Help
Lukegoff1
25
I'm 17 and trying too stream games, I normally run 70% CPU while in game and up too 90, But when I stream it's a constant 100% making my frames drop too 60-70 this wouldn't be a problem but I'm running 144hz and it makes the game play choppy, Is there a cheap way too stream 60 fps while not dropping frames, Or an upgrade I can make which isn't buying a RTX 2080TI and I9 9900K ?
Like how would a 2nd pc too stream work ?
So other can assist some more information is needed.
With out knowing what platform and or software you are using and streaming to it is hard say.
What speed is you internet up and down
Need to know complete system specs
make model
power supply make and model
age of system
what games
