Laptop Is Not Running Exactly Right
PC Hunter Scan!
Download PCHunter
Disable your antivirus prior to this scan!!
Unzip the program to your desktop.
You will need to run the version that is compatible with your windows.
Right click either the 64 or 32 bit version and Run as Administrator.
After the program starts, go to the Examination Tab.
Click it once -- Look at the bottom and check mark Hide Safe Items.
Then click Generate Examination Report.
Allow 5 to 10 minutes for the program to generate the report.
Once complete you will be able to click the Export Examination Report button.
Save it where you like and name it what you like.
Then copy the entire report, and paste it here in your next reply.
Step 2: MiniToolBox Scan
Checkmark following boxes:
Flush DNS
Reset FF proxy Settings
Reset Ie Proxy Settings
Report IE Proxy Settings
Report FF Proxy Settings
List content of Hosts
List IP configuration
List Winsock Entries
List last 10 Event Viewer log
List Installed Programs
List Devices (problems only)
Click Go post the result.
Step 3: HijackThis.
2- Run the program.
5- Copy paste the log here.
