Lenovo screen problem
Gabbo
19
hi, I have a problem with my Lenovo V15-ADA computer screen, with a screen that has the serial B156HTN06.1.
Would this screen from Amazon be any good? I didn't find my serial number inside but they look the same
The B156HTN06.1 screen has the following key specifications:
  • Screen Size: 15.6 inches
  • Resolution: 1920 x 1080 (Full HD)
  • Panel Type: IPS (In-Plane Switching)
  • Aspect Ratio: 16:9
  • Connector Type: eDP (Embedded DisplayPort)
  • Backlight Type: LED
If all of those match then yes. It’s ok. Since this is a picture only, it’s hard to tell.
No follow up. Thread will be closed. If you need to have your thread reopen ask a staff member .
