i have a big problem help pls
bigC
11
24
hey guys can someone help me i've been experiencing some problem basically i play normally with just 54 ping average but suddenly everyone gets freeezed and it disconnects me can some1 help pls
What is the brand and model name or number of the PSU.
is this something that just started?
what are your internet speeds?
Connecting Wired and or wireless?
what have you tried and what were the results?
Have you rebooted the network?
reset the systems network settings?
only durning games or watching youtube or other online browsing?
1 no
3 Wired Through usb cable (MW70VK Alcatel On sim cards)
4 I tried to change DNS Restartting router everything that you can think off
5 i did but it's not wworking
6 nope
7 for example roblox when am playing its normal but suddenly freeze and am getting disconnected from game but everything is alright (discord call or youtube video)
thats basically it
what speed are you paying for and supposed to be getting?
The speccy information from post 2?
Have you also tried to reset the network setting through windows and or using commands? (Do not have to do both).
For Windows
Go into Setting
Select Network and Internet
Make sure you are under Status in the left
On the Right scroll down and select Network Reset
Read the information and then select Reset Now
Select Yes for the network to be reset and the system to reboot.
The rest before the system reboots may take a few minutes
How to reset via Command Prompt
Open an Administrator Command Prompt
type (Copy and Paste) the following Commands and press Enter
ipconfig /release
ipconfig /renew
ipconfig /flushdns
nbtstat -R
nbtstat -RR
netsh int reset all
netsh int ip reset c:\resetlog.txt
netsh int ipv6 reset
netsh int ipv4 reset
netsh winsock reset catalog
Reboot your computer and see if that helps at all.
For Windows
Go into Setting
ipconfig /release
ipconfig /renew
ipconfig /flushdns
nbtstat -R
nbtstat -RR
netsh int reset all
that speecy seems suspucious for me it shows my ip adress
Others may have more to comment.
One issue is
Partition 1
Disk Letter: C:
File System: NTFS
Volume Serial Number: 4081DC32
Used Space: 399 GB (88%)
Free Space: 53 GB (12%)
You are running low on space.
For windows to run properly plus 32 GB available for Windows to update. Then there is also reserved around 7-10 GB. The less space the harder the drive has to work to store data including temp files that they system uses for the program running on you C drive.
Power Profile
Active power scheme: Performance
Change to balanced and see how that works then test High.
Looks like you have Driver Easy install get rid of it nothing but crap and snake oil. Drivers should ONLY be updated to correct an issue and from the system manufacture.
When you are playing games are you on the mains (plugged into power) or battery?
Might see what happens when you disable the VPN to see if that makes a difference.
also let's see what happens during a clean boot.
I also see that you have the google DNS configured. Have seen a few that have that and issues connecting and or stable connections.
One issue is
Partition 1
Disk Letter: C:
File System: NTFS
Power Profile
One issue is
Partition 1
Disk Letter: C:
File System: NTFS
Power Profile
I have VPN disabled and my drivers are up to date (my main problem is network not performance of the game bro)
Reset your Hosts file.
  1. Click here to download RstHosts v2.0\
  2. Save the file to your desktop.
  3. Right Click and Run as Administrator.
  4. Click on Restaurer, then click OK at the prompt.
  5. This will restore the default host file.
Open a notepad and copy the content of the code box below, paste into open notepad and save it to your desktop as clean.bat then right click on clean.bat and run as admin.
Code:
@echo off
wmic /Namespace:\\root\default Path SystemRestore Call Enable "%SystemDrive%"
WMIC /Namespace:\\root\default Path SystemRestore Call CreateRestorePoint "BatchRestorePoint", 100, 10
fsutil resource setautoreset true c:\&fsutil usn deletejournal /d /n c:
powercfg.exe /setactive 381b4222-f694-41f0-9685-ff5bb260df2e
powercfg -hibernate off
bitsadmin /reset /allusers
ipconfig /registerdns
nbtstat -R
nbtstat -RR
netsh winsock reset all
netsh winhttp reset proxy
netsh int tcp set heuristics disabled
netsh int tcp set global rss=enabled
netsh int tcp set global autotuninglevel=normal
netsh interface httpstunnel reset all
netsh interface portproxy reset all
netsh interface ip delete arpcache
netsh advfirewall reset
netsh advfirewall set allprofiles state On
wmic nicconfig where (IPEnabled=TRUE) call SetDNSServerSearchOrder ("76.76.19.19", "8.8.4.4")
%WINDIR%\SYSTEM32\lodctr.exe /R
%WINDIR%\SysWOW64\lodctr.exe /R
C:\Windows\SYSTEM32\lodctr.exe /R
C:\Windows\SysWOW64\lodctr.exe /R
DISM.exe /Online /Cleanup-Image /StartComponentCleanup
pause
DISM.exe /Online /Cleanup-image /Restorehealth
pause
del /s /q C:\Windows\SoftwareDistribution\download\*.*
del /s /q "%userprofile%\AppData\Local\Microsoft\Edge\User Data\Default\Cache\*.*"
del /s /q "%userprofile%\AppData\Local\Google\Chrome\User Data\Default\Cache\*.*"
del /s /q "%userprofile%\AppData\Local\Opera Software\Opera Stable\Cache\Cache_Data\*.*"
del /s /q "%userprofile%\AppData\Local\temp\*.*"
del /f /s /q %systemdrive%\*.tmp
del /f /s /q %systemdrive%\*.log
del /f /s /q %systemdrive%\*.chk
del /f /s /q %systemdrive%\recycled\*.*
del /f /s /q %windir%\*.bak
del /f /s /q %windir%\prefetch\*.*
ipconfig /flushdns
sc stop RasAuto
sc stop RasMan
sc stop SessionEnv
sc stop TermService
sc stop UmRdpService
sc stop RemoteAccess
sc config RasAuto start= disabled
sc config RasMan start= disabled
sc config SessionEnv start= disabled
sc config TermService start= disabled
sc config UmRdpService start= disabled
sc config RemoteAccess start= disabled
sc stop sysmain
sc config sysmain start= disabled
sc stop iphlpsvc
sc config iphlpsvc start= disabled
sc stop DiagTrack
sc config DiagTrack start= disabled
sc stop dmwappushservice
sc config dmwappushservice start= disabled
sc stop WSearch
sc config WSearch start= disabled
sc stop lfsvc
sc config lfsvc start= disabled
del /s /q %ProgramData%\Microsoft\Diagnosis\ETLLogs\AutoLogger\AutoLogger-Diagtrack-Listener.etl
REG ADD HKLM\SOFTWARE\Policies\Microsoft\Windows\DataCollection /v AllowTelemetry /d 0 /t REG_DWORD /f
reg add HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\SQMClient\parameters /v DisabledComponents /t REG_DWORD /d 0xFFFFFFFF
reg add hklm\system\currentcontrolset\services\tcpip6\parameters /v DisabledComponents /t REG_DWORD /d 0xFFFFFFFF
echo "" > %ProgramData%\Microsoft\Diagnosis\ETLLogs\AutoLogger\AutoLogger-Diagtrack-Listener.etl
sfc /scannow
pause
shutdown -r
Exit /B
Use O&O shutup ten with suggested and somewhat suggested settings enabled.
Disable windows update, and only enable it once a week to update on your terms not whenever microsoft feels you need an update.
Uninstall Useless to you windows apps with O&O App buster.
Reboot your machine and check the issue.
Does Gdata have a firewall? If so omit this line from the batch file.
Also, from your speccy log. Have you ever had Avira on this computer? This may be a sign your computer has a malware infection.
Avira_Security_Installation
too many things idk i jsut want to play a ****ing game without disconnecting me from it
am not tech guy am not turning my whole computer upside down to play a *** **** bf5
Thread closed. You need to learn some manors, cussing people who try to help you isn’t going to work in your favor ever.
There are plenty of other sites to get help from, try another one. Asking for help then not doing anything suggested , because you become enraged that it is not a one click solution. Then cuss the person who set aside his personal time to try and help a stranger... Good luck with your issue, and good luck in life if you are going to carry around with you that type of mindset and attitude.
Reactions: Bruce and veeg
