Solved How to monitor my internet connection?
sorcerer
PCHF Donator
Apr 10, 2017
136
9
I've just had fibre installed with a new router and been getting some connection issues. Is there an app which will monitor the performance over a period so I can see if the issue is my connection or the site I'm connected to?
there's speedtest.net website which you can keep refreshing to get speed values.
but I don't know of any other that would constantly monitor your web connection.
let's see who else chimes in. :)
What connections issues are you experiencing. Sometimes it does take the connection a day or two to settle.
Previous issue or one that just started with the new ISP (Fiber)
I had connection issues with my bank, but they won't admit it was their problem, which it may well have been. Also with another site. Both since the new setup. Most everything else seems perfect. It's been 10 days since the upgrade.
OK, so it looks like I can't get what I want. Anyway, thanks for your help. You can close this thread now.
