Hello all,
My factory fitted battery was dying so I got a replacement from hplaptopbattery dot co dot uk and installed it myself.
The battery icon at the bottom right says 31% (plugged in) when obviously plugged in and simply 31% when unplugged.
HP Support Assistant tells me the battery is Discharging (31%) - Primary Battery: No Battery (60) - A battery was not detected.
I have scanned online and not found anything particularly similar, just other HP users being advised to uninstall the battery driver, power off and unplug battery, then power on. This didn't fix my issue.
Also believe I have latest BIOS installed.
Does anybody have an idea on how to fix my problem and charge the new battery?
Thanks.
HP Omen 17-an0xx
Thanks.
HP Omen 17-an0xx
