Help please
V3dalam gaming
25
So recently I've been getting high 'var' spikes and fps drops in csgo and i have done nothing to cause this
Nor have i had this problem before
I've tried some fixes like uninstalling then installing again change settings pls suggest something
Thank you
You have post on a tech forum looking for help but have told us zero about your computer or its hardware so not sure what you are expecting from us.
Sorry my bad
I have intel pentium g4560
8 gb corsiar vengeance ddr4
Gtx1050ti
Ga h11m0 m-h motherboard
I have a monitor of acer kg241qP 144hz
Specs are ok for the game so you may want to check out your internet connection by trying another online game.
Is your 8GB of RAM two 4GB sticks or one 8GB stick.
What is the brand and model name or number of the PSU.
What browser and anti virus do you use.
Being that the OP revisited the forums after my post #4 but chose not to reply this thread will be closed.
