Ran by Duo (administrator) on 18-06-2022 at 23:57:06
Running from "D:\Users\Duo\OneDrive\Desktop"
Model: System Product Name Manufacturer: ASUS
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Intel(R) Wi-Fi 6E AX210 160MHz = Wi-Fi (Connected)
Bluetooth Device (Personal Area Network) = Bluetooth Network Connection (Media disconnected)
Intel(R) Ethernet Controller (3) I225-V = Ethernet (Media disconnected)
Intel(R) Ethernet Controller (3) I225-V = Ethernet 2 (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global
set interface interface="Ethernet (Kernel Debugger)" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth Network Connection" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 9" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 10" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : NewNamek
DNS Suffix Search List. . . . . . : hsd1.tn.comcast.net
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Intel(R) Ethernet Controller (3) I225-V
Physical Address. . . . . . . . . : 7C-10-C9-22-27-95
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : Intel(R) Ethernet Controller (3) I225-V #2
Physical Address. . . . . . . . . : 7C-10-C9-22-27-96
Wireless LAN adapter Local Area Connection* 9:
Physical Address. . . . . . . . . : 28-D0-EA-00-E4-F8
Wireless LAN adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 2A-D0-EA-00-E4-F7
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : hsd1.tn.comcast.net
Description . . . . . . . . . . . : Intel(R) Wi-Fi 6E AX210 160MHz
Physical Address. . . . . . . . . : 28-D0-EA-00-E4-F7
Link-local IPv6 Address . . . . . : fe80::b040:1628:87be:b7a1%12(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.196(Preferred)
Lease Obtained. . . . . . . . . . : Saturday, June 18, 2022 9:20:01 PM
Lease Expires . . . . . . . . . . : Sunday, June 19, 2022 9:20:05 PM
DHCPv6 IAID . . . . . . . . . . . : 489214186
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-29-3A-50-7A-7C-10-C9-22-27-95
Connection-specific DNS Suffix Search List :
hsd1.tn.comcast.net
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 28-D0-EA-00-E4-FB
Server: Linksys04411.hsd1.tn.comcast.net
Address: 192.168.1.1
Addresses: 2607:f8b0:4002:c08::65
2607:f8b0:4002:c08::8a
2607:f8b0:4002:c08::8b
2607:f8b0:4002:c08::66
74.125.21.113
74.125.21.101
74.125.21.102
74.125.21.139
74.125.21.138
74.125.21.100
Pinging google.com [74.125.21.100] with 32 bytes of data:
Reply from 74.125.21.100: bytes=32 time=38ms TTL=56
Ping statistics for 74.125.21.100:
Minimum = 38ms, Maximum = 38ms, Average = 38ms
Addresses: 2001:4998:24:120d::1:1
2001:4998:44:3507::8000
2001:4998:124:1507::f000
2001:4998:124:1507::f001
2001:4998:44:3507::8001
2001:4998:24:120d::1:0
74.6.231.21
74.6.143.25
98.137.11.164
98.137.11.163
74.6.231.20
74.6.143.26
Pinging yahoo.com [74.6.143.26] with 32 bytes of data:
Reply from 74.6.143.26: bytes=32 time=56ms TTL=51
Reply from 74.6.143.26: bytes=32 time=58ms TTL=50
Ping statistics for 74.6.143.26:
Minimum = 56ms, Maximum = 58ms, Average = 57ms
Interface List
18...7c 10 c9 22 27 95 ......Intel(R) Ethernet Controller (3) I225-V
15...7c 10 c9 22 27 96 ......Intel(R) Ethernet Controller (3) I225-V #2
11...28 d0 ea 00 e4 f8 ......Microsoft Wi-Fi Direct Virtual Adapter
13...2a d0 ea 00 e4 f7 ......Microsoft Wi-Fi Direct Virtual Adapter #2
12...28 d0 ea 00 e4 f7 ......Intel(R) Wi-Fi 6E AX210 160MHz
4...28 d0 ea 00 e4 fb ......Bluetooth Device (Personal Area Network)
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.196 35
192.168.1.0 255.255.255.0 On-link 192.168.1.196 291
192.168.1.196 255.255.255.255 On-link 192.168.1.196 291
192.168.1.255 255.255.255.255 On-link 192.168.1.196 291
224.0.0.0 240.0.0.0 On-link 192.168.1.196 291
255.255.255.255 255.255.255.255 On-link 192.168.1.196 291
Persistent Routes:
None
IPv6 Route Table
Active Routes:
1 331 ::1/128 On-link
12 291 fe80::/64 On-link
12 291 fe80::b040:1628:87be:b7a1/128
On-link
1 331 ff00::/8 On-link
12 291 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\Windows\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
Catalog5 02 C:\Windows\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\Windows\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog5 05 C:\Windows\SysWOW64\NLAapi.dll [71168] (Microsoft Corporation)
Catalog5 06 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog5 07 C:\Windows\SysWOW64\winrnr.dll [34304] (Microsoft Corporation)
Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 11 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 12 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 13 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
Catalog9 14 C:\Windows\SysWOW64\mswsock.dll [324416] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [70144] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [89088] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [89088] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\wshbth.dll [64000] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\NLAapi.dll [97280] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\winrnr.dll [49152] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
x64-Catalog9 14 C:\Windows\System32\mswsock.dll [418416] (Microsoft Corporation)
Application errors:
Error: (06/18/2022 09:19:59 PM) (Source: Freemake Improver) (User: )
Description: Service cannot be started. System.IO.FileLoadException: Could not load file or assembly 'Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
File name: 'Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' ---> System.IO.FileLoadException: Could not load file or assembly 'Newtonsoft.Json, Version=6.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
File name: 'Newtonsoft.Json, Version=6.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed'
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly ...
Error: (06/18/2022 09:19:58 PM) (Source: OVRServiceLauncher) (User: )
Description: [LauncherService] Unable to launch: There is no active interactive user session.
Error: (06/18/2022 07:54:21 PM) (Source: Freemake Improver) (User: )
Error: (06/18/2022 07:54:20 PM) (Source: OVRServiceLauncher) (User: )
Error: (06/18/2022 06:04:18 PM) (Source: Freemake Improver) (User: )
Error: (06/18/2022 06:04:18 PM) (Source: OVRServiceLauncher) (User: )
Error: (06/18/2022 01:52:32 AM) (Source: VSS) (User: )
Description: Volume Shadow Copy Service information: The COM Server with CLSID {4e14fba2-2e22-11d1-9964-00c04fbbb345} and name CEventSystem cannot be started. [0x8007045b, A system shutdown is in progress.
Error: (06/17/2022 10:49:46 PM) (Source: Freemake Improver) (User: )
Error: (06/17/2022 10:49:45 PM) (Source: OVRServiceLauncher) (User: )
Error: (06/17/2022 10:15:10 PM) (Source: Freemake Improver) (User: )
System errors:
Error: (06/18/2022 09:19:59 PM) (Source: BugCheck) (User: )
Description: 0x00000101 (0x000000000000000c, 0x0000000000000000, 0xffffb58020340180, 0x000000000000000b)C:\Windows\MEMORY.DMPbf75dcb4-c229-4d86-8af9-c6fa24173123
Error: (06/18/2022 09:19:49 PM) (Source: volmgr) (User: )
Description: Dump file creation failed due to error during dump creation.
Error: (06/18/2022 09:19:56 PM) (Source: EventLog) (User: )
Description: The previous system shutdown at 7:54:19 PM on 6/18/2022 was unexpected.
Error: (06/18/2022 07:54:21 PM) (Source: BugCheck) (User: )
Description: 0x0000009c (0x0000000080000001, 0xfffff80222e69b30, 0x0000000000000000, 0x0000000000000000)C:\Windows\MEMORY.DMP2f68ed99-6795-4ad4-9c5a-1bc1550f5b13
Error: (06/18/2022 07:54:14 PM) (Source: volmgr) (User: )
Error: (06/18/2022 07:54:19 PM) (Source: EventLog) (User: )
Description: The previous system shutdown at 7:24:16 PM on 6/18/2022 was unexpected.
Error: (06/18/2022 06:04:19 PM) (Source: BugCheck) (User: )
Description: 0x00000101 (0x000000000000000c, 0x0000000000000000, 0xffffbc01349c4180, 0x0000000000000009)C:\Windows\MEMORY.DMP6ddd406b-c2df-4c9f-8680-858b25ddf813
Error: (06/18/2022 06:04:09 PM) (Source: volmgr) (User: )
Error: (06/18/2022 06:04:16 PM) (Source: EventLog) (User: )
Description: The previous system shutdown at 1:52:57 AM on 6/18/2022 was unexpected.
Microsoft Office Sessions:
CodeIntegrity Errors:
Date: 2022-06-18 18:04:21.4240000Z
Description: Code Integrity determined that a process (\Device\HarddiskVolume3\ProgramData\Microsoft\Windows Defender\Platform\4.18.2203.5-0\MsMpEng.exe) attempted to load \Device\HarddiskVolume3\Program Files (x86)\Microsoft Office\root\vfs\ProgramFilesCommonX64\Microsoft Shared\OFFICE16\MSOXMLMF.DLL that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2022-06-11 08:50:51.7300000Z
Date: 2022-06-04 01:59:58.9480000Z
Date: 2022-05-17 00:35:07.6370000Z
Date: 2022-05-13 21:50:07.9950000Z
Date: 2022-05-06 20:05:19.8420000Z
Date: 2022-05-01 11:14:50.7070000Z
Date: 2022-04-29 00:28:19.0630000Z
Date: 2022-04-20 23:39:02.2400000Z
Date: 2022-04-14 22:51:26.4000000Z
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 21.007.20099 - Adobe Systems Incorporated)
Advanced Combat Tracker (remove only) (HKLM-x32\...\Advanced Combat Tracker) (Version: 3.6.0.275 - EQAditu)
Advanced SystemCare (HKLM-x32\...\Advanced SystemCare_is1) (Version: 14.3.0 - IObit)
Aeon's End (HKLM\...\Steam App 1063580) (Version: - Handelabra Games Inc.)
Age of Empires II: Definitive Edition (HKLM\...\Steam App 813780) (Version: - Forgotten Empires)
Age of Empires: Definitive Edition (HKLM\...\Steam App 1017900) (Version: - Forgotten Empires)
Albion Online (HKLM-x32\...\SandboxAlbionOnline) (Version: - Sandbox Interactive GmbH)
Apple Mobile Device Support (HKLM\...\{527DD209-8A66-482F-8779-C7B3BACCA8F1}) (Version: 15.0.0.16 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{A3985C05-7386-411F-A4BF-32A73F37EB44}) (Version: 2.6.3.1 - Apple Inc.)
ARMOURY CRATE Lite Service (HKLM\...\{EF3944FF-2501-4568-B15C-5701E726719E}) (Version: 5.0.8 - ASUS)
ASUS AIOFan HAL (HKLM\...\{EAE80DED-1A39-41C5-9F60-87CC947F6454}) (Version: 1.1.40.0 - ASUSTek COMPUTER INC.) Hidden
ASUS AIOFan HAL (HKLM-x32\...\{10f6ee35-55c3-46eb-91a6-816ce9af34c7}) (Version: 1.1.40.0 - ASUSTek COMPUTER INC.) Hidden
ASUS AURA Extension Card HAL (HKLM\...\{237E1CAC-1708-4940-AC34-DF15C079AB70}) (Version: 1.1.0.13 - ASUSTeK COMPUTER INC.) Hidden
ASUS AURA Extension Card HAL (HKLM-x32\...\{c398adfb-d090-4897-8845-baca53f7ecde}) (Version: 1.1.0.13 - ASUSTeK COMPUTER INC.) Hidden
ASUS AURA Motherboard HAL (HKLM\...\{4EBEAC95-76BC-46A8-8644-6E2F1C87CF70}) (Version: 1.2.6.0 - ASUSTeK COMPUTER INC.) Hidden
ASUS AURA Motherboard HAL (HKLM-x32\...\{84e91062-91cd-4caf-ab18-1805169f546d}) (Version: 1.2.6.0 - ASUSTeK COMPUTER INC.) Hidden
ASUS Aura SDK (HKLM\...\{CF8E6E00-9C03-4440-81C0-21FACB921A6B}) (Version: 3.04.11 - ASUSTek COMPUTER INC.) Hidden
ASUS AURA VGA Component (HKLM\...\{71BB96A6-EAC4-45AE-A17D-D3ED43FF1D14}) (Version: 0.0.4.3 - ASUSTek COMPUTER INC. ) Hidden
ASUS AURA VGA Component (HKLM-x32\...\{7a0d5159-cb5e-4f66-91f8-bab46f864f14}) (Version: 0.0.4.3 - ASUSTek COMPUTER INC. ) Hidden
ASUS Framework Service (HKLM-x32\...\{8bf47d14-406b-49e8-8759-966757033aa0}) (Version: 2.1.1.3 - ASUSTek COMPUTER INC.)
ASUS Framework Service (HKLM-x32\...\{EA6A87BE-8AD3-40D2-944C-9DF5FBFF4332}) (Version: 2.1.1.3 - ASUSTek COMPUTER INC.) Hidden
ASUS Motherboard (HKLM-x32\...\{93795eb8-bd86-4d4d-ab27-ff80f9467b37}) (Version: 2.01.06 - ASUSTek Computer Inc.)
ASUS Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.107.79 - ASUSTeK Computer Inc.) Hidden
AURA DRAM Component (HKLM\...\{9AFE5429-866B-457D-A864-80BCF7672EE8}) (Version: 1.1.16 - ASUS) Hidden
AURA DRAM Component (HKLM-x32\...\{41a78792-5489-400c-a567-b78d40b8c878}) (Version: 1.1.16 - ASUS) Hidden
AURA lighting effect add-on (HKLM-x32\...\{1E2EA04B-FCA7-457E-B6F4-F33E1858E859}) (Version: 0.0.18 - ASUS)
AURA lighting effect add-on x64 (HKLM\...\{C5A4A164-4428-4931-B728-96EEF0FA3C44}) (Version: 0.0.18 - ASUS)
AURA Service (HKLM-x32\...\{0E536061-3B55-4D45-BF58-0BDA261C94B0}) (Version: 3.05.29 - ASUSTeK Computer Inc.) Hidden
AURA Service (HKLM-x32\...\{abff099e-96f5-4bf4-9c6e-6f435f9f6c55}) (Version: 3.05.29 - ASUSTeK Computer Inc.)
BattleCON: Online (HKLM\...\Steam App 792570) (Version: - Level 99 Games)
Bigscreen Remote Desktop (HKCU\...\BigscreenRemoteDesktop) (Version: 0.902.18 - Bigscreen, Inc.)
BONEWORKS (HKLM\...\Steam App 823500) (Version: - Stress Level Zero)
Boss Monster (HKLM\...\Steam App 362350) (Version: - Plain Concepts Corp)
Boundless (HKLM\...\Steam App 324510) (Version: - Wonderstruck)
CCleaner (HKLM\...\CCleaner) (Version: 6.00 - Piriform)
Common Desktop Agent (HKLM\...\{031A0E14-0413-4C97-9772-2639B782F46F}) (Version: 1.62.0 - OEM) Hidden
Content Manager Assistant for PlayStation(R) (HKLM-x32\...\{C0115E87-E731-48DC-B258-DB2AD494DC80}) (Version: 3.56.7933.1204 - Sony Interactive Entertainment Inc.)
Control Center 5.0001.1.76 (HKLM-x32\...\{2F385B5D-5F23-4513-B3CE-9F5E4F4B882A}) (Version: 5.0001.1.76 - Control Center)
CPUID CPU-Z 1.98 (HKLM\...\CPUID CPU-Z_is1) (Version: 1.98 - CPUID, Inc.)
CPUID HWMonitor 1.45 (HKLM\...\CPUID HWMonitor_is1) (Version: 1.45 - CPUID, Inc.)
CyberLink PowerDVD 12 (HKLM-x32\...\InstallShield_{B46BEA36-0B71-4A4E-AE41-87241643FA0A}) (Version: 12.0.5522.55 - CyberLink Corp.)
DashCAM VIEWER version 1.4.3.9 (HKLM-x32\...\DE070C16-B942-4695-B07E-83C38FCA9CCF_is1) (Version: 1.4.3.9 - Thinkware)
Dead Secret Circle (HKLM\...\Steam App 671920) (Version: - Robot Invader)
Discord (HKCU\...\Discord) (Version: 0.0.309 - Discord Inc.)
Driver Easy 5.7.1 (HKLM\...\DriverEasy_is1) (Version: 5.7.1 - Easeware)
EaseUS Partition Master 12.9 (HKLM-x32\...\EaseUS Partition Master_is1) (Version: - EaseUS)
ENE IO Driver (HKLM-x32\...\{D0512FFD-6194-4D2E-967E-25B82A3322FF}) (Version: 3.3.0 - ENE TECHNOLOGY INC.) Hidden
ENE RGB HAL (HKLM\...\{E050E98C-5524-4AFB-9E53-97700BEF2C02}) (Version: 1.1.37.0 - Ene Tech.) Hidden
ENE RGB HAL (HKLM-x32\...\{413fe4b8-1352-4234-a775-ff2f04ad9042}) (Version: 1.1.37.0 - Ene Tech.) Hidden
ENE_EHD_M2_HAL (HKLM\...\{37A48B7F-D4EA-4863-844E-A284E2AA3C5D}) (Version: 1.0.9.1 - ENE TECHNOLOGY INC.) Hidden
ENE_EHD_M2_HAL (HKLM-x32\...\{bf1d7028-d935-477f-b5b2-053062f9b527}) (Version: 1.0.9.1 - ENE TECHNOLOGY INC.) Hidden
EVE Online (HKLM\...\Steam App 8500) (Version: - CCP)
FINAL FANTASY XI (HKLM-x32\...\{678F6475-D227-432A-94FF-806178A34520}) (Version: 1.011.0 - SQUARE ENIX CO., LTD.) Hidden
FINAL FANTASY XI (HKLM-x32\...\InstallShield_{678F6475-D227-432A-94FF-806178A34520}) (Version: 1.011.0 - SQUARE ENIX CO., LTD.)
FINAL FANTASY XI Seekers of Adoulin (HKLM-x32\...\{E86A33A7-6C77-48F3-9D72-2D8F4C1AD5AC}) (Version: 1.50.0 - SQUARE ENIX CO., LTD.) Hidden
FINAL FANTASY XI: Chains of Promathia (HKLM-x32\...\{3C0619B4-4A2C-4244-8077-488E420DF907}) (Version: 1.28.0 - SQUARE ENIX CO., LTD.) Hidden
FINAL FANTASY XI: Chains of Promathia (HKLM-x32\...\InstallShield_{3C0619B4-4A2C-4244-8077-488E420DF907}) (Version: 1.28.0 - SQUARE ENIX CO., LTD.)
FINAL FANTASY XI: Rise of the Zilart (HKLM-x32\...\{6FC76C41-8C1D-4B43-85E7-0BAA2002F1BE}) (Version: 1.19.0 - SQUARE ENIX CO., LTD.) Hidden
FINAL FANTASY XI: Rise of the Zilart (HKLM-x32\...\InstallShield_{6FC76C41-8C1D-4B43-85E7-0BAA2002F1BE}) (Version: 1.19.0 - SQUARE ENIX CO., LTD.)
FINAL FANTASY XI: Seekers of Adoulin (HKLM-x32\...\InstallShield_{E86A33A7-6C77-48F3-9D72-2D8F4C1AD5AC}) (Version: 1.50.0 - SQUARE ENIX CO., LTD.)
FINAL FANTASY XI: Treasures of Aht Urhgan (HKLM-x32\...\{A606C6FF-12E7-40BE-B777-D8F360FF00CD}) (Version: 1.36.0 - SQUARE ENIX CO., LTD.) Hidden
FINAL FANTASY XI: Treasures of Aht Urhgan (HKLM-x32\...\InstallShield_{A606C6FF-12E7-40BE-B777-D8F360FF00CD}) (Version: 1.36.0 - SQUARE ENIX CO., LTD.)
FINAL FANTASY XI: Wings of the Goddess (HKLM-x32\...\{5B037ED7-0755-48D4-9554-808E5AF50F17}) (Version: 1.43.0 - SQUARE ENIX CO., LTD.) Hidden
FINAL FANTASY XI: Wings of the Goddess (HKLM-x32\...\InstallShield_{5B037ED7-0755-48D4-9554-808E5AF50F17}) (Version: 1.43.0 - SQUARE ENIX CO., LTD.)
FINAL FANTASY XIV ONLINE (HKLM-x32\...\{2B41E132-07DF-4925-A3D3-F2D1765CCDFE}) (Version: 1.0.0000 - SQUARE ENIX CO., LTD.)
Freemake Video Converter version 4.1.13 (HKLM-x32\...\Freemake Video Converter_is1) (Version: 4.1.13 - Mixbyte Inc.)
Gloomhaven (HKLM\...\Steam App 780290) (Version: - Flaming Fowl Studios)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 102.0.5005.115 - Google LLC)
Gordian Quest (HKLM\...\Steam App 981430) (Version: - Mixed Realms Pte Ltd)
Gyazo 4.1.2.0 (HKLM-x32\...\{6DB8C365-E719-4BA5-9594-10DFC244D3FD}_is1) (Version: - Nota Inc.)
Half-Life: Alyx (HKLM\...\Steam App 546560) (Version: - Valve)
ImgBurn (HKLM-x32\...\ImgBurn) (Version: 2.5.8.0 - LIGHTNING UK!)
Insyde Airplane Mode HID Mini-Driver (HKLM\...\AirplaneModeHid) (Version: 1.4.0.8 - Insyde Corporation)
Intel(R) Chipset Device Software (HKLM-x32\...\{9b79ab4c-1596-44ee-84e2-a2001f7af089}) (Version: 10.1.18836.8283 - Intel(R) Corporation)
Intel(R) Serial IO (HKLM\...\{9FD91C5C-44AE-4D9D-85BE-AE52816B0294}) (Version: 30.100.2129.8 - Intel Corporation)
IObit Unlocker (HKLM-x32\...\IObit Unlocker_is1) (Version: 1.1.2 - IObit)
Istanbul: Digital Edition (HKLM\...\Steam App 943410) (Version: - Mobo Studio)
iTunes (HKLM\...\{0B3CC856-3A62-443A-B6CE-DED2D4495D56}) (Version: 12.12.2.2 - Apple Inc.)
Kingston AURA DRAM Component (HKLM\...\{965CDF5F-901C-476F-B3A8-7396701B1129}) (Version: 1.1.12 - KINGSTON COMPONENTS INC.) Hidden
Kingston AURA DRAM Component (HKLM-x32\...\{2237a879-7fa4-4e21-ae3b-00f6a649b9d9}) (Version: 1.1.12 - KINGSTON COMPONENTS INC.) Hidden
Laplink PCmover Professional (HKLM-x32\...\{64D581AC-F592-426A-927D-9D262B2CF53B}) (Version: 11.3.1015.1224 - Laplink Software, Inc.) Hidden
Laplink PCmover Professional (HKLM-x32\...\{846df3fe-581f-40b2-85b2-f7241703b31e}) (Version: 11.3.1015.1224 - Laplink Software, Inc.)
LAV Filters 0.74.1 (HKLM-x32\...\lavfilters_is1) (Version: 0.74.1 - Hendrik Leppkes)
Microsoft 365 - en-us (HKLM\...\O365HomePremRetail - en-us) (Version: 16.0.15225.20288 - Microsoft Corporation)
Microsoft Edge (HKLM-x32\...\Microsoft Edge) (Version: 102.0.1245.44 - Microsoft Corporation)
Microsoft Edge Update (HKLM-x32\...\Microsoft Edge Update) (Version: 1.3.163.19 - )
Microsoft Edge WebView2 Runtime (HKLM-x32\...\Microsoft EdgeWebView) (Version: 102.0.1245.44 - Microsoft Corporation)
Microsoft Office Word 2007 (HKLM-x32\...\WORD) (Version: 12.0.4518.1014 - Microsoft Corporation)
Microsoft Update Health Tools (HKLM\...\{7B1FCD52-8F6B-4F12-A143-361EA39F5E7C}) (Version: 3.67.0.0 - Microsoft Corporation)
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.30319 (HKLM-x32\...\{196BB40D-1578-3D01-B289-BEFC77A11A1E}) (Version: 10.0.30319 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.28.29913 (HKLM-x32\...\{855e31d2-9031-46e1-b06d-c9d7777deefb}) (Version: 14.28.29913.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.27.29112 (HKLM-x32\...\{be826f5f-eda5-45a2-a3fe-c2cb5c1b9842}) (Version: 14.27.29112.0 - Microsoft Corporation)
MiniTool Partition Wizard Free 10.2.3 (HKLM\...\{05D996FA-ADCB-4D23-BA3C-A7C184A8FAC6}_is1) (Version: - MiniTool Solution Ltd.)
MiniTool Power Data Recovery 8.1 (HKLM\...\{E1BCD081-4BF4-4E2F-832A-911EC42EF3C5}_is1) (Version: 8.1 - MiniTool Software Limited)
Mozilla Firefox (x64 en-US) (HKLM\...\Mozilla Firefox 101.0.1 (x64 en-US)) (Version: 101.0.1 - Mozilla)
MSI Afterburner 4.6.2 (HKLM-x32\...\Afterburner) (Version: 4.6.2 - MSI Co., LTD)
Mudlet (HKCU\...\Mudlet) (Version: 4.12.0 - Mudlet Makers)
NVIDIA FrameView SDK 1.2.7521.31103277 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_FrameViewSdk) (Version: 1.2.7521.31103277 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.25.1.27 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.25.1.27 - NVIDIA Corporation)
NVIDIA Graphics Driver 512.77 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 512.77 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.39.3 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.39.3 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.21.0713 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.21.0713 - NVIDIA Corporation)
NvModuleTracker (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvModuleTracker.Driver) (Version: 6.14.24370.22713 - NVIDIA Corporation) Hidden
Oculus (HKLM\...\Oculus) (Version: <3 - Facebook Technologies, LLC)
Office 16 Click-to-Run Extensibility Component (HKLM-x32\...\{90160000-008C-0000-0000-0000000FF1CE}) (Version: 16.0.15225.20150 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Extensibility Component 64-bit Registration (HKLM\...\{90160000-00DD-0000-1000-0000000FF1CE}) (Version: 16.0.15128.20178 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (HKLM\...\{90160000-008F-0000-1000-0000000FF1CE}) (Version: 16.0.15225.20288 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (HKLM-x32\...\{90160000-008C-0409-0000-0000000FF1CE}) (Version: 16.0.14131.20278 - Microsoft Corporation) Hidden
One Deck Dungeon (HKLM\...\Steam App 770100) (Version: - Handelabra Games Inc.)
Patriot Viper DRAM RGB (HKLM\...\{1F9C282E-CCB4-4D8E-A5CB-7B74DFCD8C95}) (Version: 1.0.9.2 - Patriot Memory) Hidden
Patriot Viper DRAM RGB (HKLM-x32\...\{fdc098ce-d76c-4e2e-a0a6-01a24e9a1f7d}) (Version: 1.0.9.2 - Patriot Memory)
Patriot Viper M2 SSD RGB (HKLM\...\{8B4C0A3D-C135-4E1F-98D8-3926494B4D61}) (Version: 1.0.6.4 - Patriot Memory) Hidden
Patriot Viper M2 SSD RGB (HKLM-x32\...\{3c403389-0bc5-4298-bebf-09de0c0b745d}) (Version: 1.0.6.4 - Patriot Memory)
PHISON HAL (HKLM\...\{966E33F0-6786-4B38-AA29-C1B3F6C1955D}) (Version: 1.0.9.0 - PHISON Electronics Corp.) Hidden
PHISON HAL (HKLM-x32\...\{549da357-1b81-456b-83f2-dcc47c41dfff}) (Version: 1.0.9.0 - PHISON Electronics Corp.) Hidden
PlayOnline Viewer & Tetra Master (HKLM-x32\...\{47004155-7376-403E-89E9-4C9F44AAF0D0}) (Version: 1.18.00 - SQUARE ENIX CO., LTD.) Hidden
PlayOnline Viewer & Tetra Master (HKLM-x32\...\InstallShield_{47004155-7376-403E-89E9-4C9F44AAF0D0}) (Version: 1.18.00 - SQUARE ENIX CO., LTD.)
PPSSPP (HKLM\...\PPSSPP_is1) (Version: 1.11.3.0 - PPSSPP Team)
Quake II (HKLM\...\Steam App 2320) (Version: - id Software)
Quake II RTX (HKLM\...\Steam App 1089130) (Version: - Lightspeed Studios™)
Raiders of the North Sea (HKLM\...\Steam App 965600) (Version: - Dire Wolf)
Realtek USB Audio (HKLM-x32\...\{0A46A65D-89AC-464C-8026-3CD44960BD04}) (Version: 6.3.9600.2307 - Realtek Semiconductor Corp.)
RivaTuner Statistics Server 7.2.3 (HKLM-x32\...\RTSS) (Version: 7.2.3 - Unwinder)
ROG FAN XPERT 4 (HKLM-x32\...\{2dfe216d-3481-4684-ad4d-2566bd7cfe4f}) (Version: 1.00.10 - ASUSTek Computer Inc.)
ROG Live Service (HKLM-x32\...\{2D87BFB6-C184-4A59-9BBE-3E20CE797631}) (Version: 1.3.12.0 - ASUSTek COMPUTER INC.)
RPG Maker MV (HKLM\...\Steam App 363890) (Version: - KADOKAWA)
Samsung Easy Printer Manager (HKLM-x32\...\Samsung Easy Printer Manager) (Version: 2.00.01.34 - HP Inc.)
Samsung Easy Wireless Setup (HKLM-x32\...\Easy Wireless Setup) (Version: 3.70.18.0 - Samsung Electronics Co., Ltd.)
Samsung Printer Center (HKLM-x32\...\Samsung Printer Center) (Version: 1.0.0.28 - Samsung Electronics Co., Ltd.)
Samsung Scan Process Machine (HKLM-x32\...\Samsung Scan Process Machine) (Version: 1.03.05.28 - Samsung Electronics Co., Ltd.) Hidden
SD Card Formatter (HKLM-x32\...\{A61131DC-B92D-4AD8-A925-E2D6D5FE217C}) (Version: 5.0.1 - SD Association)
SeaTools for Windows 1.4.0.7 (HKLM-x32\...\SeaTools for Windows) (Version: 1.4.0.7 - Seagate Technology)
SecondLifeViewer (HKLM\...\SecondLifeViewer) (Version: 6.5.0.565607 - Linden Research, Inc.)
Sentinels of the Multiverse (HKLM\...\Steam App 337150) (Version: - Handelabra Games Inc.)
SideQuest 0.10.26 (HKLM\...\4924ec51-3e48-5cb7-b145-2119467094c7) (Version: 0.10.26 - Shane Harris)
Skype version 8.72 (HKLM-x32\...\Skype_is1) (Version: 8.72 - Skype Technologies S.A.)
Speccy (HKLM\...\Speccy) (Version: 1.32 - Piriform)
SpeedFan (remove only) (HKLM-x32\...\SpeedFan) (Version: - )
Splendor (HKLM\...\Steam App 376680) (Version: - Days of Wonder)
SteamVR (HKLM\...\Steam App 250820) (Version: - Valve)
SteamVR Performance Test (HKLM\...\Steam App 323910) (Version: - Valve)
StepMania 5 (HKLM-x32\...\StepMania 5) (Version: 5.0.12 - StepMania)
Streets Of Kamurocho (HKLM\...\Steam App 1368430) (Version: - Empty Clip Studios)
Tabletop Simulator (HKLM\...\Steam App 286160) (Version: - Berserk Games)
Talisman: Digital Edition (HKLM\...\Steam App 247000) (Version: - Nomad Games)
Terraforming Mars (HKLM\...\Steam App 800270) (Version: - Luckyhammers)
The Room (HKLM\...\Steam App 288160) (Version: - Fireproof Games)
The Room 4: Old Sins (HKLM\...\Steam App 1361320) (Version: - Fireproof Games)
The Room Three (HKLM\...\Steam App 456750) (Version: - Fireproof Games)
The Room Two (HKLM\...\Steam App 425580) (Version: - Fireproof Games)
UltraISO Premium V9.71 (HKLM-x32\...\UltraISO_is1) (Version: - )
Uninstall Samsung Printer Software (HKLM-x32\...\TotalUninstaller) (Version: 4.0.0.93 - Samsung Electronics CO., LTD.)
Universal Holtek RGB DRAM (HKLM\...\{826388E4-E31F-4514-948B-3BB954FB3EAF}) (Version: 1.0.0.2 - PD) Hidden
Universal Holtek RGB DRAM (HKLM-x32\...\{6870588f-9f28-488b-a169-cf548ad6b393}) (Version: 1.0.0.2 - PD)
Virtual Desktop Service (HKLM\...\{424DBB6C-F04F-422C-9C4B-F2487201BBDC}) (Version: 1.18.11 - Virtual Desktop, Inc.)
Virtual Desktop Streamer (HKLM\...\{AA6B2847-5500-494B-BCC0-3F5DD4549678}) (Version: 1.20.21 - Virtual Desktop, Inc.)
VLC media player (HKLM\...\VLC media player) (Version: 3.0.12 - VideoLAN)
VLC media player (HKLM-x32\...\VLC media player) (Version: 3.0.16 - VideoLAN)
VSO Inspector 2.0.2 (HKLM-x32\...\VSO Inspector_is1) (Version: - VSO-Software SARL)
Vulkan Run Time Libraries 1.0.65.1 (HKLM\...\VulkanRT1.0.65.1) (Version: 1.0.65.1 - LunarG, Inc.) Hidden
WD_BLACK AN1500 (HKLM\...\{085E2365-0A70-4230-B664-02D5E4FE7E9C}) (Version: 1.0.14.0 - ENE TECHNOLOGY INC.) Hidden
WD_BLACK AN1500 (HKLM-x32\...\{e42c5874-37b0-4977-9e8d-70bf006e1f76}) (Version: 1.0.14.0 - ENE TECHNOLOGY INC.) Hidden
WhatsApp (HKCU\...\WhatsApp) (Version: 2.2216.8 - WhatsApp)
WhoCrashed 6.70 (HKLM\...\WhoCrashed_is1) (Version: - Resplendence Software Projects Sp.)
Windows PC Health Check (HKLM\...\{6798C408-2636-448C-8AC6-F4E341102D27}) (Version: 3.6.2204.08001 - Microsoft Corporation)
WinRAR 6.11 (64-bit) (HKLM\...\WinRAR archiver) (Version: 6.11.0 - win.rar GmbH)
Wondershare Helper Compact 2.5.2 (HKLM-x32\...\{5363CE84-5F09-48A1-8B6C-6BB590FFEDF2}_is1) (Version: 2.5.2 - Wondershare)
Wondershare PDFelement(Build 7.4.5) (HKLM-x32\...\{77078E40-A92E-47FD-A0F6-168A4BF6CF3A}_is1) (Version: 7.4.5.4719 - Wondershare Software Co.,Ltd.)
World Wide Hack (HKLM\...\Steam App 1765690) (Version: - Lotus Innovations)
Yu-Gi-Oh! Duel Links (HKLM\...\Steam App 601510) (Version: - Konami Digital Entertainment)
Description: Generic software device
Class Guid: {62f9c741-b25a-46ce-b54c-9bccce08b6f2}
Manufacturer: Microsoft
Service:
Device ID: SWD\RADIO\BLUETOOTH_28D0EA00E4FB
Name: OneNote for Windows 10
Description: Local Print Queue
Class Guid: {1ed2bbf9-11f0-4084-b21f-ad83a8e6dcdc}
Service:
Device ID: SWD\PRINTENUM\{661948AA-F980-4EC9-89E7-E37F3A6A3A6E}
Name: Wireless Controller
Description: USB Audio Device
Class Guid: {4d36e96c-e325-11ce-bfc1-08002be10318}
Manufacturer: (Generic USB Audio)
Service: usbaudio
Device ID: USB\VID_054C&PID_0CE6&MI_00\6&1447DC06&0&0000
Name: Intel(R) Host Bridge/DRAM Registers - 4C43
Description: Intel(R) Host Bridge/DRAM Registers - 4C43
Class Guid: {4d36e97d-e325-11ce-bfc1-08002be10318}
Manufacturer: INTEL
Service:
Device ID: PCI\VEN_8086&DEV_4C43&SUBSYS_86941043&REV_01\3&11583659&0&00
Name: Intel(R) Dynamic Application Loader Host Interface
Description: Intel(R) Dynamic Application Loader Host Interface
Class Guid: {5c4c3332-344d-483c-8739-259e934c9cc8}
Manufacturer: Intel
Service:
Device ID: SWD\DRIVERENUM\OEM_DAL_COMPONENT&4&282507D1&0
Name: HID-compliant game controller
Description: HID-compliant game controller
Class Guid: {745a17a0-74d3-11d0-b6fe-00a0c90f57da}
Manufacturer: (Standard system devices)
Service:
Device ID: HID\VID_054C&PID_0CE6&MI_03\7&2404819A&0&0000
Name: Motherboard resources
Description: Motherboard resources
Service:
Device ID: ACPI\PNP0C02\0
Service:
Device ID: ACPI\PNP0C02\1
Service:
Device ID: ACPI\PNP0C02\2
Service:
Device ID: ACPI\PNP0C02\5
Manufacturer: LG
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:22D8552F-E57A-4588-BF36-AD74202FACC7
Description: Volume
Class Guid: {71a27cdd-812a-11d0-bec7-08002be2092f}
Service: volume
Device ID: STORAGE\VOLUME\{9B582AA3-5353-11EC-BE70-806E6F6E6963}#0000000006500000
Name: USB Composite Device
Description: USB Composite Device
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Manufacturer: (Standard USB Host Controller)
Service: usbccgp
Device ID: USB\VID_0B05&PID_18F3\9876543210
Name: Basement Fire TV
Manufacturer: Amazon
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:2BC22373-C1B9-3622-BA98-8E760B0DCE4D
Service: usbccgp
Device ID: USB\VID_054C&PID_0CE6\5&153678D8&0&8
Description: ACPI Fan
Service:
Device ID: ACPI\PNP0C0B\0
Service:
Device ID: ACPI\PNP0C0B\1
Service:
Device ID: ACPI\PNP0C0B\2
Service:
Device ID: ACPI\PNP0C0B\3
Service:
Device ID: ACPI\PNP0C0B\4
Service: usbccgp
Device ID: USB\VID_0B05&PID_1996\5&153678D8&0&14
Name: ACPI Processor Aggregator
Description: ACPI Processor Aggregator
Service: acpipagr
Device ID: ACPI\ACPI000C\2&DABA3FF&0
Name: Intel(R) PCI Express Root Port #6 - 43BD
Description: Intel(R) PCI Express Root Port #6 - 43BD
Manufacturer: INTEL
Service: pci
Device ID: PCI\VEN_8086&DEV_43BD&SUBSYS_86941043&REV_11\3&11583659&0&E5
Name: Microsoft Print to PDF
Service:
Device ID: SWD\PRINTENUM\{D060A58C-8CD8-45AD-BAAB-B7A63AB77149}
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:8F103363-02CC-3939-972A-61DDA7E53494
Name: Root Print Queue
Service:
Device ID: SWD\PRINTENUM\PRINTQUEUES
Manufacturer: INSIGNIA
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:AF2E021E-C288-34BF-8C0A-5A4699D07F6E
Name: Simon's 26th Fire TV
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:F81213FF-3CDA-3245-97C8-FC3C3076CF85
Name: High Definition Audio Controller
Description: High Definition Audio Controller
Service: HDAudBus
Device ID: PCI\VEN_10DE&DEV_1AEF&SUBSYS_261219DA&REV_A1\4&39FDDC03&0&0108
Service:
Device ID: SWD\RADIO\{776F6FD5-0177-4A9B-9C6D-A15D75C7C797}
Description: Volume Manager
Service: volmgr
Device ID: ROOT\VOLMGR\0000
Name: Intel(R) PEG10 - 4C01
Description: Intel(R) PEG10 - 4C01
Manufacturer: INTEL
Service: pci
Device ID: PCI\VEN_8086&DEV_4C01&SUBSYS_86941043&REV_01\3&11583659&0&08
Name: HID-compliant vendor-defined device
Description: HID-compliant vendor-defined device
Service:
Device ID: HID\VID_046D&PID_C534&MI_01&COL05\8&19A31460&0&0004
Description: Microsoft Wireless Router Module
Class Guid: {b6a945de-134c-4279-9a66-61a63c6f0dc5}
Manufacturer: Linksys
Service: UmPass
Device ID: SWD\DAFUPNPPROVIDER\UUID:EBF5A0A0-1DD1-11B2-A90F-C4411E3FAB09
Name: Intel(R) Ethernet Controller (3) I225-V
Description: Intel(R) Ethernet Controller (3) I225-V
Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
Manufacturer: Intel
Service: e2fexpress
Device ID: PCI\VEN_8086&DEV_15F3&SUBSYS_87D21043&REV_03\4&356AA108&0&00E5
Service:
Device ID: HID\VID_0B05&PID_18F3&MI_02\7&CA0C55&0&0000
Name: WAN Miniport (PPPOE)
Description: WAN Miniport (PPPOE)
Service: RasPppoe
Device ID: SWD\MSRRAS\MS_PPPOEMINIPORT
Description: Digital Media Device
Class Guid: {14b62f50-3f15-11dd-ae16-0800200c9a66}
Manufacturer: LG Electronics.
Service: UmPass
Device ID: SWD\DAFUPNPPROVIDER\UUID:E1B58D2D-9B0F-E1B3-8297-961353BBB739
Name: Microsoft Basic Display Driver
Description: Microsoft Basic Display Driver
Manufacturer: (Standard display types)
Service: BasicDisplay
Device ID: ROOT\BASICDISPLAY\0000
Name: ACPI Sleep Button
Description: ACPI Sleep Button
Service:
Device ID: ACPI\PNP0C0E\2&DABA3FF&0
Name: USB Root Hub (USB 3.0)
Description: USB Root Hub (USB 3.0)
Manufacturer: (Standard USB HUBs)
Service: USBHUB3
Device ID: USB\ROOT_HUB30\4&1C1E67E3&0&0
Name: ACPI Thermal Zone
Description: ACPI Thermal Zone
Service:
Device ID: ACPI\THERMALZONE\TZ00
Name: Brother MFC-L2710DW series
Description: Brother MFC-L2710DW series
Class Guid: {4d36e979-e325-11ce-bfc1-08002be10318}
Manufacturer: Brother
Service:
Device ID: SWD\PRINTENUM\WSD-C8B06EF8-ED61-4425-BF67-15EF19DB08C3
Name: Microsoft RRAS Root Enumerator
Service:
Device ID: SWD\MSRRAS\{5E259276-BC7E-40E3-B93B-8F89B5F3ABC0}
Name: Realtek Hardware Support Application
Description: Realtek Hardware Support Application
Manufacturer: Realtek
Service:
Device ID: SWD\DRIVERENUM\{C3A63EDD-2D27-4B66-B155-5E94B43D926A}#REALTEKHSA&7&32A33C09&0
Name: WAN Miniport (PPTP)
Description: WAN Miniport (PPTP)
Service: PptpMiniport
Device ID: SWD\MSRRAS\MS_PPTPMINIPORT
Name: Microsoft Hyper-V Virtualization Infrastructure Driver
Description: Microsoft Hyper-V Virtualization Infrastructure Driver
Service: Vid
Device ID: ROOT\VID\0000
Name: High precision event timer
Description: High precision event timer
Service:
Device ID: ACPI\PNP0103\0
Service:
Device ID: ACPI\PNP0C02\ISCLK
Name: WAN Miniport (IKEv2)
Description: WAN Miniport (IKEv2)
Service: RasAgileVpn
Device ID: SWD\MSRRAS\MS_AGILEVPNMINIPORT
Name: Composite Bus Enumerator
Description: Composite Bus Enumerator
Service: CompositeBus
Device ID: ROOT\COMPOSITEBUS\0000
Name: Microsoft Virtual Drive Enumerator
Description: Microsoft Virtual Drive Enumerator
Service: vdrvroot
Device ID: ROOT\VDRVROOT\0000
Name: Headphones (Oculus Virtual Audio Device)
Description: Audio Endpoint
Class Guid: {c166523c-fe0c-4a94-a586-f1a80cfbbf3e}
Service:
Device ID: SWD\MMDEVAPI\{0.0.0.00000000}.{2FFC90A2-B1FA-4512-A5E7-9371409B6C5E}
Name: Wondershare PDFelement
Manufacturer:
Service:
Device ID: SWD\PRINTENUM\{E6183ADC-84A8-442F-9CFB-91BB8B47CB9D}
Name: Intel(R) Wireless Bluetooth(R)
Description: Intel(R) Wireless Bluetooth(R)
Class Guid: {e0cbf06c-cd8b-4647-bb8a-263b43f0f974}
Manufacturer: Intel Corporation
Service: BTHUSB
Device ID: USB\VID_8087&PID_0032\5&153678D8&0&2
Name: Microsoft Storage Spaces Controller
Description: Microsoft Storage Spaces Controller
Class Guid: {4d36e97b-e325-11ce-bfc1-08002be10318}
Service: spaceport
Device ID: ROOT\SPACEPORT\0000
Name: Logitech HID Device
Description: Logitech HID Device
Class Guid:
Manufacturer:
Service:
Device ID: {C1FCC185-55B3-4E00-814B-C588A13525E1}\VID_046D&PID_C534&REV_2901&MI_01&COL03&HIDFILT\9&2A8E2C12&0&00
Name: Logicool HID-compliant Cordless Mouse
Description: Logicool HID-compliant Cordless Mouse
Class Guid: {4d36e96f-e325-11ce-bfc1-08002be10318}
Manufacturer: Logicool
Service: mouhid
Device ID: HID\VID_046D&PID_C534&MI_01&COL01\8&19A31460&0&0000
Name: Microsoft Wi-Fi Direct Virtual Adapter
Description: Microsoft Wi-Fi Direct Virtual Adapter
Service: vwifimp
Device ID: {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_WFD\5&3C46D3D&0&11
Name: Microsoft Wi-Fi Direct Virtual Adapter #2
Service: vwifimp
Device ID: {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_WFD\5&3C46D3D&0&12
Name: Intel(R) USB 3.20 eXtensible Host Controller - 1.20 (Microsoft)
Description: USB xHCI Compliant Host Controller
Manufacturer: Generic USB xHCI Host Controller
Service: USBXHCI
Device ID: PCI\VEN_8086&DEV_43ED&SUBSYS_86941043&REV_11\3&11583659&0&A0
Description: System Firmware
Class Guid: {f2e7dd72-6468-4e36-b6f1-6488f42c1b52}
Service:
Device ID: UEFI\RES_{D8CBEA2A-7D5C-57F5-80BE-2D53A98300BF}\0
Name: Microsoft Kernel Debug Network Adapter
Description: Microsoft Kernel Debug Network Adapter
Service: kdnic
Device ID: ROOT\KDNIC\0000
Class Guid:
Manufacturer:
Service:
Device ID: {C1FCC185-55B3-4E00-814B-C588A13525E1}\VID_046D&PID_C534&REV_2901&MI_00&HIDFILT\9&1330DD43&0&00
Name: Brother MFC-L2710DW series Printer
Service:
Device ID: SWD\PRINTENUM\{27AF43D3-F066-4A34-BD91-7A4E380E6BD7}
Name: Realtek USB Audio
Description: Realtek USB Audio
Service: RtkUsbAD
Device ID: USB\VID_0B05&PID_1996&MI_00\6&33160C55&0&0000
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:7916B2EA-7AD2-3EB2-A9CB-C53B96DDA164
Name: Generic volume shadow copy
Description: Generic volume shadow copy
Class Guid: {533c5b84-ec70-11d2-9505-00c04f79deaf}
Service:
Device ID: STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT1
Service:
Device ID: STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT2
Service:
Device ID: STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT3
Service:
Device ID: STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT4
Name: Intel(R) PCI Express Root Port #8 - 43BF
Description: Intel(R) PCI Express Root Port #8 - 43BF
Manufacturer: INTEL
Service: pci
Device ID: PCI\VEN_8086&DEV_43BF&SUBSYS_86941043&REV_11\3&11583659&0&E7
Name: Intel(R) Ethernet Controller (3) I225-V #2
Manufacturer: Intel
Service: e2fexpress
Device ID: PCI\VEN_8086&DEV_15F3&SUBSYS_87D21043&REV_03\4&255B870&0&00E6
Name: Microsoft Windows Management Interface for ACPI
Description: Microsoft Windows Management Interface for ACPI
Service: WmiAcpi
Device ID: ACPI\PNP0C14\ASUSMBSWINTERFACE
Name: AURA LED Controller
Description: WinUsb Device
Class Guid: {88bae032-5a81-49f0-bc3d-a4ff138216d6}
Manufacturer: WinUsb Device
Service: WINUSB
Device ID: USB\VID_0B05&PID_18F3&MI_00\6&2EFC6B98&0&0000
Service:
Device ID: ACPI\PNP0C02\PCHRESV
Name: Intel(R) Serial IO I2C Host Controller - 43E9
Description: Intel(R) Serial IO I2C Host Controller - 43E9
Service: iaLPSS2_I2C_TGL
Device ID: PCI\VEN_8086&DEV_43E9&SUBSYS_86941043&REV_11\3&11583659&0&A9
Name: Realtek Audio Universal Service
Description: Realtek Audio Universal Service
Service:
Device ID: SWD\DRIVERENUM\{C3A63EDD-2D27-4B66-B155-5E94B43D926A}#REALTEKSRV&7&32A33C09&0
Name: Programmable interrupt controller
Description: Programmable interrupt controller
Service:
Device ID: ACPI\PNP0000\4&363CB9A&0
Name: Headset Microphone (Wireless Controller)
Service:
Device ID: SWD\MMDEVAPI\{0.0.1.00000000}.{8A145657-3D3C-4AB2-8DFA-567783617C4C}
Service:
Device ID: HID\VID_0B05&PID_1996&MI_07\7&37C08BBB&0&0000
Name: Microsoft XPS Document Writer
Service:
Device ID: SWD\PRINTENUM\{68248CFF-7E32-4DB0-A210-771A852781B8}
Name: Intel(R) Serial IO GPIO Host Controller - INT34C6
Description: Intel(R) Serial IO GPIO Host Controller - INT34C6
Service: iaLPSS2_GPIO2_TGL
Device ID: ACPI\INT34C6\2&DABA3FF&0
Name: NVIDIA High Definition Audio
Description: NVIDIA High Definition Audio
Manufacturer: NVIDIA
Service: NVHDA
Device ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_009A&SUBSYS_19DA2612&REV_1001\5&21C727F&0&0001
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:EBF5A0A0-1DD1-11B2-A91F-C4411E3FAB09
Class Guid:
Manufacturer:
Service:
Device ID: {C1FCC185-55B3-4E00-814B-C588A13525E1}\VID_046D&PID_C534&REV_2901&MI_01&COL01&HIDFILT\9&1D204F72&0&00
Name: Sonic Studio Virtual Mixer
Description: Sonic Studio Virtual Mixer
Manufacturer: Nahimic
Service: AVoluteSS3Vad
Device ID: SWD\DRIVERENUM\{1B98EF90-CA0E-11E7-8F1A-0800200C9A66}#AVOLUTESS3VAD&7&32A33C09&0
Name: UMBus Root Bus Enumerator
Description: UMBus Root Bus Enumerator
Service: umbus
Device ID: ROOT\UMBUS\0000
Name: Logitech Pointing Device
Description: Logitech Pointing Device
Class Guid:
Manufacturer:
Service:
Device ID: {C1FCC185-55B3-4E00-814B-C588A13525E1}\VID_046D&PID_C534&REV_2901&MI_01&COL01&MOUFILT\9&1D204F72&0&00
Description: Volume
Service: volume
Device ID: STORAGE\VOLUME\{9B582AA4-5353-11EC-BE70-806E6F6E6963}#0000000000100000
Service: WmiAcpi
Device ID: ACPI\PNP0C14\SAMPLEDEV
Name: Microsoft Radio Device Enumeration Bus
Service:
Device ID: SWD\RADIO\{3DB5895D-CC28-44B3-AD3D-6F01A782B8D2}
Name: Intel(R) PCI Express Root Port #9 - 43B0
Description: Intel(R) PCI Express Root Port #9 - 43B0
Manufacturer: INTEL
Service: pci
Device ID: PCI\VEN_8086&DEV_43B0&SUBSYS_86941043&REV_11\3&11583659&0&E8
Name: Microsoft Device Association Root Enumerator
Service:
Device ID: SWD\MSDAS\{CE958E9A-424F-4C88-86F4-11314821E75A}
Name: Intel(R) iCLS Client
Description: Intel(R) iCLS Client
Manufacturer: Intel
Service:
Device ID: SWD\DRIVERENUM\OEM_ICLS_COMPONENT&4&282507D1&0
Name: ACPI x64-based PC
Description: ACPI x64-based PC
Class Guid: {4d36e966-e325-11ce-bfc1-08002be10318}
Manufacturer: (Standard computers)
Service: \Driver\ACPI_HAL
Device ID: ROOT\ACPI_HAL\0000
Name: Intel(R) LPC Controller (Z590) - 4385
Description: Intel(R) LPC Controller (Z590) - 4385
Manufacturer: INTEL
Service: msisadrv
Device ID: PCI\VEN_8086&DEV_4385&SUBSYS_86941043&REV_11\3&11583659&0&F8
Name: WAN Miniport (Network Monitor)
Description: WAN Miniport (Network Monitor)
Service: NdisWan
Device ID: SWD\MSRRAS\MS_NDISWANBH
Name: WAN Miniport (IP)
Description: WAN Miniport (IP)
Service: NdisWan
Device ID: SWD\MSRRAS\MS_NDISWANIP
Service: WmiAcpi
Device ID: ACPI\PNP0C14\ATK
Service: WmiAcpi
Device ID: ACPI\PNP0C14\ATW
Service: WmiAcpi
Device ID: ACPI\PNP0C14\AWW
Name: Logicool HID Keyboard Consumer Controls
Description: Logicool HID Keyboard Consumer Controls
Service: LHidFilt
Device ID: HID\VID_046D&PID_C534&MI_01&COL02\8&19A31460&0&0001
Service: WmiAcpi
Device ID: ACPI\PNP0C14\TESTDEV
Name: PCI Express Root Complex
Description: PCI Express Root Complex
Service: pci
Device ID: ACPI\PNP0A08\0
Name: Microsoft Bluetooth LE Enumerator
Description: Microsoft Bluetooth LE Enumerator
Service: BthLEEnum
Device ID: BTH\MS_BTHLE\6&2094FA75&0&3
Name: Intel(R) PCI Express Root Port #1 - 43B8
Description: Intel(R) PCI Express Root Port #1 - 43B8
Manufacturer: INTEL
Service: pci
Device ID: PCI\VEN_8086&DEV_43B8&SUBSYS_86941043&REV_11\3&11583659&0&E0
Name: Generic USB Hub
Description: Generic USB Hub
Service: USBHUB3
Device ID: USB\VID_174C&PID_2074\5&153678D8&0&10
Name: Generic PnP Monitor
Description: Generic PnP Monitor
Class Guid: {4d36e96e-e325-11ce-bfc1-08002be10318}
Manufacturer: (Standard monitor types)
Service: monitor
Device ID: DISPLAY\GSMC0C8\5&5CD83F4&0&UID4352
Name: Intel(R) 500 Series Chipset Family SATA AHCI Controller
Description: Intel(R) 500 Series Chipset Family SATA AHCI Controller
Class Guid: {4d36e96a-e325-11ce-bfc1-08002be10318}
Service: iaStorAC
Device ID: PCI\VEN_8086&DEV_43D2&SUBSYS_86941043&REV_11\3&11583659&0&B8
Name: ACPI Power Button
Description: ACPI Power Button
Service:
Device ID: ACPI\PNP0C0C\2&DABA3FF&0
Name: Microsoft ACPI-Compliant System
Description: Microsoft ACPI-Compliant System
Service: ACPI
Device ID: ACPI_HAL\PNP0C08\0
Name:
Description:
Class Guid:
Manufacturer:
Service:
Device ID: HTREE\ROOT\0
Name: Microsoft Basic Render Driver
Description: Microsoft Basic Render Driver
Service: BasicRender
Device ID: ROOT\BASICRENDER\0000
Name: Intel(R) Shared SRAM - 43EF
Description: Intel(R) Shared SRAM - 43EF
Manufacturer: INTEL
Service:
Device ID: PCI\VEN_8086&DEV_43EF&SUBSYS_86941043&REV_11\3&11583659&0&A2
Name: Microsoft ACPI-Compliant Embedded Controller
Description: Microsoft ACPI-Compliant Embedded Controller
Service:
Device ID: ACPI\PNP0C09\4&363CB9A&0
Name: Intel(R) SPI (flash) Controller - 43A4
Description: Intel(R) SPI (flash) Controller - 43A4
Manufacturer: INTEL
Service:
Device ID: PCI\VEN_8086&DEV_43A4&SUBSYS_86941043&REV_11\3&11583659&0&FD
Name: LG TV SSCR2 (NVIDIA High Definition Audio)
Service:
Device ID: SWD\MMDEVAPI\{0.0.0.00000000}.{06D10647-3AC7-4258-9C39-0CF89B1A7639}
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:E674771D-2C08-353F-9355-DF2AC611DD1F
Name: Numeric data processor
Description: Numeric data processor
Service:
Device ID: ACPI\PNP0C04\4&363CB9A&0
Name: WAN Miniport (SSTP)
Description: WAN Miniport (SSTP)
Service: RasSstp
Device ID: SWD\MSRRAS\MS_SSTPMINIPORT
Name: Standard NVM Express Controller
Description: Standard NVM Express Controller
Manufacturer: Standard NVM Express Controller
Service: stornvme
Device ID: PCI\VEN_1BB1&DEV_5018&SUBSYS_50181BB1&REV_01\4&12FB7CC4&0&0030
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:F6153879-CA66-3FB7-8137-B2D999B5C9BD
Service:
Device ID: SWD\PRINTENUM\{E363CABA-8BA8-4D9A-87A1-BD22FF000F4D}
Name: Microsoft UEFI-Compliant System
Description: Microsoft UEFI-Compliant System
Service: UEFI
Device ID: ACPI_HAL\UEFI\0
Name: Headset Microphone (Oculus Virtual Audio Device)
Service:
Device ID: SWD\MMDEVAPI\{0.0.1.00000000}.{93EFDC28-C276-41A0-8BBA-62A2C8437B14}
Service: usbccgp
Device ID: USB\VID_046D&PID_C534\6&580F0AE&0&3
Name: Microphone (Virtual Desktop Audio)
Service:
Device ID: SWD\MMDEVAPI\{0.0.1.00000000}.{8AE3B9A3-6B41-4F8A-8812-57149F5C344D}
Name: USB Input Device
Description: USB Input Device
Service: HidUsb
Device ID: USB\VID_054C&PID_0CE6&MI_03\6&1447DC06&0&0003
Service: stornvme
Device ID: PCI\VEN_1BB1&DEV_5016&SUBSYS_50161BB1&REV_01\4&17F2C710&0&000A
Name: Trusted Platform Module 2.0
Description: Trusted Platform Module 2.0
Class Guid: {d94ee5d8-d189-4994-83d2-f68d7d41b0e6}
Manufacturer: (Standard)
Service: TPM
Device ID: ACPI\MSFT0101\1
Name: ACPI Fixed Feature Button
Description: ACPI Fixed Feature Button
Service:
Device ID: ACPI\FIXEDBUTTON\2&DABA3FF&0
Service: WmiAcpi
Device ID: ACPI\PNP0C14\ASUSBACKUPWMI
Name: Realtek Asio Component
Description: Realtek Asio Component
Service:
Device ID: SWD\DRIVERENUM\{C3A63EDD-2D27-4B66-B155-5E94B43D926A}#REALTEKASIO&7&32A33C09&0
Name: ACPI Wake Alarm
Description: ACPI Wake Alarm
Service: acpitime
Device ID: ACPI\ACPI000E\2&DABA3FF&0
Name: Realtek Audio Effects Component (USB)
Description: Realtek Audio Effects Component
Service:
Device ID: SWD\DRIVERENUM\{C3A63EDD-2D27-4B66-B155-5E94B43D926A}#REALTEKAPO&7&32A33C09&0
Description: Volume
Service: volume
Device ID: STORAGE\VOLUME\{9B582AA3-5353-11EC-BE70-806E6F6E6963}#0000000000100000
Name: Logicool HID-Compliant Keyboard (106 keys)
Description: Logicool HID-Compliant Keyboard (106 keys)
Class Guid: {4d36e96b-e325-11ce-bfc1-08002be10318}
Service: kbdhid
Device ID: HID\VID_046D&PID_C534&MI_00\8&1DF881B&0&0000
Service: USBHUB3
Device ID: USB\VID_05E3&PID_0608\5&153678D8&0&13
Service: WmiAcpi
Device ID: ACPI\PNP0C14\MXM2
Name: Brother MFC-L2710DW series [b422005592cd]
Description: WSD Scan Device
Class Guid: {6bdd1fc6-810f-11d0-bec7-08002be2092f}
Service: WSDScan
Device ID: SWD\DAFWSDPROVIDER\URN:UUID:E3248000-80CE-11DB-8000-B422005592CD/URI:E3248000-80CE-11DB-8000-B422005592CD/SCANNERSERVICE
Name: Intel(R) PCI Express Root Port #7 - 43BE
Description: Intel(R) PCI Express Root Port #7 - 43BE
Manufacturer: INTEL
Service: pci
Device ID: PCI\VEN_8086&DEV_43BE&SUBSYS_86941043&REV_11\3&11583659&0&E6
Name: Intel(R) Power Engine Plug-in
Description: Intel(R) Power Engine Plug-in
Service: intelpep
Device ID: ACPI\INT33A1\1
Name: Logicool HID Keyboard Power Key
Description: Logicool HID Keyboard Power Key
Service: LHidFilt
Device ID: HID\VID_046D&PID_C534&MI_01&COL03\8&19A31460&0&0002
Description: System timer
Service:
Device ID: ACPI\PNP0100\4&363CB9A&0
Name: Intel(R) Management Engine Interface #1
Description: Intel(R) Management Engine Interface #1
Manufacturer: Intel
Service: MEIx64
Device ID: PCI\VEN_8086&DEV_43E0&SUBSYS_86941043&REV_11\3&11583659&0&B0
Name: Seagate FireCuda 530 ZP4000GM30013
Description: Disk drive
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Manufacturer: (Standard disk drives)
Service: disk
Device ID: SCSI\DISK&VEN_NVME&PROD_SEAGATE_FIRECUDA\5&1C7F025B&0&000000
Name: Realtek Digital Output (Realtek USB Audio)
Service:
Device ID: SWD\MMDEVAPI\{0.0.0.00000000}.{86D39340-0272-4294-A65C-6A5AAE52B75C}
Service:
Device ID: ACPI\PNP0C02\IOTRAPS
Service:
Device ID: SWD\IPP\E3248000-80CE-11DB-8000-B422005592CD
Service: HidUsb
Device ID: USB\VID_046D&PID_C534&MI_00\7&3938E3A3&0&0000
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:E5853667-2202-3738-A147-1AD7D3136B37
Class Guid:
Manufacturer:
Service:
Device ID: {C1FCC185-55B3-4E00-814B-C588A13525E1}\VID_046D&PID_C534&REV_2901&MI_01&COL02&HIDFILT\9&6B6EE50&0&00
Service: HidUsb
Device ID: USB\VID_0B05&PID_1996&MI_07\6&33160C55&0&0007
Description: Volume
Service: volume
Device ID: STORAGE\VOLUME\{9B582AA3-5353-11EC-BE70-806E6F6E6963}#000000E8C0F00000
Name: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Description: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Service: nvvad_WaveExtensible
Device ID: ROOT\UNNAMED_DEVICE\0000
Description: NvModuleTracker Device
Class Guid: {aa018edf-4915-415e-9c17-d7ebec8917d2}
Service: NvModuleTracker
Device ID: ROOT\UNNAMED_DEVICE\0001
Name: NVVHCI Enumerator
Description: NVVHCI Enumerator
Service: nvvhci
Device ID: ROOT\UNNAMED_DEVICE\0002
Name: A-Volute Nh3 Audio Effects Component
Description: Nahimic 3 APO
Manufacturer: A-Volute
Service:
Device ID: SWD\DRIVERENUM\{1B98EF90-CA0E-11E7-8F1A-0800200C9A66}#AVOLUTE_NH3APO&7&32A33C09&0
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:EBF5A0A0-1DD1-11B2-A92F-C4411E3FAB09
Name: High Definition Audio Device
Description: High Definition Audio Device
Service: HdAudAddService
Device ID: HDAUDIO\FUNC_01&VEN_8086&DEV_2816&SUBSYS_80860101&REV_1000\4&1EB7316&0&0201
Name: Intel(R) Serial IO I2C Host Controller - 43E8
Description: Intel(R) Serial IO I2C Host Controller - 43E8
Device ID: PCI\VEN_8086&DEV_43E8&SUBSYS_86941043&REV_11\3&11583659&0&A8
Name: Microsoft GS Wavetable Synth
Service:
Device ID: SWD\MMDEVAPI\MICROSOFTGSWAVETABLESYNTH
Name: Intel(R) PEG60 - 4C09
Description: Intel(R) PEG60 - 4C09
Manufacturer: INTEL
Service: pci
Device ID: PCI\VEN_8086&DEV_4C09&SUBSYS_00000000&REV_01\3&11583659&0&30
Service: HidUsb
Device ID: USB\VID_0B05&PID_18F3&MI_02\6&2EFC6B98&0&0002
Name: Intel® PROSet/Wireless WiFi Software extension
Description: Intel® PROSet/Wireless WiFi Software extension
Service:
Device ID: SWD\DRIVERENUM\{4D3C822D-417D-4B03-B562-CD33F5FDA354}#PIESOFTWARECOMPONENT&5&3C46D3D&0
Name: Kitchen Fire TV
Service:
Device ID: SWD\DAFUPNPPROVIDER\UUID:8988DA43-A2FC-3CBA-840F-2F3BB987203B
Name: Seagate FireCuda 520 SSD ZP1000GM30002
Service: disk
Device ID: SCSI\DISK&VEN_NVME&PROD_SEAGATE_FIRECUDA\5&1B62382D&0&000000
Name: OneNote (Desktop)
Service:
Device ID: SWD\PRINTENUM\{8AD8AA1C-50BC-45CA-9AFF-CB48A13C90FC}
Name: Intel(R) Watchdog Timer Driver (Intel(R) WDT)
Description: Intel(R) Watchdog Timer Driver (Intel(R) WDT)
Manufacturer: Intel
Service: ICCWDT
Device ID: ACPI\INT3F0D\4&363CB9A&0
Name: NDIS Virtual Network Adapter Enumerator
Description: NDIS Virtual Network Adapter Enumerator
Service: NdisVirtualBus
Device ID: ROOT\NDISVIRTUALBUS\0000
Name: Generic SuperSpeed USB Hub
Description: Generic SuperSpeed USB Hub
Service: USBHUB3
Device ID: USB\VID_174C&PID_3074\5&153678D8&0&24
Name: Microsoft Bluetooth Enumerator
Description: Microsoft Bluetooth Enumerator
Service: BthEnum
Device ID: BTH\MS_BTHBRB\6&2094FA75&0&1
Name: Speakers (Wireless Controller)
Service:
Device ID: SWD\MMDEVAPI\{0.0.0.00000000}.{CDEA1FBC-E2DF-4C5D-B83A-F6074BA51BF7}
Description: Volume
Service: volume
Device ID: STORAGE\VOLUME\{9B582AA3-5353-11EC-BE70-806E6F6E6963}#0000000007500000
Name: Intel(R) PEG12 - 4C07
Description: Intel(R) PEG12 - 4C07
Manufacturer: INTEL
Service: pci
Device ID: PCI\VEN_8086&DEV_4C07&SUBSYS_86941043&REV_01\3&11583659&0&0A
Name: Intel(R) PCI Express Root Port #17 - 43C0
Description: Intel(R) PCI Express Root Port #17 - 43C0
Manufacturer: INTEL
Service: pci
Device ID: PCI\VEN_8086&DEV_43C0&SUBSYS_86941043&REV_11\3&11583659&0&D8
Description: WSD Print Device
Class Guid: {c30ecea0-11ef-4ef9-b02e-6af81e6e65c0}
Service: WSDPrintDevice
Device ID: SWD\DAFWSDPROVIDER\URN:UUID:E3248000-80CE-11DB-8000-B422005592CD/URI:E3248000-80CE-11DB-8000-B422005592CD/PRINTERSERVICE
Name: Microsoft System Management BIOS Driver
Description: Microsoft System Management BIOS Driver
Service: mssmbios
Device ID: ROOT\MSSMBIOS\0000
Service:
Device ID: ACPI\INT340E\2&DABA3FF&0
Service:
Device ID: HID\VID_046D&PID_C534&MI_01&COL04\8&19A31460&0&0003
Name: Intel(R) Wi-Fi 6E AX210 160MHz
Description: Intel(R) Wi-Fi 6E AX210 160MHz
Service: Netwtw10
Device ID: PCI\VEN_8086&DEV_2725&SUBSYS_00248086&REV_1A\4&13199003&0&00E7
Name: Bluetooth Device (RFCOMM Protocol TDI)
Description: Bluetooth Device (RFCOMM Protocol TDI)
Service: RFCOMM
Device ID: BTH\MS_RFCOMM\6&2094FA75&0&0
Service: HDAudBus
Device ID: PCI\VEN_8086&DEV_43C8&SUBSYS_86941043&REV_11\3&11583659&0&FB
Name: Bluetooth Device (Personal Area Network)
Description: Bluetooth Device (Personal Area Network)
Service: BthPan
Device ID: BTH\MS_BTHPAN\6&2094FA75&0&2
Service: HidUsb
Device ID: USB\VID_046D&PID_C534&MI_01\7&3938E3A3&0&0001
Service:
Name: Plug and Play Software Device Enumerator
Description: Plug and Play Software Device Enumerator
Service: swenum
Device ID: ROOT\SYSTEM\0000
Name: Oculus Virtual Gamepad Emulation Bus
Description: Oculus Virtual Gamepad Emulation Bus
Manufacturer: Facebook, Inc.
Service: Oculus_ViGEmBus
Device ID: ROOT\SYSTEM\0001
Name: Virtual Desktop Gamepad Emulation Bus
Description: Virtual Desktop Gamepad Emulation Bus
Manufacturer: Virtual Desktop
Service: vdvge
Device ID: ROOT\SYSTEM\0002
Name: Intel(R) SMBus - 43A3
Description: Intel(R) SMBus - 43A3
Manufacturer: INTEL
Service:
Device ID: PCI\VEN_8086&DEV_43A3&SUBSYS_86941043&REV_11\3&11583659&0&FC
Name: NVIDIA GeForce RTX 3080 Ti
Description: NVIDIA GeForce RTX 3080 Ti
Class Guid: {4d36e968-e325-11ce-bfc1-08002be10318}
Service: nvlddmkm
Device ID: PCI\VEN_10DE&DEV_2208&SUBSYS_261219DA&REV_A1\4&39FDDC03&0&0008
Name: Remote Desktop Device Redirector Bus
Description: Remote Desktop Device Redirector Bus
Service: rdpbus
Device ID: ROOT\RDPBUS\0000
Name: WAN Miniport (IPv6)
Description: WAN Miniport (IPv6)
Service: NdisWan
Device ID: SWD\MSRRAS\MS_NDISWANIPV6
Name: 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz
Description: Intel Processor
Class Guid: {50127dc3-0f36-415e-a6cc-4cb3be910b65}
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_0
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_1
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_2
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_3
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_4
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_5
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_6
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_7
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_8
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_9
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_A
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_B
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_C
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_D
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_E
Manufacturer: Intel
Service: intelppm
Device ID: ACPI\GENUINEINTEL_-_INTEL64_FAMILY_6_MODEL_167_-_11TH_GEN_INTEL(R)_CORE(TM)_I9-11900K_@_3.50GHZ\_F
Name: Oculus Virtual Audio Device
Description: Oculus Virtual Audio Device
Manufacturer: Oculus
Service: oculusvad_oculusvad
Device ID: ROOT\MEDIA\0000
Name: Virtual Desktop Audio
Description: Virtual Desktop Audio
Service: vdvad_WaveExtensible
Device ID: ROOT\MEDIA\0001
Name: Samsung ML-1865W Series (192.168.1.157)
Manufacturer: Samsung
Service:
Device ID: SWD\PRINTENUM\{356A58FC-2BEA-46D6-BA02-34EC1FBF6001}
Name: WAN Miniport (L2TP)
Description: WAN Miniport (L2TP)
Service: Rasl2tp
Device ID: SWD\MSRRAS\MS_L2TPMINIPORT
Name: Intel(R) Management Engine WMI Provider
Description: Intel(R) Management Engine WMI Provider
Manufacturer: Intel
Service:
Device ID: SWD\DRIVERENUM\OEM_WMI_COMPONENT&4&282507D1&0
Percentage of memory in use: 12%
Total physical RAM: 65380.66 MB
Available physical RAM: 57184.31 MB
Total Virtual: 75108.66 MB
Available Virtual: 63093.34 MB
1 Drive c: () (Fixed) (Total:930.9 GB) (Free:785.87 GB) NTFS
2 Drive d: (Piccolo) (Fixed) (Total:3726.02 GB) (Free:2010.56 GB) NTFS
User accounts for \\NEWNAMEK
Administrator DefaultAccount Duo
Guest WDAGUtilityAccount
========================= Minidump Files ==================================
C:\Windows\Minidump\061722-6859-01.dmp
C:\Windows\Minidump\061722-6984-01.dmp
C:\Windows\Minidump\061822-6640-01.dmp
C:\Windows\Minidump\061822-8734-01.dmp
C:\Windows\Minidump\061822-8796-01.dmp
========================= Restore Points ==================================
08-06-2022 23:29:13 Driver Easy: Installed UpdateAutomatically
13-06-2022 20:39:04 Windows Modules Installer
17-06-2022 04:06:24 Windows Modules Installer
17-06-2022 04:07:00 Windows Modules Installer
**** End of log ****
