Ingenuity Bouncer – Quality Baby Bouncers!
The Bouncer is a great item to have with you and your baby. It keeps them safe and secure while allowing for some bouncy movement at the same time. It is like a big swing that you can set up anywhere with you. The bouncy chair also helps train your baby’s legs and feet for standing – which they will one day need to stand on their own two feet!
The company that stands behind the Ingenuity brand, Kids2 Inc, is built on family. Their goal is to make fun products for your child while also being safe! On top of their innovative solutions, they are also very conscious of what parents look for in baby products. Kids2 Inc wants to make sure that their products are easy to use while still cost-efficient! We all know how expensive children can be, so this is an excellent point of consideration.
The Ingenuity Bouncers are great bouncy chairs for your baby. They come in several different styles, all with their unique features and each one with the Ingenuity standard of quality that parents know and love. Let’s take a look at some of the best Ingenuity Bouncers available today:
Ingenuity SmartBounce
With this bouncer, you can take care of a baby hands-free! The Ingenuity SmartBounce will gently rock and swaddle your baby in 2-speed automatic soothing motions that mimic mom’s natural movements, making your little one feel at peace.
The 3-point safety harness on the bouncing seat ensures your baby stays safe and secure while you can relax. Let’s not forget that the baby needs some fun, too: that’s why this Ingenuity automatic bouncer comes with 11 melodies and soothing nature sounds, as well as toys on a pivot bar.
In addition to being a very safe bouncer with a 3-point harness, the Ingenuity SmartBounce works on batteries. This is great because you can easily carry spare batteries in your bag when out and about. No more worrying about the bouncer running the electricity bill up. This bouncer rocks, bounces, swaddles, and entertains your baby – it even has an automatic turn-off mode to save battery life.
The seat pad on this baby bouncer is machine washable, making it simple to keep clean. Last but not least: it is fantastic to look at, and the colors are fabulous! Perfect for newborns and babies up to 6 months.
How to assemble Ingenuity automatic bouncer​
This bouncer seat is straightforward to put together, but if you run into any trouble, we are happy to offer guidance.
Download SmartBounce User Manual
The bouncer seat comes in a box with all the parts and a manual to help you assemble it. It is a great idea to look at the manual before using the Ingenuity automatic bouncer to take care of any safety concerns.
Inspect your Ingenuity baby bouncer carefully when you get it home from the store and before first-time use to ensure that no parts are missing and that there is no visible damage.
Ingenuity Cradling Bouncer
When there’s a baby in the picture, it is challenging to keep up with your everyday chores! Keep your baby happy and within view with a bouncer explicitly designed for daily activities.
Ingenuity Cradling Bouncer is a safe spot for your baby: it provides a secure environment, and the 3-point harness keeps your baby safe. The soft fabric seat is comfortable and gentle on your baby’s delicate skin. It also has a head support area to help keep them supported when they fall asleep.
This baby bouncer also comes with two built-in comfort vibration settings that allow you to soothe your baby easily. Some parents also love that this bouncer has a vibration feature because it makes their life easier, which means happier babies and more time for everyday chores.
There is a removable toy bar with toys that your baby can play with, and there are 8 soothing melodies you both will love. You can easily switch between movement and vibration modes with the push of a button.
The Ingenuity Cradling Bouncer is also super easy to clean, making it perfect for busy parents on the go! The bouncer seat cover is machine washable. This baby bouncer also takes up minimal space, allowing you to use it anywhere in the house.
You will need 3 “C” batteries that are not included in the box to use this baby bouncer. However, it is worth mentioning that the Ingenuity Cradling Bouncer uses minimum energy so that the batteries will go a long way.
Ingenuity cradling bouncer manual and assembly​
The user manual comes with detailed diagrams and instructions to guide you through the assembly process.
Download Cradling Bouncer Manual
The Ingenuity cradling bouncer requires minimal assembly. The frame comes with the fabric seat already installed. You just need to attach the toys and batteries, and you’re ready to go. It should take up about 5-7 minutes for the whole process.
If you need to wash the fabric seat, it is easily removed and machine washed. The frame may require a quick wipe down to keep it looking good as new.
Ingenuity Bouncity Bounce
A perfect substitute for parents’ arms: the Ingenuity Bouncity Bounce is a great option for parents looking to give their baby a bouncing seat that is lightweight and easy to move around.
When you need a cozy place for your baby to relax and play, the Ingenuity Buncity Bounce seat is a great solution. Your baby will feel extra safe and secure in this bouncing seat, thanks to its 3-point harness system.
The plush, removable headrest helps keep newborns comfortable. You can easily remove, wash and replace the seat pad for easy cleaning. As the child grows and begins to kick those legs, the baby can create their own steady bounce. This will help strengthen their leg muscles while having fun at the same time!
Moreover, the Ingenuity Bouncity seat has a vibration mode with adjustable intensity levels. It also comes equipped with both music and plush toys to keep your child entertained and happy during playtime.
The Ingenuity Bouncity Bounce seat requires just 1 “C” battery to operate. This provides about 100 hours of power, which means you won’t need to replace the batteries often.
Ingenuity Bouncity Bounce Manual and Assembly​
The user’s manual has comprehensive illustrations to assist you with the installation. All in all, it should take up about 5-7 minutes to install this seat.
Download Bouncity Bounce User Manual
The Ingenuity bouncy seat requires minimal assembly before use. It is an easy task, even for those not technically inclined or DIY savvy.
The plush seat pad is easily removable and machine washable. The bouncer does not require any special maintenance either, so you don’t have to worry about waking up in the middle of the night for a routine clean-up.
Ingenuity InLighten Baby Bouncer
The Ingenuity InLighten Baby Bouncer has some cool features that come in handy for new parents. It has two vibration settings that can be turned on or off by the push of a button. It also has a removable headrest that can be quickly dealt with by machine washing it when necessary.
The comfortable, cradling bouncing chair is covered in soft velours to hug your infant. The Ingenuity InLighten bouncer seat can accommodate your child from infancy to 20 pounds.
Your baby will enjoy kicking and playing in this baby bouncer, as it is full of surprises: the dazzling lights that dance over the canopy toy bar, the spinning mobile with removable plush toys, and the melodies that keep your baby entertained.
The Ingenuity InLighten bouncer also includes a set of tranquil melodies, nature sounds, and white noise to allow your child to relax and sleep. Soothing vibrations add to the calming atmosphere.
Ingenuity InLighten Baby Bouncer Manual and Assembly​
The Ingenuity InLighten bouncer is easy to install and only takes a couple of minutes with simple instructions illustrated in the user’s manual.
Download InLighten User Manual
Assembly time usually takes no more than 5 minutes. The bouncer is not bulky or heavy so that you can carry it around with you to different house rooms for convenience.
The Ingenuity InLighten Baby Bouncer requires 3 “D” batteries to operate. They are not included in the package, so be ready to spend some extra bucks to buy them.
Which Ingenuity Baby Bouncer to choose?​
All Ingenuity baby bouncers come with their benefits. Depending on your baby’s needs, convenience and preferences, you can pick the best model that will suit their lifestyle. If we were to choose ComfyBummy’s favorites, we would go with:
  • Ingenuity SmartBounce
  • InLighten Baby Bouncer
The Ingenuity SmartBounce is an automatic baby bouncer that emulates the natural motions of parents when comforting their children. With this model, you will bounce your child without any difficulties. Your baby will be cradled and comfortable.
The Ingenuity InLighten Baby Bouncer is also worth purchasing if you want a bouncer with many features. It is very engaging and entertaining for your infant, so it can significantly contribute to your kid’s development.
These amazing devices have many benefits that first-time moms may not even be aware of, but for those with an experienced hand, they are the only way to go. They provide a safe place for your baby to play or sleep, soothe them with a gentle rocking motion, and help to develop their motor skills. These great features combine to make the best baby bouncers money can buy!
The post Ingenuity Bouncer – Quality Baby Bouncers! appeared first on Comfy Bummy.
