Solved In Dire Need Of Help
Eddie Paul Litz
464
30
35
Novelty Ohio
W/ Google Chrome & IE your Website shows broken images & is preventing me from posting. I can only use COMODO Dragon to access the site fully. How can I fix this for my other web browsers? Google Chrome is already set to show all images & it still won't work here.
Image is from Google Chrome.
I don't use chrome but here is a screenshot from IE 11. No problems with it.
Have you tried performing a hard refresh? I have gotten the reported issue time from time, the hard refresh typically resolves the issue.
You can do this by holding down the control key and pressing f5. You may have to do this a few times.
Otherwise the next step would be checking to see if you have an addon possibly blocking the images.
Tried a few times & didn't work
Is this happening on just this forum?
I have had some not show properly and others work just fine.
Is this happening when you are logged in/out to the forum?
Some time the pics do not show properly if I am not logged into the site.
Have you tried rebooting?
Have you tried resetting one of the offending browsers to factory?
Do you think you could try Rustys suggestions, and respond to them before asking more questions?
I've done rebooting several times & I have reset the browser before & it didn't work.
Please answer the other two questions.
Any update for us Eddie Paul Litz? If unreplied to within 48hrs this thread will be closed.
OP advised via PM the following;
The issued seems to be resolved. The images don't seem to be broken anymore.
