Solved I need some help....
PatL
83
5
39
Hi, so the other day I had my computer freeze when I was transferring files via USB which interrupted the Windows Update restart. Since that time I've been unable to shut down my computer in normal mode without holding down the power button. It just says shutting down but never actually shuts down. Also beginning around last week or so I installed Freedome VPN and now notice a strange instance of conhost running all the time. In process explorer it has shown up with several different string of numbers after it's name, any ideas? I also just found I can't run FRST in Normal Mode it says it's running but never proceeds past 'Scanning Files' W. T. F.? Any help would be grateful.
These are the entries that Process Explorer shows in conhost. Also Killswitch says conhost is 'unknown' and unrecognized.
\??\C:\Windows\system32\conhost.exe "-526163917204026652-1602556940-206166442249880667683736887941597085-706841680
\??\C:\Windows\system32\conhost.exe "430084954-474288438-182572785115439089871184030295202798216-1332693948-879887487
\??\C:\Windows\system32\conhost.exe "-876781241-1198739928730586247-7186158361429504512005407591481015877230397628
Scan result of Farbar Recovery Scan Tool (FRST) (x86) Version: 15-03-2017
Ran by Patrick (administrator) on PATRICK-PC (13-04-2017 15:41:23)
Running from C:\Users\Patrick\Desktop
Loaded Profiles: Patrick (Available Profiles: Patrick)
Platform: Microsoft Windows 7 Home Premium Service Pack 1 (X86) Language: English (United States)
Internet Explorer Version 11 (Default browser: FF)
Boot Mode: Safe Mode (minimal)
Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
==================== Registry (Whitelisted) ====================
HKLM\...\Run: [AvastUI.exe] => C:\Program Files\AVAST Software\Avast\AvLaunch.exe [213824 2017-04-07] (AVAST Software)
HKLM\...\Run: [VoodooShield] => C:\Program Files\VoodooShield\VoodooShield.exe [2441040 2017-03-01] (VoodooSoft, LLC )
HKLM\...\Run: [ZAM] => C:\Program Files\Zemana AntiMalware\ZAM.exe [14522512 2017-04-03] (Copyright 2017.)
HKLM Group Policy restriction on software: *.xlsx.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.frm <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.xml <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.msp <====== ATTENTION
HKLM Group Policy restriction on software: cipher.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.xcs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.msc <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.reg <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: eventvwr.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.jar <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.ws* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.hta <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.crt <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.nsf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %systemdrive%\dccon.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: magic.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.png.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.png.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.xml <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.xml <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.vb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.com <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.pif <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.phps <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.vbe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.reg <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.msc <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.ade <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.mde <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.inx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.bat <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.png.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.vbe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.chm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.sct <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.ins <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.msi <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.inx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.png.bas <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.p <====== ATTENTION
HKLM Group Policy restriction on software: *.png.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.isp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.vbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.isp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\rkcl\ldr.exe <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.hta <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.msi <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.png.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\x64.exe <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.xcs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.js <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.png.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.ins <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.sct <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.scsb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %systemdrive%\Mount.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.application <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.hta <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.com <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.ws* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.hta <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.js <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.p <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.jse <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.rbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.msc <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.msc <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\x86.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.bin <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.exe <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\processor.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %systemdrive%\mount.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.url <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.pls <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.url <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.job <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: lsassw86s.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.ade <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.shb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.bat <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.adp <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.ns <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.mde <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.p <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.url <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.url <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.lua <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.pcd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.com <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.png.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.shs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.ns <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.js <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.com <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.application <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.pcd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.xml <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.shs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.rbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.png.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.tcls <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.92bs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.paf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.p <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.vbe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.msp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.job <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.mde <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.scr <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.reg <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.url <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.lua <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.bas <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.ws* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.msc <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.shs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.png.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.48s <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.shs <====== ATTENTION
HKLM Group Policy restriction on software: PDFBewerbungsmappe.exe <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\IKvtxoiPx.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.gadget <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.js <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.png.job <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.job <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.48s <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.url <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.ns <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.xml <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.mod <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.url <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.p <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.msc <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.png.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.hta <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.frm <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.mod <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.p <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\wrmXNhWbacF.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.url <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.lua <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.rx* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.js <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.application <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.jse <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.nsf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.jar <====== ATTENTION
HKLM Group Policy restriction on software: deleteMyProgram.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.png.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: extratools.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\imgdesktop.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.url <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\delback.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %programfiles%\*\svchost.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.bat <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.pcd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.bat <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: vssadmin.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.inx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.inf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.vbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: %systemdrive%\*\svchost.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.png.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.cmd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.mod <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.url <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.url <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.hta <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.klx <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.bat <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.job <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.bat <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.scf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.url <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.job <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.png.url <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.isu <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.application <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.chm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: %systemdrive%\netpass.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.com <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.mod <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.chm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.gadget <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\System32\WindowsPowerShell\v1.0\powershell_ise.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.jse <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.shs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: WifiHack.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.application <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.psc* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.ocx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.msp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Steg\steg.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.url <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.psc* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.gadget <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.scr <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.msi <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.nsf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.ocx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %localappdata%\MS\app_roaming.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.msc <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.ade <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.js <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.job <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.chm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.klx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.p <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.url <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.gadget <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.jar <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.png.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.msi <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.vbe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.msi <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.hta <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: commerc.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\RegAsm.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.application <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.jse <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.png.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.inf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\windefrag.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.bin <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.psc* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.sct <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.gadget <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\software.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.shs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\bbv.exe <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.job <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.lua <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.job <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: lsassvrtdbks.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.png.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\{213D7F33-4942-1C20-3D56=8-1A0B31CDFFF3}.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.js <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.mod <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.92bs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.jse <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.pif <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.mod <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.com <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.png.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.crt <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\dsadee.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.paf <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.com <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.psc* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.scsb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.mdb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.application <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.bat <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.pls <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.nsf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.png.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.js <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.msc <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.com <====== ATTENTION
HKLM Group Policy restriction on software: surprise.exe <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.paf <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.exe <====== ATTENTION
HKLM Group Policy restriction on software: 7_Sp.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.nsf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.png.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.png.bat <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.job <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.chm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.url <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.png.shb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.msp <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.p <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.ade <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.job <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.com <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.url <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.jar <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.scf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.u3p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.application <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.xml <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\MS\Def*nder.exe <====== ATTENTION
HKLM Group Policy restriction on software: pokemongo.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.vb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.com <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.scsb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.crt <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.p <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.crt <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.bas <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.application <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.png.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.png.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.paf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.hta <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.mde <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.bin <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: msconfig.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.vb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.xml <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.exe <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.pls <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.com <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.cpl <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.sct <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.ns <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.msp <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.job <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.isu <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.png.ns <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.js <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.bas <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.job <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.ns <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.ins <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.mod <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.application <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.js <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.inx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.scr <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.png.bin <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.scf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\svchost.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.msc <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.pif <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.png.js <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.p <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.png.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.pif <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.vbe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.lua <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.png.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.application <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.sct <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.mst <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.pif <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.vb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.com <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.gadget <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.url <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.pls <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\IEUpdate\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.png.inx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.hta <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.bin <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.com <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.paf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.js <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\new.bat <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.inf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.vbe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\random\random.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.js <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.bat <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.mdb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.application <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.u3p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.js <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.inf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.png.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.hta <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.inf <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.wwb <====== ATTENTION
HKLM Group Policy restriction on software: msoyasdx.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.shs <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.inx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.url <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.isu <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.gadget <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.bat <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.jar <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\uTorrent.exe <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\clean.exe <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.ocx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.com <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.vb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.js <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\freegaza_israeli_killers.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.inx <====== ATTENTION
HKLM Group Policy restriction on software: kek.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.ws* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.frm <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.sct <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.scf <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.frm <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.bat <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.application <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.nsf <====== ATTENTION
HKLM Group Policy restriction on software: regedit.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.job <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.js <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.bin <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\drvpci.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\arra.bat <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.pls <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.rbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.com <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.url <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.isu <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.p <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.com <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.92bs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.bin <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %systemdrive%\Network Prosoft\* <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.hta <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.png.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.reg <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.isp <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.wwb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.u3p <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.inx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.png.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.isu <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.jar <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.pys <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.vbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.isp <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.bin <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.lua <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.rex <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\Ponmsiyyks.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.ns <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.png.msc <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.bin <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.isp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.p <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.msi <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\Downloads <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.bas <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\winpnp.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.48s <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: scsvserv.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.com <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.pcd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\Pokemon\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.ns <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.cpl <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\rkcl\rkcl.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.paf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.mod <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.application <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.msp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.scsb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.png.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.phps <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.mdb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.cmd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.png.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.hlp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.p <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.adp <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.com <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: syskey.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: bcdedit.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.png.hta <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.js <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.ws* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.com <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.rex <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.vbs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.png.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.rx* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.ns <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.job <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.p <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.msp <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.xcs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.pif <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.msc <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.rgs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.png.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.crt <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.jar <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.pif <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.url <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.com <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.mdb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.ins <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.url <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.klx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.crt <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.application <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.job <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.jse <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\svchost.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.mod <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.scf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.js <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.mde <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.isu <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.shb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.png.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.url <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.application <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.png.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.js <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.ocx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.ns <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.com <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.png.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.sct <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.scr <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.isu <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.js <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.hta <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.bat <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.reg <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*\svchost.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.adp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.vbe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.com <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.png.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.com <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.chm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.pcd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.msi <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.frm <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.url <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.p <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.url <====== ATTENTION
HKLM Group Policy restriction on software: *.png.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.sct <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *.png.lua <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Windows\csrss.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: %temp%\windrv.exe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.cmd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.js <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.pif <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.nsf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.png.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.xcs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.adp <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.application <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.png.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.phps <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.hta <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.phps <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.jar <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.ws* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.p <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.url <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.pls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.inf <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.klx <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.phps <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.adp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.msi <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.job <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\dbddbccdf.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.png.scsb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.sct <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.vbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.psc* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.gadget <====== ATTENTION
HKLM Group Policy restriction on software: %systemdrive%\dcrypt.exe <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.url <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.u3p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.shb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.com <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.ocx <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.reg <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.application <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.cpl <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.png.rex <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.chm <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.mde <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.hta <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.pcd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.ps2* <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.92bs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.job <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.png.application <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.pptx.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.shb <====== ATTENTION
HKLM Group Policy restriction on software: *.png.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.crt <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.shs <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.klx <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.psc* <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.job <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.mst <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.u3p <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.msc <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.rbs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*.url <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.vb <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.com <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.inf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.xcs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.png.pls <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.application <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.isu <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.shs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.application <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.mp4.pls <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.lnk <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.paf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.jar <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.com <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.rx* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.application <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.com <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.xcs <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.u3p <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.ps1* <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.mdb <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.xml <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.scr <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.url <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.png.cfxb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *.png.rx* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\wz*\*.cmd <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.ns <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.cpl <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.hta <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.cmd <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.mod <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.crt <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.sct <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.rgs <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.bat <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.chm <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.p <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*\*.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.ocx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\Calipso\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: *.pub.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*.bas <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.vb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.rbs <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.crt <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.inf <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.exe <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.scr <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.shs <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.hlp <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.chm <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.ns <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.msc <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.wmv.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.zip.msi <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.vbscript <====== ATTENTION
HKLM Group Policy restriction on software: *.xls.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.xcs <====== ATTENTION
HKLM Group Policy restriction on software: C:\Windows\Temp\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.isp <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.adp <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.ade <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.msp <====== ATTENTION
HKLM Group Policy restriction on software: *.wma.js <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\*\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Default User\*.hta <====== ATTENTION
HKLM Group Policy restriction on software: %appdata%\cryptohost.exe <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.92bs <====== ATTENTION
HKLM Group Policy restriction on software: *.rar.frm <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.rex <====== ATTENTION
HKLM Group Policy restriction on software: *.txt.mdb <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *\u202e*.chm <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.inx <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.reg <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\rar*\*.shb <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\All Users\*.scf <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.mst <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.wwb <====== ATTENTION
HKLM Group Policy restriction on software: *.doc.vbs <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.msh* <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.gadget <====== ATTENTION
HKLM Group Policy restriction on software: *.jpeg.crt <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.isp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.mde <====== ATTENTION
HKLM Group Policy restriction on software: *.mp3.tcls <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.nsf <====== ATTENTION
HKLM Group Policy restriction on software: *.rtf.rgs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\*.msh* <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.wwb <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.jse <====== ATTENTION
HKLM Group Policy restriction on software: *.bmp.adp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\*.crt <====== ATTENTION
HKLM Group Policy restriction on software: *:\$Recycle.Bin\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\*.application <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.92bs <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\LocalLow\*\*.ade <====== ATTENTION
HKLM Group Policy restriction on software: *.pdf.isp <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\*.xml <====== ATTENTION
HKLM Group Policy restriction on software: *.gif.inf <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.scsb <====== ATTENTION
HKLM Group Policy restriction on software: *.7z.tcls <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\*.zip\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: *.jpg.isp <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.jar <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.48s <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\*\*.frm <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Local\Temp\7z*\*.bin <====== ATTENTION
HKLM Group Policy restriction on software: *.docx.pcd <====== ATTENTION
HKLM Group Policy restriction on software: *.xlsx.lua <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Public\*.hlp <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.pif <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\*.job <====== ATTENTION
HKLM Group Policy restriction on software: *.ppt.isu <====== ATTENTION
HKLM Group Policy restriction on software: %programdata%\Microsoft\Windows\Start Menu\Programs\Startup\*.vbe <====== ATTENTION
HKLM Group Policy restriction on software: *.avi.ins <====== ATTENTION
HKLM Group Policy restriction on software: *.divx.pys <====== ATTENTION
HKLM Group Policy restriction on software: *.wav.bat <====== ATTENTION
HKLM Group Policy restriction on software: %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\*.paf <====== ATTENTION
HKLM Group Policy restriction on software: C:\Users\Patrick\*.jse <====== ATTENTION
HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\Run: [MCShield Monitor] => C:\Program Files\MCShield\mcshieldrtm.exe [650816 2015-06-03] (MyCity)
HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\Run: [WinPatrol] => C:\Program Files\Ruiware\WinPatrol\winpatrol.exe [1231240 2017-01-27] (Ruiware)
ShellIconOverlayIdentifiers: [00asw] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShell.dll [2017-04-07] (AVAST Software)
BootExecute: autocheck autochk *
Hosts: There are more than one entry in Hosts. See Hosts section of Addition.txt
Tcpip\Parameters: [DhcpNameServer] 198.18.8.237
Tcpip\..\Interfaces\{03B1C063-BA67-49A2-8164-B0381B336D41}: [DhcpNameServer] 198.18.8.237
Tcpip\..\Interfaces\{084AFF87-4C03-499A-AB4A-DA3055C45748}: [DhcpNameServer] 75.75.75.75 75.75.76.76
Internet Explorer:
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
HKU\.DEFAULT\Software\Microsoft\Internet Explorer\Main,Search Page = hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
HKU\.DEFAULT\Software\Microsoft\Internet Explorer\Main,Start Page = hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=msnhome
HKU\S-1-5-21-2985130882-1756615807-8858886-1000\Software\Microsoft\Internet Explorer\Main,Search Page = hxxp://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
SearchScopes: HKLM -> {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
SearchScopes: HKU\S-1-5-21-2985130882-1756615807-8858886-1000 -> {012E1000-F331-11DB-8314-0800200C9A66} URL = hxxp://www.google.com/search?q={searchTerms}
Handler: ms-itss - {0A9007C0-4076-11D3-8789-0000F8105754} - C:\Program Files\Common Files\Microsoft Shared\Information Retrieval\msitss.dll [2001-06-20] (Microsoft Corporation)
FireFox:
FF ProfilePath: C:\Users\Patrick\AppData\Roaming\Mozilla\Firefox\Profiles\v7d7tla4.default-1483372895367 [2017-04-13]
FF NewTab: Mozilla\Firefox\Profiles\v7d7tla4.default-1483372895367 -> about:newtab
FF Homepage: Mozilla\Firefox\Profiles\v7d7tla4.default-1483372895367 -> about:home
FF Extension: (Adguard AdBlocker) - C:\Users\Patrick\AppData\Roaming\Mozilla\Firefox\Profiles\v7d7tla4.default-1483372895367\Extensions\adguardadblocker@adguard.com.xpi [2017-03-04]
FF Extension: (HTTPS Everywhere) - C:\Users\Patrick\AppData\Roaming\Mozilla\Firefox\Profiles\v7d7tla4.default-1483372895367\Extensions\https-everywhere@eff.org.xpi [2017-04-12]
FF Extension: (Self-Destructing Cookies) - C:\Users\Patrick\AppData\Roaming\Mozilla\Firefox\Profiles\v7d7tla4.default-1483372895367\Extensions\jid0-9XfBwUWnvPx4wWsfBWMCm4Jj69E@jetpack.xpi [2017-03-25]
FF Extension: (uBlock Origin) - C:\Users\Patrick\AppData\Roaming\Mozilla\Firefox\Profiles\v7d7tla4.default-1483372895367\Extensions\uBlock0@raymondhill.net.xpi [2017-04-11]
FF Extension: (Video DownloadHelper) - C:\Users\Patrick\AppData\Roaming\Mozilla\Firefox\Profiles\v7d7tla4.default-1483372895367\Extensions\{b9db16a4-6edc-47ec-a1f4-b86292ed211d}.xpi [2017-03-07]
FF Extension: (Disable Prefetch) - C:\Users\Patrick\AppData\Roaming\Mozilla\Firefox\Profiles\v7d7tla4.default-1483372895367\features\{ba491e37-c838-424c-ad2f-1c09b439d5da}\disable-prefetch@mozilla.org.xpi [2017-04-04]
FF Extension: (Site Deployment Checker) - C:\Program Files\Mozilla Firefox\browser\features\deployment-checker@mozilla.org.xpi [2017-03-28] [not signed]
FF Plugin: @adobe.com/FlashPlayer -> C:\Windows\system32\Macromed\Flash\NPSWF32_25_0_0_127.dll [2017-03-21] ()
FF Plugin: @Microsoft.com/NpCtrl,version=1.0 -> c:\Program Files\Microsoft Silverlight\5.1.50906.0\npctrl.dll [2017-03-09] ( Microsoft Corporation)
FF Plugin: @videolan.org/vlc,version=2.2.4 -> C:\Program Files\VideoLAN\VLC\npvlc.dll [No File]
FF Plugin: Adobe Reader -> C:\Program Files\Adobe\Reader 11.0\Reader\AIR\nppdf32.dll [2016-10-01] (Adobe Systems Inc.)
S3 aswbIDSAgent; C:\Program Files\AVAST Software\Avast\aswidsagent.exe [5765408 2017-04-07] (AVAST Software s.r.o.)
S2 avast! Antivirus; C:\Program Files\AVAST Software\Avast\AvastSvc.exe [262736 2017-04-07] (AVAST Software)
S2 CmdAgent; C:\Program Files\COMODO\COMODO Internet Security\cmdagent.exe [8149832 2017-04-04] (COMODO)
S3 cmdvirth; C:\Program Files\COMODO\COMODO Internet Security\cmdvirth.exe [2080448 2017-04-04] (COMODO)
S3 CryptoPreventEmail; C:\Program Files\Foolish IT\CryptoPrevent\CryptoPreventMonSvc.exe [688792 2017-04-11] (Foolish IT LLC)
S3 CryptoPreventFolderWatch; C:\Program Files\Foolish IT\CryptoPrevent\CryptoPreventMonSvc.exe [688792 2017-04-11] (Foolish IT LLC)
S2 CryptoPreventMonSvc; C:\Program Files\Foolish IT\CryptoPrevent\CryptoPreventMonSvc.exe [688792 2017-04-11] (Foolish IT LLC)
S4 Disc Soft Lite Bus Service; C:\Program Files\DAEMON Tools Lite\DiscSoftBusService.exe [1125568 2016-04-07] (Disc Soft Ltd)
S2 Freedome Service; C:\Program Files\F-Secure\Freedome\Freedome\1\FreedomeService.exe [528352 2017-03-30] (F-Secure Corporation)
S2 hmpalertsvc; C:\Program Files\HitmanPro.Alert\hmpalert.exe [4859528 2017-04-05] (SurfRight B.V.)
S4 isesrv; C:\Program Files\COMODO\Internet Security Essentials\isesrv.exe [118464 2016-12-22] (COMODO)
S4 K2Service.exe; C:\Program Files\Kruptos 2 Software\Kruptos 2 Professional\K2Service.exe [103432 2016-09-26] ()
S2 MBAMScheduler; C:\Program Files\Malwarebytes Anti-Malware\mbamscheduler.exe [1514464 2017-02-11] (Malwarebytes)
S2 MBAMService; C:\Program Files\Malwarebytes Anti-Malware\mbamservice.exe [1136608 2017-02-11] (Malwarebytes)
S4 Secunia PSI Agent; C:\Program Files\Secunia\PSI\PSIA.exe [1570520 2016-11-12] (Secunia)
S4 Secunia Update Agent; C:\Program Files\Secunia\PSI\sua.exe [837848 2016-11-12] (Secunia)
S2 Unchecky; C:\Program Files\Unchecky\bin\unchecky_svc.exe [304408 2017-01-29] (RaMMicHaeL)
S4 VoodooShieldService; C:\Program Files\VoodooShield\VoodooShieldService.exe [129360 2017-03-01] (VoodooSoft, LLC )
S4 WDDriveService; C:\Program Files\Western Digital\WD Drive Manager\WDDriveService.exe [315768 2016-08-05] (Western Digital Technologies, Inc.)
S3 WinDefend; C:\Program Files\Windows Defender\mpsvc.dll [680960 2015-06-03] (Microsoft Corporation)
S2 ZAMSvc; C:\Program Files\Zemana AntiMalware\ZAM.exe [14522512 2017-04-03] (Copyright 2017.)
S1 aswbidsdriver; C:\Windows\system32\drivers\aswbidsdriverx.sys [255184 2017-04-07] (AVAST Software s.r.o.)
S0 aswbidsh; C:\Windows\system32\drivers\aswbidshx.sys [148208 2017-04-07] (AVAST Software s.r.o.)
S0 aswblog; C:\Windows\system32\drivers\aswblogx.sys [267528 2017-04-07] (AVAST Software s.r.o.)
S0 aswbuniv; C:\Windows\system32\drivers\aswbunivx.sys [41176 2017-04-07] (AVAST Software s.r.o.)
S3 aswHwid; C:\Windows\system32\drivers\aswHwid.sys [34136 2017-04-07] (AVAST Software)
S2 aswMonFlt; C:\Windows\system32\drivers\aswMonFlt.sys [106904 2017-04-07] (AVAST Software)
S1 aswRdr; C:\Windows\system32\drivers\aswRdr2.sys [90336 2017-04-07] (AVAST Software)
S0 aswRvrt; C:\Windows\system32\drivers\aswRvrt.sys [62152 2017-04-07] (AVAST Software)
S1 aswSnx; C:\Windows\system32\drivers\aswSnx.sys [764576 2017-04-07] (AVAST Software)
S1 aswSP; C:\Windows\system32\drivers\aswSP.sys [475320 2017-04-07] (AVAST Software)
S2 aswStm; C:\Windows\system32\drivers\aswStm.sys [118800 2017-04-07] (AVAST Software)
S0 aswVmm; C:\Windows\system32\drivers\aswVmm.sys [279800 2017-04-07] (AVAST Software)
R1 cmderd; C:\Windows\System32\DRIVERS\cmderd.sys [27504 2017-03-28] (COMODO)
S1 cmdGuard; C:\Windows\System32\DRIVERS\cmdguard.sys [662864 2017-04-10] (COMODO)
S1 cmdHlp; C:\Windows\System32\DRIVERS\cmdhlp.sys [53344 2017-03-28] (COMODO)
S3 dg_ssudbus; C:\Windows\System32\DRIVERS\ssudbus.sys [107648 2016-08-11] (Samsung Electronics Co., Ltd.)
R3 dtlitescsibus; C:\Windows\System32\DRIVERS\dtlitescsibus.sys [26168 2016-04-05] (Disc Soft Ltd)
R3 dtliteusbbus; C:\Windows\System32\DRIVERS\dtliteusbbus.sys [40504 2016-04-05] (Disc Soft Ltd)
S1 ElbyCDIO; C:\Windows\System32\Drivers\ElbyCDIO.sys [30616 2014-12-20] (Elaborate Bytes AG)
S1 epp; C:\EEK\bin32\epp.sys [95664 2016-10-31] (Emsisoft Ltd)
S3 fsfreedometap; C:\Windows\System32\DRIVERS\fsfreedometap.sys [30760 2017-03-30] (The OpenVPN Project)
S3 hmpalert; C:\Windows\system32\drivers\hmpalert.sys [210368 2017-04-05] (SurfRight B.V.)
S3 hmpnet; C:\Windows\system32\drivers\hmpnet.sys [83136 2017-04-05] (SurfRight B.V.)
S1 inspect; C:\Windows\System32\DRIVERS\inspect.sys [104816 2017-04-10] (COMODO)
S1 isedrv; C:\Windows\system32\drivers\isedrv.sys [39856 2016-12-22] (COMODO)
S1 mbamchameleon; C:\Windows\system32\drivers\mbamchameleon.sys [94936 2017-04-07] (Malwarebytes)
S3 MBAMProtector; C:\Windows\system32\drivers\mbam.sys [24448 2017-02-11] (Malwarebytes)
S3 MBAMSwissArmy; C:\Windows\system32\drivers\MBAMSwissArmy.sys [170200 2017-04-13] (Malwarebytes)
S3 MBAMWebAccessControl; C:\Windows\system32\drivers\mwac.sys [53120 2017-02-11] (Malwarebytes Corporation)
S2 NPF; C:\Windows\System32\drivers\npf.sys [36600 2013-02-28] (Riverbed Technology, Inc.)
S3 pbfilter; C:\Program Files\PeerBlock\pbfilter.sys [20040 2015-06-07] ()
S3 PSI; C:\Windows\System32\DRIVERS\psi_mf_x86.sys [16024 2016-11-12] (Secunia)
S3 qcusbser; C:\Windows\System32\DRIVERS\qcusbser.sys [232160 2015-09-02] (QUALCOMM Incorporated)
S2 secdrv; C:\Windows\system32\Drivers\secdrv.sys [11973 2015-10-20] (Macrovision Corporation, Macrovision Europe Limited, and Macrovision Japan and Asia K.K.) [File not signed]
S3 tap0901; C:\Windows\System32\DRIVERS\tap0901.sys [23040 2016-09-02] (The OpenVPN Project)
S1 VBoxNetAdp; C:\Windows\System32\DRIVERS\VBoxNetAdp6.sys [103544 2016-06-05] (Oracle Corporation)
S3 VSScanner; C:\Windows\System32\DRIVERS\vsscanner.sys [19016 2017-03-01] (VoodooSoft, LLC)
S3 WDC_SAM; C:\Windows\System32\DRIVERS\wdcsam_prewin8.sys [20256 2017-02-12] (Western Digital Technologies)
S1 ZAM; C:\Windows\System32\drivers\zam32.sys [181496 2016-10-02] (Zemana Ltd.)
S1 ZAM_Guard; C:\Windows\System32\drivers\zamguard32.sys [181496 2016-10-02] (Zemana Ltd.)
U5 AppMgmt; C:\Windows\system32\svchost.exe [20992 2009-07-13] (Microsoft Corporation)
========================== Drivers MD5 =======================
C:\Windows\system32\drivers\1394ohci.sys ==> MD5 is legit
C:\Windows\System32\drivers\ACPI.sys ==> MD5 is legit
C:\Windows\system32\drivers\acpipmi.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\adp94xx.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\adpahci.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\adpu320.sys ==> MD5 is legit
C:\Windows\system32\drivers\afd.sys 93B49FA857F7036A4EFF32371F6E7391
C:\Windows\system32\drivers\agp440.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\djsvs.sys ==> MD5 is legit
C:\Windows\system32\drivers\aliide.sys ==> MD5 is legit
C:\Windows\system32\drivers\amdagp.sys ==> MD5 is legit
C:\Windows\system32\drivers\amdide.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\amdk8.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\amdppm.sys ==> MD5 is legit
C:\Windows\system32\drivers\amdsata.sys D320BF87125326F996D4904FE24300FC
C:\Windows\system32\DRIVERS\amdsbs.sys ==> MD5 is legit
C:\Windows\System32\drivers\amdxata.sys 46387FB17B086D16DEA267D5BE23A2F2
C:\Windows\system32\drivers\appid.sys 083B44921C176809C1F219C59AE83C75
C:\Windows\system32\DRIVERS\arc.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\arcsas.sys ==> MD5 is legit
C:\Windows\system32\drivers\aswbidsdriverx.sys E9C3A1127B337D714E1063EA79F03A17
C:\Windows\system32\drivers\aswbidshx.sys A92138A0F584382FAE8EF9DFFF4D7F4B
C:\Windows\system32\drivers\aswblogx.sys 8E0180DB1905C7DB5FFD57F9BC3195E9
C:\Windows\system32\drivers\aswbunivx.sys 462D412B2329BC5507BC850A8AF0B33D
C:\Windows\system32\drivers\aswHwid.sys 2CD0E738296581592262B266BD71D5EA
C:\Windows\system32\drivers\aswMonFlt.sys C2D8CF8C0675AFE286D940A21F71401F
C:\Windows\system32\drivers\aswRdr2.sys 030A276904C84FE1346D362A64BF2281
C:\Windows\system32\drivers\aswRvrt.sys C1239FE95C135F2E94CCE6B81244346B
C:\Windows\system32\drivers\aswSnx.sys 3C74ADFFC2AC7AD8BF0EE0C8EECA36A1
C:\Windows\system32\drivers\aswSP.sys 5EA26BF4009E91724997BA9CC28235DF
C:\Windows\system32\drivers\aswStm.sys 08C382532F56D5DA18FB4582BB3A38DF
C:\Windows\system32\drivers\aswVmm.sys 5C78BB445F95B0A49DFA72F9EE131368
C:\Windows\System32\DRIVERS\asyncmac.sys ==> MD5 is legit
C:\Windows\System32\drivers\atapi.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\bxvbdx.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\b57nd60x.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\bcmwl6.sys EB7C2DADF52F50F69F198C14C3556DC1
C:\Windows\system32\Drivers\Beep.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\blbdrive.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\bowser.sys 28AF7D4427868B7CE4C00CAB1864C7F6
C:\Windows\system32\DRIVERS\BrFiltLo.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\BrFiltUp.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\bridge.sys 77361D72A04F18809D0EFB6CCEB74D4B
C:\Windows\System32\Drivers\Brserid.sys ==> MD5 is legit
C:\Windows\System32\Drivers\BrSerWdm.sys ==> MD5 is legit
C:\Windows\System32\Drivers\BrUsbMdm.sys ==> MD5 is legit
C:\Windows\System32\Drivers\BrUsbSer.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\bthmodem.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\cdfs.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\cdrom.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\circlass.sys ==> MD5 is legit
C:\Windows\System32\CLFS.sys 1136E4A71849BCFCB057140AD03AAEE6
C:\Windows\System32\DRIVERS\CmBatt.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\cmderd.sys 7C0F8DC6E8EB324643634E021758B510
C:\Windows\System32\DRIVERS\cmdguard.sys CC1BA54B4232B70D7AEE29EFF67937BC
C:\Windows\System32\DRIVERS\cmdhlp.sys 4095A5A3D914D1A6FAFAAEA8110231BF
C:\Windows\system32\drivers\cmdide.sys ==> MD5 is legit
C:\Windows\System32\Drivers\cng.sys 7F7D4B16389CEF932950F6B2604D2601
C:\Windows\System32\DRIVERS\compbatt.sys ==> MD5 is legit
C:\Windows\system32\drivers\CompositeBus.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\crcdisk.sys ==> MD5 is legit
C:\Windows\system32\Drivers\CtAudDrv.sys 0F538DF1673E5216F3BAACB6911D9D0F
C:\Windows\System32\DRIVERS\CtClsFlt.sys 9A6CA307151505730DBFC91D97F01C7E
C:\Windows\System32\Drivers\dfsc.sys EA9DBD76CE9254C77BAAB4339DD4C4FB
C:\Windows\System32\DRIVERS\ssudbus.sys B8AF290680D6995D98801F70E1BAB56D
C:\Windows\System32\drivers\discache.sys ==> MD5 is legit
C:\Windows\System32\drivers\disk.sys B7B470F163002A0D0E381EE45834BF6B
C:\Windows\system32\drivers\drmkaud.sys A3F684B866A7D89AE396276CE7AFD416
C:\Windows\System32\DRIVERS\dtlitescsibus.sys 8A32FF671D452D36CC7421171B78F939
C:\Windows\System32\DRIVERS\dtliteusbbus.sys 0098B71A5D28FEAF321B4AC4549765D9
C:\Windows\System32\drivers\dxgkrnl.sys C1618B0E6527BA60F0D7CEDA4AE8FE10
C:\Windows\system32\DRIVERS\evbdx.sys ==> MD5 is legit
C:\Windows\System32\Drivers\ElbyCDIO.sys 72753D5CC94A90F5CFC6C00ECC47163F
C:\Windows\system32\DRIVERS\elxstor.sys ==> MD5 is legit
C:\EEK\bin32\epp.sys 0013002D699CCF9D7B93F30D44A51739
C:\Windows\system32\drivers\errdev.sys ==> MD5 is legit
C:\Windows\system32\Drivers\exfat.sys ==> MD5 is legit
C:\Windows\system32\Drivers\fastfat.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\fdc.sys ==> MD5 is legit
C:\Windows\System32\drivers\fileinfo.sys ==> MD5 is legit
C:\Windows\System32\drivers\filetrace.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\flpydisk.sys ==> MD5 is legitB
C:\Windows\System32\drivers\fltmgr.sys ==> MD5 is legit
C:\Windows\System32\drivers\FsDepends.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\fsfreedometap.sys 833063742BFFD1158DFB4D2298074C12
C:\Windows\system32\Drivers\Fs_Rec.sys 7DAE5EBCC80E45D3253F4923DC424D05
C:\Windows\System32\DRIVERS\fvevol.sys E306A24D9694C724FA2491278BF50FDB
C:\Windows\system32\DRIVERS\gagp30kx.sys ==> MD5 is legit
C:\Windows\system32\drivers\hcw85cir.sys ==> MD5 is legit
C:\Windows\system32\drivers\HdAudio.sys A5EF29D5315111C80A5C1ABAD14C8972
C:\Windows\system32\drivers\HDAudBus.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\HidBatt.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\hidbth.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\hidir.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\hidusb.sys ==> MD5 is legit
C:\Windows\system32\drivers\hmpalert.sys B1935050055A4D70090370B26BC98EF7
C:\Windows\system32\drivers\hmpnet.sys B9D28C4715A453EF47A4ACFD4E4BA9DC
C:\Windows\system32\drivers\HpSAMD.sys ==> MD5 is legit
C:\Windows\System32\drivers\HTTP.sys 487569E5DA56A5A432FF8AF6D3599CF9
C:\Windows\System32\drivers\hwpolicy.sys ==> MD5 is legit
C:\Windows\system32\drivers\i8042prt.sys ==> MD5 is legit
C:\Windows\system32\drivers\iaStorV.sys 5CD5F9A5444E6CDCB0AC89BD62D8B76E
C:\Windows\System32\DRIVERS\igdkmd32.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\iirsp.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\inspect.sys 9BC1FFC1308542DA3A03BD94231EFE84
C:\Windows\system32\drivers\intelide.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\intelppm.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\ipfltdrv.sys ==> MD5 is legit
C:\Windows\system32\drivers\IPMIDrv.sys ==> MD5 is legit
C:\Windows\System32\drivers\ipnat.sys ==> MD5 is legit
C:\Windows\System32\drivers\irenum.sys ==> MD5 is legit
C:\Windows\system32\drivers\isapnp.sys ==> MD5 is legit
C:\Windows\system32\drivers\msiscsi.sys EB34CE31FABD4DC4343FD2AD16D2CAF9
C:\Windows\system32\drivers\isedrv.sys 8A49EB5F799ED4208080CCCFE2DB90C2
C:\Windows\System32\DRIVERS\kbdclass.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\kbdhid.sys ==> MD5 is legit
C:\Windows\System32\Drivers\ksecdd.sys BF8589C56B6C0A863B35FF7C2756297B
C:\Windows\System32\Drivers\ksecpkg.sys 2F25ED3988208414CE52494781CAD572
C:\Windows\System32\DRIVERS\lltdio.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\lsi_fc.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\lsi_sas.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\lsi_sas2.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\lsi_scsi.sys ==> MD5 is legit
C:\Windows\system32\drivers\luafv.sys ==> MD5 is legit
C:\Windows\system32\drivers\mbamchameleon.sys FDBDEDB746A33BAFC17394D1960ADEAF
C:\Windows\system32\drivers\mbam.sys A1D52DB330E18B5A7A718D31D950CA87
C:\Windows\system32\drivers\MBAMSwissArmy.sys 5023F594D5448E16F920157174C61358
C:\Windows\system32\drivers\mwac.sys 66DDF98174707CBADBCA6BBABDA1231C
C:\Windows\system32\DRIVERS\megasas.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\MegaSR.sys ==> MD5 is legit
C:\Windows\System32\drivers\modem.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\monitor.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\mouclass.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\mouhid.sys ==> MD5 is legit
C:\Windows\System32\drivers\mountmgr.sys D1BDF813C9FE5ED53134EDF360927735
C:\Windows\system32\drivers\mpio.sys ==> MD5 is legit
C:\Windows\System32\drivers\mpsdrv.sys ==> MD5 is legit
C:\Windows\system32\drivers\mrxdav.sys 06AC0310138E4B2C35AF7344D18BC686
C:\Windows\System32\DRIVERS\mrxsmb.sys DF054C04C065D628B54D19BB7DDC24C1
C:\Windows\System32\DRIVERS\mrxsmb10.sys 3A40C64637BA66317351FE3E653B6BE0
C:\Windows\System32\DRIVERS\mrxsmb20.sys 15D285A71358198EA18BE60A8EB6D9AA
C:\Windows\System32\drivers\msahci.sys ==> MD5 is legit
C:\Windows\system32\drivers\msdsm.sys ==> MD5 is legit
C:\Windows\system32\Drivers\Msfs.sys ==> MD5 is legit
C:\Windows\System32\drivers\mshidkmdf.sys ==> MD5 is legit
C:\Windows\System32\drivers\msisadrv.sys ==> MD5 is legit
C:\Windows\System32\drivers\MSKSSRV.sys ==> MD5 is legit
C:\Windows\System32\drivers\MSPCLOCK.sys ==> MD5 is legit
C:\Windows\System32\drivers\MSPQM.sys ==> MD5 is legit
C:\Windows\system32\Drivers\MsRPC.sys ==> MD5 is legit
C:\Windows\system32\drivers\mssmbios.sys ==> MD5 is legit
C:\Windows\System32\drivers\MSTEE.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\MTConfig.sys ==> MD5 is legit
C:\Windows\System32\Drivers\mup.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\nwifi.sys ==> MD5 is legit
C:\Windows\System32\drivers\ndis.sys 9804FB2E46077F2977552347DFCA7E05
C:\Windows\System32\DRIVERS\ndiscap.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\ndistapi.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\ndisuio.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\ndiswan.sys ==> MD5 is legit
C:\Windows\system32\Drivers\NDProxy.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\netbios.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\netbt.sys A00996C9BFEF29A93B9F21DBE1DC502D
C:\Windows\system32\DRIVERS\nfrd960.sys ==> MD5 is legit
C:\Windows\System32\drivers\npf.sys 25401B0C9576C8456B3E0BBD74FF0771
C:\Windows\system32\Drivers\Npfs.sys ==> MD5 is legit
C:\Windows\System32\drivers\nsiproxy.sys ==> MD5 is legit
C:\Windows\system32\Drivers\Ntfs.sys 978E7A2E4BF4E8E70D0776EF0D9E97FB
C:\Windows\system32\Drivers\Null.sys ==> MD5 is legit
C:\Windows\system32\drivers\nvraid.sys B3E25EE28883877076E0E1FF877D02E0
C:\Windows\system32\drivers\nvstor.sys 4380E59A170D88C4F1022EFF6719A8A4
C:\Windows\system32\drivers\nv_agp.sys ==> MD5 is legit
C:\Windows\system32\drivers\ohci1394.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\parport.sys ==> MD5 is legit
C:\Windows\System32\drivers\partmgr.sys 3F34A1B4C5F6475F320C275E63AFCE9B
C:\Windows\system32\DRIVERS\parvdm.sys ==> MD5 is legit
C:\Program Files\PeerBlock\pbfilter.sys DD20CD5991712BE6004F45BE5C44CAD0
C:\Windows\System32\drivers\pci.sys ==> MD5 is legit
C:\Windows\system32\drivers\pciide.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\pcmcia.sys ==> MD5 is legit
C:\Windows\System32\drivers\pcw.sys ==> MD5 is legit
C:\Windows\System32\drivers\peauth.sys 0C941A3F148B4228867908F98F394461
C:\Windows\System32\DRIVERS\raspptp.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\processr.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\pacer.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\psi_mf_x86.sys 68B57D7C11277EA89F78255480376B4D
C:\Windows\System32\DRIVERS\qcusbser.sys C087900935B6472233EECE8A86AE9C77
C:\Windows\system32\DRIVERS\ql2300.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\ql40xx.sys ==> MD5 is legit
C:\Windows\system32\drivers\qwavedrv.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\rasacd.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\AgileVpn.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\rasl2tp.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\raspppoe.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\rassstp.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\rdbss.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\rdpbus.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\RDPCDD.sys ==> MD5 is legit
C:\Windows\System32\drivers\rdpencdd.sys ==> MD5 is legit
C:\Windows\System32\drivers\rdprefmp.sys ==> MD5 is legit
C:\Windows\System32\drivers\rdpvideominiport.sys 65375DF758CA1872AB7EBBBA457FD5E6
C:\Windows\system32\Drivers\RDPWD.sys CD9214A6AE17D188D17C3CF8CB9CC693
C:\Windows\System32\drivers\rdyboost.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\rspndr.sys ==> MD5 is legit
C:\Windows\system32\drivers\sbp2port.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\scfilter.sys ==> MD5 is legit
C:\Windows\system32\Drivers\secdrv.sys 72DFFA33F8ED1C847075EEE2C1E790EE
C:\Windows\system32\DRIVERS\serenum.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\serial.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\sermouse.sys ==> MD5 is legit
C:\Windows\system32\drivers\sffdisk.sys ==> MD5 is legit
C:\Windows\system32\drivers\sffp_mmc.sys ==> MD5 is legit
C:\Windows\system32\drivers\sffp_sd.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\sfloppy.sys ==> MD5 is legit
C:\Windows\system32\drivers\sisagp.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\SiSRaid2.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\sisraid4.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\smb.sys ==> MD5 is legit
C:\Windows\system32\Drivers\spldr.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\srv.sys 90FBF12A93BB60360993F690CF0ACF45
C:\Windows\System32\DRIVERS\srv2.sys 14B6849E81F75ECDCA29261F707686E8
C:\Windows\System32\DRIVERS\srvnet.sys 4589FBE14AB0E789D7BD43B04A0BB618
C:\Windows\System32\DRIVERS\ssudmdm.sys 1F568F98A6BBBB174965A182D17AA75D
C:\Windows\system32\DRIVERS\stexstor.sys ==> MD5 is legit
C:\Windows\system32\drivers\swenum.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\tap0901.sys F49967C396969B71C3A72537DB03A68B
C:\Windows\System32\drivers\tcpip.sys C7E41209132B9CF084CCEA8593F61328
C:\Windows\System32\DRIVERS\tcpip.sys C7E41209132B9CF084CCEA8593F61328
C:\Windows\System32\drivers\tcpipreg.sys A4BF8BE9D1F7D563C7868AC7B2561545
C:\Windows\System32\drivers\tdpipe.sys ==> MD5 is legit
C:\Windows\System32\drivers\tdtcp.sys 2C2C5AFE7EE4F620D69C23C0617651A8
C:\Windows\System32\DRIVERS\tdx.sys BB8817D0508DD5EA69C770C8DEF5AB67
C:\Windows\system32\drivers\termdd.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\tssecsrv.sys B89F89A2308E9569A1022A50F78C5506
C:\Windows\System32\drivers\tsusbflt.sys C6A5FBD4977305E1FA23E02C042DB463
C:\Windows\System32\DRIVERS\tunnel.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\uagp35.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\udfs.sys ==> MD5 is legit
C:\Windows\system32\drivers\uliagpkx.sys ==> MD5 is legit
C:\Windows\system32\drivers\umbus.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\umpass.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\usbccgp.sys 325A69967CC7B4BFB170F5636143A94A
C:\Windows\system32\drivers\usbcir.sys 2352AB5F9F8F097BF9D41D5A4718A041
C:\Windows\system32\drivers\usbehci.sys 5D57798CAE5A0DD0B8F61C52B8E7C3D1
C:\Windows\system32\drivers\usbhub.sys 3835ECC1E928042F92D7AA1963D40523
C:\Windows\system32\drivers\usbohci.sys 81E1E90305A4C7A13BADC5DFA22ABA37
C:\Windows\system32\DRIVERS\usbprint.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\USBSTOR.SYS 144DA53294922A84FFAA3D90B1453745
C:\Windows\system32\drivers\usbuhci.sys B4A1789BE90403D9549EF9DBAD37A429
C:\Windows\System32\Drivers\usbvideo.sys DE014425522610BEDCA3821BB8C0F1D5
C:\Windows\System32\DRIVERS\VBoxNetAdp6.sys 3AA7D74157C922E0C794C2F44F3D5F21
C:\Windows\System32\Drivers\VBoxUSB.sys FE10BFADA31398EA4E4F9BE77A184255
C:\Windows\System32\DRIVERS\VClone.sys 6BEE3F8B3A08179BA475AA6043CAB30D
C:\Windows\System32\drivers\vdrvroot.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\vgapnp.sys ==> MD5 is legit
C:\Windows\System32\drivers\vga.sys ==> MD5 is legit
C:\Windows\system32\drivers\vhdmp.sys ==> MD5 is legit
C:\Windows\system32\drivers\viaagp.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\viac7.sys ==> MD5 is legit
C:\Windows\system32\drivers\viaide.sys ==> MD5 is legit
C:\Windows\System32\drivers\volmgr.sys ==> MD5 is legit
C:\Windows\System32\drivers\volmgrx.sys ==> MD5 is legit
C:\Windows\System32\drivers\volsnap.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\vsmraid.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\vsscanner.sys EC53AE296AD313521B7C401EC156B6E9
C:\Windows\System32\DRIVERS\vwifibus.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\vwififlt.sys 7090D3436EEB4E7DA3373090A23448F7
C:\Windows\System32\DRIVERS\vwifimp.sys A3F04CBEA6C2A10E6CB01F8B47611882
C:\Windows\system32\DRIVERS\wacompen.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\wanarp.sys ==> MD5 is legit
C:\Windows\system32\DRIVERS\wd.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\wdcsam_prewin8.sys 68F092B4491632458C6370C64DFC48DF
C:\Windows\System32\drivers\Wdf01000.sys 25944D2CC49E0A6C581D02A74B7D6645
C:\Windows\System32\DRIVERS\wfplwf.sys ==> MD5 is legit
C:\Windows\System32\drivers\wimmount.sys ==> MD5 is legit
C:\Windows\System32\DRIVERS\WinUsb.sys A67E5F9A400F3BD1BE3D80613B45F708
C:\Windows\system32\drivers\wmiacpi.sys ==> MD5 is legit
C:\Windows\system32\drivers\ws2ifsl.sys ==> MD5 is legit
C:\Windows\System32\drivers\WudfPf.sys 06E6F32C8D0A3F66D956F57B43A2E070
C:\Windows\System32\DRIVERS\WUDFRd.sys 867C301E8B790040AE9CF6486E8041DF
C:\Windows\System32\DRIVERS\yk62x86.sys B07C5B7EFDF936FF93D4F540938725BE
C:\Windows\System32\drivers\zam32.sys 06897B431C07886454E0681723DD53E6
C:\Windows\System32\drivers\zamguard32.sys 06897B431C07886454E0681723DD53E6
==================== Three Months Created files and folders ========
2017-04-13 15:05 - 2017-04-13 15:42 - 00363610 _____ C:\Users\Patrick\Desktop\FRST.txt
2017-04-13 15:01 - 2017-04-13 15:01 - 01766912 _____ (Farbar) C:\Users\Patrick\Desktop\FRST.exe
2017-04-13 14:41 - 2017-04-13 14:41 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\Comodo
2017-04-13 14:19 - 2017-04-13 14:19 - 00000000 ____D C:\Users\Patrick\AppData\Local\Macromedia
2017-04-13 13:53 - 2017-04-13 14:09 - 00000000 ____D C:\Users\Patrick\dwhelper
2017-04-13 13:25 - 2017-04-13 15:04 - 00000000 ____D C:\Users\Patrick\AppData\LocalLow\Mozilla
2017-04-13 12:56 - 2017-04-13 12:56 - 00000000 ____D C:\Users\Patrick\AppData\Local\CEF
2017-04-13 12:45 - 2017-04-13 12:45 - 00081224 _____ C:\Users\Patrick\AppData\Local\GDIPFONTCACHEV1.DAT
2017-04-13 12:42 - 2017-04-13 12:42 - 00337688 _____ C:\Windows\system32\FNTCACHE.DAT
2017-04-13 12:38 - 2017-04-13 15:40 - 00225836 _____ C:\Windows\ntbtlog.txt
2017-04-11 12:05 - 2017-03-27 10:28 - 00346320 _____ (Microsoft Corporation) C:\Windows\system32\iedkcs32.dll
2017-04-11 12:05 - 2017-03-25 12:39 - 20284416 _____ (Microsoft Corporation) C:\Windows\system32\mshtml.dll
2017-04-11 12:05 - 2017-03-25 12:07 - 04604416 _____ (Microsoft Corporation) C:\Windows\system32\jscript9.dll
2017-04-11 12:05 - 2017-03-25 12:06 - 13654016 _____ (Microsoft Corporation) C:\Windows\system32\ieframe.dll
2017-04-11 12:05 - 2017-03-25 11:55 - 02767360 _____ (Microsoft Corporation) C:\Windows\system32\wininet.dll
2017-04-11 12:05 - 2017-03-25 11:52 - 02289152 _____ (Microsoft Corporation) C:\Windows\system32\iertutil.dll
2017-04-11 12:05 - 2017-03-25 11:51 - 01313280 _____ (Microsoft Corporation) C:\Windows\system32\urlmon.dll
2017-04-11 12:05 - 2017-03-25 11:48 - 00499200 _____ (Microsoft Corporation) C:\Windows\system32\vbscript.dll
2017-04-11 12:05 - 2017-03-25 11:47 - 02055680 _____ (Microsoft Corporation) C:\Windows\system32\inetcpl.cpl
2017-04-11 12:05 - 2017-03-25 11:47 - 00710144 _____ (Microsoft Corporation) C:\Windows\system32\ieapfltr.dll
2017-04-11 12:05 - 2017-03-25 11:47 - 00103936 _____ (Microsoft Corporation) C:\Windows\system32\ieetwcollector.exe
2017-04-11 12:05 - 2017-03-25 11:47 - 00047616 _____ (Microsoft Corporation) C:\Windows\system32\ieetwproxystub.dll
2017-04-11 12:05 - 2017-03-25 11:47 - 00004096 _____ (Microsoft Corporation) C:\Windows\system32\ieetwcollectorres.dll
2017-04-11 12:05 - 2017-03-25 11:46 - 00693248 _____ (Microsoft Corporation) C:\Windows\system32\msfeeds.dll
2017-04-11 12:05 - 2017-03-25 11:46 - 00663552 _____ (Microsoft Corporation) C:\Windows\system32\jscript.dll
2017-04-11 12:05 - 2017-03-25 11:46 - 00620032 _____ (Microsoft Corporation) C:\Windows\system32\jscript9diag.dll
2017-04-11 12:05 - 2017-03-25 11:46 - 00230400 _____ (Microsoft Corporation) C:\Windows\system32\webcheck.dll
2017-04-11 12:05 - 2017-03-25 11:46 - 00168960 _____ (Microsoft Corporation) C:\Windows\system32\msrating.dll
2017-04-11 12:05 - 2017-03-25 11:46 - 00130048 _____ (Microsoft Corporation) C:\Windows\system32\occache.dll
2017-04-11 12:05 - 2017-03-25 11:46 - 00060416 _____ (Microsoft Corporation) C:\Windows\system32\JavaScriptCollectionAgent.dll
2017-04-11 12:05 - 2017-03-25 11:46 - 00047104 _____ (Microsoft Corporation) C:\Windows\system32\jsproxy.dll
2017-04-11 12:05 - 2017-03-25 11:45 - 00689664 _____ (Microsoft Corporation) C:\Windows\system32\ie4uinit.exe
2017-04-11 12:05 - 2017-03-25 11:45 - 00416256 _____ (Microsoft Corporation) C:\Windows\system32\dxtmsft.dll
2017-04-11 12:05 - 2017-03-25 11:45 - 00279040 _____ (Microsoft Corporation) C:\Windows\system32\dxtrans.dll
2017-04-11 12:05 - 2017-03-25 11:45 - 00115712 _____ (Microsoft Corporation) C:\Windows\system32\ieUnatt.exe
2017-04-11 12:05 - 2017-03-25 11:45 - 00091136 _____ (Microsoft Corporation) C:\Windows\system32\inseng.dll
2017-04-11 12:05 - 2017-03-25 11:45 - 00064000 _____ (Microsoft Corporation) C:\Windows\system32\MshtmlDac.dll
2017-04-11 12:05 - 2017-03-25 11:45 - 00062464 _____ (Microsoft Corporation) C:\Windows\system32\iesetup.dll
2017-04-11 12:05 - 2017-03-25 11:45 - 00030720 _____ (Microsoft Corporation) C:\Windows\system32\iernonce.dll
2017-04-11 12:05 - 2017-03-25 11:44 - 02724864 _____ (Microsoft Corporation) C:\Windows\system32\mshtml.tlb
2017-04-11 12:05 - 2017-03-25 11:44 - 00076288 _____ (Microsoft Corporation) C:\Windows\system32\mshtmled.dll
2017-04-11 12:05 - 2017-03-25 10:19 - 00341504 _____ (Microsoft Corporation) C:\Windows\system32\html.iec
2017-04-11 12:05 - 2017-03-25 10:06 - 00476160 _____ (Microsoft Corporation) C:\Windows\system32\ieui.dll
2017-04-11 12:05 - 2017-03-25 09:57 - 00667648 _____ (Microsoft Corporation) C:\Windows\system32\MsSpellCheckingFacility.exe
2017-04-11 12:05 - 2017-03-25 09:27 - 01155072 _____ (Microsoft Corporation) C:\Windows\system32\mshtmlmedia.dll
2017-04-11 12:05 - 2017-03-24 15:41 - 00306688 _____ (Microsoft Corporation) C:\Windows\system32\gdi32.dll
2017-04-11 12:05 - 2017-03-22 08:24 - 02953216 _____ (Microsoft Corporation) C:\Windows\system32\wucltux.dll
2017-04-11 12:05 - 2017-03-22 08:24 - 00174080 _____ (Microsoft Corporation) C:\Windows\system32\wuwebv.dll
2017-04-11 12:05 - 2017-03-22 08:20 - 00073728 _____ (Microsoft Corporation) C:\Windows\system32\WinSetupUI.dll
2017-04-11 12:05 - 2017-03-22 08:06 - 02091520 _____ (Microsoft Corporation) C:\Windows\system32\wuaueng.dll
2017-04-11 12:05 - 2017-03-22 08:05 - 00573440 _____ (Microsoft Corporation) C:\Windows\system32\wuapi.dll
2017-04-11 12:05 - 2017-03-22 08:05 - 00136192 _____ (Microsoft Corporation) C:\Windows\system32\wuauclt.exe
2017-04-11 12:05 - 2017-03-22 08:05 - 00093696 _____ (Microsoft Corporation) C:\Windows\system32\wudriver.dll
2017-04-11 12:05 - 2017-03-22 08:05 - 00035840 _____ (Microsoft Corporation) C:\Windows\system32\wups2.dll
2017-04-11 12:05 - 2017-03-22 08:05 - 00035328 _____ (Microsoft Corporation) C:\Windows\system32\wuapp.exe
2017-04-11 12:05 - 2017-03-22 08:05 - 00030208 _____ (Microsoft Corporation) C:\Windows\system32\wups.dll
2017-04-11 12:05 - 2017-03-22 08:05 - 00011776 _____ (Microsoft Corporation) C:\Windows\system32\wu.upgrade.ps.dll
2017-04-11 12:05 - 2017-03-14 08:23 - 00730344 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\dxgkrnl.sys
2017-04-11 12:05 - 2017-03-14 08:23 - 00218856 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\dxgmms1.sys
2017-04-11 12:05 - 2017-03-14 08:17 - 00107520 _____ (Microsoft Corporation) C:\Windows\system32\cdd.dll
2017-04-11 12:05 - 2017-03-10 09:27 - 00308456 _____ (Adobe Systems Incorporated) C:\Windows\system32\atmfd.dll
2017-04-11 12:05 - 2017-03-10 09:19 - 00070656 _____ (Microsoft Corporation) C:\Windows\system32\fontsub.dll
2017-04-11 12:05 - 2017-03-10 09:19 - 00026112 _____ (Microsoft Corporation) C:\Windows\system32\lpk.dll
2017-04-11 12:05 - 2017-03-10 09:19 - 00010240 _____ (Microsoft Corporation) C:\Windows\system32\dciman32.dll
2017-04-11 12:05 - 2017-03-10 08:54 - 02400256 _____ (Microsoft Corporation) C:\Windows\system32\win32k.sys
2017-04-11 12:05 - 2017-03-10 08:53 - 00034304 _____ (Adobe Systems) C:\Windows\system32\atmlib.dll
2017-04-11 12:05 - 2017-03-08 13:10 - 00805376 _____ (Microsoft Corporation) C:\Windows\system32\cdosys.dll
2017-04-11 12:05 - 2017-03-07 21:26 - 04000488 _____ (Microsoft Corporation) C:\Windows\system32\ntkrnlpa.exe
2017-04-11 12:05 - 2017-03-07 21:26 - 03945192 _____ (Microsoft Corporation) C:\Windows\system32\ntoskrnl.exe
2017-04-11 12:05 - 2017-03-07 21:26 - 00137960 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\ksecpkg.sys
2017-04-11 12:05 - 2017-03-07 21:26 - 00067304 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\ksecdd.sys
2017-04-11 12:05 - 2017-03-07 21:24 - 01310528 _____ (Microsoft Corporation) C:\Windows\system32\ntdll.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 01416192 _____ (Microsoft Corporation) C:\Windows\system32\ole32.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 01062912 _____ (Microsoft Corporation) C:\Windows\system32\lsasrv.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00872448 _____ (Microsoft Corporation) C:\Windows\system32\kernel32.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00655360 _____ (Microsoft Corporation) C:\Windows\system32\rpcrt4.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00553472 _____ (Microsoft Corporation) C:\Windows\system32\kerberos.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00400896 _____ (Microsoft Corporation) C:\Windows\system32\srcore.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00294400 _____ (Microsoft Corporation) C:\Windows\system32\KernelBase.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00261120 _____ (Microsoft Corporation) C:\Windows\system32\msv1_0.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00254464 _____ (Microsoft Corporation) C:\Windows\system32\schannel.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00223232 _____ (Microsoft Corporation) C:\Windows\system32\ncrypt.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00172032 _____ (Microsoft Corporation) C:\Windows\system32\wdigest.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00171008 _____ (Microsoft Corporation) C:\Windows\system32\winsrv.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00146432 _____ (Microsoft Corporation) C:\Windows\system32\msaudite.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00141312 _____ (Microsoft Corporation) C:\Windows\system32\rpchttp.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00099840 _____ (Microsoft Corporation) C:\Windows\system32\sspicli.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00065536 _____ (Microsoft Corporation) C:\Windows\system32\TSpkg.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00060416 _____ (Microsoft Corporation) C:\Windows\system32\msobjs.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00050176 _____ (Microsoft Corporation) C:\Windows\system32\setbcdlocale.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00043008 _____ (Microsoft Corporation) C:\Windows\system32\srclient.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00038912 _____ (Microsoft Corporation) C:\Windows\system32\csrsrv.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00022016 _____ (Microsoft Corporation) C:\Windows\system32\secur32.dll
2017-04-11 12:05 - 2017-03-07 21:22 - 00017408 _____ (Microsoft Corporation) C:\Windows\system32\credssp.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00690688 _____ (Microsoft Corporation) C:\Windows\system32\adtschema.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00644096 _____ (Microsoft Corporation) C:\Windows\system32\advapi32.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00082432 _____ (Microsoft Corporation) C:\Windows\system32\bcrypt.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00050688 _____ (Microsoft Corporation) C:\Windows\system32\appidapi.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00006656 _____ (Microsoft Corporation) C:\Windows\system32\apisetschema.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00005120 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-file-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00004608 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-processthreads-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-sysinfo-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-synch-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-misc-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-localregistry-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-localization-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-processenvironment-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-namedpipe-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-memory-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-libraryloader-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-interlocked-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-heap-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-string-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-rtlsupport-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-profile-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-io-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-handle-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-fibers-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-errorhandling-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-delayload-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-debug-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-datetime-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 21:21 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-console-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 20:58 - 00097792 _____ (Microsoft Corporation) C:\Windows\system32\appidpolicyconverter.exe
2017-04-11 12:05 - 2017-03-07 20:58 - 00050688 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\appid.sys
2017-04-11 12:05 - 2017-03-07 20:58 - 00029696 _____ (Microsoft Corporation) C:\Windows\system32\appidsvc.dll
2017-04-11 12:05 - 2017-03-07 20:58 - 00016896 _____ (Microsoft Corporation) C:\Windows\system32\appidcertstorecheck.exe
2017-04-11 12:05 - 2017-03-07 20:57 - 00050176 _____ (Microsoft Corporation) C:\Windows\system32\auditpol.exe
2017-04-11 12:05 - 2017-03-07 20:56 - 00271360 _____ (Microsoft Corporation) C:\Windows\system32\conhost.exe
2017-04-11 12:05 - 2017-03-07 20:55 - 00262656 _____ (Microsoft Corporation) C:\Windows\system32\rstrui.exe
2017-04-11 12:05 - 2017-03-07 20:54 - 00226304 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxsmb10.sys
2017-04-11 12:05 - 2017-03-07 20:54 - 00124416 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxsmb.sys
2017-04-11 12:05 - 2017-03-07 20:54 - 00098304 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxsmb20.sys
2017-04-11 12:05 - 2017-03-07 20:53 - 00069632 _____ (Microsoft Corporation) C:\Windows\system32\smss.exe
2017-04-11 12:05 - 2017-03-07 20:53 - 00036352 _____ (Microsoft Corporation) C:\Windows\system32\cryptbase.dll
2017-04-11 12:05 - 2017-03-07 20:53 - 00022016 _____ (Microsoft Corporation) C:\Windows\system32\lsass.exe
2017-04-11 12:05 - 2017-03-07 20:53 - 00015872 _____ (Microsoft Corporation) C:\Windows\system32\sspisrv.dll
2017-04-11 12:05 - 2017-03-07 20:53 - 00006144 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-security-base-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 20:53 - 00004608 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-threadpool-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 20:53 - 00003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-xstate-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 20:53 - 00003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-util-l1-1-0.dll
2017-04-11 12:05 - 2017-03-07 09:17 - 00067584 _____ (Microsoft Corporation) C:\Windows\system32\asycfilt.dll
2017-04-11 12:05 - 2017-03-07 08:06 - 02746880 _____ (Microsoft Corporation) C:\Windows\system32\rdpcorets.dll
2017-04-11 12:05 - 2017-03-07 08:06 - 00221184 _____ (Microsoft Corporation) C:\Windows\system32\rdpudd.dll
2017-04-11 12:05 - 2017-03-07 08:06 - 00013824 _____ (Microsoft Corporation) C:\Windows\system32\RdpGroupPolicyExtension.dll
2017-04-11 12:05 - 2017-03-03 18:14 - 01329664 _____ (Microsoft Corporation) C:\Windows\system32\quartz.dll
2017-04-11 12:05 - 2017-03-03 18:14 - 00077312 _____ (Microsoft Corporation) C:\Windows\system32\mfmjpegdec.dll
2017-04-07 19:12 - 2017-04-07 19:15 - 00205834 _____ C:\TDSSKiller.3.1.0.12_07.04.2017_19.12.02_log.txt
2017-04-07 14:47 - 2017-04-07 14:49 - 00409160 _____ C:\TDSSKiller.3.1.0.12_07.04.2017_14.47.54_log.txt
2017-04-07 14:45 - 2017-04-07 14:46 - 00204978 _____ C:\TDSSKiller.3.1.0.12_07.04.2017_14.45.17_log.txt
2017-04-07 10:59 - 2017-04-07 10:58 - 00330768 _____ (AVAST Software) C:\Windows\system32\aswBoot.exe
2017-04-06 18:12 - 2017-04-06 18:12 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware
2017-04-06 10:40 - 2017-04-13 12:30 - 00000000 ____D C:\Users\Patrick\AppData\Local\Mozilla
2017-04-06 10:14 - 2017-04-13 15:05 - 00000000 ____D C:\FRST
2017-04-06 09:12 - 2017-04-13 15:26 - 00003414 _____ C:\Windows\system32\Drivers\fvstore.dat
2017-04-04 14:06 - 2017-04-04 14:06 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Wipe
2017-04-04 10:01 - 2017-04-04 10:03 - 00000000 ____D C:\Users\Patrick\Downloads\Azrael (001 - 018) (2009 - 2011)
2017-03-30 18:12 - 2017-03-30 18:12 - 00000000 ____D C:\Users\Patrick\AppData\Local\F-Secure
2017-03-30 18:12 - 2017-03-30 18:12 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Freedome
2017-03-30 18:11 - 2017-03-30 18:11 - 00030760 _____ (The OpenVPN Project) C:\Windows\system32\Drivers\fsfreedometap.sys
2017-03-30 18:11 - 2017-03-30 18:11 - 00000000 ____D C:\Program Files\F-Secure
2017-03-30 18:10 - 2017-03-30 18:11 - 00000000 ____D C:\ProgramData\F-Secure
2017-03-30 10:49 - 2017-03-30 10:49 - 00000000 ____D C:\ProgramData\Shared Space
2017-03-30 10:37 - 2016-12-22 23:28 - 00235696 _____ (COMODO) C:\Windows\system32\iseguard32.dll
2017-03-30 10:37 - 2016-12-22 23:28 - 00039856 _____ (COMODO) C:\Windows\system32\Drivers\isedrv.sys
2017-03-28 21:50 - 2017-03-28 21:50 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\Registry Mechanic
2017-03-23 19:09 - 2017-03-23 19:10 - 00922432 _____ (Microsoft Corporation) C:\Windows\system32\ucrtbase.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00066400 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-private-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00022368 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-math-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00019808 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-multibyte-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00017760 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-string-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00017760 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-stdio-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00016224 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-runtime-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00015712 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-convert-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00014176 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-time-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00014176 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-localization-l1-2-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00013664 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-filesystem-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00012640 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-process-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00012640 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-heap-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00012640 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-conio-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-utility-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-locale-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-environment-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-synch-l1-2-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-processthreads-l1-1-1.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00011616 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-xstate-l2-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00011616 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-timezone-l1-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00011616 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-file-l2-1-0.dll
2017-03-23 19:09 - 2017-03-23 19:10 - 00011616 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-file-l1-2-0.dll
2017-03-23 19:09 - 2017-03-23 19:09 - 00060416 _____ (Microsoft Corporation) C:\Windows\system32\samlib.dll
2017-03-23 19:09 - 2017-03-23 19:09 - 00002048 _____ (Microsoft Corporation) C:\Windows\system32\tzres.dll
2017-03-23 19:09 - 2017-02-14 09:19 - 00497664 _____ (Microsoft Corporation) C:\Windows\system32\win32spl.dll
2017-03-23 19:09 - 2017-02-09 09:14 - 00575488 _____ (Microsoft Corporation) C:\Windows\system32\samsrv.dll
2017-03-15 14:24 - 2017-03-15 14:24 - 00971776 _____ (Microsoft Corporation) C:\Windows\system32\aeinv.dll
2017-03-15 14:24 - 2017-03-15 14:24 - 00505344 _____ (Microsoft Corporation) C:\Windows\system32\generaltel.dll
2017-03-15 14:24 - 2017-03-15 14:24 - 00071400 _____ (Microsoft Corporation) C:\Windows\system32\CompatTelRunner.exe
2017-03-15 14:24 - 2017-02-18 07:05 - 01331200 _____ (Microsoft Corporation) C:\Windows\system32\appraiser.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 01251328 _____ (Microsoft Corporation) C:\Windows\system32\DWrite.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 01241088 _____ (Microsoft Corporation) C:\Windows\system32\msxml3.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 00909824 _____ (Microsoft Corporation) C:\Windows\system32\FntCache.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 00741888 _____ (Microsoft Corporation) C:\Windows\system32\inetcomm.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 00628736 _____ (Microsoft Corporation) C:\Windows\system32\usp10.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 00497152 _____ (Microsoft Corporation) C:\Windows\HelpPane.exe
2017-03-15 12:25 - 2017-03-15 12:25 - 00481792 _____ (Microsoft Corporation) C:\Windows\system32\mscms.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 00313856 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\srv2.sys
2017-03-15 12:25 - 2017-03-15 12:25 - 00311808 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\srv.sys
2017-03-15 12:25 - 2017-03-15 12:25 - 00215040 _____ (Microsoft Corporation) C:\Windows\system32\icm32.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 00116224 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\srvnet.sys
2017-03-15 12:25 - 2017-03-15 12:25 - 00084480 _____ (Microsoft Corporation) C:\Windows\system32\INETRES.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 00032768 _____ (Microsoft Corporation) C:\Windows\system32\WcsPlugInService.dll
2017-03-15 12:25 - 2017-03-15 12:25 - 00002048 _____ (Microsoft Corporation) C:\Windows\system32\msxml3r.dll
2017-03-14 18:30 - 2017-03-14 18:31 - 00000000 ____D C:\Program Files\DiskCheckup
2017-03-14 18:30 - 2017-03-14 18:30 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\DiskCheckup
2017-03-13 18:25 - 2017-03-13 18:25 - 00000000 ____D C:\Users\Patrick\Documents\My Kindle Content
2017-03-13 13:23 - 2017-04-06 09:42 - 00000777 _____ C:\DelFix.txt
2017-03-05 12:02 - 2017-04-07 14:43 - 00000000 ____D C:\ProgramData\Malwarebytes' Anti-Malware (portable)
2017-03-04 22:19 - 2017-03-28 14:47 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\calibre
2017-03-04 19:36 - 2017-03-30 10:35 - 00000000 ____D C:\ProgramData\Comodo Downloader
2017-03-04 17:39 - 2017-03-04 17:39 - 00000000 ____D C:\Program Files\PrivaZer
2017-03-02 16:44 - 2017-03-02 16:44 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Thief 1 HD
2017-02-12 23:14 - 2017-02-12 23:14 - 00000000 ____D C:\ProgramData\Western Digital
2017-02-12 23:13 - 2017-02-12 23:13 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Western Digital
2017-02-12 23:12 - 2017-02-12 23:12 - 00000000 ____D C:\Program Files\Western Digital
2017-02-11 14:14 - 2017-02-11 14:14 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes Anti-Malware
2017-02-11 14:14 - 2017-02-11 14:14 - 00000000 ____D C:\ProgramData\Malwarebytes
2017-02-11 14:14 - 2017-02-11 14:14 - 00000000 ____D C:\Program Files\Malwarebytes Anti-Malware
2017-02-10 17:35 - 2017-02-10 17:35 - 00270848 _____ (Microsoft Corporation) C:\Windows\system32\invagent.dll
2017-02-10 17:35 - 2017-02-10 17:35 - 00212480 _____ (Microsoft Corporation) C:\Windows\system32\centel.dll
2017-02-10 17:35 - 2017-02-10 17:35 - 00183808 _____ (Microsoft Corporation) C:\Windows\system32\aepic.dll
2017-02-10 17:35 - 2017-02-10 17:35 - 00104960 _____ (Microsoft Corporation) C:\Windows\system32\acmigration.dll
2017-02-10 17:35 - 2016-12-31 08:36 - 00442368 _____ (Microsoft Corporation) C:\Windows\system32\devinv.dll
2017-02-01 19:57 - 2017-02-02 15:43 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\gtk-2.0
2017-02-01 19:54 - 2017-04-08 11:39 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\gsmartcontrol
2017-02-01 19:53 - 2017-04-08 11:39 - 00000000 ____D C:\Program Files\GSmartControl
2017-02-01 19:53 - 2017-02-01 19:53 - 00002029 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GSmartControl.lnk
2017-01-31 22:53 - 2017-01-31 22:55 - 00000000 ____D C:\Program Files\Speccy
2017-01-31 19:28 - 2017-04-07 10:58 - 00267528 _____ (AVAST Software s.r.o.) C:\Windows\system32\Drivers\aswblogx.sys
2017-01-31 19:28 - 2017-04-07 10:58 - 00255184 _____ (AVAST Software s.r.o.) C:\Windows\system32\Drivers\aswbidsdriverx.sys
2017-01-31 19:28 - 2017-04-07 10:58 - 00148208 _____ (AVAST Software s.r.o.) C:\Windows\system32\Drivers\aswbidshx.sys
2017-01-31 19:28 - 2017-04-07 10:58 - 00041176 _____ (AVAST Software s.r.o.) C:\Windows\system32\Drivers\aswbunivx.sys
2017-01-26 10:33 - 2017-01-26 10:33 - 00001253 _____ C:\Users\Patrick\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\VTM Bloodlines Antitribu Mod.lnk
2017-01-26 10:19 - 2017-01-26 23:14 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Vampire - The Masquerade Bloodlines
2017-01-26 10:19 - 2017-01-26 10:19 - 00000292 _____ C:\Windows\vtmb.ini
2017-01-26 10:11 - 2017-01-26 10:11 - 00000000 ____D C:\Program Files\Activision
2017-01-16 11:51 - 2017-04-13 13:55 - 00170200 _____ (Malwarebytes) C:\Windows\system32\Drivers\MBAMSwissArmy.sys
2017-01-16 11:37 - 2017-04-07 14:28 - 00094936 _____ (Malwarebytes) C:\Windows\system32\Drivers\mbamchameleon.sys
2017-01-16 11:37 - 2017-02-11 14:14 - 00053120 _____ (Malwarebytes Corporation) C:\Windows\system32\Drivers\mwac.sys
2017-01-16 11:37 - 2017-02-11 14:14 - 00024448 _____ (Malwarebytes) C:\Windows\system32\Drivers\mbam.sys
==================== Three Months Modified files and folders ========
2017-04-13 15:41 - 2016-02-07 16:45 - 00000000 ____D C:\Users\Patrick\Desktop\Games
2017-04-13 15:31 - 2016-06-08 07:29 - 00047223 _____ C:\Windows\ZAM_Guard.krnl.trace
2017-04-13 15:30 - 2015-11-16 08:56 - 00284280 _____ C:\Windows\ZAM.krnl.trace
2017-04-13 15:30 - 2015-06-23 15:12 - 00000000 ____D C:\ProgramData\HitmanPro.Alert
2017-04-13 15:27 - 2015-06-23 15:13 - 00000000 ____D C:\Windows\CryptoGuard
2017-04-13 14:51 - 2015-06-02 13:49 - 00920970 _____ C:\Windows\system32\PerfStringBackup.INI
2017-04-13 14:51 - 2009-07-13 19:37 - 00000000 ____D C:\Windows\inf
2017-04-13 14:47 - 2015-06-03 12:04 - 00000000 ____D C:\ProgramData\MCShield
2017-04-13 14:08 - 2015-06-02 14:20 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\vlc
2017-04-13 13:53 - 2015-06-02 13:58 - 00000000 ____D C:\Users\Patrick
2017-04-13 13:45 - 2015-06-08 14:56 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\Adobe
2017-04-13 13:45 - 2015-06-08 14:56 - 00000000 ____D C:\Users\Patrick\AppData\LocalLow\Adobe
2017-04-13 13:25 - 2015-06-03 12:24 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\Mozilla
2017-04-13 12:51 - 2009-07-13 21:34 - 00015120 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0
2017-04-13 12:51 - 2009-07-13 21:34 - 00015120 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0
2017-04-13 12:42 - 2009-07-13 21:53 - 00000006 ____H C:\Windows\Tasks\SA.DAT
2017-04-13 12:41 - 2016-02-14 22:30 - 00000000 ____D C:\Users\Patrick\Documents\My Games
2017-04-13 12:34 - 2015-09-18 11:33 - 00000000 ____D C:\Users\Patrick\AppData\Local\PrivaZer
2017-04-13 12:34 - 2015-06-07 16:55 - 00000000 ____D C:\Program Files\PeerBlock
2017-04-13 12:34 - 2015-06-04 10:44 - 00000000 ____D C:\Program Files\System Ninja
2017-04-13 12:30 - 2016-10-10 21:59 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\uTorrent
2017-04-13 12:28 - 2017-01-08 21:38 - 00000000 ____D C:\ProgramData\TEMP
2017-04-13 12:27 - 2015-06-24 20:53 - 00000000 ____D C:\Program Files\PC Tools Registry Mechanic
2017-04-12 09:14 - 2015-06-04 10:45 - 00000000 ____D C:\Users\Patrick\AppData\Roaming\Wipe
2017-04-11 13:56 - 2016-04-22 20:48 - 00000000 _____ C:\Windows\system32\last.dump
2017-04-11 12:50 - 2015-10-04 10:38 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
2017-04-11 12:50 - 2015-10-04 10:37 - 00000000 ____D C:\Program Files\Microsoft Silverlight
2017-04-10 11:02 - 2016-12-28 00:21 - 00104816 _____ (COMODO) C:\Windows\system32\Drivers\inspect.sys
2017-04-10 11:01 - 2016-12-28 00:21 - 00662864 _____ (COMODO) C:\Windows\system32\Drivers\cmdguard.sys
2017-04-08 13:27 - 2015-06-28 17:29 - 00002611 _____ C:\Users\Patrick\AppData\Roaming\Microsoft\Windows\Start Menu\µTorrent.lnk
2017-04-07 10:58 - 2015-09-12 19:59 - 00764576 _____ (AVAST Software) C:\Windows\system32\Drivers\aswSnx.sys
2017-04-07 10:58 - 2015-09-12 19:59 - 00475320 _____ (AVAST Software) C:\Windows\system32\Drivers\aswSP.sys
2017-04-07 10:58 - 2015-09-12 19:59 - 00279800 _____ (AVAST Software) C:\Windows\system32\Drivers\aswVmm.sys
2017-04-07 10:58 - 2015-09-12 19:59 - 00118800 _____ (AVAST Software) C:\Windows\system32\Drivers\aswStm.sys
2017-04-07 10:58 - 2015-09-12 19:59 - 00106904 _____ (AVAST Software) C:\Windows\system32\Drivers\aswMonFlt.sys
2017-04-07 10:58 - 2015-09-12 19:59 - 00090336 _____ (AVAST Software) C:\Windows\system32\Drivers\aswRdr2.sys
2017-04-07 10:58 - 2015-09-12 19:59 - 00062152 _____ (AVAST Software) C:\Windows\system32\Drivers\aswRvrt.sys
2017-04-07 10:58 - 2015-09-12 19:59 - 00034136 _____ (AVAST Software) C:\Windows\system32\Drivers\aswHwid.sys
2017-04-07 10:44 - 2016-09-10 13:09 - 00000000 ____D C:\ProgramData\VoodooShield
2017-04-06 18:12 - 2015-09-16 17:17 - 00000000 ____D C:\Program Files\Zemana AntiMalware
2017-04-06 09:31 - 2015-10-24 14:15 - 00000000 ____D C:\Users\Patrick\Documents\Games
2017-04-06 08:58 - 2009-07-13 19:04 - 00000215 _____ C:\Windows\system.ini
2017-04-06 08:47 - 2015-06-12 10:55 - 00000000 ____D C:\Windows\erdnt
2017-04-05 17:23 - 2016-10-06 10:43 - 00000000 ____D C:\Program Files\HitmanPro.Alert
2017-04-05 16:09 - 2016-10-06 10:43 - 00839304 _____ (SurfRight B.V.) C:\Windows\system32\hmpalert.dll
2017-04-05 16:09 - 2016-10-06 10:43 - 00210368 _____ (SurfRight B.V.) C:\Windows\system32\Drivers\hmpalert.sys
2017-04-05 16:09 - 2016-10-06 10:43 - 00083136 _____ (SurfRight B.V.) C:\Windows\system32\Drivers\hmpnet.sys
2017-04-04 23:01 - 2016-12-28 00:20 - 00044008 _____ (COMODO) C:\Windows\system32\cmdcsr.dll
2017-04-04 23:01 - 2016-12-28 00:19 - 00732368 _____ (COMODO) C:\Windows\system32\guard32.dll
2017-04-04 22:56 - 2016-12-28 00:15 - 00363200 _____ (COMODO) C:\Windows\system32\cmdvrt32.dll
2017-04-04 22:56 - 2016-12-28 00:15 - 00194752 _____ (COMODO) C:\Windows\system32\cmdshim32.dll
2017-04-04 14:06 - 2015-06-04 10:45 - 00000000 ____D C:\Program Files\Wipe
2017-04-03 09:56 - 2015-06-03 11:58 - 00000000 ____D C:\Program Files\Mozilla Firefox
2017-04-02 11:49 - 2009-07-13 19:37 - 00000000 ____D C:\Windows\rescache
2017-04-01 10:00 - 2015-06-09 10:59 - 00000000 ____D C:\Program Files\IrfanView
2017-03-31 11:57 - 2009-07-13 21:53 - 00032656 _____ C:\Windows\Tasks\SCHEDLGU.TXT
2017-03-30 10:51 - 2015-06-03 11:43 - 00000000 ____D C:\ProgramData\Comodo
2017-03-30 10:49 - 2015-06-03 11:45 - 00000000 ____D C:\Program Files\COMODO
2017-03-30 10:42 - 2016-11-17 10:11 - 00000682 _____ C:\Windows\system32\{7995330B-E01F-4645-B702-53481E7CB778}.cmdfile
2017-03-28 21:50 - 2009-07-13 19:03 - 51904512 _____ C:\Windows\system32\config\software.rmbak
2017-03-28 21:50 - 2009-07-13 19:03 - 04980736 _____ C:\Windows\system32\config\default.rmbak
2017-03-28 13:32 - 2016-12-28 00:21 - 00053344 _____ (COMODO) C:\Windows\system32\Drivers\cmdhlp.sys
2017-03-28 13:32 - 2016-12-28 00:21 - 00027504 _____ (COMODO) C:\Windows\system32\Drivers\cmderd.sys
2017-03-27 14:09 - 2017-01-08 20:32 - 00000000 ____D C:\Program Files\Everything
2017-03-23 16:15 - 2015-06-26 17:03 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\calibre - E-book Management
2017-03-23 16:15 - 2015-06-03 16:30 - 00000000 ____D C:\Program Files\Calibre2
2017-03-21 08:39 - 2015-06-03 11:49 - 00802904 _____ (Adobe Systems Incorporated) C:\Windows\system32\FlashPlayerApp.exe
2017-03-21 08:39 - 2015-06-03 11:49 - 00144472 _____ (Adobe Systems Incorporated) C:\Windows\system32\FlashPlayerCPLApp.cpl
2017-03-21 08:39 - 2015-06-03 11:49 - 00000000 ____D C:\Windows\system32\Macromed
2017-03-18 11:24 - 2015-06-03 14:21 - 00000000 ____D C:\Program Files\Glary Utilities 5
2017-03-16 13:52 - 2015-06-03 14:21 - 00001046 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Glary Utilities 5.lnk
2017-03-16 12:37 - 2015-09-12 19:57 - 00000000 ____D C:\ProgramData\AVAST Software
2017-03-15 18:34 - 2015-10-24 17:09 - 00000000 ____D C:\Users\Patrick\Documents\WBGames
2017-03-15 14:30 - 2009-07-13 21:52 - 00000000 ____D C:\Program Files\DVD Maker
2017-03-15 14:26 - 2015-06-02 13:55 - 00000000 ____D C:\Windows\system32\appraiser
C:\Windows\explorer.exe => File is digitally signed
C:\Windows\system32\winlogon.exe => File is digitally signed
C:\Windows\system32\wininit.exe => File is digitally signed
C:\Windows\system32\svchost.exe => File is digitally signed
C:\Windows\system32\services.exe => File is digitally signed
C:\Windows\system32\User32.dll => File is digitally signed
C:\Windows\system32\userinit.exe => File is digitally signed
C:\Windows\system32\rpcss.dll => File is digitally signed
C:\Windows\system32\dnsapi.dll => File is digitally signed
C:\Windows\system32\Drivers\volsnap.sys => File is digitally signed
==================== BCD ================================
Windows Boot Manager
identifier {bootmgr}
device partition=\Device\HarddiskVolume1
description Windows Boot Manager
locale en-US
inherit {globalsettings}
default {current}
resumeobject {433a583b-0971-11e5-a284-9c5c1998d34b}
displayorder {current}
toolsdisplayorder {memdiag}
timeout 30
Windows Boot Loader
identifier {current}
device partition=C:
path \Windows\system32\winload.exe
description Windows 7
locale en-US
inherit {bootloadersettings}
recoverysequence {433a583d-0971-11e5-a284-9c5c1998d34b}
recoveryenabled Yes
osdevice partition=C:
systemroot \Windows
nx OptIn
bootlog No
Windows Boot Loader
identifier {433a583d-0971-11e5-a284-9c5c1998d34b}
device ramdisk=[C:]\Recovery\433a583d-0971-11e5-a284-9c5c1998d34b\Winre.wim,{433a583e-0971-11e5-a284-9c5c1998d34b}
path \windows\system32\winload.exe
description Windows Recovery Environment
osdevice ramdisk=[C:]\Recovery\433a583d-0971-11e5-a284-9c5c1998d34b\Winre.wim,{433a583e-0971-11e5-a284-9c5c1998d34b}
systemroot \windows
nx OptIn
winpe Yes
Resume from Hibernate
identifier {433a583b-0971-11e5-a284-9c5c1998d34b}
device partition=C:
path \Windows\system32\winresume.exe
description Windows Resume Application
locale en-US
inherit {resumeloadersettings}
filedevice partition=C:
filepath \hiberfil.sys
pae Yes
debugoptionenabled No
Windows Memory Tester
identifier {memdiag}
path \boot\memtest.exe
description Windows Memory Diagnostic
locale en-US
badmemoryaccess Yes
EMS Settings
identifier {emssettings}
bootems Yes
Debugger Settings
identifier {dbgsettings}
debugtype Serial
debugport 1
baudrate 115200
RAM Defects
identifier {badmemory}
Global Settings
identifier {globalsettings}
inherit {dbgsettings}
{emssettings}
{badmemory}
Boot Loader Settings
identifier {bootloadersettings}
{hypervisorsettings}
Hypervisor Settings
identifier {hypervisorsettings}
hypervisordebugtype Serial
hypervisordebugport 1
hypervisorbaudrate 115200
Resume Loader Settings
identifier {resumeloadersettings}
Device options
identifier {433a583e-0971-11e5-a284-9c5c1998d34b}
description Ramdisk Options
ramdisksdidevice partition=C:
ramdisksdipath \Recovery\433a583d-0971-11e5-a284-9c5c1998d34b\boot.sdi
LastRegBack: 2017-04-02 11:41
Additional scan result of Farbar Recovery Scan Tool (x86) Version: 15-03-2017
Ran by Patrick (13-04-2017 15:43:13)
Running from C:\Users\Patrick\Desktop
Microsoft Windows 7 Home Premium Service Pack 1 (X86) (2015-06-02 20:58:32)
Boot Mode: Safe Mode (minimal)
Administrator (S-1-5-21-2985130882-1756615807-8858886-500 - Administrator - Disabled)
Guest (S-1-5-21-2985130882-1756615807-8858886-501 - Limited - Disabled)
Patrick (S-1-5-21-2985130882-1756615807-8858886-1000 - Administrator - Enabled) => C:\Users\Patrick
AV: Avast Antivirus (Enabled - Up to date) {8EA8924E-BC81-DC44-8BB0-8BAE75D86EBF}
AS: COMODO Advanced Protection (Enabled - Up to date) {B730BF64-C56F-6633-0EF5-9E639E46CC40}
AS: Avast Antivirus (Enabled - Up to date) {35C973AA-9ABB-D3CA-B100-B0DC0E5F2402}
FW: COMODO Firewall (Enabled) {346ADFA5-A93A-68E5-1F1A-0C241B12C186}
µTorrent (HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\uTorrent) (Version: 3.5.0.43580 - BitTorrent Inc.)
9-lab Removal Tool (HKLM\...\9-lab Removal Tool) (Version: - )
Adobe Flash Player 25 NPAPI (HKLM\...\Adobe Flash Player NPAPI) (Version: 25.0.0.127 - Adobe Systems Incorporated)
Adobe Reader XI (11.0.18) (HKLM\...\{AC76BA86-7AD7-1033-7B44-AB0000000001}) (Version: 11.0.18 - Adobe Systems Incorporated)
Advanced Audio FX Engine (HKLM\...\Advanced Audio FX Engine) (Version: 1.12.05 - Creative Technology Ltd)
Avast Free Antivirus (HKLM\...\Avast Antivirus) (Version: 17.4.2292 - AVAST Software)
Baldur's Gate II (HKLM\...\Baldur's Gate II_is1) (Version: - GOG.com)
calibre (HKLM\...\{B76A3B8A-CD1E-4260-BA4A-6A6EAA05715D}) (Version: 2.82.0 - Kovid Goyal)
CCleaner (HKLM\...\CCleaner) (Version: 5.28 - Piriform)
CDisplay 1.8 (HKLM\...\CDisplay_is1) (Version: - dvd8n)
COMODO Firewall (HKLM\...\COMODO Internet Security) (Version: 10.0.0.6092 - COMODO Security Solutions Inc.)
COMODO Firewall (Version: 10.0.0.6092 - COMODO Security Solutions Inc.) Hidden
Compatibility Pack for the 2007 Office system (HKLM\...\{90120000-0020-0409-0000-0000000FF1CE}) (Version: 12.0.6612.1000 - Microsoft Corporation)
CryptoPrevent (HKLM\...\{5C5B24E7-4694-4049-A222-CCE7D3FAC63F}_is1) (Version: 8.0.3.4 - Foolish IT LLC)
DAEMON Tools Lite (HKLM\...\DAEMON Tools Lite) (Version: 10.3.0.0154 - Disc Soft Ltd)
DARK EARTH (HKLM\...\DARK EARTH) (Version: - )
Dell Webcam Central (HKLM\...\Dell Webcam Central) (Version: 1.40.05 - Creative Technology Ltd)
DiskCheckup v3.4 (HKLM\...\DiskCheckup_is1) (Version: 3.4.1003 - PassMark Software)
ESET Online Scanner v3 (HKLM\...\ESET Online Scanner) (Version: - )
Everything 1.3.4.686 (x86) (HKLM\...\Everything) (Version: - )
Freedome (HKLM\...\F-Secure Freedome) (Version: 1.10.3502.0 - F-Secure Corporation)
Glary Utilities 5.71 (HKLM\...\Glary Utilities 5) (Version: 5.71.0.92 - Glarysoft Ltd)
Google Update Helper (HKLM\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.30.3 - Google Inc.)
Grammarly (HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\GrammarlyForWindows) (Version: 1.4.23 - Grammarly)
GSmartControl (HKLM\...\GSmartControl) (Version: 0.8.7 - Alexander Shaduri)
HD Tune 2.55 (HKLM\...\HD Tune_is1) (Version: - EFD Software)
herdProtect Anti-Malware Scanner (HKLM\...\herdProtectScan) (Version: 1.0 - Reason Company Software Inc.)
HitmanPro 3.7 (HKLM\...\HitmanPro37) (Version: 3.7.18.284 - SurfRight B.V.)
HitmanPro.Alert 3 (HKLM\...\HitmanPro.Alert) (Version: 3.6.4.588 - SurfRight B.V.)
HostsMan 4.5.102 (HKLM\...\{1A3DD1A9-7B7B-4ECA-AD2F-98466F49F62C}_is1) (Version: 4.5.102.0 - abelhadigital.com)
Internet Security Essentials (HKLM\...\ComodoIse) (Version: 1.1.404762.41 - Comodo)
IrfanView (remove only) (HKLM\...\IrfanView) (Version: 4.42 - Irfan Skiljan)
Kruptos 2 Professional (HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\Kruptos 2 Professional 6.2.3) (Version: 6.2.3 - Kruptos 2 Software)
Kruptos 2 Professional (Version: 6.2.3 - Kruptos 2 Software) Hidden
Live! Cam Avatar Creator (HKLM\...\{65D0C510-D7B6-4438-9FC8-E6B91115AB0D}) (Version: 4.6.3009.1 - Creative Technology Ltd)
Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM\...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
MCShield ::Anti-Malware Tool:: (HKLM\...\MCShield) (Version: 3.0.5.28 - MyCity)
Microsoft Office PowerPoint Viewer 2007 (English) (HKLM\...\{95120000-00AF-0409-0000-0000000FF1CE}) (Version: 12.0.6612.1000 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50906.0 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 (HKLM\...\{9BE518E6-ECC6-35A9-88E4-87755C07200F}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 (HKLM\...\{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Works (HKLM\...\{15BC8CD0-A65B-47D0-A2DD-90A824590FA8}) (Version: 9.7.0621 - Microsoft Corporation)
Mozilla Firefox 52.0.2 (x86 en-US) (HKLM\...\Mozilla Firefox 52.0.2 (x86 en-US)) (Version: 52.0.2 - Mozilla)
OpenAL (HKLM\...\OpenAL) (Version: - )
OpenOffice 4.1.3 (HKLM\...\{EEA30AEB-8BA7-465B-85D4-098BB99733E7}) (Version: 4.13.9783 - Apache Software Foundation)
PC Tools Registry Mechanic 11.0 (HKLM\...\Registry Mechanic_is1) (Version: 11.0 - PC Tools)
PeerBlock 1.2 (r693) (HKLM\...\{015C5B35-B678-451C-9AEE-821E8D69621C}_is1) (Version: 1.2.0.693 - PeerBlock, LLC)
Planescape Torment (HKLM\...\GOGPACKPLANESCAPETORMENT_is1) (Version: 2.0.0.8 - GOG.com)
PrivaZer (HKLM\...\PrivaZer) (Version: 3.0.18.0 - Goversoft LLC)
Revo Uninstaller 1.95 (HKLM\...\Revo Uninstaller) (Version: 1.95 - VS Revo Group)
RogueKiller version 12.9.9.0 (HKLM\...\8B3D7924-ED89-486B-8322-E8594065D5CB_is1) (Version: 12.9.9.0 - Adlice Software)
Secunia PSI (3.0.0.11005) (HKLM\...\Secunia PSI) (Version: 3.0.0.11005 - Secunia)
Speccy (HKLM\...\Speccy) (Version: 1.30 - Piriform)
SpywareBlaster 5.5 (HKLM\...\SpywareBlaster_is1) (Version: 5.5.0 - BrightFort LLC)
Star Wars Galactic Battlegrounds: Saga (HKLM\...\{10133CDD-50B9-4783-B336-8B48F3653715}) (Version: - )
STAR WARS® - Knights of the Old Republic™ (HKLM\...\1207666283_is1) (Version: 2.0.0.3 - GOG.com)
Starcraft (HKLM\...\Starcraft) (Version: - )
System Ninja version 3.1.6 (HKLM\...\{6E67710E-206D-43AB-BF21-E7CD63056C55}_is1) (Version: 3.1.6 - SingularLabs)
Thief GOLD (HKLM\...\GOGPACKTHIEF1GOLD_is1) (Version: 2.0.0.46 - GOG.com)
Thief Gold HD Mod 1.2 (HKLM\...\Thief1HD) (Version: - )
Unchecky v1.0.2 (HKLM\...\Unchecky) (Version: 1.0.2 - RaMMicHaeL)
Vampire - The Masquerade Bloodlines (HKLM\...\InstallShield_{C4E2A4A7-B623-40CB-8EEA-72F577E49D56}) (Version: 1.00.0000 - Activision)
Vampire - The Masquerade Bloodlines (Version: 1.00.0000 - Activision) Hidden
Visual Studio 2012 x86 Redistributables (HKLM\...\{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
VLC media player (HKLM\...\VLC media player) (Version: 2.2.4 - VideoLAN)
VoodooShield version 3.53 (HKLM\...\{A8644328-A66F-490E-B8FA-901FF649189D}_is1) (Version: 3.53 - VoodooSoft, LLC)
WD Security (Version: 1.4.0.92 - Western Digital Technologies, Inc.) Hidden
WinPatrol (HKLM\...\{6A206A04-6BC1-411B-AA04-4E52EDEEADF2}) (Version: 34.11.2016.27 - Ruiware)
WinPcap 4.1.3 (HKLM\...\WinPcapInst) (Version: 4.1.0.2980 - Riverbed Technology, Inc.)
WinRAR 5.40 (32-bit) (HKLM\...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
Wipe (HKLM\...\wipe) (Version: 17.04 - PrivacyRoot.com)
Wireshark 2.0.3 (32-bit) (HKLM\...\Wireshark) (Version: 2.0.3 - The Wireshark developer community, hxxps://www.wireshark.org)
Zemana AntiMalware (HKLM\...\{8F0CD7D1-42F3-4195-95CD-833578D45057}_is1) (Version: 2.72.0.388 - Zemana Ltd.)
Task: {1E325CE4-366D-47C3-B726-E927D7DC1DFC} - System32\Tasks\COMODO\COMODO Signature Update {B9D5C6F9-17D2-4917-8BD0-614BAA1C6A59} => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe [2017-04-04] (COMODO)
Task: {3DD6A81D-4BC4-41BA-8A1D-1F9288D03CFB} - System32\Tasks\Avast Emergency Update => C:\Program Files\AVAST Software\Avast\AvEmUpdate.exe [2017-04-07] (AVAST Software)
Task: {59E656A7-4AB4-404E-AA87-25E9074A00ED} - System32\Tasks\CryptoPrevent Update => C:\Program Files\Foolish IT\CryptoPrevent\CryptoPrevent.exe [2017-04-11] (Foolish IT LLC)
Task: {5C1A8A26-5916-4124-9CBA-B4AA3C9A2CC6} - System32\Tasks\AVAST Software\Avast settings backup => C:\Program Files\Common Files\AV\avast! Antivirus\backup.exe [2017-04-13] (AVAST Software)
Task: {8158EF6C-F25B-4E3D-A2A6-333D35220EF2} - System32\Tasks\COMODO\COMODO Autostart {D5EFF3B3-E126-4AF6-BCE9-852A72129E10} => C:\Program Files\COMODO\COMODO Internet Security\cistray.exe [2017-04-04] (COMODO)
Task: {C5AE9163-17A7-4C78-B1B9-2019F5AF466D} - System32\Tasks\COMODO\COMODO Update {A6D52E4F-569B-4756-B3D8-DF217313DA85} => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe [2017-04-04] (COMODO)
Task: {D08439C4-B30F-43CA-A2DF-F82619DBDAC5} - System32\Tasks\COMODO\COMODO CMC {06A09C0F-DD9C-4191-A670-71115CD78627} => C:\Program Files\COMODO\COMODO Internet Security\cfpconfg.exe [2017-04-04] (COMODO)
==================== Shortcuts =============================
2015-09-16 17:17 - 2017-02-02 18:19 - 00130928 _____ () C:\Program Files\Zemana AntiMalware\ZAMShellExt32.dll
AlternateDataStreams: C:\ProgramData\TEMP:D1B5B4F1 [151]
(If an entry is included in the fixlist, it will be removed from the registry. The "AlternateShell" value will be restored.)
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Option => "OptionValue"="1"
river"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\99835780.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\BFE => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\BITS => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MpsSvc => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\msiserver => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SharedAccess => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\vss => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\94990110.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\99835780.sys => ""="Driver"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\BITS => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\msiserver => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\SMR501 => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\vss => ""="Service"
IE restricted site: HKU\.DEFAULT\...\007guard.com -> install.007guard.com
IE restricted site: HKU\.DEFAULT\...\008i.com -> 008i.com
IE restricted site: HKU\.DEFAULT\...\008k.com -> www.008k.com
IE restricted site: HKU\.DEFAULT\...\00hq.com -> www.00hq.com
IE restricted site: HKU\.DEFAULT\...\010402.com -> 010402.com
IE restricted site: HKU\.DEFAULT\...\032439.com -> 80gw6ry3i3x3qbrkwhxhw.032439.com
IE restricted site: HKU\.DEFAULT\...\0scan.com -> www.0scan.com
IE restricted site: HKU\.DEFAULT\...\1-2005-search.com -> www.1-2005-search.com
IE restricted site: HKU\.DEFAULT\...\1-domains-registrations.com -> www.1-domains-registrations.com
IE restricted site: HKU\.DEFAULT\...\1000gratisproben.com -> www.1000gratisproben.com
IE restricted site: HKU\.DEFAULT\...\1001namen.com -> www.1001namen.com
IE restricted site: HKU\.DEFAULT\...\100888290cs.com -> mir.100888290cs.com
IE restricted site: HKU\.DEFAULT\...\100sexlinks.com -> www.100sexlinks.com
IE restricted site: HKU\.DEFAULT\...\10sek.com -> www.10sek.com
IE restricted site: HKU\.DEFAULT\...\12-26.net -> user1.12-26.net
IE restricted site: HKU\.DEFAULT\...\12-27.net -> user1.12-27.net
IE restricted site: HKU\.DEFAULT\...\123fporn.info -> www.123fporn.info
IE restricted site: HKU\.DEFAULT\...\123haustiereundmehr.com -> www.123haustiereundmehr.com
IE restricted site: HKU\.DEFAULT\...\123moviedownload.com -> www.123moviedownload.com
IE restricted site: HKU\.DEFAULT\...\123simsen.com -> www.123simsen.com
There are 7923 more sites.
IE trusted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\secunia.com -> hxxps://secunia.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\007guard.com -> install.007guard.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\008i.com -> 008i.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\008k.com -> www.008k.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\00hq.com -> www.00hq.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\010402.com -> 010402.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\0190-dialers.com -> 0190-dialers.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\01i.info -> 01i.info
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\02pmnzy5eo29bfk4.com -> 02pmnzy5eo29bfk4.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\032439.com -> 80gw6ry3i3x3qbrkwhxhw.032439.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\0411dd.com -> 0411dd.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\0511zfhl.com -> 0511zfhl.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\05p.com -> 05p.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\0632qyw.com -> 0632qyw.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\07ic5do2myz3vzpk.com -> 07ic5do2myz3vzpk.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\08nigbmwk43i01y6.com -> 08nigbmwk43i01y6.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\093qpeuqpmz6ebfa.com -> 093qpeuqpmz6ebfa.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\0calories.net -> 0calories.net
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\0cj.net -> 0cj.net
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\0scan.com -> www.0scan.com
IE restricted site: HKU\S-1-5-21-2985130882-1756615807-8858886-1000\...\1-2005-search.com -> www.1-2005-search.com
There are 12738 more sites.
==================== Hosts content: ==========================
2015-08-31 09:41 - 2017-04-13 12:42 - 23555889 ____A C:\Windows\system32\Drivers\etc\hosts
127.0.0.1 localhost
127.0.0.1 www.007guard.com
127.0.0.1 007guard.com
127.0.0.1 008i.com
127.0.0.1 www.008k.com
127.0.0.1 008k.com
127.0.0.1 www.00hq.com
127.0.0.1 00hq.com
127.0.0.1 010402.com
127.0.0.1 www.032439.com
127.0.0.1 032439.com
127.0.0.1 www.0scan.com
127.0.0.1 0scan.com
127.0.0.1 1000gratisproben.com
127.0.0.1 www.1000gratisproben.com
127.0.0.1 1001namen.com
127.0.0.1 www.1001namen.com
127.0.0.1 100888290cs.com
127.0.0.1 www.100888290cs.com
127.0.0.1 www.100sexlinks.com
127.0.0.1 100sexlinks.com
127.0.0.1 10sek.com
127.0.0.1 www.10sek.com
127.0.0.1 www.1-2005-search.com
127.0.0.1 1-2005-search.com
127.0.0.1 123fporn.info
127.0.0.1 www.123fporn.info
127.0.0.1 www.123haustiereundmehr.com
127.0.0.1 123haustiereundmehr.com
127.0.0.1 123moviedownload.com
There are 684618 more lines.
HKU\S-1-5-21-2985130882-1756615807-8858886-1000\Control Panel\Desktop\\Wallpaper -> C:\Users\Patrick\AppData\Roaming\Mozilla\Firefox\Desktop Background.bmp
DNS Servers: Media is not connected to internet.
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System => (ConsentPromptBehaviorAdmin: 2) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
MSCONFIG\Services: !SASCORE => 2
MSCONFIG\Services: AdobeARMservice => 2
MSCONFIG\Services: AdobeFlashPlayerUpdateSvc => 3
MSCONFIG\Services: CG6Service => 3
MSCONFIG\Services: CmdAgent => 2
MSCONFIG\Services: cmdvirth => 3
MSCONFIG\Services: Disc Soft Lite Bus Service => 3
MSCONFIG\Services: ehSched => 2
MSCONFIG\Services: gupdate => 2
MSCONFIG\Services: gupdatem => 3
MSCONFIG\Services: isesrv => 2
MSCONFIG\Services: K2Service.exe => 2
MSCONFIG\Services: MBAMScheduler => 2
MSCONFIG\Services: MBAMService => 2
MSCONFIG\Services: PCToolsSSDMonitorSvc => 2
MSCONFIG\Services: SDScannerService => 3
MSCONFIG\Services: SDUpdateService => 3
MSCONFIG\Services: SDWSCService => 3
MSCONFIG\Services: Secunia PSI Agent => 3
MSCONFIG\Services: Secunia Update Agent => 3
MSCONFIG\Services: VoodooShieldService => 2
MSCONFIG\Services: WDDriveService => 2
MSCONFIG\Services: ZAMSvc => 2
MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^Secunia PSI Tray.lnk => C:\Windows\pss\Secunia PSI Tray.lnk.CommonStartup
MSCONFIG\startupreg: COMODO Internet Security => C:\Program Files\COMODO\COMODO Internet Security\cistray.exe
MSCONFIG\startupreg: IseUI => C:\Program Files\COMODO\Internet Security Essentials\vkise.exe
MSCONFIG\startupreg: Logitech Download Assistant => C:\Windows\system32\rundll32.exe C:\Windows\System32\LogiLDA.dll,LogiFetch
MSCONFIG\startupreg: PeerBlock => C:\Program Files\PeerBlock\peerblock.exe
MSCONFIG\startupreg: WD Drive Unlocker => C:\Program Files\Western Digital\WD Security\WDDriveAutoUnlock.exe
MSCONFIG\startupreg: ZAM => "C:\Program Files\Zemana AntiMalware\ZAM.exe" /minimized
11-04-2017 12:42:59 Windows Update
11-04-2017 14:09:43 Windows Update
Description: avast! Revert
Class Guid: {8ECC055D-047F-11D1-A537-0000F8753ED1}
Manufacturer:
Service: aswRvrt
Problem: : This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)
Resolution: The device is installed incorrectly. The problem could be a hardware failure, or a new driver might be needed.
Devices stay in this state if they have been prepared for removal.
After you remove the device, this error disappears.Remove the device, and this error should be resolved.
Name: avast! VM Monitor
Description: avast! VM Monitor
Manufacturer:
Service: aswVmm
Name: Security Processor Loader Driver
Description: Security Processor Loader Driver
Manufacturer:
Service: spldr
Application errors:
Error: (04/13/2017 12:41:23 PM) (Source: SideBySide) (EventID: 33) (User: )
Description: Activation context generation failed for "C:\Users\Patrick\Documents\My Games\Autoruns64.exe".
Dependent Assembly Microsoft.Windows.Common-Controls,language="&#x2a;",processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0" could not be found.
Please use sxstrace.exe for detailed diagnosis.
Description: Activation context generation failed for "C:\Users\Patrick\Documents\My Games\autorunsc64.exe".
Error: (04/13/2017 12:35:01 PM) (Source: ESENT) (EventID: 454) (User: )
Description: DllHost (188) WebCacheLocal: Database recovery/restore failed with unexpected error -543.
Error: (04/13/2017 12:35:01 PM) (Source: ESENT) (EventID: 452) (User: )
Description: DllHost (188) WebCacheLocal: Database C:\Users\Patrick\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.dat requires logfiles 67-77 in order to recover successfully. Recovery could only locate logfiles starting at 77.
System errors:
Error: (04/13/2017 03:35:33 PM) (Source: Service Control Manager) (EventID: 7001) (User: )
Description: The Network List Service service depends on the Network Location Awareness service which failed to start because of the following error:
The dependency service or group failed to start.
Error: (04/13/2017 03:35:28 PM) (Source: Service Control Manager) (EventID: 7001) (User: )
Error: (04/13/2017 03:35:28 PM) (Source: DCOM) (EventID: 10005) (User: )
Description: DCOM got error "1068" attempting to start the service netprofm with arguments "" in order to run the server:
{A47979D2-C419-11D9-A5B4-001185AD2B89}
Description: DCOM got error "1068" attempting to start the service netman with arguments "" in order to run the server:
{BA126AD1-2166-11D1-B1D0-00805FC1270E}
CodeIntegrity:
Date: 2017-04-13 15:23:18.521
Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\iseguard32.dll because the set of per-page image hashes could not be found on the system.
Date: 2017-04-13 15:23:18.443
Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\api-ms-win-core-synch-l1-2-0.dll because the set of per-page image hashes could not be found on the system.
Date: 2017-04-13 15:23:18.287
Date: 2017-04-13 15:02:38.942
Date: 2017-04-13 15:02:38.877
Date: 2017-04-13 15:02:38.724
Date: 2017-04-13 14:53:42.336
Date: 2017-04-13 14:53:42.258
Date: 2017-04-13 14:53:42.008
Date: 2017-04-13 14:39:30.954
Processor: Pentium(R) Dual-Core CPU T4300 @ 2.10GHz
Percentage of memory in use: 12%
Total physical RAM: 3544.36 MB
Available physical RAM: 3102.94 MB
Total Virtual: 7087.05 MB
Available Virtual: 6687.91 MB
Drive c: () (Fixed) (Total:465.66 GB) (Free:388.44 GB) NTFS
Disk: 0 (MBR Code: Windows 7 or 8) (Size: 465.8 GB) (Disk ID: 864A2DB2)
Partition 1: (Active) - (Size=100 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=465.7 GB) - (Type=07 NTFS)
ZHP Diag Scan
Download ZHP Diag to your desktop.
1. Right Click Run as Admin.
2. Click the Scanner button.
upload_2017-2-23_3-32-26-png.1647
A notepad will open... copy and paste the report in your next reply.
ZHPDiag will not finish I continuously encounter this error in Normal Mode, should I try it in safe mode?
Update: It does the same thing in Safe Mode. Should I try a System Restore from when the Windows Updates Installed? Maybe that'll help?
Step 1: Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
Step 2: MiniToolBox Scan
Checkmark following boxes:
Flush DNS
Reset FF proxy Settings
Reset Ie Proxy Settings
Report IE Proxy Settings
Report FF Proxy Settings
List content of Hosts
List IP configuration
List Winsock Entries
List last 10 Event Viewer log
List Installed Programs
List Devices (problems only)
Click Go post the result.
Step 3: Autoruns Scan.
Step 4: Security Check Scan.
  • Download Security Check to your desktop.
  • Right click it run as administrator.
  • When the program completes, the tool will automatically open a log file.
  • Please post that log here in your next post.
  • Please copy and paste this log, do not attach it. :)
Okay we got some good news and bad news.
Good news I used System Restore and seemed to have fixed my restart/shut down error
Bad new conhost is still going crazy. I will post the requested logs when they complete.
Here's MTB (Note my HOST File is 22MB so I don't want to wait 4 hours for it to list everything and I deselected it)
Ran by Patrick (administrator) on 14-04-2017 at 15:09:47
Running from "C:\Users\Patrick\Desktop"
Model: Inspiron 1545 Manufacturer: Dell Inc.
Boot Mode: Normal
Windows IP Configuration
Could not flush the DNS Resolver Cache: Function failed during execution.
Proxy is not enabled.
No Proxy Server is set.
Dell Wireless 1397 WLAN Mini-Card = Wireless Network Connection (Connected)
Freedome TAP driver = FreedomeVPNConnection (Connected)
Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller = Local Area Connection (Media disconnected)
Microsoft Virtual WiFi Miniport Adapter = Wireless Network Connection 2 (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled taskoffload=disabled
add route prefix=104.96.147.3/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=111.221.29.177/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=111.221.29.253/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=131.253.40.37/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=134.170.115.60/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=134.170.165.248/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=134.170.165.253/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=134.170.185.70/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=134.170.30.202/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=137.116.81.24/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=137.117.235.16/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=157.55.129.21/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=157.55.133.204/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=157.55.240.220/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=157.56.106.189/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=157.56.121.89/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=157.56.124.87/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
add route prefix=157.56.91.77/32 interface="iftype0_0" nexthop=0.0.0.0 metric=1 publish=Yes
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : Patrick-PC
DNS Suffix Search List. . . . . . : hsd1.ca.comcast.net.
Ethernet adapter FreedomeVPNConnection:
Description . . . . . . . . . . . : Freedome TAP driver
Physical Address. . . . . . . . . : 00-FF-03-B1-C0-63
IPv6 Address. . . . . . . . . . . : fc00:fed0:0:1002::1034(Preferred)
Link-local IPv6 Address . . . . . : fe80::f023:a8fe:df16:10fe%16(Preferred)
IPv4 Address. . . . . . . . . . . : 198.18.8.214(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.252
Lease Obtained. . . . . . . . . . : Friday, April 14, 2017 2:58:28 PM
Lease Expires . . . . . . . . . . : Saturday, April 14, 2018 2:58:28 PM
Default Gateway . . . . . . . . . :
DHCP Server . . . . . . . . . . . : 198.18.8.213
DHCPv6 IAID . . . . . . . . . . . : 285277955
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1C-FF-CF-EA-00-25-64-60-FA-A9
DNS Servers . . . . . . . . . . . : 198.18.8.213
Wireless LAN adapter Wireless Network Connection 2:
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Physical Address. . . . . . . . . : 70-1A-04-1C-10-F2
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : hsd1.ca.comcast.net.
Description . . . . . . . . . . . : Dell Wireless 1397 WLAN Mini-Card
IPv6 Address. . . . . . . . . . . : 2601:647:cb00:29f2:7077:e9c8:a60a:f015(Preferred)
IPv6 Address. . . . . . . . . . . : 2601:647:cb00:29f2:822b:b3a9:a6db:d469(Preferred)
Lease Obtained. . . . . . . . . . : Friday, April 14, 2017 2:45:26 PM
Lease Expires . . . . . . . . . . : Monday, April 17, 2017 7:24:46 PM
Temporary IPv6 Address. . . . . . : 2601:647:cb00:29f2:d894:d762:5266:767(Preferred)
Link-local IPv6 Address . . . . . : fe80::7077:e9c8:a60a:f015%11(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.4(Preferred)
Lease Obtained. . . . . . . . . . : Friday, April 14, 2017 2:39:29 PM
Lease Expires . . . . . . . . . . : Friday, April 21, 2017 2:58:52 PM
Default Gateway . . . . . . . . . : fe80::c639:3aff:febc:2f62%11
10.0.0.1
DHCP Server . . . . . . . . . . . : 10.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 225450500
DNS Servers . . . . . . . . . . . : 2001:558:feed::1
2001:558:feed::2
Description . . . . . . . . . . . : Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller
Physical Address. . . . . . . . . : 00-25-64-60-FA-A9
Tunnel adapter isatap.hsd1.ca.comcast.net.:
Tunnel adapter Local Area Connection* 15:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6abd:14ad:3fe2:a050:9782(Preferred)
Link-local IPv6 Address . . . . . : fe80::14ad:3fe2:a050:9782%24(Preferred)
Tunnel adapter isatap.{03B1C063-BA67-49A2-8164-B0381B336D41}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{48AAE418-7A06-4B01-B67C-69F8C3DD738A}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Server: UnKnown
Address: 198.18.8.213
Addresses: 2a00:1450:4011:805::1001
74.125.232.225
74.125.232.228
74.125.232.231
74.125.232.224
74.125.232.229
74.125.232.232
74.125.232.233
74.125.232.226
74.125.232.230
74.125.232.238
74.125.232.227
Pinging google.com [2a00:1450:4011:805::1001] with 32 bytes of data:
Request timed out.
Reply from 2a00:1450:4011:805::1001: time=232ms
Ping statistics for 2a00:1450:4011:805::1001:
Packets: Sent = 2, Received = 1, Lost = 1 (50% loss),
Minimum = 232ms, Maximum = 232ms, Average = 232ms
Server: UnKnown
Addresses: 2001:4998:44:204::a7
2001:4998:c:a06::2:4008
2001:4998:58:c02::a9
98.139.183.24
98.138.253.109
206.190.36.45
Pinging yahoo.com [2001:4998:58:c02::a9] with 32 bytes of data:
Request timed out.
Reply from 2001:4998:58:c02::a9: time=341ms
Ping statistics for 2001:4998:58:c02::a9:
Minimum = 341ms, Maximum = 341ms, Average = 341ms
Interface List
16...00 ff 03 b1 c0 63 ......Freedome TAP driver
14...70 1a 04 1c 10 f2 ......Microsoft Virtual WiFi Miniport Adapter
11...70 1a 04 1c 10 f2 ......Dell Wireless 1397 WLAN Mini-Card
10...00 25 64 60 fa a9 ......Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller
23...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
24...00 00 00 00 00 00 00 e0 Microsoft Teredo Tunneling Adapter
46...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
47...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 10.0.0.1 10.0.0.4 25
0.0.0.0 128.0.0.0 198.18.8.213 198.18.8.214 20
10.0.0.0 255.255.255.0 On-link 10.0.0.4 281
10.0.0.4 255.255.255.255 On-link 10.0.0.4 281
10.0.0.255 255.255.255.255 On-link 10.0.0.4 281
95.175.104.65 255.255.255.255 10.0.0.1 10.0.0.4 25
128.0.0.0 128.0.0.0 198.18.8.213 198.18.8.214 20
198.18.8.1 255.255.255.255 198.18.8.213 198.18.8.214 20
198.18.8.212 255.255.255.252 On-link 198.18.8.214 276
198.18.8.214 255.255.255.255 On-link 198.18.8.214 276
198.18.8.215 255.255.255.255 On-link 198.18.8.214 276
224.0.0.0 240.0.0.0 On-link 198.18.8.214 276
224.0.0.0 240.0.0.0 On-link 10.0.0.4 281
255.255.255.255 255.255.255.255 On-link 198.18.8.214 276
255.255.255.255 255.255.255.255 On-link 10.0.0.4 281
Persistent Routes:
Network Address Netmask Gateway Address Metric
104.96.147.3 255.255.255.255 On-link 1
111.221.29.177 255.255.255.255 On-link 1
111.221.29.253 255.255.255.255 On-link 1
131.253.40.37 255.255.255.255 On-link 1
134.170.115.60 255.255.255.255 On-link 1
134.170.165.248 255.255.255.255 On-link 1
134.170.165.253 255.255.255.255 On-link 1
134.170.185.70 255.255.255.255 On-link 1
134.170.30.202 255.255.255.255 On-link 1
137.116.81.24 255.255.255.255 On-link 1
137.117.235.16 255.255.255.255 On-link 1
157.55.129.21 255.255.255.255 On-link 1
157.55.133.204 255.255.255.255 On-link 1
157.55.240.220 255.255.255.255 On-link 1
157.56.106.189 255.255.255.255 On-link 1
157.56.121.89 255.255.255.255 On-link 1
157.56.124.87 255.255.255.255 On-link 1
157.56.91.77 255.255.255.255 On-link 1
IPv6 Route Table
Active Routes:
11 281 ::/0 fe80::c639:3aff:febc:2f62
16 276 ::/1 fe80::8
1 306 ::1/128 On-link
24 58 2001::/32 On-link
24 306 2001:0:9d38:6abd:14ad:3fe2:a050:9782/128
On-link
11 33 2601:647:cb00:29f2::/64 On-link
11 281 2601:647:cb00:29f2:7077:e9c8:a60a:f015/128
On-link
11 281 2601:647:cb00:29f2:822b:b3a9:a6db:d469/128
On-link
11 281 2601:647:cb00:29f2:d894:d762:5266:767/128
On-link
16 276 8000::/1 fe80::8
16 276 fc00:fed0:0:1002::/64 fe80::8
16 276 fc00:fed0:0:1002::1034/128
On-link
16 276 fe80::/64 On-link
11 281 fe80::/64 On-link
24 306 fe80::/64 On-link
24 306 fe80::14ad:3fe2:a050:9782/128
On-link
11 281 fe80::7077:e9c8:a60a:f015/128
On-link
16 276 fe80::f023:a8fe:df16:10fe/128
On-link
1 306 ff00::/8 On-link
16 276 ff00::/8 On-link
11 281 ff00::/8 On-link
24 306 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\Windows\system32\NLAapi.dll [52224] (Microsoft Corporation)
Catalog5 02 C:\Windows\system32\napinsp.dll [52224] (Microsoft Corporation)
Catalog5 03 C:\Windows\system32\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 04 C:\Windows\system32\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog5 06 C:\Windows\system32\winrnr.dll [20992] (Microsoft Corporation)
Catalog5 07 C:\Windows\system32\wshbth.dll [36352] (Microsoft Corporation)
Catalog9 01 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 02 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 03 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 04 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 05 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 06 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 07 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 08 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 09 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 10 C:\Windows\system32\mswsock.dll [231424] (Microsoft Corporation)
Application errors:
Error: (04/14/2017 02:33:37 PM) (Source: System Restore) (User: )
Description: An unspecified error occurred during System Restore: (Windows Update). Additional information: 0x80070005.
Error: (04/14/2017 01:41:38 PM) (Source: ESENT) (User: )
Description: DllHost (1176) WebCacheLocal: Database recovery/restore failed with unexpected error -543.
Description: DllHost (1176) WebCacheLocal: Database C:\Users\Patrick\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.dat requires logfiles 11-28 in order to recover successfully. Recovery could only locate logfiles starting at 28.
System errors:
Error: (04/14/2017 03:08:36 PM) (Source: Service Control Manager) (User: )
Description: The COMODO Virtual Service Manager service failed to start due to the following error:
%%1053 = The service did not respond to the start or control request in a timely fashion.
Description: A timeout was reached (30000 milliseconds) while waiting for the COMODO Virtual Service Manager service to connect.
Error: (04/14/2017 02:39:48 PM) (Source: Service Control Manager) (User: )
Description: The following boot-start or system-start driver(s) failed to load:
VBoxNetAdp
Error: (04/14/2017 02:39:35 PM) (Source: Service Control Manager) (User: )
Description: The Windows Image Acquisition (WIA) service depends on the Shell Hardware Detection service which failed to start because of the following error:
%%1058 = The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
Error: (04/14/2017 02:39:34 PM) (Source: Service Control Manager) (User: )
Description: The Internet Connection Sharing (ICS) service depends on the Remote Access Connection Manager service which failed to start because of the following error:
Error: (04/14/2017 02:36:41 PM) (Source: VDS Basic Provider) (User: )
Description: Unexpected failure. Error code: 490@01010004
Error: (04/14/2017 02:31:01 PM) (Source: Service Control Manager) (User: )
VBoxNetAdp
Error: (04/14/2017 02:30:35 PM) (Source: Service Control Manager) (User: )
Error: (04/14/2017 02:30:34 PM) (Source: Service Control Manager) (User: )
Error: (04/14/2017 02:29:06 PM) (Source: Microsoft-Windows-DNS-Client) (User: NT AUTHORITY)
Description: There was an error while attempting to read the local hosts file.
Microsoft Office Sessions:
Error: (04/14/2017 02:33:37 PM) (Source: System Restore)(User: )
Description: Windows Update0x80070005
Error: (04/14/2017 01:41:38 PM) (Source: ESENT)(User: )
Description: DllHost1176WebCacheLocal: -543
Description: DllHost1176WebCacheLocal: C:\Users\Patrick\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.dat112828
CodeIntegrity Errors:
Date: 2017-04-14 14:47:59.401
Date: 2017-04-14 14:47:59.292
Date: 2017-04-14 14:47:59.089
Date: 2017-04-14 14:39:18.965
Date: 2017-04-14 14:39:18.934
Date: 2017-04-14 14:39:18.794
Date: 2017-04-14 14:30:27.832
Date: 2017-04-14 14:30:27.816
Date: 2017-04-14 14:30:27.692
Date: 2017-04-14 14:17:32.600
µTorrent (HKCU\...\uTorrent) (Version: 3.5.0.43580 - BitTorrent Inc.)
Adobe Refresh Manager (HKLM\...\{AC76BA86-0804-1033-1959-001824202044}) (Version: 1.8.0 - Adobe Systems Incorporated) Hidden
COMODO Firewall (HKLM\...\{67DA4459-33A8-4E69-9C7B-FB5CBADA60AB}) (Version: 10.0.0.6092 - COMODO Security Solutions Inc.) Hidden
Grammarly (HKCU\...\GrammarlyForWindows) (Version: 1.5.25 - Grammarly)
Kruptos 2 Professional (HKCU\...\Kruptos 2 Professional 6.2.3) (Version: 6.2.3 - Kruptos 2 Software)
Kruptos 2 Professional (HKLM\...\{A3F80325-CA48-4C85-9967-767DA76CB13F}) (Version: 6.2.3 - Kruptos 2 Software) Hidden
Vampire - The Masquerade Bloodlines (HKLM\...\{C4E2A4A7-B623-40CB-8EEA-72F577E49D56}) (Version: 1.00.0000 - Activision) Hidden
WD Security (HKLM\...\{A2D70EE4-2462-4F04-9955-5761E3F3F47A}) (Version: 1.4.0.92 - Western Digital Technologies, Inc.) Hidden
Wireshark 2.0.3 (32-bit) (HKLM\...\Wireshark) (Version: 2.0.3 - The Wireshark developer community, https://www.wireshark.org)
Percentage of memory in use: 63%
Available physical RAM: 1304.41 MB
Available Virtual: 4596.78 MB
1 Drive c: () (Fixed) (Total:465.66 GB) (Free:387.86 GB) NTFS
User accounts for \\PATRICK-PC
Administrator Guest Patrick
========================= Minidump Files ==================================
No minidump file found
========================= Restore Points ==================================
11-04-2017 19:42:59 Windows Update
11-04-2017 21:09:43 Windows Update
14-04-2017 21:21:14 Restore Operation
**** End of log ****
Autoruns is too large to attach and my shut down problems seems to have re-occurred. I let it run for 3.5 minutes with no shut down occurring. I think the best bet is to just wipe the drive.
I tried system restore again, as with the last time on loading after restart it says it failed to access a file and failed. Nothing was running though so I'm confused. I managed to get FRST to run after the Restore, here are the results.
You have too many security programs on your machine, not a trace of malware. If we are to continue, you must remove some of them then your machine will function normally.
I actually figured it out. It was a bug report from avast conflicting with my comodo that caused the conhost error. Thanks for the help!
