Hi all,
Im having an issue with a HP Envy 15 laptop thats a good few years old, the laptop had windows 8 when I originally got it and then upgraded to w10 which it worked fine on for years, but now my daughter needs it for schoolwork and roblox and its so slow that I decided a fresh o/s install was the best way to go. But clearly not.
the problem is the graphics card, its a Radeon HD 8600/8700m,
if I download any Radeon drivers the system on restart after installation says “ no AMD graphics drivers is installed, or the AMD driver is not functioning properly”. the display driver says its working but anything graphic intensive wont run properly and I get Bsod
If I uninstall all Radeon drivers and let windows build its own,again on restart it says windows has topped the device because it has reported a problem code 43.
Sorry for the long story, just thought more info the better.
Any help would be grateful.
Regards
Regards
