Solved Help with ram
XLX
23
So Im going with a Amd ryzen 9 5950x and a asus rog strix x570-e gaming motherboard. I been looking at two rams but im not sure witch one to choice or if there is anythin better
Neither of the two.
AMD state here up to 3200MHz for their Ryzen 9 5950X and if you were to fit 3600MHz RAM and enable XMP the computer will either not boot from the off or it will blue screen before you get chance to install Windows.
Stick with any 3200MHz RAM that is on the MBs support list (QVL) and you will be fine, MBs QVL here
Reactions: XLX
