Hi,
My desktop is a Asus motherboard running on i3, I just recently upgraded the Ram from 2GB to 16GB. It went well, but suddenly there is this glitches and the PC shut down, it went on and of between seconds for eternity. I then reset the PC, it went ok for around 15 minutes. Then the glitches and on and off happens again.
I then discovered that there are a couple of dead dried lizards inside the power supply and the fan was stuck. I didn't open the power supply, but just pushed the lizard into it. The power work fine, but it's fan is whizzing all the time. I don't know if I reset the system wrong, but now the PC is **** slow. Slow to turn on and off...
Anything I can do to make it top notch like before?
