I just bought a new pc and installed a 4tb hard drive together with a 275 gb SSD. Whilest trying to alocate the 4TB hard drive i noticed that it capped at 2TB per partition. After some research i found out that i need to change the hard drive from MBR to GPT. Whilest watching some videos and other forum posts i noticed that the option to convert disk to GPT wasnt there in disk management even if none of it was allocated.
Next thing i did was download this handy program called ''AOMEI Partition Assistant'' after some looking around i found the option to convert it to a GPT disk.
However! it gave me this message: The systen partition and boot partition are seperated on different disks. If you convert the disk, your system will be unable to boot next time. So we strongly suggest you not to convert this disk. Do you still want to convert it?
As far as i know i havent even touched this disk yet as i had to allocate the disk space before i could even see it in my pc at start up. I installed my windows 10 on the SSD after all.
Can someone tell me what i should do to be able to access the full 4TB?
