Solved How to turn read request read recipt on
auratodd
61
43
UK
louisetopp.weebly.com
Hi I've tried following U tube which is helpful. But on composing an email I cant find the request read recipt section as it's simply not there. How do i turn it on please? Thanks.
Ok a web browser then.
While you are in the email that you are writting look in the lower right corner.
There will be 3 Vertical dots click there.
I have checked on three different browsers and they all show the same as my previous post. Have also looked in the setting and there is nothing. That is the only place I have found it in the web based. Have you tried a different browser?
Do you have any add-on running in Chrome?
I have some, but it wouldn't unterfear with that would it?
With out knowing which ones can not say and I would think no. Yet strange things have happened.
On yours I see this. I understand the send later I do not know what the other three on the left do and or are for. What happens when you select the Wheel on the right corner?
The arrow means auto followups is off
https://chrome.google.com/webstore/...low-up/omlanehmflpiihaadkghlgnbocimgokm?hl=en
Gmail Auto Follow Up is a Google Chrome Extension that helps you follow up with your clients or prospects. Just set up a sequence of emails to send to your prospects over time from your Gmail.
Apparently the eye sign means track opens and clicks on
https://chrome.google.com/webstore/...-gmail/ndnaehgpjlnokgebbaldlmgkapkpjkkb?hl=en
Which I thing you were looking for...
Overview
Mail Tracking free forever and unlimited. Add double check marks (✓✓) to your Gmail.
Know when your emails are opened.
Mailtrack is an email tracking extension for Gmail that lets you know if the emails you’ve sent have been read or not.
Reactions: auratodd
