Solved I am building my first pc, please see my option and tell me what is wrong
Yox
27
Intel i5 13400f
Rtx 3060 dual 12gb
Asrock b760m pro rs/d4
Team T-create classic 8×2
Samsung ssd 970 evo plus 1 tb
Schyte fuma 3
Corsair rm 750e atx 3.0
Tecware flatline tg mk2
Thats pretty much the component. What do you guys think?
Check the memory is compatible with the motherboard.
Asrock will have a Quality Vendors List on their support page for that mobo.
Reactions: Yox
Change the MB to one that is DDR5 and change the CPU to one that has onboard video.
The present board is limited to DDR4 which is now old tech and as a double whammy it restricts the speed of RAM to DDR4 3200MHz whereas the CPU on the list can handle up to DDR5 4800MHz, build for the future, not to be tied to the past.
Some CPU benchmarks for you here the i5-13400F is the least expensive only because it is so limited.
