I write the relevant details here
Summary
Operating System
Windows 11 Home Single Language 64-bit
CPU
Intel Core i5 1235U:
35 °C
Alder Lake 10nm Technology
RAM
8,00GB Single-Channel DDR4 @ 1330MHz (19-19-19-43)
Motherboard
HP 89E8 (U3E1):
41 °C
Graphics
HP ALL-in-One (1920x1080@60Hz)
Intel UHD Graphics (HP)
Storage
238GB NVMe KBG40ZNV256G KIOXIA (Unknown (SSD))
Optical Drives
No optical disk drives detected
Audio
Realtek High Definition Audio
Operating System
Computer type: Virtual
Installation Date: 5/12/2024 14:38:07
Windows Security Center
Intel Core i5 1235U
Cores:
10
Threads:
12
Name:
Intel Core i5 1235U
Code Name:
Alder Lake
Package:
Socket 1744 FCBGA
Technology:
10nm
Specification:
12th Gen Intel Core i5-1235U
Family:
6
Extended Family:
6
Model:
A
Extended Model:
9A
Stepping:
4
Revision:
R0
Instructions:
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64, NX, AES, AVX, AVX2, FMA3
Virtualization:
Not supported
Hyperthreading:
Not supported
Bus Speed:
99.8 MHz
Average Temperature:
35 °C
Caches
L1 Data Cache Size:
2 x 48 KBytes
L1 Instructions Cache Size:
2 x 32 KBytes
L2 Unified Cache Size:
2 x 1280 KBytes
L3 Unified Cache Size:
12288 KBytes
Cores
Core 0
Core Speed:
3990.2 MHz
Multiplier:
x 40.0
Bus Speed:
99.8 MHz
Temperature:
40 °C
Threads:
APIC ID: 0, 1
Core 1
Core Speed:
897.8 MHz
Multiplier:
x 9.0
Bus Speed:
99.8 MHz
Temperature:
32 °C
Threads:
APIC ID: 8, 9
Core 2
Core Speed:
1097.3 MHz
Multiplier:
x 11.0
Bus Speed:
99.8 MHz
Temperature:
31 °C
Threads:
APIC ID: 16
Core 3
Core Speed:
1296.8 MHz
Multiplier:
x 13.0
Bus Speed:
99.8 MHz
Temperature:
30 °C
Threads:
APIC ID: 18
Core 4
Core Speed:
3192.2 MHz
Multiplier:
x 32.0
Bus Speed:
99.8 MHz
Temperature:
37 °C
Threads:
APIC ID: 20
Core 5
Core Speed:
3192.2 MHz
Multiplier:
x 32.0
Bus Speed:
99.8 MHz
Temperature:
37 °C
Threads:
APIC ID: 22
Core 6
Core Speed:
1097.3 MHz
Multiplier:
x 11.0
Bus Speed:
99.8 MHz
Temperature:
34 °C
Threads:
APIC ID: 24
Core 7
Core Speed:
1596.1 MHz
Multiplier:
x 16.0
Bus Speed:
99.8 MHz
Temperature:
34 °C
Threads:
APIC ID: 26
Core 8
Core Speed:
1596.1 MHz
Multiplier:
x 16.0
Bus Speed:
99.8 MHz
Temperature:
36 °C
Threads:
APIC ID: 28
Core 9
Core Speed:
1097.3 MHz
Multiplier:
x 11.0
Bus Speed:
99.8 MHz
Temperature:
34 °C
Threads:
APIC ID: 30
RAM
Memory slots
Total memory slots:
Used memory slots:
Free memory slots:
Memory
Type:
DDR4
Size:
8192 MBytes
Channels #:
Single
DRAM Frequency:
1330.1 MHz
CAS# Latency (CL):
19 clocks
RAS# to CAS# Delay (tRCD):
19 clocks
RAS# Precharge (tRP):
19 clocks
Cycle Time (tRAS):
43 clocks
Bank Cycle Time (tRC):
62 clocks
Command Rate (CR):
2T
Physical Memory
Memory Usage:
85 %
Total Physical:
7.69 GB
Available Physical:
1.09 GB
Total Virtual:
9.57 GB
Available Virtual:
2.12 GB
SPD
Number Of SPD Modules:
Slot #1
Type:
DDR4
Size:
8192 MBytes
Manufacturer:
SK Hynix
Max Bandwidth:
DDR4-3200 (1600 MHz)
Part Number:
HMA81GS6DJR8N-XN
Serial Number:
5517BFBB
Week/year:
09 / 22
Timing table
JEDEC #1
Frequency:
733.3 MHz
CAS# Latency:
10,0
RAS# To CAS#:
11
RAS# Precharge:
11
tRAS:
24
tRC:
34
Voltage:
1,200 V
JEDEC #2
Frequency:
800.0 MHz
CAS# Latency:
11,0
RAS# To CAS#:
11
RAS# Precharge:
11
tRAS:
tRC:
37
Voltage:
1,200 V
JEDEC #3
Frequency:
866.7 MHz
CAS# Latency:
12,0
RAS# To CAS#:
12
RAS# Precharge:
12
tRAS:
28
tRC:
40
Voltage:
1,200 V
JEDEC #4
Frequency:
933.3 MHz
CAS# Latency:
13,0
RAS# To CAS#:
13
RAS# Precharge:
13
tRAS:
30
tRC:
43
Voltage:
1,200 V
JEDEC #5
Frequency:
1033.3 MHz
CAS# Latency:
14,0
RAS# To CAS#:
15
RAS# Precharge:
15
tRAS:
34
tRC:
48
Voltage:
1,200 V
JEDEC #6
Frequency:
1100.0 MHz
CAS# Latency:
15,0
RAS# To CAS#:
16
RAS# Precharge:
16
tRAS:
36
tRC:
51
Voltage:
1,200 V
JEDEC #7
Frequency:
1166.7 MHz
CAS# Latency:
16,0
RAS# To CAS#:
17
RAS# Precharge:
17
tRAS:
38
tRC:
54
Voltage:
1,200 V
JEDEC #8
Frequency:
1233.3 MHz
CAS# Latency:
17,0
RAS# To CAS#:
17
RAS# Precharge:
17
tRAS:
40
tRC:
57
Voltage:
1,200 V
JEDEC #9
Frequency:
1300.0 MHz
CAS# Latency:
18,0
RAS# To CAS#:
18
RAS# Precharge:
18
tRAS:
42
tRC:
60
Voltage:
1,200 V
JEDEC #10
Frequency:
1366.7 MHz
CAS# Latency:
19,0
RAS# To CAS#:
19
RAS# Precharge:
19
tRAS:
44
tRC:
63
Voltage:
1,200 V
JEDEC #11
Frequency:
1466.7 MHz
CAS# Latency:
20,0
RAS# To CAS#:
21
RAS# Precharge:
21
tRAS:
47
tRC:
68
Voltage:
1,200 V
JEDEC #12
Frequency:
1533.3 MHz
CAS# Latency:
21,0
RAS# To CAS#:
22
RAS# Precharge:
22
tRAS:
50
tRC:
71
Voltage:
1,200 V
JEDEC #13
Frequency:
1600.0 MHz
CAS# Latency:
22,0
RAS# To CAS#:
22
RAS# Precharge:
22
tRAS:
52
tRC:
74
Voltage:
1,200 V
JEDEC #14
Frequency:
1600.0 MHz
CAS# Latency:
24,0
RAS# To CAS#:
22
RAS# Precharge:
22
tRAS:
52
tRC:
74
Voltage:
1,200 V
Motherboard
Manufacturer:
HP
Model:
89E8 (U3E1)
Version:
0100
Chipset Vendor:
Intel
Chipset Model:
Alder Lake
Chipset Revision:
04
Southbridge Vendor:
Intel
Southbridge Model:
Alder Lake PCH
Southbridge Revision:
01
System Temperature:
41 °C
BIOS
Brand:
AMI
Version:
F.36
Date:
25/9/2024
PCI Data
Slot PCI-E
Slot Type:
PCI-E
Slot Usage:
In Use
Data lanes:
x16
Slot Designation:
J6B2
Characteristics:
3.3V, Shared, PME
Slot Number:
Graphics
Monitor
Name:
HP ALL-in-One on Intel UHD Graphics
Current Resolution:
1920x1080 pixels
Work Resolution:
1920x1032 pixels
State:
Enabled, Primary
Monitor Width:
1920
Monitor Height:
1080
Monitor BPP:
32 bits per pixel
Monitor Frequency:
60 Hz
Device:
\\.\DISPLAY1\Monitor0
Intel UHD Graphics
Manufacturer:
Intel
Model:
UHD Graphics
Device ID:
8086-4628
Revision:
D
Subvendor:
HP (103C)
Current Performance Level:
Level 0
Current GPU Clock:
600 MHz
Voltage:
0.285 V
Driver version:
31.0.101.5590
Count of performance levels : 1
Level 1 - "Perf Level 0"
GPU Clock:
600 MHz
Storage
Hard drives
NVMe KBG40ZNV256G KIOXIA (SSD)
Interface:
Unknown
Capacity:
238 GB
Real size:
256 060 514 304 bytes
RAID Type:
None
S.M.A.R.T
S.M.A.R.T not supported
Partition 0
Partition ID:
Disk #0, Partition #0
File System:
FAT32
Volume Serial Number:
E6439E3A
Size:
256 MB
Used Space:
84 MB (33%)
Free Space:
171 MB (67%)
Partition 1
Partition ID:
Disk #0, Partition #1
Disk Letter:
C:
File System:
NTFS
6030A7ED
Size:
237 GB
Used Space:
98 GB (41%)
Free Space:
139 GB (59%)
Partition 2
Partition ID:
Disk #0, Partition #2
File System:
NTFS
1C1C84E0
Size:
808 MB
Used Space:
697 MB (86%)
Free Space:
111 MB (14%)
Optical Drives
