Hi guys weird little issue.
JamFtw
17
29
Weird little issue I am having. Seems to only happen when I am playing a game. But normally my fps will start dropping before this happens, but I lose controll of my mouse and everything is very delayed for probably 30 seconds. I literally have zero control. It is almost as if I am being "DDOS'D" or something lol. which im pretty sure I am not.
But within 30 seconds everything will comeback to normal. It is just quite annoying because in some games it will get me killed and cost me big time.
Every time before it happens. I know its going to happen i will feel the fps stutter before it drops hard and everything freezes up.
I have a 3070 ventus 3x.
Figured specs aren't too important seeing as this clearly isn't a hardware issue.
Can you Download and run and then post. https://www.ccleaner.com/speccy/download
To post: https://www.ccleaner.com/docs/speccy/using-speccy/publishing-a-speccy-profile-to-the-webNote you do not have to include the speccy report here just the link.
Could you also include the power supply specs E.g Cooler Master 850W Gold V2 NOT E.g 850w
Also are you running backups or sync to the cloud
Evga 850 B3
I really think I don't have any backup or cloud settings enabled. definitely not on purpose.
Very odd issue not sure what could be causing it.
Does seem odd
Can you change your power to normal
Active power scheme:
AMD Ryzen High Performance
Ram should not be a problem - Have you overclocked your ram in the bios?
If yes set bios back to defaults for testing
Does seem odd
I can change it to normal. and yes i have x amp on. i can turn it off tho.
Might also be worth disabling windows updates, just while you game.
You can re enable at any time to have it check for updates on your own terms.
Easy service Optmizer will turn off Wifi by default. Make sure Wlansvc is enabled if you select tweaked mode.
I mean you could always disable it prior to gaming, service and startup.
Also, you could block it in windows firewall, to test....
Same issue as users' other thread closing this thread.
