem for 4k display ?
Widows 10 pro
version 20H2
Intel(R) Pentium(R) CPU G4400 @ 3.30GHz 3.30 GHz
64-bit operating system, x64-based processor
Installed RAM 4.00 GB (3.87 GB usable)
Widows 10 pro
version 20H2
