I have a HP Envy laptop.I've had it for about 2 years and I use it at home and at work. In the last month or two its having issues starting up. I turn it on and the HP logo and loading icon comes up, then it goes to a black screen and stays there. I have to hold the power button down and shut it off and restart the system, then it usually boots up fine. Other times in boots up with no issues. I have noticed in my task manager that the hard drive stays at 100% when nothing is open. It does go down after 5-10 mins, so Im not sure if this is normal. I have been told that the hard drive is failing, so I bought a new one and mainly want to know if I clone my hard drive to the new one, is it as simply as cloning it and my system should load up just as normal. Any help would be great. Thanks
