Solved Here's my PC parts list. Could you guys look at it and give me suggestions on what to add/change?
CanadaCray
24
I am looking to build my first PC. Any suggestions on my parts list. Should I add/subtract/change anything?
[PCPartPicker Part List](https://ca.pcpartpicker.com/list/7qZhGq)
**CPU** | [AMD Ryzen 5 3600 3.6 GHz 6-Core Processor]
**CPU Cooler** | [Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler]
**Motherboard** | [MSI B450 TOMAHAWK MAX ATX AM4 Motherboard]
**Memory** | [G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory]
**Storage** | [Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive]
**Video Card** | [Gigabyte GeForce GTX 1660 SUPER 6 GB GAMING OC Video Card]
**Case** | [Antec DF600 FLUX ATX Mid Tower Case]
**Power Supply** | [EVGA BR 600 W 80+ Bronze Certified ATX Power Supply]
**Operating System** | [Microsoft Windows 10 Pro OEM 64-bit]
What will be the main use of the computer.
Your CPU ships with its own Wraith cooler which means that if you use anything else you will void the AMD warranty.
You should have an SSD for Windows on its own and at least the one HDD for storing data on, for reliability you should choose Western Digital over Seagate, WD Caviar Black being the best.
Bronze efficiency rated PSUs should not be used when there is any more than onboard graphics, you nee at least Gold efficiency rated for your GPU and iy must be from a proven brand such as Corsair, EVGA or Seasonic.
