Solved I need help buying RAM for hp 15-f272wm laptop
Your computer takes regular laptop DDR3l sodimm memory. Do a Google search for the ram listed below on a seller of your choice.
Used the Crucial tool here and their RAM is guaranteed compatible when you order from Crucial.com, used the exact specs from Crucial and matched it to the least expensive that I could find which is here
Thanks, do you know if buying batteries on ebay is safe? They are like $15 vs $25 on newegg.
Be careful when purchasing batteries, there are millions of cheap chinese ones out there that are an accident just waiting to happen, check the feedback of the seller and where they are shipping from and whenever possible always purchase a genuine OEM replacement.
