I need a larger PC case.
matabhaine
80
8
55
I bought a Strix 4090 OC and it doesn't fit my case by half an inch. I really want a much bigger case as I had trouble mounting the rad in the top of my old Corsair Obsidian 650D case.
My Specs:
MOBO: ASUS Z790-E Gaming WiFi
PSU: EVGA SuperNOVA 1600 T2 Titanium 1600W
CPU liquid Cooler: Corsair iCUE H115i ELITE CAPELLIX XT 280mm
There are no HDDs, and just a single SSD.
I would also like to return to a case with room for a bluray writer; if possible.
Any help appreciated.
Regards Matt.
Is an external blu-ray writer an option?
Typically with high performing gaming rigs I recommend as much mesh for airflow as I can. If a writer can be external/USB then that gives you a lot more options.
Thanx for the reply: I can buy an external drive, it's just my case is too small for my 4090-OC, and my liquid cooler was a bugger to fit. I would like to top mount my rad, in fact, if it was top mounted, the 4090 would fit into my case just now. I did some research on cases a little while back, asked various online PC hardware shops for advice on which case to buy. PC cases seem to be tiny compared to the old days. I had a coolermaster stacker and an obsidian 650d, both were too small for the cooler to top mount.
That's what I was hoping you would say. :)
I'm a huge fan of Fractal cases, something like the Meshify 2 meets all of your space criteria.
The Corsair 4000D also looks suitable, but the size constraints on it are going to be a bit tighter for your GPU/PSU.
Finally the Cooler Master TD500- although this looks as though you might need to front-mount your AIO.
These are just a few I picked out based on what I read, I do not have personal experience with any- but all of these brands are reputable enough I would purchase from one or the other.
Thanx for that, I'll take a look.
Closing - no activity.
