Solved Help please
Will1600
8
24
Hi there, I've just finished building my first pc build, and I got the whole thing fired up, fans were working fine but when I went to use the monitor, it stated "no signal" but the VGA adapter was inserted correctly also my rgb keyboard and mouse were not glowing and not responding to the pc, could someone please direct me in the right direction of resolving this thanks
We can`t make a start with nothing to work with I`m afraid :(
Please provide information about your hardware, post the brand and model name or number for the CPU, MB, the RAM (including the amount) add on video card if one is used and the PSU (power supply unit) providing these details will enable folk to better assist you.
The Cpu is an I3
The motherboard is MSI H310M PRO-VDH PLUS
Ram 2x 8gb sticks of crucial ballistix ddr4
Psu-500watt evga
HDD seagate 1 Tb
Case Micro atx(eBay) ARGB fans
Intel Pentium i3-9100F SRF7W, 3.60GHz
Sorry to be the bearer of bad news but you are not getting a signal because the CPU does not have any on die video, note the letter F.
CPU specs here
MB specs here says *No Display support when using the Processor model with suffix “F” Click on Detail to get the specs.
CPU specs here
Fs thanks for the help what would be the best solution to this now...
What do you intend the main use of the computer to be, reason I ask is you are going to need an add on video card and depending on the use you could be looking at having to spend circa £200 for a half decent GPU
Yeah intending to use it for a bit of gaming, what Gpu would you recommend, I would like to be able to run most games warzone, and a few others, also thank you for your help it means a lot
Hi again I've got the
Call of Duty: Warzone System Requirements
Least expensive cards on the above lists benchmark info here first two cards are ok for the recommended requirements, third card only good for minimum.
You are looking at circa £200 I`m afraid, get prices from here
You are welcome btw :)
Hi how's it going sorry to disturb you again but I've now got the GPU connected but the still seems to be no connection any idea what could be the problem now
What card did you get.
Have you made sure that you have not connected to a MB port instead of the GPU, sorry if not the case but it is a common mistake.
The card I got was a RADEON RX 570 ARMOR 8G OC Graphics Card '8GB GDDR5, 1268Hz,. I have inerterted in the correct port. I have now got my rgb keyboard working but monitor still stating no signal
Have you securely connected the 6+2 (8 pin) PCI-E connector to the GPU from the PSU.
What type of port on the GPU are you connected to.
What is the brand and model name or number of the screen that you are connected to.
Can I ask that you do not quote every reply, it really does not help any and just makes for unnecessary reading, thanks.
Sorry, I got it sorted in the end, everything is now working great thanks for the help.
For the benefit of others that may encounter the same issues, can I ask what the problem was.
