Solved Help! My internet is doing a weird thing!
Jarcojr
7
28
I have Cox internet 150Mbps package. Cox originally gave me one of their cable router modems but I didn't want to pay the monthly fee so I bought my own. I made sure the router modem was just as, if not more, capable than the old cable router modem.
Anyways I take off the old router and plug in the new one. I called my ISP and had them add it to the system. I get a connection, but my internet is very slow. I call up Cox again and they have to rearrange somethings they had apparently screwed up while initially adding the new router. Finally get internet speed (browsing) back up, but I got to do a speed test and I'm only pulling 6-9 Mbps ( I tried multiple sites).
So I called Cox yet again and they tried troubleshooting by resetting the modem (of course). They eventually conceded to sending out a technician. He shows up and is getting perfectly good speed tests at around 190Mbps. Then I try the speed test on my phone and it's also getting 150+.
So now I'm just really confused. I've tried fixing it myself for a while now, but I can't figure it out.
I went to this website because its worked in the past, and did step three... multiple times.https://pchelpforum.net/resources/how-to-speed-up-your-internet-connection.121/
Cable router modem - C7000 Netgear Nighthawk AC1900
Modem is connected via ethernet
Computer specs:
Windows 10
24gb ram
i-5 6600k
GTX 1070
wifi card is a TP link ac1300
You should be using the 5GHz band for internet connection and 802.11ac. Are you using these settings?
The 2.4 GHz band is limited to 802.11n speeds.
Yes definitely. It's not the wifi I'm having trouble with. My computer is hooked up to the ethernet and only gets 6Mbps. The phone is on wifi and gets 190. Same with the technician's equipment. He got 150+ on both of the machines he tried. I think the issue is something internal in my computer but I have no idea how to figure it out. The cable company pretty much just said... sucks for you.
Something to note: when i try to do config/ release it says the media is disconnected for LAN 11. (not sure if that means anything.
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
Ran by Jarvis (administrator) on 08-02-2017 at 23:17:34
Running from "C:\Users\Jarvis\Downloads"
Model: MS-7A12 Manufacturer: MSI
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
127.0.0.1 localhost
127.0.0.1 localhost
Intel(R) Ethernet Connection (2) I219-V = Ethernet (Connected)
TP-LINK 802.11ac Network Adapter = Wi-Fi 2 (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set interface interface="Wi-Fi 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 11" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : Jarvis-PC
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V
Physical Address. . . . . . . . . : 4C-CC-6A-24-86-FB
IPv4 Address. . . . . . . . . . . : 192.168.0.11(Preferred)
Lease Obtained. . . . . . . . . . : Wednesday, February 8, 2017 6:14:34 PM
Lease Expires . . . . . . . . . . : Thursday, February 9, 2017 6:14:35 PM
DNS Servers . . . . . . . . . . . : 68.105.28.11
68.105.29.11
68.105.28.12
Wireless LAN adapter Wi-Fi 2:
Description . . . . . . . . . . . : TP-LINK 802.11ac Network Adapter
Physical Address. . . . . . . . . : 84-16-F9-8C-8E-DB
Wireless LAN adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 86-16-F9-8C-8E-DB
Server: cdns1.cox.net
Address: 68.105.28.11
Addresses: 2607:f8b0:4007:80c::200e
172.217.5.78
Pinging google.com [172.217.4.142] with 32 bytes of data:
Reply from 172.217.4.142: bytes=32 time=20ms TTL=55
Reply from 172.217.4.142: bytes=32 time=21ms TTL=55
Ping statistics for 172.217.4.142:
Minimum = 20ms, Maximum = 21ms, Average = 20ms
Addresses: 2001:4998:c:a06::2:4008
2001:4998:58:c02::a9
2001:4998:44:204::a7
206.190.36.45
98.139.183.24
98.138.253.109
Pinging yahoo.com [98.139.183.24] with 32 bytes of data:
Reply from 98.139.183.24: bytes=32 time=87ms TTL=52
Reply from 98.139.183.24: bytes=32 time=90ms TTL=52
Ping statistics for 98.139.183.24:
Minimum = 87ms, Maximum = 90ms, Average = 88ms
Interface List
22...4c cc 6a 24 86 fb ......Intel(R) Ethernet Connection (2) I219-V
14...84 16 f9 8c 8e db ......TP-LINK 802.11ac Network Adapter
23...86 16 f9 8c 8e db ......Microsoft Wi-Fi Direct Virtual Adapter #2
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.11 25
192.168.0.0 255.255.255.0 On-link 192.168.0.11 281
192.168.0.11 255.255.255.255 On-link 192.168.0.11 281
192.168.0.255 255.255.255.255 On-link 192.168.0.11 281
224.0.0.0 240.0.0.0 On-link 192.168.0.11 281
255.255.255.255 255.255.255.255 On-link 192.168.0.11 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
1 331 ::1/128 On-link
1 331 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\WINDOWS\SysWoW64\napinsp.dll [55808] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWoW64\NLAapi.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWoW64\winrnr.dll [24064] (Microsoft Corporation)
Catalog5 07 C:\Program Files (x86)\Bonjour\mdnsNSP.dll [122128] (Apple Inc.)
Catalog9 01 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67584] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31744] (Microsoft Corporation)
x64-Catalog5 07 C:\Program Files\Bonjour\mdnsNSP.dll [133392] (Apple Inc.)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
Application errors:
Error: (02/08/2017 07:26:29 PM) (Source: DbxSvc) (User: )
Description: Failed to connect to the driver: (-2147024894) The system cannot find the file specified.
Description: Filter Unload failed with: (-2145452013) The system could not find the filter specified.
Error: (02/08/2017 06:14:21 PM) (Source: DbxSvc) (User: )
Error: (02/08/2017 05:54:35 PM) (Source: Perflib) (User: )
Description: BITSC:\Windows\System32\bitsperf.dll4
Error: (02/08/2017 05:54:32 PM) (Source: DbxSvc) (User: )
Error: (02/08/2017 05:53:47 PM) (Source: Microsoft-Windows-Immersive-Shell) (User: JARVIS-PC)
Description: Activation of app Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy!App failed with error: -2144927141 See the Microsoft-Windows-TWinUI/Operational log for additional information.
System errors:
Error: (02/08/2017 06:15:45 PM) (Source: Service Control Manager) (User: )
Description: A timeout (60000 milliseconds) was reached while waiting for a transaction response from the Intel(R) Online Connect Helper service.
Error: (02/08/2017 06:14:45 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: application-specificLocalActivation{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}NT AUTHORITYLOCAL SERVICES-1-5-19LocalHost (Using LRPC)UnavailableUnavailable
Description: application-specificLocalActivation{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}{F72671A9-012C-4725-9D2F-2A4D32D65169}NT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
Error: (02/08/2017 06:14:18 PM) (Source: Microsoft-Windows-Kernel-Processor-Power) (User: NT AUTHORITY)
Description: Performance power management features on Hyper-V logical processor 3 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Description: Performance power management features on Hyper-V logical processor 2 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Description: Performance power management features on Hyper-V logical processor 1 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Description: Performance power management features on Hyper-V logical processor 0 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Error: (02/08/2017 06:13:40 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: application-specificLocalActivation{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}NT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
Error: (02/08/2017 05:55:54 PM) (Source: Service Control Manager) (User: )
Microsoft Office Sessions:
Error: (02/08/2017 07:26:29 PM) (Source: DbxSvc)(User: )
Description: (-2147024894) The system cannot find the file specified.
Description: (-2145452013) The system could not find the filter specified.
Error: (02/08/2017 06:14:21 PM) (Source: DbxSvc)(User: )
Error: (02/08/2017 05:54:35 PM) (Source: Perflib)(User: )
Error: (02/08/2017 05:54:32 PM) (Source: DbxSvc)(User: )
Error: (02/08/2017 05:53:47 PM) (Source: Microsoft-Windows-Immersive-Shell)(User: JARVIS-PC)
Description: Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy!App-2144927141
CodeIntegrity Errors:
Date: 2017-02-08 21:15:32.744
Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume5\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2DevProps.dll that did not meet the Store signing level requirements.
Date: 2017-02-08 21:15:32.740
Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume5\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2OSD.dll that did not meet the Store signing level requirements.
Date: 2017-02-08 21:15:02.069
Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume5\Windows\System32\nvspcap64.dll that did not meet the Store signing level requirements.
Date: 2017-02-08 21:15:01.957
Date: 2017-02-08 21:15:01.951
7-Zip 16.02 (x64 edition) (HKLM\...\{23170F69-40C1-2702-1602-000001000000}) (Version: 16.02.00.0 - Igor Pavlov)
7-Zip 16.04 (x64) (HKLM\...\7-Zip) (Version: 16.04 - Igor Pavlov)
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 15.023.20056 - Adobe Systems Incorporated)
Adobe Flash Player 24 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 24.0.0.194 - Adobe Systems Incorporated)
Adobe Flash Player 24 PPAPI (HKLM-x32\...\Adobe Flash Player PPAPI) (Version: 24.0.0.194 - Adobe Systems Incorporated)
Age of Mythology: Extended Edition (HKLM\...\Steam App 266840) (Version: - SkyBox Labs)
Alien Swarm (HKLM\...\Steam App 630) (Version: - Valve)
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 378.49 - NVIDIA Corporation) Hidden
ApoDispatchConfigurator (HKLM\...\{064FCD7F-935D-4A3C-BDA5-8B272AA5A698}) (Version: 2.3.1401 - Nahimic) Hidden
Apowersoft Photo Viewer V1.1.2 (HKLM-x32\...\{AA88C325-55DB-463A-801E-ED6929D0260E}_is1) (Version: 1.1.2 - APOWERSOFT LIMITED)
Apple Application Support (32-bit) (HKLM-x32\...\{D079CAAD-0C31-47A2-9AF5-A82F9CD9B221}) (Version: 5.2 - Apple Inc.)
Apple Application Support (64-bit) (HKLM\...\{64E6007B-1DA9-42CD-BBE4-D5FA67A7C71D}) (Version: 5.2 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}) (Version: 10.0.1.3 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
Asmedia USB Host Controller Driver (HKLM-x32\...\{E4FB0B39-C991-4EE7-95DD-1A1A7857D33D}) (Version: 1.16.33.1 - Asmedia Technology)
AudioLaunchpadConfigurator (HKLM\...\{E49685B2-DE80-4609-9B01-A993282D563B}) (Version: 2.3.1401 - Nahimic) Hidden
Battlefield™ 1 (HKLM-x32\...\{335B50BC-6130-4BAF-9A6A-F1561270587B}) (Version: 1.0.47.30570 - Electronic Arts)
BeamNG.drive (HKLM\...\Steam App 284160) (Version: - BeamNG)
Bitdefender Agent (HKLM\...\Bitdefender Agent) (Version: 1.0.1 - Bitdefender)
Bitdefender Antivirus Free (HKLM\...\{1FCCF41D-5F00-4FE2-9653-162D0486C8B4}) (Version: 1.0.4.28 - Bitdefender)
Borderlands 2 (HKLM\...\Steam App 49520) (Version: - Gearbox Software)
Borderless Gaming (HKLM-x32\...\Borderless Gaming_is1) (Version: 8.4 - Codeusa Software)
Call of Duty: Modern Warfare 2 - Multiplayer (HKLM\...\Steam App 10190) (Version: - Infinity Ward)
Call of Duty: Modern Warfare 2 (HKLM\...\Steam App 10180) (Version: - Infinity Ward)
CAM (HKLM-x32\...\{4D246B88-693F-4079-894E-68F943210CC8}) (Version: 3.3.0 - NZXT)
CCleaner (HKLM\...\CCleaner) (Version: 5.26 - Piriform)
cFosSpeed v10.11 (HKLM\...\cFosSpeed) (Version: 10.11 - cFos Software GmbH, Bonn)
CheckDevicesConfigurator (HKLM\...\{F17C92A4-9E41-43A2-B0C1-6BFAFD4B0354}) (Version: 2.3.1401 - Nahimic) Hidden
Cities: Skylines (HKLM\...\Steam App 255710) (Version: - Colossal Order Ltd.)
Corsair Utility Engine (HKLM-x32\...\{A95A2CA8-D121-4F63-B513-C94AEDDD35C4}) (Version: 2.9.53 - Corsair)
Counter-Strike: Global Offensive (HKLM\...\Steam App 730) (Version: - Valve)
CPUID CPU-Z MSI 1.74 (HKLM\...\CPUID CPU-Z MSI_is1) (Version: 1.74 - CPUID, Inc.)
Curse (HKLM-x32\...\{DEE70742-F4E9-44CA-B2B9-EE95DCF37295}) (Version: 6.0.0.0 - Curse)
Curse Client (HKCU\...\101a9f93b8f0bb6f) (Version: 5.1.1.844 - Curse)
Darksiders II: Deathinitive Edition (HKLM\...\Steam App 388410) (Version: - Gunfire Games)
Dead Space 2 (HKLM\...\Steam App 47780) (Version: - Visceral Games)
Defraggler (HKLM\...\Defraggler) (Version: 2.21 - Piriform)
Deus Ex: Mankind Divided™ (HKLM\...\Steam App 337000) (Version: - Eidos Montreal)
Discord (HKCU\...\Discord) (Version: 0.0.297 - Hammer & Chisel, Inc.)
Dishonored (HKLM\...\Steam App 205100) (Version: - Arkane Studios)
Dragon Eye(x64) (HKLM\...\{B746827A-3219-4EF8-8053-CEA5AEC12D33}) (Version: 0.0.1.1 - MSI) Hidden
Dragon Eye(x64) (HKLM-x32\...\Installshield_{B746827A-3219-4EF8-8053-CEA5AEC12D33}) (Version: 0.0.1.1 - )
Dragon's Dogma: Dark Arisen (HKLM\...\Steam App 367500) (Version: - Capcom)
Dropbox (HKLM-x32\...\Dropbox) (Version: 19.4.13 - Dropbox, Inc.)
Dropbox Update Helper (HKLM-x32\...\{099218A5-A723-43DC-8DB5-6173656A1E94}) (Version: 1.3.59.1 - Dropbox, Inc.) Hidden
Elite Dangerous (HKLM\...\Steam App 359320) (Version: - Frontier Developments)
Evernote v. 6.4.2 (HKLM-x32\...\{E74F0DCA-9FC8-11E6-9D98-005056950253}) (Version: 6.4.2.3788 - Evernote Corp.)
f.lux (HKCU\...\Flux) (Version: - )
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 56.0.2924.87 - Google Inc.)
Google Drive (HKLM-x32\...\{07A12123-B717-496B-B471-48AF6407B433}) (Version: 1.32.4066.7445 - Google, Inc.)
Google Photos Backup (HKCU\...\Google Photos Backup) (Version: 1.1.2.13 - Google, Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.32.7 - Google Inc.) Hidden
gpedt.msc 1.0 (HKLM-x32\...\{10B9C608-BF7C-4CCF-A658-C01D969DCA21}_is1) (Version: - Richard)
HP ENVY 4500 series Basic Device Software (HKLM\...\{6915424E-704F-4F5D-9057-9C7B406B36DB}) (Version: 32.3.198.49673 - Hewlett-Packard Co.)
HP ENVY 4500 series Help (HKLM-x32\...\{95BECC50-22B4-4FCA-8A2E-BF77713E6D3A}) (Version: 30.0.0 - Hewlett Packard)
HP Photo Creations (HKLM-x32\...\HP Photo Creations) (Version: 1.0.0.7702 - HP)
HP Support Solutions Framework (HKLM-x32\...\{2B5A1E68-6617-406D-B797-5DAB5B4630B8}) (Version: 12.5.32.203 - HP Inc.)
HP Update (HKLM-x32\...\{912D30CF-F39E-4B31-AD9A-123C6B794EE2}) (Version: 5.005.002.002 - Hewlett-Packard)
Intel Extreme Tuning Utility (HKLM-x32\...\{41E5D953-530A-441B-98D3-92B5D6B80AEB}) (Version: 6.2.0.17 - Intel Corporation) Hidden
Intel Extreme Tuning Utility (HKLM-x32\...\{fde8aa07-3912-4bdf-ad35-ff1231bfd00d}) (Version: 6.2.0.17 - Intel Corporation)
Intel(R) Chipset Device Software (HKLM-x32\...\{bb0592a7-5772-4736-9d55-2402740085db}) (Version: 10.1.1.38 - Intel(R) Corporation) Hidden
Intel(R) Management Engine Components (HKLM\...\{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 11.6.0.1036 - Intel Corporation)
Intel(R) Network Connections 21.1.30.0 (HKLM\...\PROSetDX) (Version: 21.1.30.0 - Intel)
Intel(R) Online Connect Software Asset Manager (HKLM-x32\...\{AE956AB9-CD98-4F1E-8B9E-C3C66E290D64}) (Version: 3.4.2072 - Intel Corporation) Hidden
Intel(R) Serial IO (HKLM\...\{9FD91C5C-44AE-4D9D-85BE-AE52816B0294}) (Version: 30.100.1633.3 - Intel Corporation)
Intel® Security Assist (HKLM-x32\...\{4B230374-6475-4A73-BA6E-41015E9C5013}) (Version: 1.0.0.532 - Intel Corporation)
iTunes (HKLM\...\{81C96689-EA5B-4B7D-A04F-16326EC51BC2}) (Version: 12.5.4.42 - Apple Inc.)
Java 8 Update 121 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180121F0}) (Version: 8.0.1210.13 - Oracle Corporation)
Just Cause 3 (HKLM\...\Steam App 225540) (Version: - Avalanche Studios)
LauncherSetup (HKLM\...\{EAF34292-88ED-4E8A-8DD2-39F9E0DD4DC7}) (Version: 2.3.1401 - Nahimic) Hidden
Left 4 Dead 2 (HKLM\...\Steam App 550) (Version: - Valve)
LibreOffice 5.2.5.1 (HKLM-x32\...\{79CD8EA1-DEB1-4582-9E41-8634223BDCD4}) (Version: 5.2.5.1 - The Document Foundation)
LightingController (HKLM-x32\...\{F83166E4-C89D-4F45-BDDA-94F24C85F4E5}) (Version: 0.01.0002 - iBUYPOWER)
Magicka (HKLM\...\Steam App 42910) (Version: - Arrowhead Game Studios)
Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM-x32\...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
Microsoft ASP.NET MVC 4 Runtime (HKLM-x32\...\{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50901.0 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24210 (HKLM-x32\...\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24210 (HKLM-x32\...\{23658c02-145e-483d-ba6b-1eb82c580529}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft XNA Framework Redistributable 3.1 (HKLM-x32\...\{19BFDA5D-1FE2-4F25-97F9-1A79DD04EE20}) (Version: 3.1.10527.0 - Microsoft Corporation)
Middle-earth: Shadow of Mordor (HKLM\...\Steam App 241930) (Version: - Monolith Productions, Inc.)
Might & Magic: Heroes VI (HKLM\...\Steam App 48220) (Version: - Blackhole)
Minecraft (HKLM-x32\...\{1C16BCA3-EBC1-49F6-8623-8FBFB9CCC872}) (Version: 1.0.3.0 - Mojang)
Mozilla Firefox 51.0 (x86 en-US) (HKLM-x32\...\Mozilla Firefox 51.0 (x86 en-US)) (Version: 51.0 - Mozilla)
Mozilla Maintenance Service (HKLM-x32\...\MozillaMaintenanceService) (Version: 51.0 - Mozilla)
MSI Afterburner 4.1.1 (HKLM-x32\...\Afterburner) (Version: 4.1.1 - MSI Co., LTD)
MSI Command Center (HKLM-x32\...\{85A2564E-9ED9-448A-91E4-B9211EE58A08}_is1) (Version: 2.0.0.43 - MSI)
MSI Fast Boot (HKLM-x32\...\{0F212E7A-65EB-4668-A8D7-749026A64F8E}_is1) (Version: 1.0.1.8 - MSI)
MSI Gaming APP (HKLM-x32\...\{E0229316-E73B-484B-B9E0-45098AB38D8C}}_is1) (Version: 6.0.0.30 - MSI)
MSI Gaming Lan Manager (HKLM-x32\...\{3318282C-D4D6-4B29-BBD5-95FC34B54FF0}_is1) (Version: 1.0.0.25 - MSI)
MSI Kombustor 2.5.9 (HKLM-x32\...\{0B7C79A5-5CB2-4ABD-A9C1-92A6213CE8DD}_is1) (Version: - MSI Co., LTD)
MSI Live Update 6 (HKLM-x32\...\{4F46CF54-47D2-41F4-B230-B0954C544420}}_is1) (Version: 6.2.0.06 - MSI)
MSI M-Cloud (HKLM-x32\...\{C2CA9595-A17F-4D28-BD6E-0E30447AF60B}}_is1) (Version: 1.0.0.20 - MSI)
MSI USB Speed Up (HKLM-x32\...\{79D5FA63-7003-4398-B882-C70ED18778D1}_is1) (Version: 1.0.0.09 - MSI)
Nahimic 2 (HKLM-x32\...\{05c7b70a-5d25-419a-9b71-76900393b641}) (Version: 2.3.14 - Nahimic)
Nahimic2UISetup (HKLM\...\{FD585866-680F-4FE0-8082-731D715F90CE}) (Version: 2.3.1401 - Nahimic) Hidden
NETGEAR Genie (HKLM-x32\...\NETGEAR Genie) (Version: 2.4.28.00 - NETGEAR Inc.)
NVIDIA GeForce Experience 3.3.0.95 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.3.0.95 - NVIDIA Corporation)
NVIDIA Graphics Driver 378.49 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 378.49 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.16.0318 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
NvNodejs (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.3.0.95 - NVIDIA Corporation) Hidden
NvTelemetry (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 2.3.5.0 - NVIDIA Corporation) Hidden
NvvHci (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvvHci) (Version: 2.02.0.5 - NVIDIA Corporation) Hidden
Origin (HKLM-x32\...\Origin) (Version: 10.4.2.12697 - Electronic Arts, Inc.)
Overwatch (HKLM-x32\...\Overwatch) (Version: - Blizzard Entertainment)
Path of Exile (HKLM\...\Steam App 238960) (Version: - Grinding Gear Games)
Plague Inc: Evolved (HKLM\...\Steam App 246620) (Version: - Ndemic Creations)
Product Improvement Study for HP ENVY 4500 series (HKLM\...\{58139103-BACF-4BDC-B71C-955F9164ADA6}) (Version: 32.3.198.49673 - Hewlett-Packard Co.)
ProductDaemonSetup (HKLM\...\{E5C605BF-FEF0-460C-9927-BC86E0647AD3}) (Version: 2.3.1401 - Nahimic) Hidden
ProductNSConfigurator (HKLM\...\{1B4DB619-21BD-4006-A8BA-394B70C2F761}) (Version: 2.3.1401 - Nahimic) Hidden
Rainmeter (HKLM-x32\...\Rainmeter) (Version: 4.0 beta r2613 - Win10 Widgets)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8010 - Realtek Semiconductor Corp.)
RivaTuner Statistics Server 6.3.0 (HKLM-x32\...\RTSS) (Version: 6.3.0 - Unwinder)
Rocket League (HKLM\...\Steam App 252950) (Version: - Psyonix, Inc.)
Rockstar Games Social Club (HKLM-x32\...\Rockstar Games Social Club) (Version: 1.2.0.5 - Rockstar Games)
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0351 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 3.3.0.95 - NVIDIA Corporation) Hidden
Skype™ 7.29 (HKLM-x32\...\{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.29.101 - Skype Technologies S.A.)
SonicMapperConfigurator (HKLM\...\{BC0A78EE-7CA5-4262-9F8C-2B6F7AF6EA63}) (Version: 2.3.1401 - Nahimic) Hidden
Spotify (HKCU\...\Spotify) (Version: 1.0.48.103.g15edf1ec - Spotify AB)
STAR WARS™ Jedi Knight: Jedi Academy™ (HKLM\...\Steam App 6020) (Version: - Raven Software)
Stellaris (HKLM\...\Steam App 281990) (Version: - Paradox Development Studio)
SUPERHOT (HKLM\...\Steam App 322500) (Version: - SUPERHOT Team)
Tharsis (HKLM\...\Steam App 323060) (Version: - Choice Provisions)
The Witcher 3: Wild Hunt (HKLM\...\Steam App 292030) (Version: - CD PROJEKT RED)
Titanfall™ 2 (HKLM-x32\...\{4BD80373-FEE7-45B6-8249-6E8E98717405}) (Version: 1.0.0.3 - Electronic Arts, Inc.)
Total War: SHOGUN 2 (HKLM\...\Steam App 34330) (Version: - The Creative Assembly)
TP-LINK Archer T2U_T2UH Driver (HKLM-x32\...\{F2496892-5295-4208-AB93-21F1AFD07C97}) (Version: 1.3.1 - TP-LINK)
TP-LINK Archer T6E Driver (HKLM-x32\...\{F2CF3250-3769-431E-A808-056BFA917849}) (Version: 1.3.1 - TP-LINK)
TP-LINK Wireless Configuration Utility (HKLM-x32\...\{319D91C6-3D44-436C-9F79-36C0D22372DC}) (Version: 1.3.1 - TP-LINK)
TradeSkillMaster Application version 1.0 (HKLM-x32\...\{c44da794-b956-4d50-8733-346d56ae63c7}_is1) (Version: 1.0 - TradeSkillMaster)
Ubisoft Game Launcher (HKLM-x32\...\{888F1505-C2B3-4FDE-835D-36353EBD4754}) (Version: 1.0.0.0 - UBISOFT)
UIInstallUpgrade (HKLM\...\{34755904-0831-4F83-BDDB-4395A581930D}) (Version: 2.3.1401 - Nahimic) Hidden
Uplay (HKLM-x32\...\Uplay) (Version: 21.1 - Ubisoft)
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.4 - VideoLAN)
Vulkan Run Time Libraries 1.0.26.0 (HKLM\...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
Vulkan Run Time Libraries 1.0.37.0 (HKLM\...\VulkanRT1.0.37.0) (Version: 1.0.37.0 - LunarG, Inc.)
War Thunder (HKLM\...\Steam App 236390) (Version: - Gaijin Entertainment)
WD Backup (HKLM-x32\...\{4AACAFC7-951A-4215-B430-3DFCFF2E6CED}) (Version: 1.5.5953.19614 - Western Digital Technologies, Inc) Hidden
WD Backup (HKLM-x32\...\{a8c9535a-ecd9-4172-a330-0cb5ff9dbed9}) (Version: 1.5.5953.19614 - Western Digital Technologies, Inc.)
WD Drive Utilities (HKLM-x32\...\{48996CDD-DD81-4197-93FE-0971E73C5CA7}) (Version: 1.3.2.2 - Western Digital Technologies, Inc.) Hidden
WD Drive Utilities (HKLM-x32\...\{eab1fb93-61fb-48de-b815-b4e9b68d2ef1}) (Version: 1.3.2.2 - Western Digital Technologies, Inc.)
WD Quick View (HKLM-x32\...\{965D28B5-3C86-41FD-994E-D6376815C9B3}) (Version: 2.4.10.17 - Western Digital Technologies, Inc.)
WD Security (HKLM-x32\...\{249644e6-451a-4a5c-bd5c-21eeb9eec79d}) (Version: 1.3.1.2 - Western Digital Technologies, Inc.)
WD Security (HKLM-x32\...\{7CC2EDF2-83EC-4707-BDD3-72469236A6CC}) (Version: 1.3.1.2 - Western Digital Technologies, Inc.) Hidden
WinPcap 4.1.3 (HKLM-x32\...\WinPcapInst) (Version: 4.1.0.2980 - Riverbed Technology, Inc.)
WinRAR 5.40 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
World of Warcraft (HKLM-x32\...\World of Warcraft) (Version: - Blizzard Entertainment)
Name: Unknown USB Device (Device Descriptor Request Failed)
Description: Unknown USB Device (Device Descriptor Request Failed)
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Manufacturer: (Standard USB Host Controller)
Service:
Device ID: USB\VID_0000&PID_0002\5&1216FCF8&0&2
Problem: : Windows has stopped this device because it has reported problems. (Code 43)
Resolution: One of the drivers controlling the device notified the operating system that the device failed in some manner. For more information about how to diagnose the problem, see the hardware documentation.
Name: Standard PS/2 Keyboard
Description: Standard PS/2 Keyboard
Class Guid: {4d36e96b-e325-11ce-bfc1-08002be10318}
Manufacturer: (Standard keyboards)
Service: i8042prt
Device ID: ACPI\PNP0303\0
Problem: : This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)
Resolution: The device is installed incorrectly. The problem could be a hardware failure, or a new driver might be needed.
Devices stay in this state if they have been prepared for removal.
After you remove the device, this error disappears.Remove the device, and this error should be resolved.
Name: Microsoft PS/2 Mouse
Description: Microsoft PS/2 Mouse
Class Guid: {4d36e96f-e325-11ce-bfc1-08002be10318}
Manufacturer: Microsoft
Service: i8042prt
Device ID: ACPI\PNP0F03\0
Name: High Definition Audio Controller
Description: High Definition Audio Controller
Class Guid: {4d36e97d-e325-11ce-bfc1-08002be10318}
Service: HDAudBus
Device ID: PCI\VEN_10DE&DEV_10F0&SUBSYS_85A01043&REV_A1\4&1BD5F278&0&0108
Problem: : This device is disabled. (Code 22)
Resolution: In Device Manager, click "Action", and then click "Enable Device". This starts the Enable Device wizard. Follow the instructions.
Percentage of memory in use: 18%
Total physical RAM: 24535.98 MB
Available physical RAM: 20025.94 MB
Total Virtual: 28119.98 MB
Available Virtual: 22149.69 MB
1 Drive c: (OS) (Fixed) (Total:465 GB) (Free:175.16 GB) NTFS
2 Drive d: (HDD ) (Fixed) (Total:1862.89 GB) (Free:1439.67 GB) NTFS
3 Drive e: (My Passport) (Fixed) (Total:931.48 GB) (Free:532.9 GB) NTFS
User accounts for \\JARVIS-PC
Jarvis
**** End of log ****
I have tried 2 different cat 5e ethernet cables. The speed is also limited to ~6Mbps when on WiFi.
Please run Farbar Recovery Scan Tool to give me a fresh look at your system.
  • Right-click on FRST icon and select Run as Administrator to start the tool.
    (XP users click run after receipt of Windows Security Warning - Open File).
  • Make sure that Addition option is checked, as well as Shortcut.txt
  • Press Scan button and wait.
  • The tool will produce three logfiles on your desktop: FRST.txt, and Addition.txt -- & Shortcut.txt
Please Copy & Paste them into your next reply. But attach Shortcut.txt
Make sure the settings are the same as the picture below, prior to scanning.
upload_2017-2-9_17-47-48-png.1541
Sorry its taking me so long to reply. I'm in the Navy and I work a lot so I don't have much time to fix things. Oh and i'm gonna be gone for the next couple days so please don't close this thread!!!!
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 05-02-2017
Ran by Jarvis (administrator) on JARVIS-PC (09-02-2017 18:06:45)
Running from C:\Users\Jarvis\Downloads
Loaded Profiles: Jarvis (Available Profiles: Jarvis)
Platform: Windows 10 Home Version 1607 (X64) Language: English (United States)
Internet Explorer Version 11 (Default browser: Chrome)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
() C:\Program Files (x86)\NZXT\CAM\Service\CAMService.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
(Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
(cFos Software GmbH) C:\Program Files\cFosSpeed\spd.exe
() C:\Program Files (x86)\ASUS\AXSP\1.02.00\atkexComSvc.exe
(Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
() C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.22\AsSysCtrlService.exe
(Micro-Star Int'l Co., Ltd.) C:\Program Files (x86)\MSI\Gaming APP\GamingApp_Service.exe
(Intel Corporation) C:\Windows\System32\IPROSetMonitor.exe
(Micro-Star INT'L CO., LTD.) C:\Program Files (x86)\MSI\Gaming APP\GamingHotkey_Service.exe
(Intel(R) Corporation) C:\Program Files\Intel\Intel(R) Online Connect Access\LegacyCsLoaderService.exe
(Intel(R) Corporation) C:\Program Files\Intel\Intel(R) Online Connect Access\IntelTechnologyAccessService.exe
(Micro-Star Int'l Co., Ltd.) C:\Program Files (x86)\MSI\MSI M-Cloud\MSI_Cloud_Service.exe
(Micro-Star INT'L CO., LTD.) C:\Program Files (x86)\MSI\MSI OC Kit\ActiveX_Service\MSI_ActiveX_Service.exe
(MSI) C:\Program Files (x86)\MSI\Fast Boot\FastBootService.exe
(MSI) C:\Program Files (x86)\MSI\Command Center\MSIControlService.exe
(Micro-Star INT'L CO., LTD.) C:\Program Files (x86)\MSI\Live Update\MSI_LiveUpdate_Service.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
(Bitdefender) C:\Program Files\Bitdefender Agent\ProductAgentService.exe
(Bitdefender) C:\Program Files\Bitdefender Antivirus Free\updatesrv.exe
(Bitdefender) C:\Program Files\Bitdefender Antivirus Free\vsserv.exe
(Bitdefender) C:\Program Files\Bitdefender Antivirus Free\vsservppl.exe
(Western Digital Technologies, Inc.) C:\Program Files (x86)\Western Digital\WD Drive Manager\WDDriveService.exe
(Microsoft Corporation) C:\Windows\SysWOW64\wbem\WmiPrvSE.exe
(Microsoft Corporation) C:\Windows\System32\wlanext.exe
(Intel Corporation) C:\Program Files\Intel\Intel(R) Online Connect\ioc.exe
(HP Inc.) C:\Program Files (x86)\Hewlett-Packard\HP Support Solutions\HPSupportSolutionsFrameworkService.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
(Intel(R) Corporation) C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\XtuService.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Integrated Clock Controller Service\ICCProxy.exe
(Dropbox, Inc.) C:\Windows\System32\DbxSvc.exe
(Electronic Arts) C:\Program Files (x86)\Origin\OriginWebHelperService.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
(Bitdefender) C:\Program Files\Bitdefender Antivirus Free\bdagent.exe
(MSI) C:\Windows\SysWOW64\muachost.exe
(Micro-Star INT'L CO., LTD.) C:\Program Files (x86)\MSI\Gaming APP\OSD\x86\MsiGamingOSD_x86.exe
(Micro-Star INT'L CO., LTD.) C:\Program Files (x86)\MSI\Gaming APP\OSD\x64\MsiGamingOSD_x64.exe
(Microsoft Corporation) C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\RemindersServer.exe
() C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.11.105.0_x64__kzf8qxf38zg5c\SkypeHost.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
(Microsoft Corporation) C:\Windows\System32\SettingSyncHost.exe
(Microsoft Corporation) C:\Windows\System32\smartscreen.exe
(Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
(Flux Software LLC) C:\Users\Jarvis\AppData\Local\FluxSoftware\Flux\flux.exe
() C:\Program Files\Nahimic\Nahimic2\UserInterface\Nahimic2UILauncher.exe
() C:\Program Files\Nahimic\Nahimic2\UserInterface\Nahimic2Svc32.exe
() C:\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2Svc64.exe
(Evernote Corp., 305 Walnut Street, Redwood City, CA 94063) C:\Program Files (x86)\Evernote\Evernote\EvernoteClipper.exe
(Western Digital Technologies, Inc.) C:\Program Files (x86)\Western Digital\WD Security\WDDriveAutoUnlock.exe
(Piriform Ltd) C:\Program Files\CCleaner\CCleaner64.exe
(Rainmeter) C:\Program Files\Rainmeter\Rainmeter.exe
(Western Digital Technologies, Inc.) C:\Program Files (x86)\Western Digital\WD Utilities\WDDriveUtilitiesHelper.exe
(Western Digital Technologies, Inc.) C:\Program Files (x86)\Western Digital\WD Quick View\WDDMStatus.exe
() C:\Program Files (x86)\NZXT\CAM\CAM_V3.exe
(Hewlett-Packard) C:\Program Files (x86)\HP\HP Software Update\hpwuschd2.exe
(Oracle Corporation) C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
(Western Digital Technologies, Inc.) C:\Program Files (x86)\Western Digital\WD App Manager\WDAppManager.exe
(Western Digital Technologies, Inc.) C:\Program Files (x86)\Western Digital\WD App Manager\Plugins\WD Backup\App\WDBackupService.exe
(Corsair Components, Inc.) C:\Program Files (x86)\Corsair\Corsair Utility Engine\CUE.exe
() C:\Program Files (x86)\NZXT\CAM\FPS\CAMFPS.exe
(Google Inc.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
(Node.js) C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
(Microsoft Corporation) C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\PlacesServer.exe
(Microsoft Corporation) C:\Windows\System32\InstallAgent.exe
(Google Inc.) C:\Users\Jarvis\AppData\Local\Google\Update\GoogleUpdate.exe
(Microsoft Corporation) C:\Windows\System32\InstallAgentUserBroker.exe
(Microsoft Corporation) C:\Windows\System32\rundll32.exe
==================== Registry (Whitelisted) ====================
HKLM\...\Run: [ShadowPlay] => "C:\WINDOWS\system32\rundll32.exe" C:\WINDOWS\system32\nvspcap64.dll,ShadowPlayOnSystemStart
HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe [9181696 2016-12-09] (Realtek Semiconductor)
HKLM\...\Run: [Nahimic2UILauncher] => C:\Program Files\Nahimic\Nahimic2\UserInterface\Nahimic2UILauncher.exe [705208 2017-01-13] ()
HKLM\...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [176440 2016-12-06] (Apple Inc.)
HKLM-x32\...\Run: [WD Drive Unlocker] => C:\Program Files (x86)\Western Digital\WD Security\WDDriveAutoUnlock.exe [1761120 2015-12-07] (Western Digital Technologies, Inc.)
HKLM-x32\...\Run: [DriveUtilitiesHelper] => C:\Program Files (x86)\Western Digital\WD Utilities\WDDriveUtilitiesHelper.exe [1890664 2016-01-14] (Western Digital Technologies, Inc.)
HKLM-x32\...\Run: [WD Quick View] => C:\Program Files (x86)\Western Digital\WD Quick View\WDDMStatus.exe [5564784 2015-02-12] (Western Digital Technologies, Inc.)
HKLM-x32\...\Run: [CAM] => C:\Program Files (x86)\NZXT\CAM\CAMLauncher.exe [47216 2017-01-17] ()
HKLM-x32\...\Run: [WDAppManager] => C:\Program Files (x86)\Western Digital\WD App Manager\AppManagerLauncher.exe [21384 2016-04-19] (Western Digital Technologies, Inc.)
HKLM-x32\...\Run: [HP Software Update] => C:\Program Files (x86)\Hp\HP Software Update\HPWuSchd2.exe [96056 2013-05-30] (Hewlett-Packard)
HKLM-x32\...\Run: [] => [X]
HKLM-x32\...\Run: [SunJavaUpdateSched] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [587288 2016-12-12] (Oracle Corporation)
HKLM-x32\...\Run: [Corsair Utility Engine] => C:\Program Files (x86)\Corsair\Corsair Utility Engine\CUE.exe [13178064 2017-01-12] (Corsair Components, Inc.)
HKLM-x32\...\Run: [Dropbox] => C:\Program Files (x86)\Dropbox\Client\Dropbox.exe [26220296 2017-02-06] (Dropbox, Inc.)
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\Run: [f.lux] => C:\Users\Jarvis\AppData\Local\FluxSoftware\Flux\flux.exe [1017224 2013-10-23] (Flux Software LLC)
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner64.exe [9292504 2016-12-21] (Piriform Ltd)
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\Run: [Google Update] => C:\Users\Jarvis\AppData\Local\Google\Update\1.3.32.7\GoogleUpdateCore.exe [601752 2017-01-28] (Google Inc.)
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\Run: [Spotify Web Helper] => C:\Users\Jarvis\AppData\Roaming\Spotify\SpotifyWebHelper.exe [1446000 2017-02-02] (Spotify Ltd)
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\Run: [NETGEARGenie] => C:\Program Files (x86)\NETGEAR Genie\bin\NETGEARGenie.exe [611584 2016-03-09] (NETGEAR Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt01] -> {FB314ED9-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt02] -> {FB314EDF-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt03] -> {FB314EE1-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt04] -> {FB314EDB-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt05] -> {FB314EDA-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt06] -> {FB314EDC-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt07] -> {FB314EDD-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt08] -> {FB314EE0-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt09] -> {FB314EE2-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ DropboxExt10] -> {FB314EDE-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt64.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers: [ GoogleDriveBlacklisted] -> {81539FE6-33C7-4CE7-90C7-1C7B8F2F2D42} => C:\Program Files (x86)\Google\Drive\googledrivesync64.dll [2016-11-30] (Google)
ShellIconOverlayIdentifiers: [ GoogleDriveSynced] -> {81539FE6-33C7-4CE7-90C7-1C7B8F2F2D40} => C:\Program Files (x86)\Google\Drive\googledrivesync64.dll [2016-11-30] (Google)
ShellIconOverlayIdentifiers: [ GoogleDriveSyncing] -> {81539FE6-33C7-4CE7-90C7-1C7B8F2F2D41} => C:\Program Files (x86)\Google\Drive\googledrivesync64.dll [2016-11-30] (Google)
ShellIconOverlayIdentifiers: [00avast] -> {472083B0-C522-11CF-8763-00608CC02F24} => -> No File
ShellIconOverlayIdentifiers-x32: [ DropboxExt01] -> {FB314ED9-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers-x32: [ DropboxExt02] -> {FB314EDF-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers-x32: [ DropboxExt03] -> {FB314EE1-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers-x32: [ DropboxExt04] -> {FB314EDB-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers-x32: [ DropboxExt05] -> {FB314EDA-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers-x32: [ DropboxExt06] -> {FB314EDC-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers-x32: [ DropboxExt07] -> {FB314EDD-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers-x32: [ DropboxExt08] -> {FB314EE0-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers-x32: [ DropboxExt09] -> {FB314EE2-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
ShellIconOverlayIdentifiers-x32: [ DropboxExt10] -> {FB314EDE-A251-47B7-93E1-CDD82E34AF8B} => C:\Program Files (x86)\Dropbox\Client\DropboxExt.14.0.dll [2017-02-06] (Dropbox, Inc.)
Startup: C:\Users\Jarvis\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\EvernoteClipper.lnk [2017-01-11]
ShortcutTarget: EvernoteClipper.lnk -> C:\Program Files (x86)\Evernote\Evernote\EvernoteClipper.exe (Evernote Corp., 305 Walnut Street, Redwood City, CA 94063)
Startup: C:\Users\Jarvis\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Rainmeter.lnk [2016-12-25]
ShortcutTarget: Rainmeter.lnk -> C:\Program Files\Rainmeter\Rainmeter.exe (Rainmeter)
GroupPolicy: Restriction <======= ATTENTION
Hosts: There are more than one entry in Hosts. See Hosts section of Addition.txt
Tcpip\Parameters: [DhcpNameServer] 68.105.28.11 68.105.29.11 68.105.28.12
Tcpip\..\Interfaces\{31fb6a44-ba34-4de7-b711-1033f0017e79}: [DhcpNameServer] 68.105.28.11 68.105.29.11 68.105.28.12
Tcpip\..\Interfaces\{3b910273-9ece-45c4-91e8-c99fcbed42dc}: [DhcpNameServer] 68.105.28.11 68.105.29.11 68.105.28.12
Tcpip\..\Interfaces\{9b9d86d9-9e15-4f0e-95bd-dee1bd2845c8}: [DhcpNameServer] 192.168.1.254
Internet Explorer:
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = about:blank
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL =
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL =
BHO-x32: Java(tm) Plug-In SSV Helper -> {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} -> C:\Program Files (x86)\Java\jre1.8.0_121\bin\ssv.dll [2017-01-24] (Oracle Corporation)
BHO-x32: Evernote extension -> {92EF2EAD-A7CE-4424-B0DB-499CF856608E} -> C:\Program Files (x86)\Evernote\Evernote\EvernoteIE.dll [2016-10-31] (Evernote Corp., 305 Walnut Street, Redwood City, CA 94063)
BHO-x32: Java(tm) Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files (x86)\Java\jre1.8.0_121\bin\jp2ssv.dll [2017-01-24] (Oracle Corporation)
FireFox:
FF ProfilePath: C:\Users\Jarvis\AppData\Roaming\Mozilla\Firefox\Profiles\dbtfb32b.default-1484071423074 [2017-02-08]
FF Plugin: @adobe.com/FlashPlayer -> C:\WINDOWS\system32\Macromed\Flash\NPSWF64_24_0_0_194.dll [2017-02-06] ()
FF Plugin: @Microsoft.com/NpCtrl,version=1.0 -> C:\Program Files\Microsoft Silverlight\5.1.50901.0\npctrl.dll [2016-08-31] ( Microsoft Corporation)
FF Plugin-x32: @adobe.com/FlashPlayer -> C:\WINDOWS\SysWoW64\Macromed\Flash\NPSWF32_24_0_0_194.dll [2017-02-06] ()
FF Plugin-x32: @java.com/DTPlugin,version=11.121.2 -> C:\Program Files (x86)\Java\jre1.8.0_121\bin\dtplugin\npDeployJava1.dll [2017-01-24] (Oracle Corporation)
FF Plugin-x32: @java.com/JavaPlugin,version=11.121.2 -> C:\Program Files (x86)\Java\jre1.8.0_121\bin\plugin2\npjp2.dll [2017-01-24] (Oracle Corporation)
FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 -> C:\Program Files (x86)\Microsoft Silverlight\5.1.50901.0\npctrl.dll [2016-08-31] ( Microsoft Corporation)
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-25] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2016-12-25] (Google Inc.)
FF Plugin-x32: @videolan.org/vlc,version=2.2.4 -> C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll [2016-06-01] (VideoLAN)
FF Plugin-x32: Adobe Reader -> C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2016-12-23] (Adobe Systems Inc.)
FF Plugin HKU\S-1-5-21-697782072-1053751190-176726198-1002: @tools.google.com/Google Update;version=3 -> C:\Users\Jarvis\AppData\Local\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2017-01-28] (Google Inc.)
FF Plugin HKU\S-1-5-21-697782072-1053751190-176726198-1002: @tools.google.com/Google Update;version=9 -> C:\Users\Jarvis\AppData\Local\Google\Update\1.3.32.7\npGoogleUpdate3.dll [2017-01-28] (Google Inc.)
Chrome:
CHR HomePage: Default -> hxxp://www.google.com
CHR StartupUrls: Default -> "hxxp://www.google.com/"
CHR Profile: C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default [2017-02-09]
CHR Extension: (Google Slides) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2016-06-11]
CHR Extension: (Google Docs) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake [2016-06-11]
CHR Extension: (Google Drive) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf [2016-06-11]
CHR Extension: (YouTube) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2016-06-11]
CHR Extension: (Honey) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\bmnlcjabgnpnenekpadlanbbkooimhnj [2017-02-05]
CHR Extension: (uBlock Origin) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\cjpalhdlnbpafiamejdnhcphjbkeiagm [2017-02-08]
CHR Extension: (Google Search) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\coobgpohoikkiipiblmjeljniedjpjpf [2016-06-11]
CHR Extension: (Adobe Acrobat) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2017-01-30]
CHR Extension: (Pandora) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\fbangkleohkafngihneedemihgfeikcl [2016-07-01]
CHR Extension: (Google Sheets) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2016-06-11]
CHR Extension: (Google Docs Offline) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2016-06-11]
CHR Extension: (Wolfram
Alpha (Official)) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\icncamkooinmbehmkeilcccmoljfkdhp [2016-07-01]
CHR Extension: (Stop Clickbait) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\iffolfpdcmehbghbamkgobjjdeejinma [2016-11-12]
CHR Extension: (Grammarly for Chrome) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\kbfnbcaeplbcioakkpcpgfkobkghlhen [2017-02-02]
CHR Extension: (Google Maps) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\lneaknkopdijkpnocmklfnjbeapigfbh [2016-07-01]
CHR Extension: (Chrome Web Store Payments) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2017-01-24]
CHR Extension: (Evernote Web Clipper) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\pioclpoplcdbaefihamjohnefbikjilc [2017-02-08]
CHR Extension: (Gmail) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2016-06-11]
CHR Extension: (Chrome Media Router) - C:\Users\Jarvis\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2017-02-06]
CHR HKLM\...\Chrome\Extension: [flliilndjeohchalpbbcdekjklbdgfkk] - hxxps://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [flliilndjeohchalpbbcdekjklbdgfkk] - hxxps://clients2.google.com/service/update2/crx
R2 acCAMService; C:\Program Files (x86)\NZXT\CAM\Service\CAMService.exe [27760 2017-01-03] ()
R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2016-09-22] (Apple Inc.)
R2 asComSvc; C:\Program Files (x86)\ASUS\AXSP\1.02.00\atkexComSvc.exe [936728 2014-07-22] ()
R2 AsSysCtrlService; C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.22\AsSysCtrlService.exe [1360016 2014-07-22] () [File not signed]
S3 BEService; C:\Program Files (x86)\Common Files\BattlEye\BEService.exe [1445384 2016-10-21] ()
R2 cFosSpeedS; C:\Program Files\cFosSpeed\spd.exe [726952 2015-09-28] (cFos Software GmbH)
S2 dbupdate; C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe [143144 2016-06-11] (Dropbox, Inc.)
S3 dbupdatem; C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe [143144 2016-06-11] (Dropbox, Inc.)
R2 DbxSvc; C:\WINDOWS\system32\DbxSvc.exe [46400 2017-02-06] (Dropbox, Inc.)
R2 GamingApp_Service; C:\Program Files (x86)\MSI\Gaming APP\GamingApp_Service.exe [45008 2016-09-29] (Micro-Star Int'l Co., Ltd.)
R2 GamingHotkey_Service; C:\Program Files (x86)\MSI\Gaming APP\GamingHotkey_Service.exe [2019792 2016-05-16] (Micro-Star INT'L CO., LTD.)
R2 HPSupportSolutionsFrameworkService; C:\Program Files (x86)\Hewlett-Packard\HP Support Solutions\HPSupportSolutionsFrameworkService.exe [31776 2016-12-06] (HP Inc.)
S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [987432 2016-07-26] (Intel(R) Corporation)
R3 Intel(R) Online Connect; C:\Program Files\Intel\Intel(R) Online Connect\ioc.exe [25824 2016-10-04] (Intel Corporation)
S2 Intel(R) Online Connect Helper; C:\Program Files\Intel\Intel(R) Online Connect\iocHelperService.exe [22752 2016-10-04] (Intel Corporation)
S3 Intel(R) Online Connect Software Asset Manager; C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [18152 2016-09-29] (Intel Corporation)
S4 Intel(R) Security Assist; C:\Program Files (x86)\Intel\Intel(R) Security Assist\isa.exe [335872 2015-05-19] (Intel Corporation) [File not signed]
R2 Intel(R) TechnologyAccessLegacyCSLoader; C:\Program Files\Intel\Intel(R) Online Connect Access\LegacyCsLoaderService.exe [173288 2016-10-05] (Intel(R) Corporation)
R2 Intel(R) TechnologyAccessService; C:\Program Files\Intel\Intel(R) Online Connect Access\IntelTechnologyAccessService.exe [496872 2016-10-05] (Intel(R) Corporation)
S2 isaHelperSvc; C:\Program Files (x86)\Intel\Intel(R) Security Assist\isaHelperService.exe [7680 2015-05-19] () [File not signed]
R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [177440 2016-10-20] (Intel Corporation)
S3 MSIClock_CC; C:\Program Files (x86)\MSI\Command Center\ClockGen\MSIClockService.exe [2169440 2016-11-23] (MSI)
S3 MSICOMM_CC; C:\Program Files (x86)\MSI\Command Center\MSICommService.exe [2204768 2016-09-29] (MSI)
S3 MSICPU_CC; C:\Program Files (x86)\MSI\Command Center\CPU\MSICPUService.exe [4171360 2016-11-23] (MSI)
R2 MSICTL_CC; C:\Program Files (x86)\MSI\Command Center\MSIControlService.exe [2014816 2016-11-15] (MSI)
S2 MSIDDR_CC; C:\Program Files (x86)\MSI\Command Center\DDR\MSIDDRService.exe [2327648 2016-11-23] (MSI)
S3 MSISMB_CC; C:\Program Files (x86)\MSI\Command Center\SMBus\MSISMBService.exe [2076768 2016-09-29] (MSI)
S3 MSISuperIO_CC; C:\Program Files (x86)\MSI\Command Center\SuperIO\MSISuperIOService.exe [607160 2016-09-29] (MSI)
R2 MSI_ActiveX_Service; C:\Program Files (x86)\MSI\MSI OC Kit\ActiveX_Service\MSI_ActiveX_Service.exe [78776 2016-11-09] (Micro-Star INT'L CO., LTD.)
R2 MSI_Cloud_Service; C:\Program Files (x86)\MSI\MSI M-Cloud\MSI_Cloud_Service.exe [98640 2015-09-17] (Micro-Star Int'l Co., Ltd.)
R2 MSI_FastBoot; C:\Program Files (x86)\MSI\Fast Boot\FastBootService.exe [105296 2015-06-04] (MSI)
R2 MSI_LiveUpdate_Service; C:\Program Files (x86)\MSI\Live Update\MSI_LiveUpdate_Service.exe [2237392 2016-11-10] (Micro-Star INT'L CO., LTD.)
S3 NETGEARGenieDaemon; C:\Program Files (x86)\NETGEAR Genie\bin\NETGEARGenieDaemon64.exe [232192 2016-03-09] (NETGEAR)
R2 NvContainerLocalSystem; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [462784 2017-01-20] (NVIDIA Corporation)
S3 NvContainerNetworkService; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [462784 2017-01-20] (NVIDIA Corporation)
R2 NVDisplay.ContainerLocalSystem; C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe [464440 2017-01-20] (NVIDIA Corporation)
R2 NvTelemetryContainer; C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe [425408 2017-01-20] (NVIDIA Corporation)
S3 Origin Client Service; C:\Program Files (x86)\Origin\OriginClientService.exe [2122248 2017-02-08] (Electronic Arts)
R2 Origin Web Helper Service; C:\Program Files (x86)\Origin\OriginWebHelperService.exe [2184208 2017-02-08] (Electronic Arts)
R2 ProductAgentService; C:\Program Files\Bitdefender Agent\ProductAgentService.exe [1100392 2016-10-28] (Bitdefender)
S3 rpcapd; C:\Program Files (x86)\WinPcap\rpcapd.exe [118520 2013-02-28] (Riverbed Technology, Inc.)
R2 updatesrv; C:\Program Files\Bitdefender Antivirus Free\updatesrv.exe [100392 2016-12-05] (Bitdefender)
R2 vsserv; C:\Program Files\Bitdefender Antivirus Free\vsserv.exe [100392 2016-12-05] (Bitdefender)
R2 vsservppl; C:\Program Files\Bitdefender Antivirus Free\vsservppl.exe [100392 2016-12-05] (Bitdefender)
R2 WDDriveService; C:\Program Files (x86)\Western Digital\WD Drive Manager\WDDriveService.exe [308088 2015-12-07] (Western Digital Technologies, Inc.)
S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [347328 2016-07-16] (Microsoft Corporation)
S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [103720 2016-07-16] (Microsoft Corporation)
R2 XTU3SERVICE; C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\XtuService.exe [18232 2016-10-20] (Intel(R) Corporation)
S3 WD Backup Drive Helper; C:\Windows\SysWOW64\dllhost.exe /Processid:{4AB831D3-8315-414C-8A7A-303105288D0B}
S3 WD Backup Snapshot; C:\Windows\SysWOW64\dllhost.exe /Processid:{302480DF-3AC5-4400-BE7B-DD77AF93B6DD}
R1 AsIO; C:\Windows\SysWow64\drivers\AsIO.sys [15232 2014-07-22] ()
R0 avc3; C:\WINDOWS\System32\DRIVERS\avc3.sys [1605376 2016-09-20] (BitDefender)
R3 avckf; C:\WINDOWS\System32\DRIVERS\avckf.sys [878072 2016-09-20] (BitDefender)
R3 BCM43XX; C:\WINDOWS\system32\DRIVERS\bcmwl63a.sys [7546544 2014-12-09] (Broadcom Corporation)
S0 bdelam; C:\WINDOWS\System32\drivers\bdelam.sys [23672 2016-03-14] (Bitdefender)
R1 bdfwfpf; C:\Program Files\Bitdefender Antivirus Free\bdfwfpf.sys [127312 2016-02-22] (BitDefender LLC)
R3 CH341SER_A64; C:\WINDOWS\System32\Drivers\CH341S64.SYS [59904 2015-01-25] (www.winchiphead.com)
R3 CorsairVBusDriver; C:\WINDOWS\System32\drivers\CorsairVBusDriver.sys [54256 2016-12-10] (Corsair)
R3 CorsairVHidDriver; C:\WINDOWS\System32\drivers\CorsairVHidDriver.sys [29168 2016-12-10] (Corsair)
R3 cpuz141; C:\Users\Jarvis\AppData\Local\Temp\cpuz141\cpuz141_x64.sys [46400 2017-02-08] (CPUID) <==== ATTENTION
R3 e1dexpress; C:\WINDOWS\system32\DRIVERS\e1d65x64.sys [543184 2016-07-26] (Intel Corporation)
R3 edrsensor; C:\WINDOWS\System32\DRIVERS\edrsensor.sys [342016 2017-01-11] (BitDefender S.R.L. Bucharest, ROMANIA)
R1 ESProtectionDriver; C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.sys [74984 2016-07-28] ()
R0 gzflt; C:\WINDOWS\System32\drivers\gzflt.sys [182944 2016-12-05] (BitDefender LLC)
R3 I2cHkBurn; C:\WINDOWS\system32\drivers\I2cHkBurn.sys [41760 2015-07-26] (FINTEK Corp.)
R3 iaLPSS2_GPIO2; C:\WINDOWS\System32\drivers\iaLPSS2_GPIO2.sys [89912 2016-08-29] (Intel Corporation)
R3 iaLPSS2_I2C; C:\WINDOWS\System32\drivers\iaLPSS2_I2C.sys [184632 2016-08-29] (Intel Corporation)
R3 iaLPSS2_UART2; C:\WINDOWS\System32\drivers\iaLPSS2_UART2.sys [282424 2016-08-29] (Intel Corporation)
R2 iocbios2; C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\Drivers\IocDriver\64bit\iocbios2.sys [37064 2016-08-24] (Intel Corporation)
R1 ndisrd; C:\WINDOWS\system32\DRIVERS\ndisrfl.sys [59792 2016-09-13] (Intel Corporation)
S3 NetAdapterCx; C:\WINDOWS\System32\drivers\NetAdapterCx.sys [90624 2016-07-16] ()
R2 NPF; C:\WINDOWS\system32\drivers\npf.sys [35344 2017-02-05] (CACE Technologies, Inc.)
R3 NTIOLib_ACTIVE_X; C:\Program Files (x86)\MSI\MSI OC Kit\ActiveX_Service\NTIOLib_X64.sys [13776 2016-04-12] (MSI)
R3 NTIOLib_FastBoot; C:\Program Files (x86)\MSI\Fast Boot\NTIOLib_X64.sys [13368 2012-10-26] (MSI)
R3 nvlddmkm; C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_02838dee03d82b94\nvlddmkm.sys [14427064 2017-01-21] (NVIDIA Corporation)
S3 NvStreamKms; C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamKms.sys [27584 2017-01-20] (NVIDIA Corporation)
R3 nvvad_WaveExtensible; C:\WINDOWS\system32\drivers\nvvad64v.sys [47672 2017-01-05] (NVIDIA Corporation)
R3 nvvhci; C:\WINDOWS\System32\drivers\nvvhci.sys [57792 2017-01-20] (NVIDIA Corporation)
S3 pmxdrv; C:\WINDOWS\system32\drivers\pmxdrv.sys [31152 2017-01-10] ()
R1 RawDisk3; C:\Windows\system32\drivers\rawdsk3.sys [41576 2016-02-19] (EldoS Corporation)
S3 S3XXx64; C:\WINDOWS\system32\DRIVERS\S3XXx64.sys [73856 2015-02-17] (Identiv) [File not signed]
S3 semav6msr64; C:\WINDOWS\system32\drivers\semav6msr64.sys [21984 2016-10-18] ()
S3 ssdevfactory; C:\WINDOWS\System32\drivers\ssdevfactory.sys [25088 2015-04-14] (SteelSeries ApS)
R2 trufos; C:\WINDOWS\System32\drivers\trufos.sys [520032 2016-06-22] (BitDefender S.R.L.)
S3 USBAAPL64; C:\WINDOWS\System32\Drivers\usbaapl64.sys [54784 2015-11-05] (Apple, Inc.) [File not signed]
S3 WdBoot; C:\WINDOWS\system32\drivers\WdBoot.sys [44056 2016-07-16] (Microsoft Corporation)
S3 WdFilter; C:\WINDOWS\system32\drivers\WdFilter.sys [290144 2016-07-16] (Microsoft Corporation)
S3 WdNisDrv; C:\WINDOWS\System32\Drivers\WdNisDrv.sys [123232 2016-07-16] (Microsoft Corporation)
R3 WinRing0_1_2_0; C:\Program Files (x86)\NZXT\CAM\CAM_V3.sys [14544 2017-02-08] (OpenLibSys.org)
S3 dbx; system32\DRIVERS\dbx.sys [X]
S4 NVHDA; \SystemRoot\system32\drivers\nvhda64v.sys [X]
========================== Drivers MD5 =======================
C:\WINDOWS\System32\drivers\1394ohci.sys A7901875F89D011C38CF52C98ACF5B29
C:\WINDOWS\System32\drivers\3ware.sys EE1CCC54F75C24727A218F98FC5349DA
C:\WINDOWS\System32\drivers\ACPI.sys 73C73E1AA0D4D727A04AAAB120B7F56A
C:\WINDOWS\System32\drivers\AcpiDev.sys 0935496EF9624B46B935CB35ECE1F205
C:\WINDOWS\System32\Drivers\acpiex.sys D6794C31F4077B71433988787BAA926E
C:\WINDOWS\System32\drivers\acpipagr.sys FE5F656D6B35089DA39112E74EC6A85A
C:\WINDOWS\System32\drivers\acpipmi.sys 2F242941E4DFF69B883D77A16F039557
C:\WINDOWS\System32\drivers\acpitime.sys C247E35A21682DA8D0DC3AF9F025FCC5
C:\WINDOWS\System32\drivers\ADP80XX.SYS 49B9DB97AFC85DCCBDACDAB2E90085B7
C:\WINDOWS\system32\drivers\afd.sys 323AA1953ED9C01E23F740FA891FE064
C:\WINDOWS\System32\DRIVERS\ahcache.sys 23522E5D581F7722B1B5B86737CAE39C
C:\WINDOWS\System32\drivers\amdk8.sys DF21E05E41E5AC3F13F304D91457649A
C:\WINDOWS\System32\drivers\amdppm.sys 45D0AA4BB90B821DF92E8F19ABED0C5E
C:\WINDOWS\System32\drivers\amdsata.sys 74FFBC43B4B899C9A8CA06A892F2CE73
C:\WINDOWS\System32\drivers\amdsbs.sys AAB0F1D8D7E54761ABAB13AF161F1680
C:\WINDOWS\System32\drivers\amdxata.sys F91BAAC4237C40352A807000F3B716F9
C:\WINDOWS\System32\drivers\appid.sys BC121C099C6C659126AD2102AFDFF8CF
C:\WINDOWS\System32\drivers\applockerfltr.sys 68190E2BADF23BD782344970E5B5DE9E
C:\WINDOWS\System32\drivers\arcsas.sys E6AB1F0B4C3D4E0D2A88332D76FECD03
C:\Windows\SysWow64\drivers\AsIO.sys 798DE15F187C1F013095BBBEB6FB6197
C:\WINDOWS\System32\drivers\asmthub3.sys A750BB0FA32D1CC1E0FC740F09BBA3FD
C:\WINDOWS\System32\drivers\asmtxhci.sys 3054586B131D04D2E8796806CA581361
C:\WINDOWS\System32\drivers\asyncmac.sys 61C5A480C43E7E8E49C42869F49D0D3E
C:\WINDOWS\System32\drivers\atapi.sys A10F989A812B57B9695F6C305907C9C6
C:\WINDOWS\System32\DRIVERS\avc3.sys DA978AB6E0AAEA82235C943DEED3484C
C:\WINDOWS\System32\DRIVERS\avckf.sys 09A3015AEA14CF9A4ECDE1CEA6AFE0AA
C:\WINDOWS\System32\drivers\bxvbda.sys 61BAC67048CA5C1D08C48FCC8012B613
C:\WINDOWS\System32\drivers\BasicDisplay.sys 68F72B05EBC6D1779C0D60A147C7CA0B
C:\WINDOWS\System32\drivers\BasicRender.sys 23156E7EDAF613D839E2839746B168D3
C:\WINDOWS\system32\DRIVERS\bcmwl63a.sys 833824639D5B60AFC6B2926C84DBB01B
C:\WINDOWS\System32\drivers\bcmfn.sys 3F5523DCEFE42B385659C5CB46A6B810
C:\WINDOWS\System32\drivers\bcmfn2.sys 0B750A6A6D847E73CA48ADD7A0F5A393
C:\WINDOWS\System32\drivers\bdelam.sys 4B190ACAE90EC79AD4D43EFCD3743DA0
C:\Program Files\Bitdefender Antivirus Free\bdfwfpf.sys BCC56866F6A9BD35B2BC4787787C1F32
C:\Windows\System32\Drivers\Beep.sys 0A508274355745EEF01C6BE3198D02C4
C:\WINDOWS\System32\DRIVERS\bowser.sys 9CD2A4821DE379305CACB2E99AD8953A
C:\WINDOWS\System32\drivers\BthAvrcpTg.sys 722036C26D2C4E50EC2A2EC5FD678846
C:\WINDOWS\System32\drivers\bthhfenum.sys C2E31BE025D46D189E38DD1EDF07837A
C:\WINDOWS\System32\drivers\BthHFHid.sys F7CD605FC0B0B22F3F6F247595E3A655
C:\WINDOWS\System32\drivers\bthmodem.sys 535DC41A33630AE4C262406F9E981C03
C:\WINDOWS\System32\drivers\buttonconverter.sys 23F9EF739F685E07482116425E7879AA
C:\WINDOWS\System32\drivers\capimg.sys 60EB6A4CE3E21887D302350631C16F26
C:\WINDOWS\System32\DRIVERS\cdfs.sys F8FB51B9EF6372610E9B31A1D86B62FC
C:\WINDOWS\System32\drivers\cdrom.sys 613D0137C269187FA298A157E3D14A18
C:\WINDOWS\system32\DRIVERS\cfosspeed6.sys 3954D9FAD8FCCB05116C64D458428161
C:\WINDOWS\System32\Drivers\CH341S64.SYS 3C0A1B6F538E00F318C109F4A3F29515
C:\WINDOWS\System32\drivers\cht4sx64.sys 0AED948DA8D5F08B3D6F12E4E2089736
C:\WINDOWS\System32\drivers\cht4vx64.sys 0002A0FDE087C1657AB31CE73077539C
C:\WINDOWS\System32\drivers\circlass.sys 6B4F90A287D75CCD78694F6790C911B2
C:\WINDOWS\System32\drivers\CLFS.sys B72D26074E72A757D788FB1BEF8B2F2E
C:\WINDOWS\System32\drivers\registry.sys EEC3A4A98AE1A337E3CD1483AD6F2E15
C:\WINDOWS\System32\drivers\CmBatt.sys 429623E266EF067A44E8CF148E9DFB9B
C:\WINDOWS\System32\Drivers\cng.sys 90C07EB909C42316982E753BDAA7860D
C:\WINDOWS\System32\DRIVERS\cnghwassist.sys 3DB10C59405931E2C72EFB82C1AF97D1
C:\WINDOWS\System32\DriverStore\FileRepository\compositebus.inf_amd64_a140581a8f8b58b7\CompositeBus.sys 34C935AF2A414572B412B3556586D783
C:\WINDOWS\System32\drivers\condrv.sys 44EEEB2382F566999287E13F2067693C
C:\WINDOWS\System32\drivers\CorsairVBusDriver.sys 336EC68D2FEBA9233CACC2DF09D12771
C:\WINDOWS\System32\drivers\CorsairVHidDriver.sys BB696EAC9209A95DF6910C34395ADE46
C:\Users\Jarvis\AppData\Local\Temp\cpuz141\cpuz141_x64.sys DB72DEF618CBC3C5F9AA82F091B54250
C:\WINDOWS\System32\drivers\dam.sys 039B5A8CBD5C75D1C46DF15F7C74D136
C:\WINDOWS\System32\Drivers\dfsc.sys 0D1D392ED2597F295956D058D33BD7C3
C:\WINDOWS\System32\drivers\disk.sys 35B9D46560339A5A7F0CAC6ED702C817
C:\WINDOWS\System32\drivers\dmvsc.sys 815F45161A4571C2C44491564F3D5968
C:\WINDOWS\system32\DRIVERS\drmkaud.sys AE6BD4C879A8C849E53947C92DF3B3A0
C:\WINDOWS\System32\drivers\dxgkrnl.sys 19F2B54EE8861D90579BD0E3AE5182F9
C:\WINDOWS\system32\DRIVERS\e1d65x64.sys 7FB6913DBAE787A946790FF0835714B8
C:\WINDOWS\System32\drivers\e1i63x64.sys 83E4A14F851341C933C3235BFB882ECA
C:\WINDOWS\System32\drivers\evbda.sys 7EC6FC0266D74BD47ABB130A328B70EC
C:\WINDOWS\System32\DRIVERS\edrsensor.sys 321F80E2E6DA91EEFAE6DF1C090FE1CA
C:\WINDOWS\System32\drivers\EhStorClass.sys 8D74B8B5D6F7C5BC4C525BAF2B083FF1
C:\WINDOWS\System32\drivers\EhStorTcgDrv.sys 2A9817B5A9260D8F60D52E36BEF10443
C:\WINDOWS\System32\drivers\errdev.sys 77B60DEC7DCB4233E4A69D3F52E5DB24
C:\Program Files (x86)\Malwarebytes Anti-Exploit\mbae64.sys 32710ECBE3C17C6F769BAC88CD1756FF
C:\Windows\System32\Drivers\exfat.sys FCD2C63754C2E739A8EEAD9BC63F9DDC
C:\Windows\System32\Drivers\fastfat.sys FA918EC296EB410FF02867D008D02421
C:\WINDOWS\System32\drivers\fdc.sys 99598ECA5E41996E005D5B9D9FF1EFA2
C:\WINDOWS\System32\drivers\filecrypt.sys F44F666B0EACC3181544FFCF8CA0FFC7
C:\WINDOWS\System32\drivers\fileinfo.sys 78A210DDFDF2C9EC884631D2DAA573F0
C:\WINDOWS\System32\drivers\filetrace.sys 1A97DB5E701A186989F3795223C3BE39
C:\WINDOWS\System32\drivers\flpydisk.sys 46626665F0E5906E45619B4EFD6186B8
C:\WINDOWS\System32\drivers\fltmgr.sys FDA72ACA14D516D18C33AFCD0FD9260F
C:\WINDOWS\System32\drivers\FsDepends.sys D152CCBFC8251670BF0AAFE00D6BC782
C:\Windows\System32\Drivers\Fs_Rec.sys 6D6BB5C7363CD35FA715E826F3D029EE
C:\WINDOWS\System32\DRIVERS\fvevol.sys 8EEC4925C03E375C4EC496E45C44139A
C:\WINDOWS\System32\drivers\vmgencounter.sys EF78034773CE506323655A868C949144
C:\WINDOWS\System32\drivers\genericusbfn.sys B55FEBC6A00DAA1FE074F020B6907516
C:\WINDOWS\System32\Drivers\msgpioclx.sys DDD8A8CDDC7F13EF57D1DAAE71865936
C:\WINDOWS\System32\drivers\gpuenergydrv.sys 7ACD8F69B5D6EC97E6D2C006E19BED88
C:\WINDOWS\System32\drivers\gzflt.sys F72818A52CBB5A9E8B2C9E350638A945
C:\WINDOWS\system32\DRIVERS\HdAudio.sys 217230B984AB2954E2FA5E36578D7B08
C:\WINDOWS\System32\drivers\HDAudBus.sys 10E3515FE5DBA6656FA62C29342EC4A1
C:\WINDOWS\System32\drivers\HidBatt.sys B90D284B97CD4CA9DE7430AAAD887A56
C:\WINDOWS\System32\drivers\hidbth.sys B2FE11643CC6ACDEE6C247DD36018FDB
C:\WINDOWS\System32\drivers\hidi2c.sys D24355488A2D4D2323518EC1AC7A6D9E
C:\WINDOWS\System32\drivers\hidinterrupt.sys 0AF9ABBA4F3F55C6C803890D64BC3C29
C:\WINDOWS\System32\drivers\hidir.sys CDBCF8E9AB06D88A1E1191D32F320C5D
C:\WINDOWS\System32\drivers\hidusb.sys D8536CB438CC4CCDAE047B768EED22B2
C:\WINDOWS\System32\drivers\HpSAMD.sys F5CA18197B4646E04DB9EB2D6642CC4D
C:\WINDOWS\System32\drivers\HTTP.sys A10C7C1E69FC90620C7BF2E51302A01F
C:\WINDOWS\System32\drivers\hvservice.sys 74FC79C52395B10FFD0B55CF22CF88FC
C:\WINDOWS\System32\drivers\hwpolicy.sys 771EDDA9830A3079F996F34D681FB6E5
C:\WINDOWS\System32\drivers\hyperkbd.sys 3B9F315E7FA72CC25228EB097DD9C694
C:\WINDOWS\system32\drivers\I2cHkBurn.sys 38C20EBB2621A86A5E9729EDA8F0F126
C:\WINDOWS\System32\drivers\i8042prt.sys B54B30992620C97230013A74461C8517
C:\WINDOWS\System32\drivers\iagpio.sys C6B8743B213F06AA60943D8366FE968F
C:\WINDOWS\System32\drivers\iai2c.sys 9A2A2F3C69B9A30B6E78536F6D258BAD
C:\WINDOWS\System32\drivers\iaLPSS2i_GPIO2.sys 5A0E850F8CD17791A3E6A3CF81D0CA28
C:\WINDOWS\System32\drivers\iaLPSS2i_I2C.sys 7508F1096803385D6376BFD0BD473AC4
C:\WINDOWS\System32\drivers\iaLPSS2_GPIO2.sys 456C87D2EB2ADC2F3DBA6667897BD393
C:\WINDOWS\System32\drivers\iaLPSS2_I2C.sys E2C14D6C31F27C4C370E41484674BD81
C:\WINDOWS\System32\drivers\iaLPSS2_UART2.sys 641D449D8CFB2ACDBF4D09B4E17AD537
C:\WINDOWS\System32\drivers\iaLPSSi_GPIO.sys 16A10CCEDCF5AC4CAAE43DC9FC40392F
C:\WINDOWS\System32\drivers\iaLPSSi_I2C.sys EB82A11613326691508D9ED9A4FE29E7
C:\WINDOWS\System32\drivers\iaStorAV.sys 97E553D03219D3D51705C7235D9EAEBD
C:\WINDOWS\System32\drivers\iaStorV.sys 8350FE3BCDE3428BC040877BB7E9EAEB
C:\WINDOWS\System32\drivers\ibbus.sys 3BA03F7C7700DDF4C383DDE9252F5817
C:\WINDOWS\System32\drivers\ICCWDT.sys 231ADCE77616144B8E3D29707B282C82
C:\WINDOWS\System32\drivers\IndirectKmd.sys 2A01C96DF5802D3434634E55C91232D8
C:\WINDOWS\system32\drivers\RTKVHD64.sys 407AC81C2A6A43DAB69E485AF17FEE02
C:\WINDOWS\System32\drivers\intelide.sys 9F7E87F6595D065A8A200A291043045E
C:\WINDOWS\System32\drivers\intelpep.sys A6BD2E20AE1BC5CB2776C87C28E4F4CA
C:\WINDOWS\System32\drivers\intelppm.sys 2A48DA39542636DB0FA3BA915385D1B3
C:\Program Files (x86)\Intel\Intel(R) Extreme Tuning Utility\Drivers\IocDriver\64bit\iocbios2.sys 1619EE2C1FC5684C526D6F0D7DD40F50
C:\WINDOWS\System32\drivers\iorate.sys DB32758F3A7F6CCE81A5430080A2EA65
C:\WINDOWS\System32\DRIVERS\ipfltdrv.sys FE85D0A86CA7A5A99CF8CD04DE7F80AE
C:\WINDOWS\System32\drivers\IPMIDrv.sys 450DBDD716C7911F83E05F78EE18BFA2
C:\WINDOWS\System32\drivers\ipnat.sys F1DAECC3B3D6399875D4F10529D6A77C
C:\WINDOWS\system32\drivers\irda.sys 7475A2903BB704B446AA6309E34D3362
C:\WINDOWS\System32\drivers\irenum.sys 9725E7F0C64CE9916A5CDABE8D6E13C3
C:\WINDOWS\System32\drivers\isapnp.sys 58040898883A96160D41739C80328BBF
C:\WINDOWS\System32\drivers\msiscsi.sys C9FD02D62E09337B67B0C61EC8CA38CC
C:\WINDOWS\System32\drivers\kbdclass.sys 210808437570BDDEE71A43535E3A2D30
C:\WINDOWS\System32\drivers\kbdhid.sys 0B779E9FC426CA2268D28181FA6C222F
C:\WINDOWS\System32\drivers\kdnic.sys 813BA3EB2CE038F2A5382DDD75CAD60B
C:\WINDOWS\System32\Drivers\ksecdd.sys 705C0F8BCCEF6E7CB704CCB454192D7E
C:\WINDOWS\System32\Drivers\ksecpkg.sys 55AD13E2BAFC5AB53A10F8C271F5D242
C:\WINDOWS\system32\drivers\ksthunk.sys 4ED115CD1A1099705F56B5E0FFF97CC6
C:\WINDOWS\System32\drivers\lltdio.sys 5933A6673F00D8255C52957E40C2D601
C:\WINDOWS\System32\drivers\lsi_sas.sys 8E1B0946948CCC0BC1FA3CB70374A795
C:\WINDOWS\System32\drivers\lsi_sas2i.sys 4F68163FC04C973500DC4DA0946917B0
C:\WINDOWS\System32\drivers\lsi_sas3i.sys E5AC5F2815938651CDCC27F425474673
C:\WINDOWS\System32\drivers\lsi_sss.sys CCF6EC9FB9B8F18E05B4253E81013E48
C:\WINDOWS\system32\drivers\luafv.sys C9579D32219E5B936AC3A48D470117EC
C:\WINDOWS\system32\DRIVERS\lvrs64.sys A0A527569856B9814E8920F52EBB67F5
C:\WINDOWS\system32\DRIVERS\lvuvc64.sys 415E344294D1C0D04627B29146F68481
C:\WINDOWS\System32\drivers\megasas.sys C3CDCCF07486BD2616A7B82946E07AC0
C:\WINDOWS\System32\drivers\MegaSas2i.sys 2CF0CB2A0ED68C5455371E84C16F9627
C:\WINDOWS\System32\drivers\megasr.sys FADB2FE017E69EECE0E1BA78661C2E8C
C:\WINDOWS\System32\drivers\TeeDriverW8x64.sys C4A4BE9C6EDA9640F272B48FC0AB4F06
C:\WINDOWS\System32\drivers\mlx4_bus.sys FD60818B66B2E8A5415EA840E99A9D8F
C:\WINDOWS\system32\drivers\mmcss.sys 68F6977F1CFBAAC770D940A8C0326FA1
C:\WINDOWS\System32\drivers\modem.sys 0D50B3F3AB32D416786B58D4553859CE
C:\WINDOWS\System32\drivers\monitor.sys 9CCCB7FC3EDADEBA461D78615A6011A6
C:\WINDOWS\System32\drivers\mouclass.sys 27A07B2FB2E3057DA8DAEA4F25D843C7
C:\WINDOWS\System32\drivers\mouhid.sys 7BD6E7F7C9001AB21B8362CFFEE80B25
C:\WINDOWS\System32\drivers\mountmgr.sys F5BDAEE4B7D369D4C74668DCFBA3FF10
C:\WINDOWS\System32\drivers\mpsdrv.sys 30844BD376F9D01E62C820BEF446F1F8
C:\WINDOWS\system32\drivers\mrxdav.sys 25D32BE04FE0A23FDF57FD5382757672
C:\WINDOWS\System32\DRIVERS\mrxsmb.sys E671EDAB0726E05ECEF4058B4CD73C4D
C:\WINDOWS\System32\DRIVERS\mrxsmb10.sys D4D12BC29DE0F09280868FDCA65B3474
C:\WINDOWS\System32\DRIVERS\mrxsmb20.sys 93A77008A8932FC84A173C4E97E52874
C:\WINDOWS\System32\drivers\bridge.sys 74C9D21523DAE0C18F413C196DF0058A
C:\Windows\System32\Drivers\Msfs.sys F01B849D9D4A8CEAF32D4FDBD0B83C92
C:\WINDOWS\System32\drivers\msgpiowin32.sys 22ECD8F5D1DFADF2011BBB1700CB871D
C:\WINDOWS\System32\drivers\mshidkmdf.sys FD870F6968A145E4D2BA8A8842686B03
C:\WINDOWS\System32\drivers\mshidumdf.sys 30364757963A028CE5DF0FBAAC270173
C:\WINDOWS\System32\drivers\msisadrv.sys 6BB0FEDDAE7135FA37FFAFF4D9E0E876
C:\WINDOWS\system32\DRIVERS\MSKSSRV.sys 13D614E6B51ECF36746C48CE829FA7F6
C:\WINDOWS\System32\drivers\mslldp.sys 642CDE46351D5D2D90311E77072AB46D
C:\WINDOWS\system32\DRIVERS\MSPCLOCK.sys F2302A5CE63CA7673200FAFCEEEDB6AF
C:\WINDOWS\system32\DRIVERS\MSPQM.sys 6114512EA26E835BA522C63635429DB5
C:\Windows\System32\Drivers\MsRPC.sys AA538E16E644D00E3BA5349BBA9598EC
C:\WINDOWS\System32\drivers\mssmbios.sys 0543BEFD41EC4D25C7F7CF36409CEC7D
C:\WINDOWS\system32\DRIVERS\MSTEE.sys C1569E4DB8EFE3617847BF041A3C842F
C:\WINDOWS\System32\drivers\MTConfig.sys 130B16970154BA9876B09E5C4BAC63BE
C:\WINDOWS\System32\Drivers\mup.sys 15D987C8F6CCD4AC94E070C5986762CB
C:\WINDOWS\System32\drivers\mvumis.sys 3D2C5B4995CA0751D32DEA0DE9FDFE44
C:\WINDOWS\System32\DRIVERS\nwifi.sys DB31EBB04C871F422C36A0962DA7D38B
C:\WINDOWS\System32\drivers\ndfltr.sys 629CB21AC49C8867E0F29DF1C16DB7B4
C:\WINDOWS\System32\drivers\ndis.sys D5564FC81350458ED570528C4E3B1CCF
C:\WINDOWS\System32\drivers\ndiscap.sys 6DD605338FAAF6BA17662AA874E0D162
C:\WINDOWS\System32\drivers\NdisImPlatform.sys E34196F285F8B8879E1FF36C31F7179E
C:\WINDOWS\system32\DRIVERS\ndisrfl.sys 7AAE5671C49AC344B1B83EC893D5B7CD
C:\WINDOWS\System32\DRIVERS\ndistapi.sys 1FAD2398673F30CEC616B89C46B7DCBA
C:\WINDOWS\System32\drivers\ndisuio.sys AEB8ECBE66CC46854066CB1F5623E179
C:\WINDOWS\System32\drivers\NdisVirtualBus.sys 7340104C2BF2F126714F7CDE85E63610
C:\WINDOWS\System32\drivers\ndiswan.sys 07ADC1F8DCBEB8104D75129B11584B8C
C:\WINDOWS\System32\DRIVERS\ndiswan.sys 07ADC1F8DCBEB8104D75129B11584B8C
C:\WINDOWS\System32\DRIVERS\NDProxy.sys 78A12E3DF035B5D054986949B19BE43C
C:\WINDOWS\System32\drivers\Ndu.sys 04C8859355C1DC9C0FA198D1894D71C2
C:\WINDOWS\System32\drivers\NetAdapterCx.sys 6C76780A01FC2B885BD6E957B5C36B02
C:\WINDOWS\System32\drivers\netbios.sys 5D1513BD6430307C9DB86C6E351372ED
C:\WINDOWS\System32\DRIVERS\netbt.sys 6FEBB0A847FFD5F057B9AC8889F1B9A7
C:\WINDOWS\system32\drivers\npf.sys ==> MD5 is legit
C:\Windows\System32\Drivers\Npfs.sys 001CBD7A2CD45C4EB39C01C3C677EF73
C:\WINDOWS\System32\drivers\npsvctrig.sys 90F5DC9802AAA00CD0B6E2AD9E7FFADC
C:\WINDOWS\System32\drivers\nsiproxy.sys 0C6218321A09A7B51BA7FFAFBA4CCB21
C:\Windows\System32\Drivers\NTFS.sys DB69C6DA8B3DDFDC547D455CA23A8250
C:\Program Files (x86)\MSI\MSI OC Kit\ActiveX_Service\NTIOLib_X64.sys 6126065AF2FC2639473D12EE3C0C198E
C:\Program Files (x86)\MSI\Fast Boot\NTIOLib_X64.sys 992DED5B623BE3C228F32EDB4CA3F2D2
C:\Windows\System32\Drivers\Null.sys 6E6DD6F9DD2A034CF85E94047DBDB992
C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_02838dee03d82b94\nvlddmkm.sys B360CFC497FF8070E37AEEA92CEF14BC
C:\WINDOWS\System32\drivers\nvraid.sys D261DF41F0840F734856A2B4F5E072C7
C:\WINDOWS\System32\drivers\nvstor.sys 23B702B555EB0436B9DAA0BC63DA65CE
C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamKms.sys 6C672A80B4FBF160E2814EAE0AB3020B
C:\WINDOWS\System32\drivers\nvstusb.sys 43DB182DC821C322C9EE8E936B82D8FB
C:\WINDOWS\system32\drivers\nvvad64v.sys 54ABC4EA39DDE92977DCE644D325213A
C:\WINDOWS\System32\drivers\nvvhci.sys 61BD2E2560FD1C5E0A8B8738816A0B93
C:\WINDOWS\System32\drivers\parport.sys 6B81BF7853D161DB8AC62CD8B9C2DE6B
C:\WINDOWS\System32\drivers\partmgr.sys CDBD029BAEC8D09F6FBD404632D9AF28
C:\WINDOWS\System32\drivers\pci.sys 29AF16726F4DD84376ECA85AB6AFF2C6
C:\WINDOWS\System32\drivers\pciide.sys 214DCC87E3898F738075D1341252A552
C:\WINDOWS\System32\drivers\pcmcia.sys AED76A3333B3A31536E430020E0226FC
C:\WINDOWS\System32\drivers\pcw.sys E63FB38B6E75B39467492FBAD2CD512A
C:\WINDOWS\System32\drivers\pdc.sys 9EA203A07EFA6D74F07F32EF0DAB5CA6
C:\WINDOWS\System32\drivers\peauth.sys 1509A77F840AA9E72CF8247D0CF2FBDE
C:\WINDOWS\System32\drivers\percsas2i.sys 540116170E2135FCD5DDE77702166B67
C:\WINDOWS\System32\drivers\percsas3i.sys 8356F87553BF49C703CF382033815898
C:\WINDOWS\system32\drivers\pmxdrv.sys 0BEE791C7C7ACE453C134E73633C497D
C:\WINDOWS\System32\drivers\raspptp.sys 5645B9D9788CCA2C88B9534996ED2D6D
C:\WINDOWS\System32\drivers\processr.sys 372913E12677A8CBBBABDD8311894F9D
C:\WINDOWS\System32\drivers\pacer.sys FC98407B85A31161851FDE245517574F
C:\WINDOWS\system32\drivers\qwavedrv.sys 819602BBBFDB0BD46DEA3715BF0DD452
C:\WINDOWS\System32\DRIVERS\rasacd.sys CDF47037A0939F56D11F699629C276AD
C:\WINDOWS\System32\drivers\AgileVpn.sys 28C2EA278070EE12701D0EDF8CB0EC36
C:\WINDOWS\System32\drivers\rasl2tp.sys 17E565710172ED71B8531D8822E1C5D1
C:\WINDOWS\System32\DRIVERS\raspppoe.sys 9387DF155233D45D4E010F4F2FB52A57
C:\WINDOWS\System32\drivers\rassstp.sys F0F4EEDEEBEE7A4244FAFB96A16B5712
C:\Windows\system32\drivers\rawdsk3.sys 11A199CE5EF5BCC314946F54ED2D823B
C:\WINDOWS\System32\DRIVERS\rdbss.sys AF6963414B820B7C45578ED3300438A7
C:\WINDOWS\System32\drivers\rdpbus.sys 79A415E6FA915EFC00297DAB16EC2635
C:\WINDOWS\System32\drivers\rdpdr.sys 7135785C21CA79D270D11037C43D3F19
C:\WINDOWS\System32\drivers\rdpvideominiport.sys 97A61A3CB2B5CB4FC32B3224EF333448
C:\WINDOWS\System32\drivers\rdyboost.sys 69BB204AE07EE84ECFAB1BF13C4BD04B
C:\Windows\System32\Drivers\ReFSv1.sys 940D6F5A2B0A61EE4170DF84F6C95C20
C:\WINDOWS\System32\drivers\rspndr.sys 5FF28F097C9699097B473F8FC7C1AA7D
C:\WINDOWS\System32\drivers\vms3cap.sys B5DAEE69BACA64D2BB004568E22D8756
C:\WINDOWS\system32\DRIVERS\S3XXx64.sys A53AD7D8005429E1E446A401F2BCA681
C:\WINDOWS\System32\drivers\sbp2port.sys 5E73FB63E2DBC75FE0C17DEB0010CE0E
C:\WINDOWS\System32\DRIVERS\scfilter.sys 3D9A82B03C92D1FEC42CB171D6F57778
C:\WINDOWS\System32\drivers\scmbus.sys 9055ADDFBA4C8B914C914CE693B55C0A
C:\WINDOWS\System32\drivers\scmdisk0101.sys B6F2363584E62960846F7C3F00124A4F
C:\WINDOWS\System32\drivers\sdbus.sys 7C3D10BEC8B0DBA00A78C78EB10B3AE2
C:\WINDOWS\System32\drivers\sdstor.sys 120DFCB71D6C502613A9E2D50E16850C
C:\WINDOWS\system32\drivers\semav6msr64.sys 07F83829E7429E60298440CD1E601A6A
C:\WINDOWS\System32\drivers\SerCx.sys 401D706DDC0A7AF18C3DD228ADF74551
C:\WINDOWS\System32\drivers\SerCx2.sys 7084D11083F0CDCA8B5C76F9846ABF5D
C:\WINDOWS\System32\drivers\serenum.sys 3FF478A8ED32A83C36581425F6282B6C
C:\WINDOWS\System32\drivers\serial.sys 92509187AA171A80521528B36F753E1D
C:\WINDOWS\System32\drivers\sermouse.sys 433D38FF6D08B993847EA2A10EB8CB52
C:\WINDOWS\System32\drivers\sfloppy.sys 697D3EE0740AEAB62B66ABCA1C83D13B
C:\WINDOWS\System32\drivers\SiSRaid2.sys A34CE1830E45DA98932295FDE4B7908A
C:\WINDOWS\System32\drivers\sisraid4.sys A7B5C670770E908DA5FEF5BF1136E933
C:\WINDOWS\system32\drivers\SiUSBXp.sys CEDF7CFFCCD03451FD22DBAAC2E3DE8E
C:\WINDOWS\System32\drivers\spaceport.sys C994DF90427103CCB80F893FFD2B1CE8
C:\WINDOWS\System32\drivers\SpbCx.sys E03264C4C25B568F92ED1656AD541E64
C:\WINDOWS\System32\DRIVERS\srv.sys E83830BB74AE8CBECEA0ECD94DE436F9
C:\WINDOWS\System32\DRIVERS\srv2.sys 55CA5329D1ADEB8F8034045930147AE4
C:\WINDOWS\System32\DRIVERS\srvnet.sys F13EE0DB1FB1D6946AC3228D7EFCFC8F
C:\WINDOWS\System32\drivers\ssdevfactory.sys 5BF0F8641A219B9E24A4841DA318416F
C:\WINDOWS\System32\drivers\stexstor.sys 29D26E1347AE1BBD4201014E19880B2C
C:\WINDOWS\system32\DRIVERS\serscan.sys B11724BFE7DA1BA55903B4D849415F1A
C:\WINDOWS\System32\drivers\storahci.sys 53EB8CE34B55A1EE63424C8DB7388BFC
C:\WINDOWS\System32\drivers\vmstorfl.sys C5E0ACE4771F5575D9D5B457ABF3AD03
C:\WINDOWS\System32\drivers\stornvme.sys B66D8C75C9BC59D637177AB3B1C569A6
C:\WINDOWS\System32\drivers\storqosflt.sys BEBF85EB4D90E6996047DA027D0ED26E
C:\WINDOWS\System32\drivers\storufs.sys 8E73037A6F8938475692FFCC26EBF385
C:\WINDOWS\System32\drivers\storvsc.sys 9D9DED47DA10E845EFF2DD57C94C809B
C:\WINDOWS\System32\drivers\swenum.sys 505E0C40B5D0ADDCBB414640F59BD2E0
C:\WINDOWS\System32\drivers\Synth3dVsc.sys 32F46FB0F290D16DAA452B289C985795
C:\WINDOWS\System32\drivers\tcpip.sys 4F25E481124059CC593B4C68BC485640
C:\WINDOWS\System32\drivers\tcpipreg.sys 8DBB1BE20C36E6D19BCC89EEA00B953C
C:\WINDOWS\system32\DRIVERS\tdx.sys 9D2DD64A0B51C56285512DC9454340F6
C:\WINDOWS\System32\drivers\terminpt.sys 06130AFFECEB94525FC2352936576B70
C:\WINDOWS\System32\drivers\tpm.sys 46171262D0E806779DEEDFCAB2F830CC
C:\WINDOWS\System32\drivers\trufos.sys AA129EFF64E41947F6A46388A7F5F966
C:\WINDOWS\System32\drivers\TsUsbFlt.sys A6F4025664C9D4BC2A9EDAB4092706D7
C:\WINDOWS\System32\drivers\TsUsbGD.sys 37A96AD493E110C0BF1EE0AC0F9E7DBD
C:\WINDOWS\System32\drivers\tunnel.sys 79E264287F17D56D768440B0270466DE
C:\WINDOWS\System32\drivers\uaspstor.sys AA65954F512BA097DD190790876DD991
C:\WINDOWS\System32\Drivers\UcmCx.sys AB6268022C3A5B529075A39C33904DA6
C:\WINDOWS\System32\Drivers\UcmTcpciCx.sys 7ED2EDA43D21C7A5F589A7960E265C52
C:\WINDOWS\System32\drivers\UcmUcsi.sys 169351463039B45F5CDED9768879F712
C:\WINDOWS\System32\drivers\ucx01000.sys 08A9E3AD29B215484FBB68CDC175DF3A
C:\WINDOWS\System32\drivers\udecx.sys DA70AEE267491AA56BC63AA0C0C96CA2
C:\WINDOWS\System32\DRIVERS\udfs.sys FBC5ECF6D5A868D0B116C2DBB02B8168
C:\WINDOWS\System32\drivers\UEFI.sys B918E40FAA9CD118CCA4AD388B748C98
C:\WINDOWS\System32\drivers\ufx01000.sys 0FD75222C1AD2687AB365BEBEA400DD4
C:\WINDOWS\System32\drivers\UfxChipidea.sys C1A78C53E01C641AE41BFA65797819F5
C:\WINDOWS\System32\drivers\ufxsynopsys.sys 767307212110EBEFB93EC9A5BE9E85B9
C:\WINDOWS\System32\drivers\umbus.sys DC460AAA18CA2342FBBFB2DF9B044472
C:\WINDOWS\System32\drivers\umpass.sys C3CF0377917ECE6D65D7623E1E61568F
C:\WINDOWS\System32\drivers\urschipidea.sys 6B46FC140C9AF68E6E7697D66D59CB4D
C:\WINDOWS\System32\drivers\urscx01000.sys B4402E7F0923F660270442CE76877ABE
C:\WINDOWS\System32\drivers\urssynopsys.sys 9DD431F1B94789CFB527E5D19261F124
C:\WINDOWS\System32\Drivers\usbaapl64.sys F957092C63CD71D85903CA0D8370F473
C:\WINDOWS\system32\drivers\usbaudio.sys 93F169DE94DBAC5DAF4755AFF10193DD
C:\WINDOWS\System32\drivers\usbccgp.sys C87E32B90F085970D9637FBAD45EF6FE
C:\WINDOWS\System32\drivers\usbcir.sys 0B663856474AC41924D9E9112203858F
C:\WINDOWS\System32\drivers\usbehci.sys F83D2250256203AC5DA5E8601C1AFDD7
C:\WINDOWS\System32\drivers\usbhub.sys 7FFD26742321919590ED77FCA556D65F
C:\WINDOWS\System32\drivers\UsbHub3.sys 7A749B2863B5561BE34B39E8E249AD8F
C:\WINDOWS\System32\drivers\usbohci.sys D2109F1F4FEBF1DAC415CDC5DE876479
C:\WINDOWS\System32\drivers\usbprint.sys 29C9572F2D061CFC3C0BD48A3163E343
C:\WINDOWS\System32\drivers\usbser.sys 429477D6DEF3321FF7D3EF23CAAADA00
C:\WINDOWS\System32\drivers\USBSTOR.SYS 0CC16F7B91C57AE9A4E44425A295FDAA
C:\WINDOWS\System32\drivers\usbuhci.sys C917D09064CDBD18F75ADC9B2C48F847
C:\WINDOWS\System32\drivers\USBXHCI.SYS 95BCCEFBC40D06484CF16144FE79B8A5
C:\WINDOWS\System32\drivers\vdrvroot.sys 0CBDE344FB48E42D78E29469F202ADBC
C:\WINDOWS\System32\drivers\VerifierExt.sys 723195568C8755CAD57F7933C5F2C5C2
C:\WINDOWS\System32\drivers\vhdmp.sys 3BB8D153A9A514EC9FFCB586251A1925
C:\WINDOWS\System32\drivers\vhf.sys 7929228F0E8B0C2FA0495A17A4FC27F6
C:\WINDOWS\System32\drivers\vmbus.sys AEE432ED868831B1F068E373598F6D93
C:\WINDOWS\System32\drivers\VMBusHID.sys 9444B23FC694B5F90F21B0FC7F10D8DD
C:\WINDOWS\System32\drivers\vmgid.sys 4D0287F566B36536DD812A54C015FC4A
C:\WINDOWS\System32\drivers\volmgr.sys 29075915F9BDC3437F8BED71C067D399
C:\WINDOWS\System32\drivers\volmgrx.sys 6BDB6CE6D2D9E3D3F28F1C97E12B62E2
C:\WINDOWS\System32\drivers\volsnap.sys BF2546583BB75F01DDA60A7921DFB230
C:\WINDOWS\System32\drivers\volume.sys AC2E20A74D09D24485BE8396CE04F07B
C:\WINDOWS\System32\drivers\vpci.sys 92F6E3E6D3F1795263EB34B37F74AEF7
C:\WINDOWS\System32\drivers\vsmraid.sys FD9BCB8920973CEAD4D49DC7A6D8A618
C:\WINDOWS\System32\drivers\vstxraid.sys 0C111F220798CCE80484026E06822379
C:\WINDOWS\System32\drivers\vwifibus.sys 607639716E9DB1CEF4E18B5B229293B4
C:\WINDOWS\System32\drivers\vwififlt.sys B1ED64E628763148BF84FBE23F2AD711
C:\WINDOWS\System32\drivers\vwifimp.sys 59920894C38A827091A06AF559834E47
C:\WINDOWS\System32\drivers\wacompen.sys 55D00B785A7587F4263D125817871283
C:\WINDOWS\System32\DRIVERS\wanarp.sys CEF3D306C09BEC1A800E9B4A06F859F6
C:\WINDOWS\system32\drivers\wcifs.sys E330144B97D493AA886000DCAAA8DAF5
C:\WINDOWS\system32\drivers\wcnfs.sys AEA1093B751339267D8C8C1EF3D669CF
C:\WINDOWS\system32\drivers\WdBoot.sys D520B1B849B6D4D707AB31722B952C2D
C:\WINDOWS\System32\drivers\wdcsam64.sys A556768CC1FA4F36022BEE2F0EDE2566
C:\WINDOWS\System32\drivers\Wdf01000.sys 5030C76047D756263093A47B82970868
C:\WINDOWS\system32\drivers\WdFilter.sys 29FF9199EDEB4F5470BB134D1A2563D2
C:\WINDOWS\System32\DRIVERS\wdiwifi.sys 8CB606A3057355FD5A9DBDD1A0AC94EF
C:\WINDOWS\System32\Drivers\WdNisDrv.sys 17CF416CFF408190F5A4CBD79AB12E55
C:\WINDOWS\System32\drivers\wfplwfs.sys E1785942AC51FEE6826CDF02075C5AA9
C:\WINDOWS\System32\drivers\wimmount.sys 0CF79A0EACFFBB75A50A469A27696D02
C:\WINDOWS\System32\drivers\WindowsTrustedRT.sys 0DE131733317EB4BE67028366B0CAAC6
C:\WINDOWS\System32\drivers\WindowsTrustedRTProxy.sys 92EB5D38BDF10C790450F3E46BF93A0E
C:\WINDOWS\System32\drivers\winmad.sys F95DE20312ACCA7761446DE152BD1F7C
C:\Program Files (x86)\NZXT\CAM\CAM_V3.sys 0C0195C48B6B8582FA6F6373032118DA
C:\WINDOWS\System32\drivers\WinUSB.SYS 4EFB346BFDAEEB29316AA52BBB9852B1
C:\WINDOWS\System32\drivers\winverbs.sys 8B9AFF5F08E66A6F1F1063DEC9457FB6
C:\WINDOWS\System32\drivers\wmiacpi.sys 6F4F4F5A007D1710BD76FB311DA97C07
C:\Windows\System32\Drivers\Wof.sys 43C8D087B31C592163B33A4BDA540E40
C:\WINDOWS\System32\drivers\WpdUpFltr.sys 75A9284F01FE7CB1A7D5EAE5C1EB4F33
C:\WINDOWS\system32\drivers\ws2ifsl.sys 36D7B73ADC3E10607ED6EC874AFB5D1E
C:\WINDOWS\System32\drivers\WSDPrint.sys 696EC2EAA2A42A137CCBB9A84D6917C0
C:\WINDOWS\system32\DRIVERS\WSDScan.sys 46E4A69825A7554A5DB784A55F8AD203
C:\WINDOWS\System32\drivers\WudfPf.sys AED7FE551E8672B824A56324076183EB
C:\WINDOWS\system32\DRIVERS\WUDFRd.sys CEFAB17FD7DFCFA515626C306262E89D
C:\WINDOWS\System32\drivers\xboxgip.sys 9627BBAA50878F6833A6A7843EE3B1D9
C:\WINDOWS\System32\drivers\xinputhid.sys 63088A3361D9A308F328F11E9099DD87
==================== Three Months Created files and folders ========
2017-02-09 18:06 - 2017-02-09 18:06 - 00060060 _____ C:\Users\Jarvis\Downloads\FRST.txt
2017-02-09 18:06 - 2017-02-09 18:06 - 00000000 ____D C:\FRST
2017-02-09 18:05 - 2017-02-09 18:05 - 02421248 _____ (Farbar) C:\Users\Jarvis\Downloads\FRST64.exe
2017-02-08 23:17 - 2017-02-08 23:17 - 00892416 _____ (Farbar) C:\Users\Jarvis\Downloads\MiniToolBox.exe
2017-02-08 23:17 - 2017-02-08 23:17 - 00038218 _____ C:\Users\Jarvis\Downloads\MTB.txt
2017-02-08 21:18 - 2017-02-08 21:18 - 00000000 ____D C:\WINDOWS\system\GroupPolicy
2017-02-08 21:18 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\system\GroupPolicyUsers
2017-02-08 21:18 - 2001-08-23 13:00 - 00034871 _____ C:\WINDOWS\system32\gpedit.msc
2017-02-08 21:18 - 2001-08-23 13:00 - 00034871 _____ C:\WINDOWS\system\gpedit.msc
2017-02-08 21:16 - 2017-02-08 21:16 - 00875012 _____ C:\Users\Jarvis\Downloads\add_gpedit_msc_by_jwils876-d3kh6vm.zip
2017-02-08 21:16 - 2017-02-08 21:16 - 00707354 _____ C:\WINDOWS\unins000.exe
2017-02-08 21:16 - 2017-02-08 21:16 - 00001533 _____ C:\WINDOWS\unins000.dat
2017-02-08 21:16 - 2017-02-08 21:16 - 00000000 ____D C:\WINDOWS\SysWOW64\GPBAK
2017-02-08 21:16 - 2008-04-14 02:11 - 00295936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\appmgr.dll
2017-02-08 21:16 - 2001-08-23 13:00 - 00034871 _____ C:\WINDOWS\SysWOW64\gpedit.msc
2017-02-08 19:26 - 2017-02-08 19:26 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Dropbox
2017-02-08 17:44 - 2017-02-08 17:44 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Intel
2017-02-08 17:44 - 2016-10-18 17:14 - 00021984 _____ C:\WINDOWS\system32\Drivers\semav6msr64.sys
2017-02-08 17:43 - 2017-02-08 17:44 - 09955696 _____ (Intel) C:\Users\Jarvis\Downloads\Intel Driver Update Utility Installer.exe
2017-02-06 20:38 - 2017-02-06 20:38 - 00046400 _____ (Dropbox, Inc.) C:\WINDOWS\system32\DbxSvc.exe
2017-02-06 20:38 - 2017-02-06 20:38 - 00046192 _____ (Dropbox, Inc.) C:\WINDOWS\system32\Drivers\dbx-stable.sys
2017-02-06 20:38 - 2017-02-06 20:38 - 00046192 _____ (Dropbox, Inc.) C:\WINDOWS\system32\Drivers\dbx-dev.sys
2017-02-06 20:38 - 2017-02-06 20:38 - 00046192 _____ (Dropbox, Inc.) C:\WINDOWS\system32\Drivers\dbx-canary.sys
2017-02-06 00:16 - 2017-02-06 00:18 - 00000000 ____D C:\Users\Jarvis\AppData\LocalLow\Mozilla
2017-02-05 00:25 - 2017-02-08 11:53 - 00000000 ____D C:\Users\Jarvis\AppData\Local\NETGEARGenie
2017-02-05 00:25 - 2017-02-05 00:25 - 00002137 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NETGEAR Genie.lnk
2017-02-05 00:25 - 2017-02-05 00:25 - 00002125 _____ C:\Users\Public\Desktop\NETGEAR Genie.lnk
2017-02-05 00:25 - 2017-02-05 00:25 - 00000000 ____D C:\Program Files (x86)\NETGEAR Genie
2017-02-05 00:23 - 2017-02-05 00:23 - 00002047 _____ C:\Users\Jarvis\Desktop\CAM.lnk
2017-02-05 00:22 - 2017-02-05 00:25 - 46239672 _____ (NETGEAR Inc.) C:\Users\Jarvis\Downloads\NETGEARGenie-install.exe
2017-02-05 00:22 - 2017-02-05 00:22 - 00001097 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CAM.lnk
2017-02-05 00:22 - 2017-02-05 00:22 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CAM
2017-02-05 00:21 - 2017-02-05 00:22 - 33475288 _____ (NZXT) C:\Users\Jarvis\Downloads\CAM_Installer V3.3.0.exe
2017-02-05 00:19 - 2017-02-05 00:22 - 00000000 __SHD C:\AI_RecycleBin
2017-02-03 02:41 - 2017-02-03 02:41 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Frontier Developments
2017-02-03 02:41 - 2017-02-03 02:41 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Frontier Developments
2017-02-03 02:38 - 2017-02-05 03:37 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Frontier_Developments
2017-02-02 03:36 - 2017-02-02 04:07 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Jagex
2017-02-02 03:36 - 2017-02-02 04:07 - 00000000 ____D C:\ProgramData\Jagex
2017-02-02 01:30 - 2017-02-02 01:30 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\OBS Studio
2017-02-02 01:22 - 2017-02-08 17:46 - 00000000 ____D C:\WINDOWS\System32\Tasks\Intel
2017-02-02 01:22 - 2017-02-02 01:22 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel
2017-02-02 01:21 - 2017-02-02 01:21 - 00001824 _____ C:\Users\Public\Desktop\iTunes.lnk
2017-02-02 01:21 - 2017-02-02 01:21 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
2017-02-02 01:21 - 2017-02-02 01:21 - 00000000 ____D C:\Program Files\iTunes
2017-02-02 01:21 - 2017-02-02 01:21 - 00000000 ____D C:\Program Files\iPod
2017-02-02 01:17 - 2017-02-02 01:17 - 00000000 ___HD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup-Disabled
2017-02-02 01:11 - 2017-02-03 02:31 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\GlarySoft
2017-02-02 01:11 - 2017-02-03 02:31 - 00000000 ____D C:\Program Files (x86)\Glarysoft
2017-02-02 01:11 - 2017-02-02 01:11 - 00003482 _____ C:\WINDOWS\System32\Tasks\Software Update
2017-02-02 01:11 - 2017-02-02 01:11 - 00002870 _____ C:\GUDownLoaddebug.txt
2017-02-02 01:11 - 2017-02-02 01:11 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\DiskDefrag
2017-02-02 01:03 - 2017-02-02 01:03 - 00000000 ____D C:\ProgramData\Nahimic22.3.14
2017-02-02 01:02 - 2017-02-02 01:02 - 00003206 _____ C:\WINDOWS\System32\Tasks\Nahimic2UILauncherRun
2017-02-02 01:02 - 2017-02-02 01:02 - 00003194 _____ C:\WINDOWS\System32\Tasks\Nahimic2Svc64Run
2017-02-02 01:02 - 2017-02-02 01:02 - 00003186 _____ C:\WINDOWS\System32\Tasks\Nahimic2Svc32Run
2017-02-02 01:02 - 2017-02-02 01:02 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nahimic 2
2017-02-02 00:54 - 2017-02-02 00:54 - 00000000 ____D C:\Users\Jarvis\Desktop\Gaming Utilities
2017-01-31 13:17 - 2017-01-31 13:17 - 00003834 _____ C:\WINDOWS\System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473
2017-01-31 13:10 - 2017-01-31 13:10 - 00000000 ____D C:\WINDOWS\SysWOW64\RTCOM
2017-01-31 13:10 - 2017-01-31 13:10 - 00000000 ____D C:\WINDOWS\system32\RTCOM
2017-01-31 13:10 - 2017-01-31 13:10 - 00000000 ____D C:\WINDOWS\system32\DAX3
2017-01-31 13:10 - 2017-01-31 13:10 - 00000000 ____D C:\ProgramData\Audyssey Labs
2017-01-31 13:10 - 2017-01-31 13:10 - 00000000 ____D C:\Program Files\Realtek
2017-01-31 13:10 - 2016-12-09 08:35 - 72520712 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RCoRes64.dat
2017-01-31 13:10 - 2016-12-09 08:35 - 23547544 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioRenderAVX64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 23447352 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioRender64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 17398616 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioCapture64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 15202032 _____ (Yamaha Corporation) C:\WINDOWS\system32\YamahaAE3.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 14057248 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioRealtek64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 13122576 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxVoiceAPO3064.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 12988336 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxVoiceAPO4064.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 10531584 _____ (Intel Corporation) C:\WINDOWS\system32\IntelSSTAPO.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 07890895 _____ C:\WINDOWS\system32\Drivers\RTAIODAT.DAT
2017-01-31 13:10 - 2016-12-09 08:35 - 07172912 _____ (Dolby Laboratories) C:\WINDOWS\system32\R4EEP64A.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 06198136 _____ (Nahimic Inc) C:\WINDOWS\system32\NAHIMICV3apo.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 05804772 _____ C:\WINDOWS\system32\Drivers\rtvienna.dat
2017-01-31 13:10 - 2016-12-09 08:35 - 05793520 _____ (Nahimic Inc) C:\WINDOWS\system32\NAHIMICV2apo.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 05593608 _____ (Nahimic Inc) C:\WINDOWS\system32\NAHIMICAPOlfx.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 05539328 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\Drivers\RTKVHD64.sys
2017-01-31 13:10 - 2016-12-09 08:35 - 03503048 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RtkApi64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 03299816 _____ (Yamaha Corporation) C:\WINDOWS\system32\YamahaAE2.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 03295064 _____ (Fortemedia Corporation) C:\WINDOWS\system32\FMAPO64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 03204096 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RtPgEx64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 03201368 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RltkAPO64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 03014144 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RTSnMg64.cpl
2017-01-31 13:10 - 2016-12-09 08:35 - 02995000 _____ (DTS, Inc.) C:\WINDOWS\system32\slcnt64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 02828432 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\SysWOW64\RltkAPO.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 02706856 _____ (DTS, Inc.) C:\WINDOWS\system32\sltech64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 02291304 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioAPO7064.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 02201600 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RCoInstII64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 02190976 _____ (Yamaha Corporation) C:\WINDOWS\system32\YamahaAE.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 02110592 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\WavesGUILib64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 02050176 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioEQ64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01920919 _____ C:\WINDOWS\system32\Drivers\rtkSSTsetting.dat
2017-01-31 13:10 - 2016-12-09 08:35 - 01780616 _____ (DTS) C:\WINDOWS\system32\DTSS2SpeakerDLL64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01435136 _____ (Synopsys, Inc.) C:\WINDOWS\system32\SRRPTR64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01422920 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioAPO6064.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01382232 _____ (TOSHIBA Corporation) C:\WINDOWS\system32\tosade.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01360512 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RTCOM64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01337632 _____ (Toshiba Client Solutions Co., Ltd.) C:\WINDOWS\system32\tossaeapo64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01334376 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxSpeechAPO64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01213656 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioAPO5064.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01186832 _____ (Intel Corporation) C:\WINDOWS\system32\IntelSstCApoPropPage.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01166152 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioAPO4064.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01003856 _____ (Nahimic Inc) C:\WINDOWS\system32\NahimicAPONSControl.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 01003328 _____ (Sound Research, Corp.) C:\WINDOWS\system32\SEHDHF64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00999848 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxVoiceAPO2064.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00984912 _____ (DTS, Inc.) C:\WINDOWS\system32\sl3apo64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00965024 _____ (Sony Corporation) C:\WINDOWS\system32\SFSS_APO.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00962120 _____ (Toshiba Client Solutions Co., Ltd.) C:\WINDOWS\system32\tosasfapo64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00931616 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioAPOShell64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00923736 _____ (Sony Corporation) C:\WINDOWS\system32\MISS_APO.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00873456 _____ (TOSHIBA Corporation) C:\WINDOWS\system32\tadefxapo264.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00865912 _____ (Sound Research, Corp.) C:\WINDOWS\SysWOW64\SEHDHF32.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00859216 _____ (Sound Research, Corp.) C:\WINDOWS\system32\SEHDRA64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00850408 _____ (Sound Research, Corp.) C:\WINDOWS\system32\SECOMN64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00727432 _____ (DTS) C:\WINDOWS\system32\DTSSymmetryDLL64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00721800 _____ (Sound Research, Corp.) C:\WINDOWS\SysWOW64\SECOMN32.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00708304 _____ (DTS) C:\WINDOWS\system32\DTSVoiceClarityDLL64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00689880 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RtDataProc64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00678176 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioAPO30.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00677664 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxVolumeSDAPO.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00618176 _____ (Knowles Acoustics ) C:\WINDOWS\system32\KAAPORT64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00601136 _____ (Toshiba Client Solutions Co., Ltd.) C:\WINDOWS\system32\tossaemaxapo64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00588032 _____ (ICEpower a/s) C:\WINDOWS\system32\ICEsoundAPO64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00571376 _____ (Intel Corporation) C:\WINDOWS\system32\tbb_waves.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00532376 _____ (SRS Labs, Inc.) C:\WINDOWS\system32\SRSTSX64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00514520 _____ (DTS) C:\WINDOWS\system32\DTSU2PLFX64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00500552 _____ (DTS) C:\WINDOWS\system32\DTSU2PGFX64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00499152 _____ (Sound Research, Corp.) C:\WINDOWS\system32\SEAPO64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00467152 _____ (Synopsys, Inc.) C:\WINDOWS\system32\SRAPO64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00447712 _____ (Dolby Laboratories) C:\WINDOWS\system32\R4EED64A.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00447176 _____ (Toshiba Client Solutions Co., Ltd.) C:\WINDOWS\system32\toseaeapo64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00428224 _____ (DTS) C:\WINDOWS\system32\DTSU2PREC64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00426560 _____ (Dolby Laboratories) C:\WINDOWS\system32\HiFiDAX2APIPCLL.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00416504 _____ (Harman) C:\WINDOWS\system32\HMUI.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00387312 _____ (Dolby Laboratories, Inc.) C:\WINDOWS\system32\RTEEP64A.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00381408 _____ (Synopsys, Inc.) C:\WINDOWS\system32\SRCOM64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00378384 _____ (Dolby Laboratories) C:\WINDOWS\system32\HiFiDAX2API.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00366120 _____ (Windows (R) Win 7 DDK provider) C:\WINDOWS\system32\HMAPO.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00360344 _____ (Harman) C:\WINDOWS\system32\HMClariFi.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00343704 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RtlCPAPI64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00341144 _____ (Synopsys, Inc.) C:\WINDOWS\SysWOW64\SRCOM.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00341144 _____ (Synopsys, Inc.) C:\WINDOWS\system32\SRCOM.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00330552 _____ (Waves Audio Ltd.) C:\WINDOWS\system32\MaxxAudioAPO20.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00321712 _____ (Dolby Laboratories, Inc.) C:\WINDOWS\system32\RP3DHT64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00321712 _____ (Dolby Laboratories, Inc.) C:\WINDOWS\system32\RP3DAA64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00258864 _____ (TODO: <Company name>) C:\WINDOWS\system32\slprp64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00231912 _____ (Synopsys, Inc.) C:\WINDOWS\system32\SFNHK64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00221960 _____ (SRS Labs, Inc.) C:\WINDOWS\system32\SRSTSH64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00214824 _____ (Dolby Laboratories, Inc.) C:\WINDOWS\system32\RTEED64A.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00209528 _____ (SRS Labs, Inc.) C:\WINDOWS\system32\SRSHP64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00203840 _____ (Harman) C:\WINDOWS\system32\HMHVS.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00192976 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RtkCfg64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00190928 _____ (Harman) C:\WINDOWS\system32\HMEQ_Voice.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00190928 _____ (Harman) C:\WINDOWS\system32\HMEQ.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00179592 _____ (Harman) C:\WINDOWS\system32\HMLimiter.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00166200 _____ (SRS Labs, Inc.) C:\WINDOWS\system32\SRSWOW64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00158688 _____ (TOSHIBA Corporation) C:\WINDOWS\system32\tadefxapo.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00154360 _____ (Harman) C:\WINDOWS\system32\HarmanAudioInterface.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00151784 _____ (Dolby Laboratories) C:\WINDOWS\system32\R4EEL64A.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00134192 _____ (Dolby Laboratories) C:\WINDOWS\system32\R4EEA64A.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00110976 _____ (Dolby Laboratories, Inc.) C:\WINDOWS\system32\RTEEL64A.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00090912 _____ (Synopsys, Inc.) C:\WINDOWS\system32\SFCOM64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00088344 _____ (Dolby Laboratories, Inc.) C:\WINDOWS\system32\RTEEG64A.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00088312 _____ (Synopsys, Inc.) C:\WINDOWS\system32\SFAPO64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00084608 _____ (Dolby Laboratories) C:\WINDOWS\system32\R4EEG64A.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00083624 _____ (Virage Logic Corporation / Sonic Focus) C:\WINDOWS\SysWOW64\SFCOM.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00075536 _____ (TOSHIBA CORPORATION.) C:\WINDOWS\system32\tepeqapo64.dll
2017-01-31 13:10 - 2016-12-09 08:35 - 00023688 _____ (Realtek Semiconductor Corp.) C:\WINDOWS\system32\RtkCoLDR64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 07096184 _____ (Dolby Laboratories) C:\WINDOWS\system32\DDPP64A.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 06264632 _____ (Dolby Laboratories) C:\WINDOWS\system32\DDPP64AF3.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 05347000 _____ (Dolby Laboratories) C:\WINDOWS\system32\DolbyDAX2APOv211.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 02993720 _____ (Audyssey Labs) C:\WINDOWS\system32\AudysseyEfx.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 02444688 _____ (Dolby Laboratories) C:\WINDOWS\system32\DolbyDAX2APOv201.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 01965808 _____ (Dolby Laboratories) C:\WINDOWS\system32\DDPD64A.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 01959600 _____ (Dolby Laboratories) C:\WINDOWS\system32\DDPD64AF3.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 01615656 _____ (Conexant Systems Inc.) C:\WINDOWS\system32\CX64APO.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 01591056 _____ (DTS) C:\WINDOWS\system32\DTSS2HeadphoneDLL64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 01529136 _____ (Conexant Systems Inc.) C:\WINDOWS\system32\CX64Proxy.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 01516896 _____ (Dolby Laboratories) C:\WINDOWS\system32\DAX3APOProp.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 01508928 _____ (DTS) C:\WINDOWS\system32\DTSBoostDLL64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 01363096 _____ (Dolby Laboratories) C:\WINDOWS\system32\DAX3APOv251.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 01133584 _____ (Dolby Laboratories) C:\WINDOWS\system32\DolbyDAX2APOProp.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00785608 _____ (Dolby Laboratories) C:\WINDOWS\system32\DolbyDAX2APOvlldp.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00743960 _____ (DTS) C:\WINDOWS\system32\DTSBassEnhancementDLL64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00574752 _____ (Andrea Electronics Corporation) C:\WINDOWS\system32\AERTAC64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00504304 _____ (DTS) C:\WINDOWS\system32\DTSNeoPCDLL64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00445392 _____ (DTS) C:\WINDOWS\system32\DTSLimiterDLL64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00441264 _____ (DTS) C:\WINDOWS\system32\DTSGainCompensatorDLL64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00438688 _____ (Conexant Systems, Inc.) C:\WINDOWS\system32\CAF64APO2.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00362048 _____ (Dolby Laboratories) C:\WINDOWS\system32\DDPO64AF3.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00327448 _____ (Dolby Laboratories) C:\WINDOWS\system32\DDPO64A.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00310416 _____ (Dolby Laboratories) C:\WINDOWS\system32\DDPA64F3.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00272712 _____ (Dolby Laboratories) C:\WINDOWS\system32\DDPA64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00253896 _____ (DTS) C:\WINDOWS\system32\DTSGFXAPO64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00253856 _____ (DTS) C:\WINDOWS\system32\DTSLFXAPO64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00252872 _____ (DTS) C:\WINDOWS\system32\DTSGFXAPONS64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00122320 _____ (Real Sound Lab SIA) C:\WINDOWS\system32\CONEQMSAPOGUILibrary.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00118592 _____ C:\WINDOWS\system32\AcpiServiceVnA64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00118584 _____ (Andrea Electronics Corporation) C:\WINDOWS\system32\AERTAR64.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00112488 _____ (Conexant Systems, Inc.) C:\WINDOWS\system32\Caf64api.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00105304 _____ C:\WINDOWS\system32\audioLibVc.dll
2017-01-31 13:10 - 2016-12-09 08:34 - 00005604 _____ C:\WINDOWS\system32\cxapo.lncs
2017-01-31 13:10 - 2016-12-09 08:34 - 00000736 _____ C:\WINDOWS\system32\cxapo.prop
2017-01-31 13:03 - 2017-01-31 13:03 - 00003866 _____ C:\WINDOWS\System32\Tasks\IntelIOC-Upgrade-f1c8187b-2653-47cd-a9be-b554b98f68a7
2017-01-31 13:03 - 2017-01-31 13:03 - 00003632 _____ C:\WINDOWS\System32\Tasks\IntelIOC-Upgrade-f1c8187b-2653-47cd-a9be-b554b98f68a7-Logon
2017-01-31 13:00 - 2017-01-31 13:00 - 00000000 ____D C:\WINDOWS\LastGood.Tmp
2017-01-31 12:59 - 2016-07-22 02:19 - 00091088 _____ (Intel Corporation) C:\WINDOWS\system32\NicInstD.dll
2017-01-31 12:59 - 2016-04-15 14:47 - 00080848 _____ (Intel Corporation) C:\WINDOWS\system32\e1dmsg.dll
2017-01-31 02:04 - 2017-01-31 02:04 - 00000000 ____D C:\Users\Jarvis\Documents\WB Games
2017-01-31 01:49 - 2016-08-15 23:15 - 00001857 _____ C:\Users\Jarvis\Desktop\Spotify (2).lnk
2017-01-30 04:38 - 2017-01-30 04:38 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Choice Provisions
2017-01-30 04:05 - 2017-01-30 04:05 - 00000000 ____D C:\Users\Jarvis\Documents\Paradox Interactive
2017-01-30 03:48 - 2017-01-30 03:48 - 00000000 ____D C:\Users\Jarvis\Documents\EA Games
2017-01-30 03:46 - 2017-01-30 03:46 - 00000000 ____D C:\Users\Jarvis\AppData\Local\EA Games
2017-01-30 03:46 - 2017-01-30 03:46 - 00000000 ____D C:\ProgramData\Solidshield
2017-01-30 03:21 - 2017-01-30 03:21 - 00000000 ____D C:\Users\Jarvis\Documents\Stronghold Crusader 2
2017-01-28 19:39 - 2017-01-28 19:39 - 00001201 _____ C:\Users\Jarvis\Desktop\Corsair Utility Engine.lnk
2017-01-28 19:39 - 2017-01-28 19:39 - 00000000 ____D C:\Program Files (x86)\Corsair
2017-01-28 12:42 - 2017-01-28 12:42 - 00001407 _____ C:\Users\Public\Desktop\Apowersoft Photo Viewer.lnk
2017-01-28 12:42 - 2017-01-28 12:42 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Apowersoft
2017-01-28 12:42 - 2017-01-28 12:42 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Apowersoft
2017-01-28 12:42 - 2017-01-28 12:42 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Apowersoft
2017-01-28 12:42 - 2017-01-28 12:42 - 00000000 ____D C:\Program Files (x86)\Apowersoft
2017-01-28 12:13 - 2017-01-28 12:18 - 00000000 ____D C:\Users\Jarvis\AppData\LocalLow\uTorrent
2017-01-28 12:10 - 2017-01-28 12:10 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\NVIDIA
2017-01-28 12:10 - 2017-01-28 12:10 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\LibreOffice
2017-01-28 12:00 - 2017-01-28 12:00 - 00003248 _____ C:\WINDOWS\System32\Tasks\{629FA748-A655-420C-B034-BFE42D0B39A4}
2017-01-28 11:58 - 2017-01-28 11:58 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\.purple
2017-01-28 11:54 - 2017-01-28 11:54 - 00001235 _____ C:\Users\Public\Desktop\LibreOffice 5.2.lnk
2017-01-28 11:54 - 2017-01-28 11:54 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\LibreOffice 5.2
2017-01-28 11:54 - 2017-01-28 11:54 - 00000000 ____D C:\Program Files (x86)\LibreOffice 5
2017-01-28 11:53 - 2017-01-28 11:58 - 00003674 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-697782072-1053751190-176726198-1002UA
2017-01-28 11:53 - 2017-01-28 11:58 - 00003406 _____ C:\WINDOWS\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-697782072-1053751190-176726198-1002Core
2017-01-28 11:53 - 2017-01-28 11:53 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Google Photos Backup
2017-01-26 16:03 - 2017-01-28 01:30 - 00000000 ____D C:\Users\Jarvis\AppData\Local\EvernoteNW
2017-01-24 20:54 - 2017-01-20 08:38 - 00514616 _____ (Khronos Group) C:\WINDOWS\system32\OpenCL.dll
2017-01-24 20:54 - 2017-01-20 08:38 - 00420408 _____ (Khronos Group) C:\WINDOWS\SysWOW64\OpenCL.dll
2017-01-24 20:54 - 2017-01-20 07:13 - 06401984 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcpl.dll
2017-01-24 20:54 - 2017-01-20 07:13 - 02479160 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvc64.dll
2017-01-24 20:54 - 2017-01-20 07:13 - 01762752 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvsvcr.dll
2017-01-24 20:54 - 2017-01-20 07:13 - 00548800 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshext.dll
2017-01-24 20:54 - 2017-01-20 07:13 - 00393784 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvmctray.dll
2017-01-24 20:54 - 2017-01-20 07:13 - 00083512 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nv3dappshextr.dll
2017-01-24 20:54 - 2017-01-20 07:13 - 00069568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvshext.dll
2017-01-24 20:54 - 2017-01-20 06:07 - 00001951 _____ C:\WINDOWS\NvContainerRecovery.bat
2017-01-24 20:54 - 2017-01-18 04:57 - 07755067 _____ C:\WINDOWS\system32\nvcoproc.bin
2017-01-24 20:53 - 2017-01-20 08:38 - 40192056 _____ C:\WINDOWS\system32\nvcompiler.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 35272760 _____ C:\WINDOWS\SysWOW64\nvcompiler.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 34974656 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvoglv64.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 28239928 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvoglv32.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 19008576 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvopencl.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 14677272 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvopencl.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 11123936 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcuda.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 11019192 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvptxJitCompiler.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 09308896 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvcuda.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 08990584 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvptxJitCompiler.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 04079032 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvapi64.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 03597640 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvapi.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 03167288 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvcuvid.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 02715072 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvcuvid.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 01985080 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispco6437849.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 01591352 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvdispgenco6437849.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 01051584 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvFBC64.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00988608 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvFBC.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00960568 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvIFR64.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00946456 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncMFTH264.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00944224 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncMFThevc.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00909760 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvIFR.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00721952 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncMFTH264.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00719160 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncMFThevc.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00687224 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvfatbinaryLoader.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00618232 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvmcumd.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00609216 _____ (NVIDIA Corporation) C:\WINDOWS\system32\NvIFROpenGL.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00606776 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvDecMFTMjpeg.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00576192 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvfatbinaryLoader.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00573120 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvEncodeAPI64.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00499136 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\NvIFROpenGL.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00483384 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvDecMFTMjpeg.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00447800 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvEncodeAPI.dll
2017-01-24 20:53 - 2017-01-20 08:38 - 00043556 _____ C:\WINDOWS\system32\nvinfo.pb
2017-01-24 20:53 - 2017-01-20 08:38 - 00000669 _____ C:\WINDOWS\SysWOW64\nv-vk32.json
2017-01-24 20:53 - 2017-01-20 08:38 - 00000669 _____ C:\WINDOWS\system32\nv-vk64.json
2017-01-24 20:48 - 2016-12-20 23:08 - 00142848 _____ (Microsoft Corporation) C:\WINDOWS\system32\poqexec.exe
2017-01-24 20:48 - 2016-12-20 20:44 - 00120320 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\poqexec.exe
2017-01-11 13:58 - 2017-01-11 14:00 - 00000000 ____D C:\Users\Jarvis\Evernote
2017-01-11 13:58 - 2017-01-11 13:58 - 00002523 _____ C:\Users\Public\Desktop\Evernote.lnk
2017-01-11 13:58 - 2017-01-11 13:58 - 00000000 ____D C:\Users\Jarvis\AppData\LocalLow\Evernote
2017-01-11 13:58 - 2017-01-11 13:58 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Evernote
2017-01-11 13:58 - 2017-01-11 13:58 - 00000000 ____D C:\Program Files (x86)\Evernote
2017-01-11 12:45 - 2017-01-11 12:45 - 00000000 ____D C:\Program Files (x86)\Microsoft ASP.NET
2017-01-11 11:50 - 2017-01-11 11:51 - 00000000 ____D C:\ProgramData\Malwarebytes' Anti-Malware (portable)
2017-01-11 11:48 - 2017-01-11 11:48 - 16563352 _____ (Malwarebytes Corp.) C:\Users\Jarvis\Downloads\mbar-1.09.3.1001.exe
2017-01-11 09:50 - 2017-01-11 09:51 - 00581186 _____ C:\TDSSKiller.3.1.0.12_11.01.2017_09.50.09_log.txt
2017-01-11 09:50 - 2017-01-11 09:50 - 04747704 _____ (AO Kaspersky Lab) C:\Users\Jarvis\Downloads\tdsskiller.exe
2017-01-11 09:49 - 2017-01-11 11:51 - 00000000 ____D C:\AdwCleaner
2017-01-11 09:49 - 2017-01-11 09:49 - 05659315 _____ (Swearware) C:\Users\Jarvis\Downloads\ComboFix.exe
2017-01-11 09:49 - 2017-01-11 09:49 - 03988944 _____ C:\Users\Jarvis\Downloads\AdwCleaner.exe
2017-01-11 09:48 - 2017-01-11 09:48 - 136603928 _____ (Microsoft Corporation) C:\Users\Jarvis\Downloads\msert.exe
2017-01-11 09:47 - 2017-01-11 09:47 - 06771840 _____ (ESET spol. s r.o.) C:\Users\Jarvis\Downloads\esetonlinescanner_enu.exe
2017-01-11 09:47 - 2017-01-11 09:47 - 00000000 ____D C:\Users\Jarvis\AppData\Local\ESET
2017-01-11 00:17 - 2016-12-21 00:08 - 00245600 _____ (Microsoft Corporation) C:\WINDOWS\system32\offlinesam.dll
2017-01-11 00:17 - 2016-12-21 00:08 - 00136032 _____ (Microsoft Corporation) C:\WINDOWS\system32\ImplatSetup.dll
2017-01-11 00:17 - 2016-12-21 00:04 - 07816032 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
2017-01-11 00:17 - 2016-12-20 23:49 - 00328008 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Storage.ApplicationData.dll
2017-01-11 00:17 - 2016-12-20 23:46 - 00624048 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cng.sys
2017-01-11 00:17 - 2016-12-20 23:43 - 04130440 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
2017-01-11 00:17 - 2016-12-20 23:43 - 01454504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfnetsrc.dll
2017-01-11 00:17 - 2016-12-20 23:43 - 01071736 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfnetcore.dll
2017-01-11 00:17 - 2016-12-20 23:43 - 00092512 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
2017-01-11 00:17 - 2016-12-20 23:42 - 22224480 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
2017-01-11 00:17 - 2016-12-20 23:42 - 01988560 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfmp4srcsnk.dll
2017-01-11 00:17 - 2016-12-20 23:42 - 01702392 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfasfsrcsnk.dll
2017-01-11 00:17 - 2016-12-20 23:42 - 01300600 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfmpeg2srcsnk.dll
2017-01-11 00:17 - 2016-12-20 23:41 - 01600632 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppobjs.dll
2017-01-11 00:17 - 2016-12-20 23:37 - 00455520 _____ (Microsoft Corporation) C:\WINDOWS\system32\securekernel.exe
2017-01-11 00:17 - 2016-12-20 23:15 - 22563840 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
2017-01-11 00:17 - 2016-12-20 23:14 - 00043008 _____ (Microsoft Corporation) C:\WINDOWS\system32\LaunchWinApp.exe
2017-01-11 00:17 - 2016-12-20 23:09 - 00368640 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneBackupHandler.dll
2017-01-11 00:17 - 2016-12-20 23:09 - 00363520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.BioFeedback.dll
2017-01-11 00:17 - 2016-12-20 23:08 - 00418304 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.BlockedShutdown.dll
2017-01-11 00:17 - 2016-12-20 23:08 - 00360448 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpencom.dll
2017-01-11 00:17 - 2016-12-20 23:08 - 00289792 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeveloperOptionsSettingsHandlers.dll
2017-01-11 00:17 - 2016-12-20 23:08 - 00211968 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgent.exe
2017-01-11 00:17 - 2016-12-20 23:07 - 00748544 _____ (Microsoft Corporation) C:\WINDOWS\system32\StoreAgent.dll
2017-01-11 00:17 - 2016-12-20 23:06 - 06285312 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
2017-01-11 00:17 - 2016-12-20 23:06 - 00310784 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncSettings.dll
2017-01-11 00:17 - 2016-12-20 23:06 - 00260608 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallAgentUserBroker.exe
2017-01-11 00:17 - 2016-12-20 23:06 - 00147456 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrv.dll
2017-01-11 00:17 - 2016-12-20 23:05 - 00425984 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadcloudap.dll
2017-01-11 00:17 - 2016-12-20 23:05 - 00261632 _____ (Microsoft Corporation) C:\WINDOWS\system32\indexeddbserver.dll
2017-01-11 00:17 - 2016-12-20 23:05 - 00049152 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Shell.dll
2017-01-11 00:17 - 2016-12-20 23:01 - 09131008 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
2017-01-11 00:17 - 2016-12-20 23:00 - 00440320 _____ (Microsoft Corporation) C:\WINDOWS\system32\fhcfg.dll
2017-01-11 00:17 - 2016-12-20 22:59 - 01908224 _____ (Microsoft Corporation) C:\WINDOWS\system32\AzureSettingSyncProvider.dll
2017-01-11 00:17 - 2016-12-20 22:59 - 00883712 _____ (Microsoft Corporation) C:\WINDOWS\system32\samsrv.dll
2017-01-11 00:17 - 2016-12-20 22:58 - 23678464 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
2017-01-11 00:17 - 2016-12-20 22:57 - 00462336 _____ (Microsoft Corporation) C:\WINDOWS\system32\fhsettingsprovider.dll
2017-01-11 00:17 - 2016-12-20 22:56 - 00947712 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVP9DEC.dll
2017-01-11 00:17 - 2016-12-20 22:56 - 00936960 _____ (Microsoft Corporation) C:\WINDOWS\system32\MCRecvSrc.dll
2017-01-11 00:17 - 2016-12-20 22:55 - 08129536 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
2017-01-11 00:17 - 2016-12-20 22:55 - 04749312 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
2017-01-11 00:17 - 2016-12-20 22:54 - 05511680 _____ (Microsoft Corporation) C:\WINDOWS\system32\aclui.dll
2017-01-11 00:17 - 2016-12-20 22:53 - 06664192 _____ (Microsoft Corporation) C:\WINDOWS\system32\mspaint.exe
2017-01-11 00:17 - 2016-12-20 22:53 - 04474368 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_47.dll
2017-01-11 00:17 - 2016-12-20 22:53 - 01692672 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.onecore.dll
2017-01-11 00:17 - 2016-12-20 22:51 - 08075776 _____ (Microsoft Corporation) C:\WINDOWS\system32\mstscax.dll
2017-01-11 00:17 - 2016-12-20 22:51 - 05611008 _____ (Microsoft Corporation) C:\WINDOWS\system32\d2d1.dll
2017-01-11 00:17 - 2016-12-20 22:51 - 02275840 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
2017-01-11 00:17 - 2016-12-20 22:50 - 01490432 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
2017-01-11 00:17 - 2016-12-20 22:49 - 04149248 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcorets.dll
2017-01-11 00:17 - 2016-12-20 22:49 - 02691072 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Logon.dll
2017-01-11 00:17 - 2016-12-20 22:49 - 01062912 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSyncCore.dll
2017-01-11 00:17 - 2016-12-20 22:47 - 01121280 _____ (Microsoft Corporation) C:\WINDOWS\system32\aadtb.dll
2017-01-11 00:17 - 2016-12-20 21:59 - 00218976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\offlinesam.dll
2017-01-11 00:17 - 2016-12-20 21:09 - 00263472 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Storage.ApplicationData.dll
2017-01-11 00:17 - 2016-12-20 21:02 - 03892864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
2017-01-11 00:17 - 2016-12-20 21:02 - 01852720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfmp4srcsnk.dll
2017-01-11 00:17 - 2016-12-20 21:02 - 01360464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfnetsrc.dll
2017-01-11 00:17 - 2016-12-20 21:02 - 01277344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfasfsrcsnk.dll
2017-01-11 00:17 - 2016-12-20 21:02 - 01201872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfmpeg2srcsnk.dll
2017-01-11 00:17 - 2016-12-20 21:02 - 00980832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfnetcore.dll
2017-01-11 00:17 - 2016-12-20 21:01 - 20969928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
2017-01-11 00:17 - 2016-12-20 20:46 - 00034304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LaunchWinApp.exe
2017-01-11 00:17 - 2016-12-20 20:43 - 00285184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.BlockedShutdown.dll
2017-01-11 00:17 - 2016-12-20 20:41 - 00253952 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.BioFeedback.dll
2017-01-11 00:17 - 2016-12-20 20:41 - 00231936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.LockScreen.dll
2017-01-11 00:17 - 2016-12-20 20:40 - 00557568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\StoreAgent.dll
2017-01-11 00:17 - 2016-12-20 20:40 - 00318976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpencom.dll
2017-01-11 00:17 - 2016-12-20 20:40 - 00237056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SyncSettings.dll
2017-01-11 00:17 - 2016-12-20 20:40 - 00180224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgent.exe
2017-01-11 00:17 - 2016-12-20 20:39 - 01300480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVPXENC.dll
2017-01-11 00:17 - 2016-12-20 20:39 - 00223232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallAgentUserBroker.exe
2017-01-11 00:17 - 2016-12-20 20:38 - 00866816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Cred.dll
2017-01-11 00:17 - 2016-12-20 20:35 - 04612608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
2017-01-11 00:17 - 2016-12-20 20:35 - 00198656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\indexeddbserver.dll
2017-01-11 00:17 - 2016-12-20 20:34 - 07626752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
2017-01-11 00:17 - 2016-12-20 20:33 - 19413504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
2017-01-11 00:17 - 2016-12-20 20:32 - 19417600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
2017-01-11 00:17 - 2016-12-20 20:30 - 05398016 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aclui.dll
2017-01-11 00:17 - 2016-12-20 20:30 - 01255936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AzureSettingSyncProvider.dll
2017-01-11 00:17 - 2016-12-20 20:27 - 00640000 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MCRecvSrc.dll
2017-01-11 00:17 - 2016-12-20 20:26 - 01155072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVP9DEC.dll
2017-01-11 00:17 - 2016-12-20 20:25 - 07469056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mstscax.dll
2017-01-11 00:17 - 2016-12-20 20:25 - 06474752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspaint.exe
2017-01-11 00:17 - 2016-12-20 20:24 - 06044160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
2017-01-11 00:17 - 2016-12-20 20:24 - 00886272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aadtb.dll
2017-01-11 00:17 - 2016-12-20 20:22 - 01883648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Logon.dll
2017-01-11 00:17 - 2016-12-20 20:22 - 00860672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSyncCore.dll
2017-01-11 00:17 - 2016-12-13 21:41 - 01235296 _____ (Microsoft Corporation) C:\WINDOWS\system32\aeinv.dll
2017-01-11 00:17 - 2016-12-13 21:41 - 00590960 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioSes.dll
2017-01-11 00:17 - 2016-12-13 21:34 - 02482280 _____ (Microsoft Corporation) C:\WINDOWS\system32\msmpeg2vdec.dll
2017-01-11 00:17 - 2016-12-13 21:33 - 01356864 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipUp.exe
2017-01-11 00:17 - 2016-12-13 21:23 - 00404832 _____ (Microsoft Corporation) C:\WINDOWS\system32\msv1_0.dll
2017-01-11 00:17 - 2016-12-13 21:21 - 02206496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msmpeg2vdec.dll
2017-01-11 00:17 - 2016-12-13 21:19 - 00584544 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSyncHost.exe
2017-01-11 00:17 - 2016-12-13 21:18 - 00715104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vhdmp.sys
2017-01-11 00:17 - 2016-12-13 21:18 - 00335712 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\pci.sys
2017-01-11 00:17 - 2016-12-13 21:17 - 00319288 _____ (Microsoft Corporation) C:\WINDOWS\system32\wow64.dll
2017-01-11 00:17 - 2016-12-13 21:14 - 01694712 _____ (Microsoft Corporation) C:\WINDOWS\system32\winmde.dll
2017-01-11 00:17 - 2016-12-13 21:14 - 00418952 _____ (Microsoft Corporation) C:\WINDOWS\system32\AUDIOKSE.dll
2017-01-11 00:17 - 2016-12-13 21:14 - 00089416 _____ (Microsoft Corporation) C:\WINDOWS\system32\remoteaudioendpoint.dll
2017-01-11 00:17 - 2016-12-13 21:06 - 00509792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSyncHost.exe
2017-01-11 00:17 - 2016-12-13 21:01 - 01557808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winmde.dll
2017-01-11 00:17 - 2016-12-13 21:01 - 00382784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AUDIOKSE.dll
2017-01-11 00:17 - 2016-12-13 21:01 - 00076984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\remoteaudioendpoint.dll
2017-01-11 00:17 - 2016-12-13 20:48 - 01631232 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll
2017-01-11 00:17 - 2016-12-13 20:46 - 01631232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.Resources.dll
2017-01-11 00:17 - 2016-12-13 20:46 - 00206848 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32k.sys
2017-01-11 00:17 - 2016-12-13 20:43 - 00201728 _____ (Microsoft Corporation) C:\WINDOWS\system32\ScDeviceEnum.dll
2017-01-11 00:17 - 2016-12-13 20:42 - 00352768 _____ (Microsoft Corporation) C:\WINDOWS\system32\cloudAP.dll
2017-01-11 00:17 - 2016-12-13 20:42 - 00236544 _____ (Microsoft Corporation) C:\WINDOWS\system32\WinSCard.dll
2017-01-11 00:17 - 2016-12-13 20:42 - 00208896 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.UI.Logon.ProxyStub.dll
2017-01-11 00:17 - 2016-12-13 20:42 - 00167424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WinSCard.dll
2017-01-11 00:17 - 2016-12-13 20:41 - 00223744 _____ (Microsoft Corporation) C:\WINDOWS\system32\ie4uinit.exe
2017-01-11 00:17 - 2016-12-13 20:40 - 00324096 _____ (Microsoft Corporation) C:\WINDOWS\system32\domgmt.dll
2017-01-11 00:17 - 2016-12-13 20:40 - 00231424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudBackupSettings.dll
2017-01-11 00:17 - 2016-12-13 20:40 - 00193536 _____ (Microsoft Corporation) C:\WINDOWS\system32\certprop.dll
2017-01-11 00:17 - 2016-12-13 20:39 - 00837632 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbiosrvc.dll
2017-01-11 00:17 - 2016-12-13 20:39 - 00290816 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatehandlers.dll
2017-01-11 00:17 - 2016-12-13 20:39 - 00257024 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.CredDialogController.dll
2017-01-11 00:17 - 2016-12-13 20:38 - 17188864 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
2017-01-11 00:17 - 2016-12-13 20:38 - 13869056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
2017-01-11 00:17 - 2016-12-13 20:38 - 00295424 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudBackupSettings.dll
2017-01-11 00:17 - 2016-12-13 20:38 - 00213504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.CredDialogController.dll
2017-01-11 00:17 - 2016-12-13 20:37 - 00090112 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatepolicy.dll
2017-01-11 00:17 - 2016-12-13 20:36 - 01002496 _____ (Microsoft Corporation) C:\WINDOWS\system32\SRH.dll
2017-01-11 00:17 - 2016-12-13 20:36 - 00539648 _____ (Microsoft Corporation) C:\WINDOWS\system32\usocore.dll
2017-01-11 00:17 - 2016-12-13 20:36 - 00074752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\updatepolicy.dll
2017-01-11 00:17 - 2016-12-13 20:35 - 00755712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\kerberos.dll
2017-01-11 00:17 - 2016-12-13 20:35 - 00712192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wuapi.dll
2017-01-11 00:17 - 2016-12-13 20:35 - 00600576 _____ (Microsoft Corporation) C:\WINDOWS\system32\cryptui.dll
2017-01-11 00:17 - 2016-12-13 20:35 - 00553984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cryptui.dll
2017-01-11 00:17 - 2016-12-13 20:32 - 00497152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LogonController.dll
2017-01-11 00:17 - 2016-12-13 20:26 - 00932864 _____ (Microsoft Corporation) C:\WINDOWS\system32\kerberos.dll
2017-01-11 00:17 - 2016-12-13 20:26 - 00869888 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuapi.dll
2017-01-11 00:17 - 2016-12-13 20:25 - 02009600 _____ (Microsoft Corporation) C:\WINDOWS\system32\SRHInproc.dll
2017-01-11 00:17 - 2016-12-13 20:24 - 01005568 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3D12.dll
2017-01-11 00:17 - 2016-12-13 20:24 - 00673792 _____ (Microsoft Corporation) C:\WINDOWS\system32\winlogon.exe
2017-01-11 00:17 - 2016-12-13 20:23 - 03134976 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcore.dll
2017-01-11 00:17 - 2016-12-13 20:23 - 01231872 _____ (Microsoft Corporation) C:\WINDOWS\system32\dosvc.dll
2017-01-11 00:17 - 2016-12-13 20:22 - 02998272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
2017-01-11 00:17 - 2016-12-13 20:22 - 02748416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpcore.dll
2017-01-11 00:17 - 2016-12-13 20:22 - 02317824 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
2017-01-11 00:17 - 2016-12-13 20:22 - 01513472 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
2017-01-11 00:17 - 2016-12-13 20:22 - 00391168 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
2017-01-11 00:17 - 2016-12-13 20:21 - 03616768 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
2017-01-11 00:17 - 2016-11-02 04:01 - 00484584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioSes.dll
2017-01-11 00:17 - 2016-11-02 03:00 - 00534096 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEng.dll
2017-01-11 00:17 - 2016-11-02 02:28 - 00324608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.LockScreen.dll
2017-01-11 00:17 - 2016-11-02 02:22 - 00337920 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEndpointBuilder.dll
2017-01-11 00:17 - 2016-11-02 02:21 - 00942080 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
2017-01-11 00:17 - 2016-08-01 20:30 - 00822784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakradiag.dll
2017-01-11 00:16 - 2016-12-20 23:42 - 00241504 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudExperienceHost.dll
2017-01-11 00:16 - 2016-12-20 23:13 - 00119808 _____ (Microsoft Corporation) C:\WINDOWS\system32\KnobsCsp.dll
2017-01-11 00:16 - 2016-12-20 23:12 - 00083968 _____ (Microsoft Corporation) C:\WINDOWS\system32\ProvPluginEng.dll
2017-01-11 00:16 - 2016-12-20 23:10 - 00234496 _____ (Microsoft Corporation) C:\WINDOWS\system32\KnobsCore.dll
2017-01-11 00:16 - 2016-12-20 23:08 - 01292288 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVPXENC.dll
2017-01-11 00:16 - 2016-12-20 23:08 - 00349184 _____ (Microsoft Corporation) C:\WINDOWS\system32\provengine.dll
2017-01-11 00:16 - 2016-12-20 20:24 - 05061120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d2d1.dll
2017-01-11 00:16 - 2016-12-20 20:24 - 03733504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_47.dll
2017-01-11 00:16 - 2016-12-13 21:08 - 00341344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msv1_0.dll
2017-01-11 00:16 - 2016-12-13 20:45 - 00147968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32k.sys
2017-01-11 00:16 - 2016-12-13 20:40 - 00266752 _____ (Microsoft Corporation) C:\WINDOWS\system32\ConsoleLogon.dll
2017-01-11 00:16 - 2016-12-13 20:40 - 00104448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Internal.UI.Logon.ProxyStub.dll
2017-01-11 00:16 - 2016-12-13 20:32 - 00806400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3D12.dll
2017-01-11 00:16 - 2016-12-13 20:22 - 00707584 _____ (Microsoft Corporation) C:\WINDOWS\system32\LogonController.dll
2017-01-10 22:50 - 2017-01-20 05:36 - 00001951 _____ C:\WINDOWS\NvTelemetryContainerRecovery.bat
2017-01-10 22:49 - 2017-01-20 10:39 - 00057792 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvvhci.sys
2017-01-10 22:49 - 2017-01-05 17:10 - 00158264 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvaudcap64v.dll
2017-01-10 22:49 - 2017-01-05 17:10 - 00126008 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvaudcap32v.dll
2017-01-10 22:49 - 2017-01-05 17:10 - 00047672 _____ (NVIDIA Corporation) C:\WINDOWS\system32\Drivers\nvvad64v.sys
2017-01-10 22:32 - 2017-01-10 22:32 - 00696320 _____ (Speed Guide Inc.) C:\Users\Jarvis\Downloads\TCPOptimizer.exe
2017-01-10 22:28 - 2017-01-10 22:28 - 00353632 _____ C:\Users\Jarvis\Downloads\rsthosts_2.0.exe
2017-01-10 22:26 - 2017-01-10 22:26 - 00167296 _____ (Gibson Research Corp.) C:\Users\Jarvis\Downloads\DNSBench.exe
2017-01-10 22:12 - 2017-01-10 22:12 - 00000807 _____ C:\Users\Jarvis\Desktop\Other Documents.lnk
2017-01-10 22:03 - 2017-01-10 22:03 - 01663040 _____ (Malwarebytes) C:\Users\Jarvis\Downloads\JRT.exe
2017-01-10 21:48 - 2016-03-10 00:19 - 00089600 _____ (Micro-Star Int'l Co., Ltd.) C:\WINDOWS\system32\RAMDriv.dll
2017-01-10 21:48 - 2016-03-10 00:02 - 00086936 _____ (Micro-Star Int'l Co., Ltd.) C:\WINDOWS\system32\Drivers\RAMDriv.sys
2017-01-10 21:45 - 2017-01-10 21:45 - 00003132 _____ C:\WINDOWS\System32\Tasks\MSIOSDx86_Host
2017-01-10 21:45 - 2017-01-10 21:45 - 00003132 _____ C:\WINDOWS\System32\Tasks\MSIOSDx64_Host
2017-01-10 21:45 - 2015-09-28 22:16 - 02004904 _____ (cFos Software GmbH) C:\WINDOWS\system32\Drivers\cfosspeed6.sys
2017-01-10 21:33 - 2017-01-31 13:03 - 00003738 _____ C:\WINDOWS\System32\Tasks\Intel PTT EK Recertification
2017-01-10 21:33 - 2017-01-10 21:33 - 00000472 _____ C:\WINDOWS\SysWOW64\Saved_Config.txt
2017-01-10 21:33 - 2017-01-10 21:33 - 00000135 _____ C:\WINDOWS\SysWOW64\Saved_StaticIP.txt
2017-01-10 21:33 - 2016-07-26 09:48 - 00543184 _____ (Intel Corporation) C:\WINDOWS\system32\Drivers\e1d65x64.sys
2017-01-10 21:33 - 2015-11-24 11:23 - 00003130 _____ C:\WINDOWS\system32\e1d65x64.din
2017-01-10 21:33 - 2014-04-18 12:17 - 00125728 _____ (Intel Corporation) C:\WINDOWS\system32\NicCo4.dll
2017-01-10 21:27 - 2017-01-10 21:27 - 00031152 _____ C:\WINDOWS\system32\Drivers\pmxdrv.sys
2017-01-10 21:24 - 2017-01-10 21:24 - 00000000 ____D C:\Program Files (x86)\Setup Files
2017-01-10 21:20 - 2016-11-11 15:23 - 00001348 _____ C:\WINDOWS\SysWOW64\LiveUpdate 6.2 ReleaseNote.txt
2017-01-10 15:28 - 2017-02-02 01:14 - 00000000 ____D C:\Program Files (x86)\Mozilla Firefox
2017-01-10 15:18 - 2017-01-10 16:42 - 00000000 ____D C:\Program Files (x86)\Spiceworks Traceroute
2017-01-10 15:18 - 2017-01-10 15:18 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\systray
2017-01-10 15:18 - 2017-01-10 15:18 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinPcap
2017-01-10 15:18 - 2017-01-10 15:18 - 00000000 ____D C:\Program Files (x86)\WinPcap
2017-01-10 12:50 - 2017-02-06 19:54 - 00000830 _____ C:\WINDOWS\Tasks\Adobe Flash Player Updater.job
2017-01-10 12:50 - 2017-02-06 00:18 - 00003816 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
2017-01-10 12:50 - 2017-01-10 21:29 - 00000892 _____ C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job
2017-01-10 12:50 - 2017-01-10 12:50 - 00003962 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player PPAPI Notifier
2017-01-10 10:12 - 2017-01-24 20:52 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java
2017-01-10 10:12 - 2017-01-24 20:52 - 00000000 ____D C:\Program Files (x86)\Java
2017-01-10 10:12 - 2017-01-24 20:51 - 00097856 _____ (Oracle Corporation) C:\WINDOWS\SysWOW64\WindowsAccessBridge-32.dll
2017-01-10 09:59 - 2017-01-10 09:59 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
2017-01-10 09:59 - 2017-01-10 09:59 - 00000000 ____D C:\Program Files\Microsoft Silverlight
2017-01-10 09:59 - 2017-01-10 09:59 - 00000000 ____D C:\Program Files (x86)\Microsoft Silverlight
2017-01-09 10:17 - 2017-01-09 10:17 - 05227019 _____ C:\Users\Jarvis\Downloads\namebench-1.3.1-Windows.exe
2017-01-09 01:43 - 2017-01-09 01:43 - 00001072 _____ C:\Users\Jarvis\Desktop\Curse (2).lnk
2017-01-09 01:42 - 2017-01-09 01:42 - 00001072 _____ C:\Users\Jarvis\Desktop\Curse.lnk
2017-01-09 01:39 - 2017-01-09 01:39 - 00002047 _____ C:\Users\Jarvis\Desktop\CAM (2).lnk
2017-01-09 01:33 - 2017-01-28 11:43 - 00001487 _____ C:\Users\Public\Desktop\GeForce Experience.lnk
2017-01-09 01:33 - 2017-01-20 10:39 - 01755072 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspbridge64.dll
2017-01-09 01:33 - 2017-01-20 10:39 - 01317312 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspbridge.dll
2017-01-09 01:33 - 2017-01-10 22:53 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
2017-01-09 00:47 - 2017-01-09 00:47 - 00000000 ____D C:\Users\Jarvis\Downloads\x64
2017-01-09 00:31 - 2017-01-09 00:45 - 01206060 _____ (Igor Pavlov) C:\Users\Jarvis\Downloads\DDU v15.3.1.0.exe
2016-12-29 22:30 - 2016-12-29 22:30 - 00000000 ____D C:\Program Files (x86)\NZXT
2016-12-29 20:43 - 2016-12-29 20:43 - 00000000 ____H C:\WINDOWS\system32\Drivers\Msft_User_WpdMtpDr_01_11_00.Wdf
2016-12-29 17:48 - 2017-01-09 01:31 - 00005110 _____ C:\ProgramData\NvTelemetryContainer.log
2016-12-29 17:48 - 2017-01-09 00:48 - 00004984 _____ C:\ProgramData\NvTelemetryContainer.log_backup1
2016-12-29 14:15 - 2016-12-29 14:15 - 00000000 ____D C:\Users\Jarvis\Documents\Respawn
2016-12-28 05:03 - 2010-06-02 04:55 - 00527192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_7.dll
2016-12-28 05:03 - 2010-06-02 04:55 - 00518488 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_7.dll
2016-12-28 05:03 - 2010-06-02 04:55 - 00239960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_7.dll
2016-12-28 05:03 - 2010-06-02 04:55 - 00176984 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_7.dll
2016-12-28 05:03 - 2010-06-02 04:55 - 00077656 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_5.dll
2016-12-28 05:03 - 2010-06-02 04:55 - 00074072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_5.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 02526056 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_43.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 02401112 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_43.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 02106216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_43.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 01998168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_43.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 01907552 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dcsx_43.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 01868128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dcsx_43.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 00511328 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_43.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 00470880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_43.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 00276832 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx11_43.dll
2016-12-28 05:03 - 2010-05-26 11:41 - 00248672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx11_43.dll
2016-12-28 05:03 - 2010-02-04 10:01 - 00530776 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_6.dll
2016-12-28 05:03 - 2010-02-04 10:01 - 00528216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_6.dll
2016-12-28 05:03 - 2010-02-04 10:01 - 00238936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_6.dll
2016-12-28 05:03 - 2010-02-04 10:01 - 00176984 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_6.dll
2016-12-28 05:03 - 2010-02-04 10:01 - 00078680 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_4.dll
2016-12-28 05:03 - 2010-02-04 10:01 - 00074072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_4.dll
2016-12-28 05:03 - 2010-02-04 10:01 - 00024920 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_7.dll
2016-12-28 05:03 - 2010-02-04 10:01 - 00022360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_7.dll
2016-12-28 05:03 - 2009-09-04 17:44 - 00517960 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_5.dll
2016-12-28 05:03 - 2009-09-04 17:44 - 00515416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_5.dll
2016-12-28 05:03 - 2009-09-04 17:44 - 00238936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_5.dll
2016-12-28 05:03 - 2009-09-04 17:44 - 00176968 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_5.dll
2016-12-28 05:03 - 2009-09-04 17:44 - 00073544 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_3.dll
2016-12-28 05:03 - 2009-09-04 17:44 - 00069464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_3.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 05554512 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dcsx_42.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 05501792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dcsx_42.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 02582888 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_42.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 02475352 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_42.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 01974616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_42.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 01892184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_42.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 00523088 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_42.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 00453456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_42.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 00285024 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx11_42.dll
2016-12-28 05:03 - 2009-09-04 17:29 - 00235344 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx11_42.dll
2016-12-28 05:03 - 2009-03-16 14:18 - 00521560 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_4.dll
2016-12-28 05:03 - 2009-03-16 14:18 - 00517448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_4.dll
2016-12-28 05:03 - 2009-03-16 14:18 - 00235352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_4.dll
2016-12-28 05:03 - 2009-03-16 14:18 - 00174936 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_4.dll
2016-12-28 05:03 - 2009-03-16 14:18 - 00024920 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_6.dll
2016-12-28 05:03 - 2009-03-16 14:18 - 00022360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_6.dll
2016-12-28 05:03 - 2009-03-09 15:27 - 05425496 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_41.dll
2016-12-28 05:03 - 2009-03-09 15:27 - 04178264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_41.dll
2016-12-28 05:03 - 2009-03-09 15:27 - 02430312 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_41.dll
2016-12-28 05:03 - 2009-03-09 15:27 - 01846632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_41.dll
2016-12-28 05:03 - 2009-03-09 15:27 - 00520544 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_41.dll
2016-12-28 05:03 - 2009-03-09 15:27 - 00453456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_41.dll
2016-12-28 05:03 - 2008-10-27 10:04 - 00518480 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_3.dll
2016-12-28 05:03 - 2008-10-27 10:04 - 00514384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_3.dll
2016-12-28 05:03 - 2008-10-27 10:04 - 00235856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_3.dll
2016-12-28 05:03 - 2008-10-27 10:04 - 00175440 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_3.dll
2016-12-28 05:03 - 2008-10-27 10:04 - 00074576 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_2.dll
2016-12-28 05:03 - 2008-10-27 10:04 - 00070992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_2.dll
2016-12-28 05:03 - 2008-10-27 10:04 - 00025936 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_5.dll
2016-12-28 05:03 - 2008-10-27 10:04 - 00023376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_5.dll
2016-12-28 05:03 - 2008-10-15 06:22 - 05631312 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_40.dll
2016-12-28 05:03 - 2008-10-15 06:22 - 04379984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_40.dll
2016-12-28 05:03 - 2008-10-15 06:22 - 02605920 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_40.dll
2016-12-28 05:03 - 2008-10-15 06:22 - 02036576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_40.dll
2016-12-28 05:03 - 2008-10-15 06:22 - 00519000 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_40.dll
2016-12-28 05:03 - 2008-10-15 06:22 - 00452440 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_40.dll
2016-12-28 05:03 - 2008-07-31 10:41 - 00238088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_2.dll
2016-12-28 05:03 - 2008-07-31 10:41 - 00177672 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_2.dll
2016-12-28 05:03 - 2008-07-31 10:41 - 00072200 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_1.dll
2016-12-28 05:03 - 2008-07-31 10:41 - 00068616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_1.dll
2016-12-28 05:03 - 2008-07-31 10:40 - 00513544 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_2.dll
2016-12-28 05:03 - 2008-07-31 10:40 - 00509448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_2.dll
2016-12-28 05:03 - 2008-07-10 11:01 - 00467984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_39.dll
2016-12-28 05:03 - 2008-07-10 11:00 - 04992520 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_39.dll
2016-12-28 05:03 - 2008-07-10 11:00 - 03851784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_39.dll
2016-12-28 05:03 - 2008-07-10 11:00 - 01942552 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_39.dll
2016-12-28 05:03 - 2008-07-10 11:00 - 01493528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_39.dll
2016-12-28 05:03 - 2008-07-10 11:00 - 00540688 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_39.dll
2016-12-28 05:03 - 2008-05-30 14:19 - 00511496 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_1.dll
2016-12-28 05:03 - 2008-05-30 14:19 - 00507400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_1.dll
2016-12-28 05:03 - 2008-05-30 14:18 - 00238088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_1.dll
2016-12-28 05:03 - 2008-05-30 14:18 - 00177672 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_1.dll
2016-12-28 05:03 - 2008-05-30 14:17 - 00068104 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAPOFX1_0.dll
2016-12-28 05:03 - 2008-05-30 14:17 - 00065032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAPOFX1_0.dll
2016-12-28 05:03 - 2008-05-30 14:17 - 00025608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_4.dll
2016-12-28 05:03 - 2008-05-30 14:16 - 00028168 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_4.dll
2016-12-28 05:03 - 2008-05-30 14:11 - 04991496 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_38.dll
2016-12-28 05:03 - 2008-05-30 14:11 - 03850760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_38.dll
2016-12-28 05:03 - 2008-05-30 14:11 - 01941528 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_38.dll
2016-12-28 05:03 - 2008-05-30 14:11 - 01491992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_38.dll
2016-12-28 05:03 - 2008-05-30 14:11 - 00540688 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_38.dll
2016-12-28 05:03 - 2008-05-30 14:11 - 00467984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_38.dll
2016-12-28 05:03 - 2008-03-05 16:04 - 00489480 _____ (Microsoft Corporation) C:\WINDOWS\system32\XAudio2_0.dll
2016-12-28 05:03 - 2008-03-05 16:03 - 00479752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\XAudio2_0.dll
2016-12-28 05:03 - 2008-03-05 16:03 - 00238088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine3_0.dll
2016-12-28 05:03 - 2008-03-05 16:03 - 00177672 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine3_0.dll
2016-12-28 05:03 - 2008-03-05 16:00 - 00028168 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_3.dll
2016-12-28 05:03 - 2008-03-05 16:00 - 00025608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_3.dll
2016-12-28 05:03 - 2008-03-05 15:56 - 04910088 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DX9_37.dll
2016-12-28 05:03 - 2008-03-05 15:56 - 03786760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DX9_37.dll
2016-12-28 05:03 - 2008-03-05 15:56 - 01860120 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_37.dll
2016-12-28 05:03 - 2008-03-05 15:56 - 01420824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_37.dll
2016-12-28 05:03 - 2008-02-05 23:07 - 00529424 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_37.dll
2016-12-28 05:03 - 2008-02-05 23:07 - 00462864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_37.dll
2016-12-28 05:03 - 2007-10-22 03:40 - 00411656 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_10.dll
2016-12-28 05:03 - 2007-10-22 03:39 - 00267272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_10.dll
2016-12-28 05:03 - 2007-10-22 03:37 - 00021000 _____ (Microsoft Corporation) C:\WINDOWS\system32\X3DAudio1_2.dll
2016-12-28 05:03 - 2007-10-22 03:37 - 00017928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\X3DAudio1_2.dll
2016-12-28 05:03 - 2007-10-12 15:14 - 05081608 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_36.dll
2016-12-28 05:03 - 2007-10-12 15:14 - 03734536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_36.dll
2016-12-28 05:03 - 2007-10-12 15:14 - 02006552 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_36.dll
2016-12-28 05:03 - 2007-10-12 15:14 - 01374232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_36.dll
2016-12-28 05:03 - 2007-10-02 09:56 - 00508264 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_36.dll
2016-12-28 05:03 - 2007-10-02 09:56 - 00444776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_36.dll
2016-12-28 05:03 - 2007-07-20 00:57 - 00411496 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_9.dll
2016-12-28 05:03 - 2007-07-20 00:57 - 00267112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_9.dll
2016-12-28 05:03 - 2007-07-19 18:14 - 05073256 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_35.dll
2016-12-28 05:03 - 2007-07-19 18:14 - 03727720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_35.dll
2016-12-28 05:03 - 2007-07-19 18:14 - 01985904 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_35.dll
2016-12-28 05:03 - 2007-07-19 18:14 - 01358192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_35.dll
2016-12-28 05:03 - 2007-07-19 18:14 - 00508264 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_35.dll
2016-12-28 05:03 - 2007-07-19 18:14 - 00444776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_35.dll
2016-12-28 05:03 - 2007-06-20 20:49 - 00409960 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_8.dll
2016-12-28 05:03 - 2007-06-20 20:46 - 00266088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_8.dll
2016-12-28 05:03 - 2007-05-16 16:45 - 04496232 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_34.dll
2016-12-28 05:03 - 2007-05-16 16:45 - 03497832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_34.dll
2016-12-28 05:03 - 2007-05-16 16:45 - 01401200 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_34.dll
2016-12-28 05:03 - 2007-05-16 16:45 - 01124720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_34.dll
2016-12-28 05:03 - 2007-05-16 16:45 - 00506728 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_34.dll
2016-12-28 05:03 - 2007-05-16 16:45 - 00443752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_34.dll
2016-12-28 05:03 - 2007-04-04 18:55 - 00403304 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_7.dll
2016-12-28 05:03 - 2007-04-04 18:55 - 00261480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_7.dll
2016-12-28 05:03 - 2007-04-04 18:54 - 00107368 _____ (Microsoft Corporation) C:\WINDOWS\system32\xinput1_3.dll
2016-12-28 05:03 - 2007-04-04 18:53 - 00081768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xinput1_3.dll
2016-12-28 05:03 - 2007-03-15 16:57 - 00506728 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10_33.dll
2016-12-28 05:03 - 2007-03-15 16:57 - 00443752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10_33.dll
2016-12-28 05:03 - 2007-03-12 16:42 - 04494184 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_33.dll
2016-12-28 05:03 - 2007-03-12 16:42 - 03495784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_33.dll
2016-12-28 05:03 - 2007-03-12 16:42 - 01400176 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3DCompiler_33.dll
2016-12-28 05:03 - 2007-03-12 16:42 - 01123696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3DCompiler_33.dll
2016-12-28 05:03 - 2007-03-05 12:42 - 00017688 _____ (Microsoft Corporation) C:\WINDOWS\system32\x3daudio1_1.dll
2016-12-28 05:03 - 2007-03-05 12:42 - 00015128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\x3daudio1_1.dll
2016-12-28 05:03 - 2007-01-24 15:27 - 00393576 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_6.dll
2016-12-28 05:03 - 2007-01-24 15:27 - 00255848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_6.dll
2016-12-28 05:03 - 2006-12-08 12:02 - 00251672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_5.dll
2016-12-28 05:03 - 2006-12-08 12:00 - 00390424 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_5.dll
2016-12-28 05:03 - 2006-11-29 13:06 - 04398360 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_32.dll
2016-12-28 05:03 - 2006-11-29 13:06 - 03426072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_32.dll
2016-12-28 05:03 - 2006-11-29 13:06 - 00469264 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx10.dll
2016-12-28 05:03 - 2006-11-29 13:06 - 00440080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx10.dll
2016-12-28 05:03 - 2006-09-28 16:05 - 03977496 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_31.dll
2016-12-28 05:03 - 2006-09-28 16:05 - 02414360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_31.dll
2016-12-28 05:03 - 2006-09-28 16:05 - 00237848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_4.dll
2016-12-28 05:03 - 2006-09-28 16:04 - 00364824 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_4.dll
2016-12-28 05:03 - 2006-07-28 09:31 - 00083736 _____ (Microsoft Corporation) C:\WINDOWS\system32\xinput1_2.dll
2016-12-28 05:03 - 2006-07-28 09:30 - 00363288 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_3.dll
2016-12-28 05:03 - 2006-07-28 09:30 - 00236824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_3.dll
2016-12-28 05:03 - 2006-07-28 09:30 - 00062744 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xinput1_2.dll
2016-12-28 05:03 - 2006-05-31 07:24 - 00230168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_2.dll
2016-12-28 05:03 - 2006-05-31 07:22 - 00354072 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_2.dll
2016-12-28 05:03 - 2006-03-31 12:41 - 03927248 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_30.dll
2016-12-28 05:03 - 2006-03-31 12:40 - 02388176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_30.dll
2016-12-28 05:03 - 2006-03-31 12:40 - 00352464 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_1.dll
2016-12-28 05:03 - 2006-03-31 12:39 - 00229584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_1.dll
2016-12-28 05:03 - 2006-03-31 12:39 - 00083664 _____ (Microsoft Corporation) C:\WINDOWS\system32\xinput1_1.dll
2016-12-28 05:03 - 2006-03-31 12:39 - 00062672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xinput1_1.dll
2016-12-28 05:03 - 2006-02-03 08:43 - 03830992 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_29.dll
2016-12-28 05:03 - 2006-02-03 08:43 - 02332368 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_29.dll
2016-12-28 05:03 - 2006-02-03 08:42 - 00355536 _____ (Microsoft Corporation) C:\WINDOWS\system32\xactengine2_0.dll
2016-12-28 05:03 - 2006-02-03 08:42 - 00230096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xactengine2_0.dll
2016-12-28 05:03 - 2006-02-03 08:41 - 00016592 _____ (Microsoft Corporation) C:\WINDOWS\system32\x3daudio1_0.dll
2016-12-28 05:03 - 2006-02-03 08:41 - 00014032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\x3daudio1_0.dll
2016-12-28 05:03 - 2005-12-05 18:09 - 03815120 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_28.dll
2016-12-28 05:03 - 2005-12-05 18:09 - 02323664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_28.dll
2016-12-28 05:03 - 2005-07-22 19:59 - 03807440 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_27.dll
2016-12-28 05:03 - 2005-07-22 19:59 - 02319568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_27.dll
2016-12-28 05:03 - 2005-05-26 15:34 - 03767504 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_26.dll
2016-12-28 05:03 - 2005-05-26 15:34 - 02297552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_26.dll
2016-12-28 05:03 - 2005-03-18 17:19 - 03823312 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_25.dll
2016-12-28 05:03 - 2005-03-18 17:19 - 02337488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_25.dll
2016-12-28 05:03 - 2005-02-05 19:45 - 03544272 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3dx9_24.dll
2016-12-28 05:03 - 2005-02-05 19:45 - 02222800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3dx9_24.dll
2016-12-26 11:34 - 2017-01-03 18:07 - 00000000 ____D C:\WINDOWS\Minidump
2016-12-25 13:50 - 2016-12-25 13:50 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Gaijin
2016-12-25 12:06 - 2016-12-25 12:12 - 00000000 ____D C:\Users\Jarvis\Documents\Rainmeter
2016-12-25 12:06 - 2016-12-25 12:06 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Rainmeter
2016-12-25 12:05 - 2016-12-25 12:05 - 00001749 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Rainmeter.lnk
2016-12-25 12:05 - 2016-12-25 12:05 - 00000000 ____D C:\Program Files\Rainmeter
2016-12-23 18:39 - 2016-12-09 02:42 - 01637728 _____ (Microsoft Corporation) C:\WINDOWS\system32\appraiser.dll
2016-12-23 18:39 - 2016-12-09 02:42 - 00137568 _____ (Microsoft Corporation) C:\WINDOWS\system32\acmigration.dll
2016-12-23 18:39 - 2016-12-09 02:34 - 01051112 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
2016-12-23 18:39 - 2016-12-09 02:34 - 00894096 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
2016-12-23 18:39 - 2016-12-09 02:33 - 01354320 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
2016-12-23 18:39 - 2016-12-09 02:33 - 01173496 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
2016-12-23 18:39 - 2016-12-09 02:30 - 00377184 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\clfs.sys
2016-12-23 18:39 - 2016-12-09 02:29 - 02681200 _____ C:\WINDOWS\system32\CoreUIComponents.dll
2016-12-23 18:39 - 2016-12-09 02:28 - 00764392 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreMessaging.dll
2016-12-23 18:39 - 2016-12-09 02:27 - 00172528 _____ (Microsoft Corporation) C:\WINDOWS\system32\sspicli.dll
2016-12-23 18:39 - 2016-12-09 02:20 - 02677544 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d10warp.dll
2016-12-23 18:39 - 2016-12-09 02:20 - 02189664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
2016-12-23 18:39 - 2016-12-09 02:20 - 01738560 _____ (Microsoft Corporation) C:\WINDOWS\system32\WindowsCodecs.dll
2016-12-23 18:39 - 2016-12-09 02:20 - 00658784 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
2016-12-23 18:39 - 2016-12-09 02:20 - 00402272 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms1.sys
2016-12-23 18:39 - 2016-12-09 02:19 - 01293152 _____ (Microsoft Corporation) C:\WINDOWS\system32\LicenseManager.dll
2016-12-23 18:39 - 2016-12-09 02:19 - 00168424 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcrypt.dll
2016-12-23 18:39 - 2016-12-09 02:18 - 02913144 _____ (Microsoft Corporation) C:\WINDOWS\system32\combase.dll
2016-12-23 18:39 - 2016-12-09 02:18 - 01267512 _____ (Microsoft Corporation) C:\WINDOWS\system32\WinTypes.dll
2016-12-23 18:39 - 2016-12-09 02:18 - 01100128 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
2016-12-23 18:39 - 2016-12-09 02:18 - 00989024 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
2016-12-23 18:39 - 2016-12-09 02:18 - 00947552 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.efi
2016-12-23 18:39 - 2016-12-09 02:18 - 00811872 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.exe
2016-12-23 18:39 - 2016-12-09 02:15 - 08168000 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayReady.dll
2016-12-23 18:39 - 2016-12-09 02:14 - 01274712 _____ (Microsoft Corporation) C:\WINDOWS\system32\ole32.dll
2016-12-23 18:39 - 2016-12-09 02:11 - 02048496 _____ C:\WINDOWS\SysWOW64\CoreUIComponents.dll
2016-12-23 18:39 - 2016-12-09 02:10 - 01572768 _____ (Microsoft Corporation) C:\WINDOWS\system32\gdi32full.dll
2016-12-23 18:39 - 2016-12-09 02:10 - 01461200 _____ (Microsoft Corporation) C:\WINDOWS\system32\user32.dll
2016-12-23 18:39 - 2016-12-09 02:01 - 02323728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d10warp.dll
2016-12-23 18:39 - 2016-12-09 02:01 - 01503544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WindowsCodecs.dll
2016-12-23 18:39 - 2016-12-09 02:01 - 00861024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LicenseManager.dll
2016-12-23 18:39 - 2016-12-09 02:00 - 00106896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcrypt.dll
2016-12-23 18:39 - 2016-12-09 01:59 - 02166752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\combase.dll
2016-12-23 18:39 - 2016-12-09 01:59 - 00846560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WinTypes.dll
2016-12-23 18:39 - 2016-12-09 01:57 - 06668040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayReady.dll
2016-12-23 18:39 - 2016-12-09 01:56 - 00959112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ole32.dll
2016-12-23 18:39 - 2016-12-09 01:52 - 01435896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\user32.dll
2016-12-23 18:39 - 2016-12-09 01:52 - 01415752 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gdi32full.dll
2016-12-23 18:39 - 2016-12-09 01:51 - 00117240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sspicli.dll
2016-12-23 18:39 - 2016-12-09 01:45 - 00040448 _____ (Microsoft Corporation) C:\WINDOWS\system32\WordBreakers.dll
2016-12-23 18:39 - 2016-12-09 01:42 - 00227328 _____ (Microsoft Corporation) C:\WINDOWS\system32\cdd.dll
2016-12-23 18:39 - 2016-12-09 01:41 - 00380928 _____ (Microsoft Corporation) C:\WINDOWS\system32\wincorlib.dll
2016-12-23 18:39 - 2016-12-09 01:41 - 00032768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WordBreakers.dll
2016-12-23 18:39 - 2016-12-09 01:37 - 00411136 _____ (Microsoft Corporation) C:\WINDOWS\system32\facecredentialprovider.dll
2016-12-23 18:39 - 2016-12-09 01:36 - 03059200 _____ (Microsoft Corporation) C:\WINDOWS\system32\msi.dll
2016-12-23 18:39 - 2016-12-09 01:36 - 00410112 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
2016-12-23 18:39 - 2016-12-09 01:34 - 00288768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wincorlib.dll
2016-12-23 18:39 - 2016-12-09 01:33 - 03777536 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFMediaEngine.dll
2016-12-23 18:39 - 2016-12-09 01:33 - 01589760 _____ (Microsoft Corporation) C:\WINDOWS\system32\msdtctm.dll
2016-12-23 18:39 - 2016-12-09 01:32 - 00635904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9diag.dll
2016-12-23 18:39 - 2016-12-09 01:31 - 03689984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msi.dll
2016-12-23 18:39 - 2016-12-09 01:31 - 00313856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
2016-12-23 18:39 - 2016-12-09 01:28 - 03306496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFMediaEngine.dll
2016-12-23 18:39 - 2016-12-09 01:28 - 01004544 _____ (Microsoft Corporation) C:\WINDOWS\system32\enterprisecsps.dll
2016-12-23 18:39 - 2016-12-09 01:27 - 13084160 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
2016-12-23 18:39 - 2016-12-09 01:27 - 05114368 _____ (Microsoft Corporation) C:\WINDOWS\system32\cdp.dll
2016-12-23 18:39 - 2016-12-09 01:27 - 00981504 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authentication.OnlineId.dll
2016-12-23 18:39 - 2016-12-09 01:25 - 00376832 _____ (Microsoft Corporation) C:\WINDOWS\system32\CryptoWinRT.dll
2016-12-23 18:39 - 2016-12-09 01:23 - 12177920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
2016-12-23 18:39 - 2016-12-09 01:22 - 02820096 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputService.dll
2016-12-23 18:39 - 2016-12-09 01:21 - 04746752 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
2016-12-23 18:39 - 2016-12-09 01:21 - 00716800 _____ (Microsoft Corporation) C:\WINDOWS\system32\ShareHost.dll
2016-12-23 18:39 - 2016-12-09 01:20 - 03198464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cdp.dll
2016-12-23 18:39 - 2016-12-09 01:20 - 00730624 _____ (Microsoft Corporation) C:\WINDOWS\system32\fveapi.dll
2016-12-23 18:39 - 2016-12-09 01:20 - 00187392 _____ (Microsoft Corporation) C:\WINDOWS\system32\mdmregistration.dll
2016-12-23 18:39 - 2016-12-09 01:20 - 00172544 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceEnroller.exe
2016-12-23 18:39 - 2016-12-09 01:19 - 00433664 _____ (Microsoft Corporation) C:\WINDOWS\system32\TextInputFramework.dll
2016-12-23 18:39 - 2016-12-09 01:19 - 00261120 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Core.TextInput.dll
2016-12-23 18:39 - 2016-12-09 01:19 - 00119296 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputLocaleManager.dll
2016-12-23 18:39 - 2016-12-09 01:19 - 00085504 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditBufferTestHook.dll
2016-12-23 18:39 - 2016-12-09 01:18 - 03666432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
2016-12-23 18:39 - 2016-12-09 01:18 - 02138112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputService.dll
2016-12-23 18:39 - 2016-12-09 01:18 - 00165376 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mdmregistration.dll
2016-12-23 18:39 - 2016-12-09 01:17 - 00566784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ShareHost.dll
2016-12-23 18:39 - 2016-12-09 01:16 - 00353280 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TextInputFramework.dll
2016-12-23 18:39 - 2016-12-09 01:15 - 00206848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Core.TextInput.dll
2016-12-23 18:39 - 2016-12-09 01:15 - 00092672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputLocaleManager.dll
2016-12-23 18:39 - 2016-12-09 01:15 - 00068096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EditBufferTestHook.dll
2016-12-23 18:39 - 2016-12-09 00:54 - 00483840 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreMessaging.dll
2016-12-23 18:39 - 2016-11-02 02:28 - 00807424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Security.Authentication.OnlineId.dll
2016-12-23 18:39 - 2016-11-02 02:25 - 00956416 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.desktop.dll
2016-12-23 18:39 - 2016-09-15 08:36 - 00216576 _____ (Microsoft Corporation) C:\WINDOWS\system32\fveapibase.dll
2016-12-23 15:32 - 2017-01-24 20:54 - 00000000 ____D C:\Program Files (x86)\VulkanRT
2016-12-23 15:32 - 2016-12-15 16:33 - 00273696 _____ C:\WINDOWS\SysWOW64\vulkan-1.dll
2016-12-23 15:32 - 2016-12-15 16:33 - 00266528 _____ C:\WINDOWS\system32\vulkan-1.dll
2016-12-23 15:32 - 2016-12-15 16:33 - 00111392 _____ C:\WINDOWS\SysWOW64\vulkaninfo.exe
2016-12-23 15:32 - 2016-12-15 16:32 - 00125728 _____ C:\WINDOWS\system32\vulkaninfo.exe
2016-12-23 15:23 - 2014-12-09 10:59 - 07546544 _____ (Broadcom Corporation) C:\WINDOWS\system32\Drivers\BCMWL63a.SYS
2016-12-23 15:23 - 2014-12-09 10:59 - 07546544 _____ (Broadcom Corporation) C:\WINDOWS\system32\bcmwl63a.sys
2016-12-23 15:23 - 2014-12-09 10:59 - 04136960 _____ (Broadcom Corporation) C:\WINDOWS\system32\bcmihvsrv64.dll
2016-12-23 15:23 - 2014-12-09 10:59 - 03781632 _____ (Broadcom Corporation) C:\WINDOWS\system32\bcmihvui64.dll
2016-12-23 15:23 - 2014-12-09 10:59 - 00897018 _____ C:\WINDOWS\system32\bcmwl64.inf
2016-12-23 15:23 - 2014-12-09 10:59 - 00015245 _____ C:\WINDOWS\system32\bcm43xx64.cat
2016-12-15 16:33 - 2016-12-15 16:33 - 00273696 _____ C:\WINDOWS\SysWOW64\vulkan-1-1-0-37-0.dll
2016-12-15 16:33 - 2016-12-15 16:33 - 00266528 _____ C:\WINDOWS\system32\vulkan-1-1-0-37-0.dll
2016-12-15 16:33 - 2016-12-15 16:33 - 00111392 _____ C:\WINDOWS\SysWOW64\vulkaninfo-1-1-0-37-0.exe
2016-12-15 16:32 - 2016-12-15 16:32 - 00125728 _____ C:\WINDOWS\system32\vulkaninfo-1-1-0-37-0.exe
2016-12-12 15:58 - 2016-11-11 02:15 - 00198856 _____ (Microsoft Corporation) C:\WINDOWS\system32\wscapi.dll
2016-12-12 15:58 - 2016-11-11 02:15 - 00101216 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceReactivation.dll
2016-12-12 15:58 - 2016-11-11 02:14 - 02186896 _____ (Microsoft Corporation) C:\WINDOWS\system32\hevcdecoder.dll
2016-12-12 15:58 - 2016-11-11 02:14 - 00603488 _____ (Microsoft Corporation) C:\WINDOWS\system32\ContentDeliveryManager.Utilities.dll
2016-12-12 15:58 - 2016-11-11 02:13 - 02213760 _____ (Microsoft Corporation) C:\WINDOWS\system32\KernelBase.dll
2016-12-12 15:58 - 2016-11-11 02:13 - 01886344 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntdll.dll
2016-12-12 15:58 - 2016-11-11 02:13 - 00352096 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fastfat.sys
2016-12-12 15:58 - 2016-11-11 02:12 - 00128352 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\partmgr.sys
2016-12-12 15:58 - 2016-11-11 02:08 - 00142176 _____ (Microsoft Corporation) C:\WINDOWS\system32\migisol.dll
2016-12-12 15:58 - 2016-11-11 02:03 - 01069720 _____ (Microsoft Corporation) C:\WINDOWS\system32\MrmCoreR.dll
2016-12-12 15:58 - 2016-11-11 02:03 - 00266544 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanager.dll
2016-12-12 15:58 - 2016-11-11 02:02 - 02828376 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d11.dll
2016-12-12 15:58 - 2016-11-11 02:02 - 00360040 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsAdminFlows.exe
2016-12-12 15:58 - 2016-11-11 02:01 - 07219672 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
2016-12-12 15:58 - 2016-11-11 02:01 - 01859264 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.Store.dll
2016-12-12 15:58 - 2016-11-11 02:01 - 00637400 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxgi.dll
2016-12-12 15:58 - 2016-11-11 02:00 - 00223584 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb20.sys
2016-12-12 15:58 - 2016-11-11 02:00 - 00219488 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tpm.sys
2016-12-12 15:58 - 2016-11-11 01:59 - 00433504 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rdbss.sys
2016-12-12 15:58 - 2016-11-11 01:57 - 01473048 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfplat.dll
2016-12-12 15:58 - 2016-11-11 01:56 - 04673304 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
2016-12-12 15:58 - 2016-11-11 01:56 - 01062480 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsvr.dll
2016-12-12 15:58 - 2016-11-11 01:56 - 00424616 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFPlay.dll
2016-12-12 15:58 - 2016-11-11 01:56 - 00187520 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudStorageWizard.exe
2016-12-12 15:58 - 2016-11-11 01:56 - 00163752 _____ (Microsoft Corporation) C:\WINDOWS\system32\RTWorkQ.dll
2016-12-12 15:58 - 2016-11-11 01:56 - 00126568 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfaudiocnv.dll
2016-12-12 15:58 - 2016-11-11 01:55 - 00882680 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditionUpgradeManagerObj.dll
2016-12-12 15:58 - 2016-11-11 01:55 - 00743224 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppwinob.dll
2016-12-12 15:58 - 2016-11-11 01:54 - 01418312 _____ (Microsoft Corporation) C:\WINDOWS\system32\msctf.dll
2016-12-12 15:58 - 2016-11-11 01:51 - 00454592 _____ (Microsoft Corporation) C:\WINDOWS\system32\services.exe
2016-12-12 15:58 - 2016-11-11 01:31 - 00366080 _____ (Microsoft Corporation) C:\WINDOWS\system32\RDXTaskFactory.dll
2016-12-12 15:58 - 2016-11-11 01:27 - 00068096 _____ (Microsoft Corporation) C:\WINDOWS\system32\lpremove.exe
2016-12-12 15:58 - 2016-11-11 01:26 - 00258560 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\xboxgip.sys
2016-12-12 15:58 - 2016-11-11 01:26 - 00163840 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseModernAppMgmtCSP.dll
2016-12-12 15:58 - 2016-11-11 01:26 - 00109056 _____ (Microsoft Corporation) C:\WINDOWS\system32\ReportingCSP.dll
2016-12-12 15:58 - 2016-11-11 01:26 - 00042496 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\modem.sys
2016-12-12 15:58 - 2016-11-11 01:26 - 00034816 _____ (Microsoft Corporation) C:\WINDOWS\system32\ReAgentc.exe
2016-12-12 15:58 - 2016-11-11 01:25 - 00198656 _____ (Microsoft Corporation) C:\WINDOWS\system32\BcastDVRHelper.dll
2016-12-12 15:58 - 2016-11-11 01:25 - 00185344 _____ (Microsoft Corporation) C:\WINDOWS\system32\DisplayManager.dll
2016-12-12 15:58 - 2016-11-11 01:25 - 00151040 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapsBtSvc.dll
2016-12-12 15:58 - 2016-11-11 01:25 - 00147968 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmcertinst.exe
2016-12-12 15:58 - 2016-11-11 01:25 - 00081408 _____ (Microsoft Corporation) C:\WINDOWS\system32\HttpsDataSource.dll
2016-12-12 15:58 - 2016-11-11 01:25 - 00073216 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryBroker.dll
2016-12-12 15:58 - 2016-11-11 01:24 - 00170496 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppCapture.dll
2016-12-12 15:58 - 2016-11-11 01:24 - 00159744 _____ (Microsoft Corporation) C:\WINDOWS\system32\ACPBackgroundManagerPolicy.dll
2016-12-12 15:58 - 2016-11-11 01:24 - 00158720 _____ (Microsoft Corporation) C:\WINDOWS\system32\VEStoreEventHandlers.dll
2016-12-12 15:58 - 2016-11-11 01:24 - 00122880 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryClient.dll
2016-12-12 15:58 - 2016-11-11 01:24 - 00110080 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.BackgroundTransfer.BackgroundManagerPolicy.dll
2016-12-12 15:58 - 2016-11-11 01:24 - 00107520 _____ (Microsoft Corporation) C:\WINDOWS\system32\VPNv2CSP.dll
2016-12-12 15:58 - 2016-11-11 01:24 - 00098304 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserbroker.dll
2016-12-12 15:58 - 2016-11-11 01:23 - 00567296 _____ (Microsoft Corporation) C:\WINDOWS\system32\DevicePairing.dll
2016-12-12 15:58 - 2016-11-11 01:23 - 00409088 _____ (Microsoft Corporation) C:\WINDOWS\system32\NgcCtnr.dll
2016-12-12 15:58 - 2016-11-11 01:23 - 00058880 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Shell.Search.UriHandler.dll
2016-12-12 15:58 - 2016-11-11 01:23 - 00041472 _____ (Microsoft Corporation) C:\WINDOWS\system32\EAMProgressHandler.dll
2016-12-12 15:58 - 2016-11-11 01:22 - 00489472 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetSetupShim.dll
2016-12-12 15:58 - 2016-11-11 01:22 - 00143360 _____ (Microsoft Corporation) C:\WINDOWS\system32\EDPCleanup.exe
2016-12-12 15:58 - 2016-11-11 01:21 - 00690688 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieproxy.dll
2016-12-12 15:58 - 2016-11-11 01:21 - 00379392 _____ (Microsoft Corporation) C:\WINDOWS\system32\apprepsync.dll
2016-12-12 15:58 - 2016-11-11 01:21 - 00313856 _____ (Microsoft Corporation) C:\WINDOWS\system32\moshostcore.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00657920 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasmans.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00641024 _____ (Microsoft Corporation) C:\WINDOWS\system32\ngccredprov.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00590336 _____ (Microsoft Corporation) C:\WINDOWS\system32\efswrt.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00574464 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_StorageSense.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00446976 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapConfiguration.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00407552 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Management.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00381952 _____ (Microsoft Corporation) C:\WINDOWS\system32\cryptngc.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00339456 _____ (Microsoft Corporation) C:\WINDOWS\system32\cdpusersvc.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00176128 _____ (Microsoft Corporation) C:\WINDOWS\system32\apprepapi.dll
2016-12-12 15:58 - 2016-11-11 01:20 - 00125952 _____ (Microsoft Corporation) C:\WINDOWS\system32\setupugc.exe
2016-12-12 15:58 - 2016-11-11 01:20 - 00115200 _____ (Microsoft Corporation) C:\WINDOWS\system32\IdCtrls.dll
2016-12-12 15:58 - 2016-11-11 01:19 - 00620544 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcastdvr.exe
2016-12-12 15:58 - 2016-11-11 01:19 - 00495104 _____ (Microsoft Corporation) C:\WINDOWS\system32\DataSenseHandlers.dll
2016-12-12 15:58 - 2016-11-11 01:19 - 00411648 _____ (Microsoft Corporation) C:\WINDOWS\system32\cdpsvc.dll
2016-12-12 15:58 - 2016-11-11 01:19 - 00389632 _____ (Microsoft Corporation) C:\WINDOWS\system32\ActivationManager.dll
2016-12-12 15:58 - 2016-11-11 01:19 - 00388096 _____ (Microsoft Corporation) C:\WINDOWS\system32\zipfldr.dll
2016-12-12 15:58 - 2016-11-11 01:19 - 00366080 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchFolder.dll
2016-12-12 15:58 - 2016-11-11 01:19 - 00320000 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.ApplicationModel.Store.TestingFramework.dll
2016-12-12 15:58 - 2016-11-11 01:19 - 00285696 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAppMgmtSvc.dll
2016-12-12 15:58 - 2016-11-11 01:19 - 00198144 _____ (Microsoft Corporation) C:\WINDOWS\system32\dpapisrv.dll
2016-12-12 15:58 - 2016-11-11 01:18 - 02084352 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceFlows.DataModel.dll
2016-12-12 15:58 - 2016-11-11 01:18 - 00278016 _____ (Microsoft Corporation) C:\WINDOWS\system32\netplwiz.dll
2016-12-12 15:58 - 2016-11-11 01:17 - 01220096 _____ (Microsoft Corporation) C:\WINDOWS\system32\wscui.cpl
2016-12-12 15:58 - 2016-11-11 01:17 - 00068096 _____ (Microsoft Corporation) C:\WINDOWS\system32\ProvSysprep.dll
2016-12-12 15:58 - 2016-11-11 01:16 - 02716672 _____ (Microsoft Corporation) C:\WINDOWS\system32\WsmSvc.dll
2016-12-12 15:58 - 2016-11-11 01:16 - 01477632 _____ (Microsoft Corporation) C:\WINDOWS\system32\wsecedit.dll
2016-12-12 15:58 - 2016-11-11 01:16 - 00560128 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppReadiness.dll
2016-12-12 15:58 - 2016-11-11 01:16 - 00184832 _____ (Microsoft Corporation) C:\WINDOWS\system32\wscsvc.dll
2016-12-12 15:58 - 2016-11-11 01:16 - 00161792 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditionUpgradeHelper.dll
2016-12-12 15:58 - 2016-11-11 01:16 - 00105984 _____ (Microsoft Corporation) C:\WINDOWS\system32\RjvMDMConfig.dll
2016-12-12 15:58 - 2016-11-11 01:15 - 00282624 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb10.sys
2016-12-12 15:58 - 2016-11-11 01:15 - 00159232 _____ (Microsoft Corporation) C:\WINDOWS\system32\wscinterop.dll
2016-12-12 15:58 - 2016-11-11 01:15 - 00032256 _____ (Microsoft Corporation) C:\WINDOWS\system32\WSManHTTPConfig.exe
2016-12-12 15:58 - 2016-11-11 01:14 - 07654400 _____ (Microsoft Corporation) C:\WINDOWS\system32\mos.dll
2016-12-12 15:58 - 2016-11-11 01:14 - 02104320 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlidsvc.dll
2016-12-12 15:58 - 2016-11-11 01:14 - 00713216 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srv2.sys
2016-12-12 15:58 - 2016-11-11 01:14 - 00615424 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpnprv.dll
2016-12-12 15:58 - 2016-11-11 01:14 - 00178176 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppnp.dll
2016-12-12 15:58 - 2016-11-11 01:13 - 07812096 _____ (Microsoft Corporation) C:\WINDOWS\system32\BingMaps.dll
2016-12-12 15:58 - 2016-11-11 01:13 - 00396800 _____ (Microsoft Corporation) C:\WINDOWS\system32\StorSvc.dll
2016-12-12 15:58 - 2016-11-11 01:13 - 00306176 _____ (Microsoft Corporation) C:\WINDOWS\system32\msdtcuiu.dll
2016-12-12 15:58 - 2016-11-11 01:12 - 00870912 _____ (Microsoft Corporation) C:\WINDOWS\system32\msdtcprx.dll
2016-12-12 15:58 - 2016-11-11 01:11 - 00870400 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfmkvsrcsnk.dll
2016-12-12 15:58 - 2016-11-11 01:09 - 01366016 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpncore.dll
2016-12-12 15:58 - 2016-11-11 01:09 - 00164352 _____ (Microsoft Corporation) C:\WINDOWS\system32\dialserver.dll
2016-12-12 15:58 - 2016-11-11 01:08 - 00539136 _____ (Microsoft Corporation) C:\WINDOWS\system32\PlayToManager.dll
2016-12-12 15:58 - 2016-11-11 01:07 - 03441152 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapRouter.dll
2016-12-12 15:58 - 2016-11-11 01:07 - 02953216 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapGeocoder.dll
2016-12-12 15:58 - 2016-11-11 01:07 - 02510848 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkMobileSettings.dll
2016-12-12 15:58 - 2016-11-11 01:07 - 01691136 _____ (Microsoft Corporation) C:\WINDOWS\system32\aitstatic.exe
2016-12-12 15:58 - 2016-11-11 01:07 - 01060864 _____ (Microsoft Corporation) C:\WINDOWS\system32\JpMapControl.dll
2016-12-12 15:58 - 2016-11-11 01:07 - 00991232 _____ (Microsoft Corporation) C:\WINDOWS\system32\comdlg32.dll
2016-12-12 15:58 - 2016-11-11 01:07 - 00347648 _____ (Microsoft Corporation) C:\WINDOWS\system32\rascustom.dll
2016-12-12 15:58 - 2016-11-11 01:06 - 03400192 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncCenter.dll
2016-12-12 15:58 - 2016-11-11 01:06 - 00960000 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
2016-12-12 15:58 - 2016-11-11 01:06 - 00650752 _____ (Microsoft Corporation) C:\WINDOWS\system32\RDXService.dll
2016-12-12 15:58 - 2016-11-11 01:05 - 04136448 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepository.dll
2016-12-12 15:58 - 2016-11-11 01:05 - 02852864 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsThresholdAdminFlowUI.dll
2016-12-12 15:58 - 2016-11-11 01:05 - 01779712 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
2016-12-12 15:58 - 2016-11-11 01:05 - 01031680 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapsStore.dll
2016-12-12 15:58 - 2016-11-11 01:04 - 02800128 _____ (Microsoft Corporation) C:\WINDOWS\system32\netshell.dll
2016-12-12 15:58 - 2016-11-11 01:04 - 02611200 _____ (Microsoft Corporation) C:\WINDOWS\system32\gameux.dll
2016-12-12 15:58 - 2016-11-11 01:04 - 01709056 _____ (Microsoft Corporation) C:\WINDOWS\system32\UIAutomationCore.dll
2016-12-12 15:58 - 2016-11-11 01:04 - 01359360 _____ (Microsoft Corporation) C:\WINDOWS\system32\usercpl.dll
2016-12-12 15:58 - 2016-11-11 01:04 - 00909312 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Search.dll
2016-12-12 15:58 - 2016-11-11 01:04 - 00691712 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsm.dll
2016-12-12 15:58 - 2016-11-11 01:04 - 00455168 _____ (Microsoft Corporation) C:\WINDOWS\system32\dmenrollengine.dll
2016-12-12 15:58 - 2016-11-11 01:04 - 00389632 _____ (Microsoft Corporation) C:\WINDOWS\system32\stobject.dll
2016-12-12 15:58 - 2016-11-11 01:03 - 04708864 _____ (Microsoft Corporation) C:\WINDOWS\system32\ExplorerFrame.dll
2016-12-12 15:58 - 2016-11-11 01:03 - 02669056 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
2016-12-12 15:58 - 2016-11-11 01:03 - 02287616 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmcore.dll
2016-12-12 15:58 - 2016-11-11 01:03 - 00905216 _____ (Microsoft Corporation) C:\WINDOWS\system32\MapControlCore.dll
2016-12-12 15:58 - 2016-11-11 01:03 - 00842240 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntshrui.dll
2016-12-12 15:58 - 2016-11-11 01:03 - 00283648 _____ (Microsoft Corporation) C:\WINDOWS\system32\wkssvc.dll
2016-12-12 15:58 - 2016-11-11 01:02 - 03542016 _____ (Microsoft Corporation) C:\WINDOWS\system32\actxprxy.dll
2016-12-12 15:58 - 2016-11-11 01:02 - 01726976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Immersive.dll
2016-12-12 15:58 - 2016-11-11 01:02 - 00936448 _____ (Microsoft Corporation) C:\WINDOWS\system32\NMAA.dll
2016-12-12 15:58 - 2016-11-11 00:01 - 01969912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hevcdecoder.dll
2016-12-12 15:58 - 2016-11-11 00:00 - 01706488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\KernelBase.dll
2016-12-12 15:58 - 2016-11-10 23:59 - 01572768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntdll.dll
2016-12-12 15:58 - 2016-11-10 23:54 - 00122208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\migisol.dll
2016-12-12 15:58 - 2016-11-10 23:49 - 00869848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MrmCoreR.dll
2016-12-12 15:58 - 2016-11-10 23:49 - 00248480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\policymanager.dll
2016-12-12 15:58 - 2016-11-10 23:48 - 02277248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d11.dll
2016-12-12 15:58 - 2016-11-10 23:47 - 05722832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
2016-12-12 15:58 - 2016-11-10 23:47 - 01430720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store.dll
2016-12-12 15:58 - 2016-11-10 23:47 - 00527880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxgi.dll
2016-12-12 15:58 - 2016-11-10 23:42 - 01123912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfplat.dll
2016-12-12 15:58 - 2016-11-10 23:42 - 00952416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsvr.dll
2016-12-12 15:58 - 2016-11-10 23:42 - 00374448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFPlay.dll
2016-12-12 15:58 - 2016-11-10 23:42 - 00152416 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\RTWorkQ.dll
2016-12-12 15:58 - 2016-11-10 23:42 - 00091936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfaudiocnv.dll
2016-12-12 15:58 - 2016-11-10 23:41 - 04311736 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
2016-12-12 15:58 - 2016-11-10 23:41 - 00157536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudStorageWizard.exe
2016-12-12 15:58 - 2016-11-10 23:38 - 01263856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msctf.dll
2016-12-12 15:58 - 2016-11-10 23:25 - 00117248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapsBtSvc.dll
2016-12-12 15:58 - 2016-11-10 23:25 - 00071168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MosStorage.dll
2016-12-12 15:58 - 2016-11-10 23:24 - 00519168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ngccredprov.dll
2016-12-12 15:58 - 2016-11-10 23:24 - 00156672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BcastDVRHelper.dll
2016-12-12 15:58 - 2016-11-10 23:24 - 00138240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DisplayManager.dll
2016-12-12 15:58 - 2016-11-10 23:24 - 00047104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Shell.Search.UriHandler.dll
2016-12-12 15:58 - 2016-11-10 23:23 - 00140288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppCapture.dll
2016-12-12 15:58 - 2016-11-10 23:23 - 00094208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryClient.dll
2016-12-12 15:58 - 2016-11-10 23:22 - 00505856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcastdvr.exe
2016-12-12 15:58 - 2016-11-10 23:22 - 00122880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sendmail.dll
2016-12-12 15:58 - 2016-11-10 23:21 - 00332288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapConfiguration.dll
2016-12-12 15:58 - 2016-11-10 23:21 - 00091648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.BackgroundTransfer.BackgroundManagerPolicy.dll
2016-12-12 15:58 - 2016-11-10 23:20 - 00306176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieproxy.dll
2016-12-12 15:58 - 2016-11-10 23:19 - 01755136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DeviceFlows.DataModel.dll
2016-12-12 15:58 - 2016-11-10 23:19 - 00506880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DevicePairing.dll
2016-12-12 15:58 - 2016-11-10 23:19 - 00298496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Internal.Management.dll
2016-12-12 15:58 - 2016-11-10 23:19 - 00284672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\apprepsync.dll
2016-12-12 15:58 - 2016-11-10 23:19 - 00125952 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\apprepapi.dll
2016-12-12 15:58 - 2016-11-10 23:19 - 00114176 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setupugc.exe
2016-12-12 15:58 - 2016-11-10 23:18 - 02333184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WsmSvc.dll
2016-12-12 15:58 - 2016-11-10 23:18 - 01336320 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wsecedit.dll
2016-12-12 15:58 - 2016-11-10 23:18 - 00431616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\efswrt.dll
2016-12-12 15:58 - 2016-11-10 23:18 - 00318464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchFolder.dll
2016-12-12 15:58 - 2016-11-10 23:17 - 00333312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ActivationManager.dll
2016-12-12 15:58 - 2016-11-10 23:17 - 00033280 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WSManHTTPConfig.exe
2016-12-12 15:58 - 2016-11-10 23:15 - 01357824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UIAutomationCore.dll
2016-12-12 15:58 - 2016-11-10 23:15 - 00838144 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\JpMapControl.dll
2016-12-12 15:58 - 2016-11-10 23:15 - 00348672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\zipfldr.dll
2016-12-12 15:58 - 2016-11-10 23:15 - 00285696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cryptngc.dll
2016-12-12 15:58 - 2016-11-10 23:14 - 00395264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dmenrollengine.dll
2016-12-12 15:58 - 2016-11-10 23:12 - 00259584 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msdtcuiu.dll
2016-12-12 15:58 - 2016-11-10 23:10 - 06109184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mos.dll
2016-12-12 15:58 - 2016-11-10 23:10 - 00746496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msdtcprx.dll
2016-12-12 15:58 - 2016-11-10 23:09 - 05380608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\BingMaps.dll
2016-12-12 15:58 - 2016-11-10 23:09 - 00545280 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfmkvsrcsnk.dll
2016-12-12 15:58 - 2016-11-10 23:08 - 00053248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xolehlp.dll
2016-12-12 15:58 - 2016-11-10 23:06 - 02362880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapRouter.dll
2016-12-12 15:58 - 2016-11-10 23:06 - 02109952 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapGeocoder.dll
2016-12-12 15:58 - 2016-11-10 23:06 - 01228288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\usercpl.dll
2016-12-12 15:58 - 2016-11-10 23:06 - 00400384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PlayToManager.dll
2016-12-12 15:58 - 2016-11-10 23:06 - 00359936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mtxclu.dll
2016-12-12 15:58 - 2016-11-10 23:05 - 04423680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ExplorerFrame.dll
2016-12-12 15:58 - 2016-11-10 23:05 - 03370496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepository.dll
2016-12-12 15:58 - 2016-11-10 23:04 - 02682880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netshell.dll
2016-12-12 15:58 - 2016-11-10 23:04 - 01992704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dwmcore.dll
2016-12-12 15:58 - 2016-11-10 23:04 - 01595392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
2016-12-12 15:58 - 2016-11-10 23:04 - 00912896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\comdlg32.dll
2016-12-12 15:58 - 2016-11-10 23:04 - 00715264 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MapControlCore.dll
2016-12-12 15:58 - 2016-11-10 23:04 - 00358912 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\stobject.dll
2016-12-12 15:58 - 2016-11-10 23:03 - 02484736 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gameux.dll
2016-12-12 15:58 - 2016-11-10 23:03 - 02256384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
2016-12-12 15:58 - 2016-11-10 23:03 - 01576448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\actxprxy.dll
2016-12-12 15:58 - 2016-11-10 23:03 - 01556480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll
2016-12-12 15:58 - 2016-11-10 23:03 - 00772608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntshrui.dll
2016-12-12 15:58 - 2016-11-10 23:03 - 00760832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\NMAA.dll
2016-12-12 15:58 - 2016-11-10 23:03 - 00565248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasapi32.dll
2016-12-12 15:58 - 2016-11-10 23:02 - 00711680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Search.dll
2016-12-12 15:57 - 2016-11-11 01:28 - 00040960 _____ (Microsoft Corporation) C:\WINDOWS\system32\CbtBackgroundManagerPolicy.dll
2016-12-12 15:57 - 2016-11-11 01:27 - 00086016 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetCfgNotifyObjectHost.exe
2016-12-12 15:57 - 2016-11-11 01:25 - 00089600 _____ (Microsoft Corporation) C:\WINDOWS\system32\MosStorage.dll
2016-12-12 15:57 - 2016-11-11 01:24 - 00136192 _____ (Microsoft Corporation) C:\WINDOWS\system32\sendmail.dll
2016-12-12 15:57 - 2016-11-11 01:22 - 00082944 _____ (Microsoft Corporation) C:\WINDOWS\system32\moshost.dll
2016-12-12 15:57 - 2016-11-11 01:21 - 00587776 _____ (Microsoft Corporation) C:\WINDOWS\system32\vpnike.dll
2016-12-12 15:57 - 2016-11-11 01:11 - 00096256 _____ (Microsoft Corporation) C:\WINDOWS\system32\umpoext.dll
2016-12-12 15:57 - 2016-11-11 01:03 - 00632320 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasapi32.dll
2016-12-12 15:57 - 2016-11-11 00:01 - 00167848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wscapi.dll
2016-12-12 15:57 - 2016-11-10 23:27 - 00065024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\NetCfgNotifyObjectHost.exe
2016-12-12 15:57 - 2016-11-10 23:26 - 00030720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ReAgentc.exe
2016-12-12 15:57 - 2016-11-10 23:19 - 00364544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\NetSetupShim.dll
2016-12-12 15:57 - 2016-11-10 23:18 - 01196544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wscui.cpl
2016-12-12 15:57 - 2016-11-10 23:18 - 00108544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wscinterop.dll
2016-12-12 15:57 - 2016-11-10 23:16 - 00253952 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.ApplicationModel.Store.TestingFramework.dll
2016-12-10 23:39 - 2016-12-10 23:39 - 00054256 _____ (Corsair) C:\WINDOWS\system32\Drivers\CorsairVBusDriver.sys
2016-12-10 23:39 - 2016-12-10 23:39 - 00029168 _____ (Corsair) C:\WINDOWS\system32\Drivers\CorsairVHidDriver.sys
2016-12-06 19:11 - 2016-12-06 19:11 - 00000000 ____D C:\Program Files (x86)\Microsoft XNA
2016-12-01 20:28 - 2016-12-01 20:28 - 00000000 ____D C:\Users\Jarvis\AppData\Local\CAPCOM
2016-12-01 10:12 - 2016-12-01 10:42 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\vlc
2016-12-01 10:12 - 2016-12-01 10:12 - 00001141 _____ C:\Users\Public\Desktop\VLC media player.lnk
2016-12-01 10:12 - 2016-12-01 10:12 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\dvdcss
2016-12-01 10:12 - 2016-12-01 10:12 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN
2016-12-01 10:11 - 2016-12-01 10:11 - 00000000 ____D C:\Program Files (x86)\VideoLAN
2016-12-01 10:01 - 2016-12-01 10:01 - 00028760 _____ C:\ProgramData\agent.1480615304.bdinstall.bin
2016-12-01 09:59 - 2017-01-11 10:06 - 00342016 _____ (BitDefender S.R.L. Bucharest, ROMANIA) C:\WINDOWS\system32\Drivers\edrsensor.sys
2016-12-01 09:59 - 2016-12-05 18:47 - 00182944 _____ (BitDefender LLC) C:\WINDOWS\system32\Drivers\gzflt.sys
2016-12-01 09:59 - 2016-12-01 09:59 - 00001209 _____ C:\Users\Public\Desktop\Bitdefender Antivirus Free.lnk
2016-12-01 09:59 - 2016-12-01 09:59 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Bitdefender Antivirus Free
2016-12-01 09:59 - 2016-09-20 01:17 - 01605376 _____ (BitDefender) C:\WINDOWS\system32\Drivers\avc3.sys
2016-12-01 09:59 - 2016-09-20 01:16 - 00878072 _____ (BitDefender) C:\WINDOWS\system32\Drivers\avckf.sys
2016-12-01 09:58 - 2017-02-09 18:06 - 00000000 ____D C:\Program Files\Bitdefender Antivirus Free
2016-12-01 09:58 - 2016-12-01 09:58 - 00003794 _____ C:\WINDOWS\System32\Tasks\Bitdefender Agent WatchDog_65D6944A0EF74FDAB96E31112AD39864
2016-12-01 09:58 - 2016-06-22 12:40 - 00520032 _____ (BitDefender S.R.L.) C:\WINDOWS\system32\Drivers\trufos.sys
2016-12-01 09:56 - 2017-02-09 18:01 - 00000000 ____D C:\Program Files\Bitdefender Agent
2016-11-18 13:21 - 2016-11-18 13:21 - 00000000 ____D C:\Users\Jarvis\Documents\Heroes of the Storm
2016-11-17 18:35 - 2016-11-17 18:35 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Ndemic Creations
2016-11-13 19:59 - 2016-11-13 20:02 - 00002255 _____ C:\Users\Jarvis\.kdiff3rc
==================== Three Months Modified files and folders ========
2017-02-09 18:06 - 2016-07-16 03:47 - 00000000 ___HD C:\Program Files\WindowsApps
2017-02-09 18:06 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\AppReadiness
2017-02-09 18:03 - 2016-08-05 20:05 - 00000000 ____D C:\ProgramData\NVIDIA
2017-02-09 18:02 - 2016-08-05 20:08 - 00003236 _____ C:\WINDOWS\System32\Tasks\CAM
2017-02-09 18:02 - 2016-08-05 20:05 - 00000000 ____D C:\Users\Jarvis
2017-02-08 23:51 - 2016-10-28 06:14 - 00000000 ____D C:\ProgramData\Origin
2017-02-08 23:51 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\LiveKernelReports
2017-02-08 23:51 - 2016-06-11 02:41 - 00000000 ____D C:\Program Files (x86)\Steam
2017-02-08 23:49 - 2016-10-28 06:15 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Origin
2017-02-08 23:47 - 2016-06-10 13:23 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Battle.net
2017-02-08 23:24 - 2016-10-28 06:15 - 00000000 ____D C:\Program Files (x86)\Origin
2017-02-08 21:27 - 2016-06-10 13:21 - 00000000 ____D C:\Program Files (x86)\Battle.net
2017-02-08 21:22 - 2015-10-29 23:24 - 00000000 ___HD C:\WINDOWS\system32\GroupPolicy
2017-02-08 21:18 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\SysWOW64\GroupPolicy
2017-02-08 21:18 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\System
2017-02-08 21:04 - 2016-08-05 20:04 - 00000000 ____D C:\WINDOWS\system32\SleepStudy
2017-02-08 19:26 - 2016-06-11 03:05 - 00000000 ____D C:\Program Files (x86)\Dropbox
2017-02-08 18:20 - 2016-06-01 15:31 - 02775448 _____ C:\WINDOWS\system32\PerfStringBackup.INI
2017-02-08 18:14 - 2016-08-05 20:08 - 00000006 ____H C:\WINDOWS\Tasks\SA.DAT
2017-02-08 18:13 - 2016-07-15 22:04 - 01310720 _____ C:\WINDOWS\system32\config\BBI
2017-02-08 17:59 - 2016-07-16 03:45 - 00000000 ____D C:\WINDOWS\INF
2017-02-08 17:46 - 2016-06-03 23:18 - 00000000 ____D C:\ProgramData\Package Cache
2017-02-08 17:46 - 2016-06-03 23:18 - 00000000 ____D C:\Program Files\Intel
2017-02-08 17:44 - 2016-06-03 23:19 - 00000000 ____D C:\ProgramData\Intel
2017-02-08 17:31 - 2016-06-25 08:34 - 00192216 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\MBAMSwissArmy.sys
2017-02-08 13:39 - 2016-06-11 17:38 - 00000000 ____D C:\Users\Jarvis\AppData\Local\CrashDumps
2017-02-08 11:35 - 2016-06-25 08:54 - 00000000 ____D C:\Program Files (x86)\Overwatch
2017-02-08 11:18 - 2016-06-11 03:12 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Skype
2017-02-08 11:09 - 2016-08-15 23:15 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Spotify
2017-02-08 11:07 - 2016-08-15 23:15 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Spotify
2017-02-06 17:14 - 2016-06-11 01:34 - 00002274 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
2017-02-06 17:14 - 2016-06-11 01:34 - 00002262 _____ C:\Users\Public\Desktop\Google Chrome.lnk
2017-02-06 00:23 - 2016-07-10 17:42 - 00007597 _____ C:\Users\Jarvis\AppData\Local\Resmon.ResmonCfg
2017-02-06 00:18 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\SysWOW64\Macromed
2017-02-06 00:18 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\system32\Macromed
2017-02-06 00:17 - 2016-06-20 10:49 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Adobe
2017-02-05 03:36 - 2016-07-28 20:12 - 00000000 ____D C:\Users\Jarvis\Documents\Registry Backups
2017-02-05 00:25 - 2013-02-28 17:49 - 00369168 _____ (CACE Technologies, Inc.) C:\WINDOWS\system32\wpcap.dll
2017-02-05 00:25 - 2013-02-28 17:49 - 00281104 _____ (CACE Technologies, Inc.) C:\WINDOWS\SysWOW64\wpcap.dll
2017-02-05 00:25 - 2013-02-28 17:49 - 00106000 _____ (CACE Technologies, Inc.) C:\WINDOWS\system32\packet.dll
2017-02-05 00:25 - 2013-02-28 17:49 - 00096784 _____ (CACE Technologies, Inc.) C:\WINDOWS\SysWOW64\packet.dll
2017-02-05 00:25 - 2013-02-28 17:49 - 00035344 _____ (CACE Technologies, Inc.) C:\WINDOWS\system32\Drivers\npf.sys
2017-02-04 03:53 - 2016-06-10 23:45 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Packages
2017-02-04 02:22 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\system32\NDF
2017-02-02 01:31 - 2016-06-11 03:43 - 00000000 ____D C:\Users\Jarvis\Desktop\MSI Utilities
2017-02-02 01:30 - 2016-06-11 02:23 - 00000000 ____D C:\Program Files (x86)\obs-studio
2017-02-02 01:30 - 2016-06-10 13:01 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\obs-studio
2017-02-02 01:22 - 2016-07-26 13:52 - 00000000 ____D C:\Program Files\7-Zip
2017-02-02 01:22 - 2016-06-11 03:03 - 00000000 ____D C:\Program Files\WinRAR
2017-02-02 01:22 - 2016-06-10 13:12 - 00000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
2017-02-02 01:22 - 2016-06-03 23:19 - 00000000 ____D C:\Program Files (x86)\Intel
2017-02-02 01:20 - 2016-06-11 03:01 - 00000000 ____D C:\Program Files\Common Files\Apple
2017-02-02 01:14 - 2016-06-10 13:12 - 00001230 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Mozilla Firefox.lnk
2017-02-02 01:14 - 2016-06-10 13:12 - 00001218 _____ C:\Users\Public\Desktop\Mozilla Firefox.lnk
2017-02-02 01:12 - 2016-06-11 03:03 - 00001064 _____ C:\Users\Jarvis\Desktop\WinRAR.lnk
2017-02-02 01:12 - 2016-06-11 03:03 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinRAR
2017-02-02 01:12 - 2016-06-11 03:03 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR
2017-02-02 01:02 - 2016-06-11 01:32 - 00000000 ____D C:\Program Files\Nahimic
2017-01-31 13:10 - 2016-08-05 20:04 - 00000000 ____D C:\WINDOWS\system32\DAX2
2017-01-31 13:10 - 2016-06-03 23:19 - 00000000 ___HD C:\Program Files (x86)\Temp
2017-01-31 13:00 - 2016-06-11 01:34 - 00000000 ____D C:\Program Files (x86)\MSI
2017-01-31 13:00 - 2016-06-11 01:27 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MSI
2017-01-31 13:00 - 2016-06-11 01:27 - 00000000 ____D C:\MSI
2017-01-29 00:00 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\Registration
2017-01-28 12:14 - 2016-08-05 20:04 - 00271904 _____ C:\WINDOWS\system32\FNTCACHE.DAT
2017-01-28 12:00 - 2016-10-31 04:16 - 00000000 ____D C:\Users\Jarvis\AppData\Local\ElevatedDiagnostics
2017-01-28 11:53 - 2016-06-11 01:33 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Google
2017-01-28 11:43 - 2016-10-26 11:12 - 00003894 _____ C:\WINDOWS\System32\Tasks\NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2017-01-28 11:43 - 2016-10-26 11:12 - 00003884 _____ C:\WINDOWS\System32\Tasks\NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2017-01-28 11:43 - 2016-10-26 11:12 - 00003866 _____ C:\WINDOWS\System32\Tasks\NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2017-01-28 11:43 - 2016-10-26 11:12 - 00003858 _____ C:\WINDOWS\System32\Tasks\NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2017-01-28 11:43 - 2016-10-26 11:12 - 00003696 _____ C:\WINDOWS\System32\Tasks\NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2017-01-28 11:43 - 2016-10-26 11:12 - 00003654 _____ C:\WINDOWS\System32\Tasks\NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}
2017-01-28 11:43 - 2016-08-05 20:05 - 00000000 ____D C:\ProgramData\NVIDIA Corporation
2017-01-28 11:43 - 2016-08-05 20:04 - 00000000 ____D C:\Program Files\NVIDIA Corporation
2017-01-28 11:43 - 2016-08-05 20:04 - 00000000 ____D C:\Program Files (x86)\NVIDIA Corporation
2017-01-27 17:29 - 2016-09-17 20:51 - 00002240 _____ C:\Users\Jarvis\Desktop\Discord.lnk
2017-01-27 17:29 - 2016-09-17 20:51 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Hammer & Chisel, Inc
2017-01-27 17:29 - 2016-09-17 20:51 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\discord
2017-01-27 17:29 - 2016-09-17 20:51 - 00000000 ____D C:\Users\Jarvis\AppData\Local\Discord
2017-01-24 23:29 - 2016-06-11 02:27 - 00000000 ____D C:\Users\Jarvis\Documents\My Games
2017-01-24 21:44 - 2016-07-16 03:36 - 00000000 ____D C:\WINDOWS\CbsTemp
2017-01-24 20:54 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\Help
2017-01-24 20:53 - 2016-06-10 19:27 - 00000000 ____D C:\ProgramData\Oracle
2017-01-24 20:51 - 2016-10-10 09:44 - 00000865 _____ C:\Users\Public\Desktop\CCleaner.lnk
2017-01-24 20:48 - 2016-06-20 10:51 - 00002457 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acrobat Reader DC.lnk
2017-01-20 10:39 - 2016-06-03 23:20 - 01872320 _____ (NVIDIA Corporation) C:\WINDOWS\system32\nvspcap64.dll
2017-01-20 10:39 - 2016-06-03 23:20 - 01464768 _____ (NVIDIA Corporation) C:\WINDOWS\SysWOW64\nvspcap.dll
2017-01-20 10:39 - 2016-06-03 23:20 - 00120256 _____ C:\WINDOWS\system32\NvRtmpStreamer64.dll
2017-01-12 09:29 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\rescache
2017-01-11 22:19 - 2016-07-22 05:16 - 00000000 ____D C:\Users\Jarvis\AppData\Roaming\Curse Client
2017-01-11 17:42 - 2016-07-16 03:47 - 00000000 ___RD C:\WINDOWS\ImmersiveControlPanel
2017-01-11 17:42 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\system32\WinBioPlugIns
2017-01-11 17:42 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\system32\oobe
2017-01-11 17:42 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\ShellExperiences
2017-01-11 17:42 - 2016-07-16 03:47 - 00000000 ____D C:\WINDOWS\Provisioning
2017-01-11 12:46 - 2016-06-15 14:24 - 00000000 ____D C:\WINDOWS\system32\MRT
2017-01-11 12:45 - 2016-06-15 14:24 - 135657872 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
2017-01-11 11:49 - 2016-06-25 08:34 - 00109272 _____ (Malwarebytes) C:\WINDOWS\system32\Drivers\mbamchameleon.sys
2017-01-10 22:50 - 2016-06-10 23:45 - 00000000 ____D C:\Users\Jarvis\AppData\Local\NVIDIA Corporation
2017-01-10 21:45 - 2016-06-11 02:22 - 00000000 ____D C:\Program Files\cFosSpeed
2017-01-10 10:15 - 2016-06-11 02:23 - 00000000 ____D C:\Users\Jarvis\AppData\Local\SteelSeries Engine 3 Client
2017-01-10 10:15 - 2016-06-11 02:23 - 00000000 ____D C:\Program Files\SteelSeries
2017-01-10 09:05 - 2016-08-05 20:08 - 00004562 _____ C:\WINDOWS\System32\Tasks\Adobe Acrobat Update Task
2016-07-10 17:42 - 2017-02-06 00:23 - 0007597 _____ () C:\Users\Jarvis\AppData\Local\Resmon.ResmonCfg
2016-09-19 19:40 - 2016-09-19 19:40 - 0026843 _____ () C:\ProgramData\agent.1474342806.bdinstall.bin
2016-11-01 18:29 - 2016-11-01 18:29 - 0028761 _____ () C:\ProgramData\agent.1478053761.bdinstall.bin
2016-11-10 06:45 - 2016-11-10 06:45 - 0029152 _____ () C:\ProgramData\agent.1478789098.bdinstall.bin
2016-12-01 10:01 - 2016-12-01 10:01 - 0028760 _____ () C:\ProgramData\agent.1480615304.bdinstall.bin
2016-10-19 08:49 - 2016-10-19 08:49 - 0000057 _____ () C:\ProgramData\Ament.ini
2016-08-05 20:04 - 2016-08-05 20:04 - 0000000 ____H () C:\ProgramData\DP45977C.lfl
2016-12-29 17:48 - 2017-01-09 01:31 - 0005110 _____ () C:\ProgramData\NvTelemetryContainer.log
2016-12-29 17:48 - 2017-01-09 00:48 - 0004984 _____ () C:\ProgramData\NvTelemetryContainer.log_backup1
Some files in TEMP:
2017-02-08 11:09 - 2017-02-08 11:18 - 43976160 _____ (Skype Technologies S.A.) C:\Users\Jarvis\AppData\Local\Temp\SkypeSetup.exe
LastRegBack: 2017-02-01 13:16
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 05-02-2017
Ran by Jarvis (09-02-2017 18:07:08)
Running from C:\Users\Jarvis\Downloads
Windows 10 Home Version 1607 (X64) (2016-08-06 04:09:26)
Boot Mode: Normal
Administrator (S-1-5-21-697782072-1053751190-176726198-500 - Administrator - Disabled)
DefaultAccount (S-1-5-21-697782072-1053751190-176726198-503 - Limited - Disabled)
Guest (S-1-5-21-697782072-1053751190-176726198-501 - Limited - Disabled)
Jarvis (S-1-5-21-697782072-1053751190-176726198-1002 - Administrator - Enabled) => C:\Users\Jarvis
AV: Bitdefender Antivirus Free Antimalware (Enabled - Up to date) {3FB17364-4FCC-0FA7-6BBF-973897395371}
AS: Bitdefender Antivirus Free Antimalware (Enabled - Up to date) {84D09280-69F6-0029-510F-AC4AECBE19CC}
7-Zip 16.02 (x64 edition) (HKLM\...\{23170F69-40C1-2702-1602-000001000000}) (Version: 16.02.00.0 - Igor Pavlov)
7-Zip 16.04 (x64) (HKLM\...\7-Zip) (Version: 16.04 - Igor Pavlov)
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 15.023.20056 - Adobe Systems Incorporated)
Adobe Flash Player 24 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 24.0.0.194 - Adobe Systems Incorporated)
Adobe Flash Player 24 PPAPI (HKLM-x32\...\Adobe Flash Player PPAPI) (Version: 24.0.0.194 - Adobe Systems Incorporated)
Age of Mythology: Extended Edition (HKLM\...\Steam App 266840) (Version: - SkyBox Labs)
Alien Swarm (HKLM\...\Steam App 630) (Version: - Valve)
Ansel (Version: 378.49 - NVIDIA Corporation) Hidden
ApoDispatchConfigurator (Version: 2.3.1401 - Nahimic) Hidden
Apowersoft Photo Viewer V1.1.2 (HKLM-x32\...\{AA88C325-55DB-463A-801E-ED6929D0260E}_is1) (Version: 1.1.2 - APOWERSOFT LIMITED)
Apple Application Support (32-bit) (HKLM-x32\...\{D079CAAD-0C31-47A2-9AF5-A82F9CD9B221}) (Version: 5.2 - Apple Inc.)
Apple Application Support (64-bit) (HKLM\...\{64E6007B-1DA9-42CD-BBE4-D5FA67A7C71D}) (Version: 5.2 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}) (Version: 10.0.1.3 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
Asmedia USB Host Controller Driver (HKLM-x32\...\{E4FB0B39-C991-4EE7-95DD-1A1A7857D33D}) (Version: 1.16.33.1 - Asmedia Technology)
AudioLaunchpadConfigurator (Version: 2.3.1401 - Nahimic) Hidden
Battlefield™ 1 (HKLM-x32\...\{335B50BC-6130-4BAF-9A6A-F1561270587B}) (Version: 1.0.47.30570 - Electronic Arts)
BeamNG.drive (HKLM\...\Steam App 284160) (Version: - BeamNG)
Bitdefender Agent (HKLM\...\Bitdefender Agent) (Version: 1.0.1 - Bitdefender)
Bitdefender Antivirus Free (HKLM\...\{1FCCF41D-5F00-4FE2-9653-162D0486C8B4}) (Version: 1.0.4.28 - Bitdefender)
Borderlands 2 (HKLM\...\Steam App 49520) (Version: - Gearbox Software)
Borderless Gaming (HKLM-x32\...\Borderless Gaming_is1) (Version: 8.4 - Codeusa Software)
Call of Duty: Modern Warfare 2 - Multiplayer (HKLM\...\Steam App 10190) (Version: - Infinity Ward)
Call of Duty: Modern Warfare 2 (HKLM\...\Steam App 10180) (Version: - Infinity Ward)
CAM (HKLM-x32\...\{4D246B88-693F-4079-894E-68F943210CC8}) (Version: 3.3.0 - NZXT)
CCleaner (HKLM\...\CCleaner) (Version: 5.26 - Piriform)
cFosSpeed v10.11 (HKLM\...\cFosSpeed) (Version: 10.11 - cFos Software GmbH, Bonn)
CheckDevicesConfigurator (Version: 2.3.1401 - Nahimic) Hidden
Cities: Skylines (HKLM\...\Steam App 255710) (Version: - Colossal Order Ltd.)
Corsair Utility Engine (HKLM-x32\...\{A95A2CA8-D121-4F63-B513-C94AEDDD35C4}) (Version: 2.9.53 - Corsair)
Counter-Strike: Global Offensive (HKLM\...\Steam App 730) (Version: - Valve)
CPUID CPU-Z MSI 1.74 (HKLM\...\CPUID CPU-Z MSI_is1) (Version: 1.74 - CPUID, Inc.)
Curse (HKLM-x32\...\{DEE70742-F4E9-44CA-B2B9-EE95DCF37295}) (Version: 6.0.0.0 - Curse)
Curse Client (HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\101a9f93b8f0bb6f) (Version: 5.1.1.844 - Curse)
Darksiders II: Deathinitive Edition (HKLM\...\Steam App 388410) (Version: - Gunfire Games)
Dead Space 2 (HKLM\...\Steam App 47780) (Version: - Visceral Games)
Defraggler (HKLM\...\Defraggler) (Version: 2.21 - Piriform)
Deus Ex: Mankind Divided™ (HKLM\...\Steam App 337000) (Version: - Eidos Montreal)
Discord (HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\Discord) (Version: 0.0.297 - Hammer & Chisel, Inc.)
Dishonored (HKLM\...\Steam App 205100) (Version: - Arkane Studios)
Dragon Eye(x64) (HKLM-x32\...\Installshield_{B746827A-3219-4EF8-8053-CEA5AEC12D33}) (Version: 0.0.1.1 - )
Dragon Eye(x64) (Version: 0.0.1.1 - MSI) Hidden
Dragon's Dogma: Dark Arisen (HKLM\...\Steam App 367500) (Version: - Capcom)
Dropbox (HKLM-x32\...\Dropbox) (Version: 19.4.13 - Dropbox, Inc.)
Dropbox Update Helper (x32 Version: 1.3.59.1 - Dropbox, Inc.) Hidden
Elite Dangerous (HKLM\...\Steam App 359320) (Version: - Frontier Developments)
Evernote v. 6.4.2 (HKLM-x32\...\{E74F0DCA-9FC8-11E6-9D98-005056950253}) (Version: 6.4.2.3788 - Evernote Corp.)
f.lux (HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\Flux) (Version: - )
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 56.0.2924.87 - Google Inc.)
Google Drive (HKLM-x32\...\{07A12123-B717-496B-B471-48AF6407B433}) (Version: 1.32.4066.7445 - Google, Inc.)
Google Photos Backup (HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\Google Photos Backup) (Version: 1.1.2.13 - Google, Inc.)
Google Update Helper (x32 Version: 1.3.32.7 - Google Inc.) Hidden
gpedt.msc 1.0 (HKLM-x32\...\{10B9C608-BF7C-4CCF-A658-C01D969DCA21}_is1) (Version: - Richard)
HP ENVY 4500 series Basic Device Software (HKLM\...\{6915424E-704F-4F5D-9057-9C7B406B36DB}) (Version: 32.3.198.49673 - Hewlett-Packard Co.)
HP ENVY 4500 series Help (HKLM-x32\...\{95BECC50-22B4-4FCA-8A2E-BF77713E6D3A}) (Version: 30.0.0 - Hewlett Packard)
HP Photo Creations (HKLM-x32\...\HP Photo Creations) (Version: 1.0.0.7702 - HP)
HP Support Solutions Framework (HKLM-x32\...\{2B5A1E68-6617-406D-B797-5DAB5B4630B8}) (Version: 12.5.32.203 - HP Inc.)
HP Update (HKLM-x32\...\{912D30CF-F39E-4B31-AD9A-123C6B794EE2}) (Version: 5.005.002.002 - Hewlett-Packard)
Intel Extreme Tuning Utility (HKLM-x32\...\{fde8aa07-3912-4bdf-ad35-ff1231bfd00d}) (Version: 6.2.0.17 - Intel Corporation)
Intel Extreme Tuning Utility (x32 Version: 6.2.0.17 - Intel Corporation) Hidden
Intel(R) Chipset Device Software (x32 Version: 10.1.1.38 - Intel(R) Corporation) Hidden
Intel(R) Management Engine Components (HKLM\...\{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 11.6.0.1036 - Intel Corporation)
Intel(R) Network Connections 21.1.30.0 (HKLM\...\PROSetDX) (Version: 21.1.30.0 - Intel)
Intel(R) Online Connect Software Asset Manager (x32 Version: 3.4.2072 - Intel Corporation) Hidden
Intel(R) Serial IO (HKLM\...\{9FD91C5C-44AE-4D9D-85BE-AE52816B0294}) (Version: 30.100.1633.3 - Intel Corporation)
Intel® Security Assist (HKLM-x32\...\{4B230374-6475-4A73-BA6E-41015E9C5013}) (Version: 1.0.0.532 - Intel Corporation)
iTunes (HKLM\...\{81C96689-EA5B-4B7D-A04F-16326EC51BC2}) (Version: 12.5.4.42 - Apple Inc.)
Java 8 Update 121 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180121F0}) (Version: 8.0.1210.13 - Oracle Corporation)
Just Cause 3 (HKLM\...\Steam App 225540) (Version: - Avalanche Studios)
LauncherSetup (Version: 2.3.1401 - Nahimic) Hidden
Left 4 Dead 2 (HKLM\...\Steam App 550) (Version: - Valve)
LibreOffice 5.2.5.1 (HKLM-x32\...\{79CD8EA1-DEB1-4582-9E41-8634223BDCD4}) (Version: 5.2.5.1 - The Document Foundation)
LightingController (HKLM-x32\...\{F83166E4-C89D-4F45-BDDA-94F24C85F4E5}) (Version: 0.01.0002 - iBUYPOWER)
Magicka (HKLM\...\Steam App 42910) (Version: - Arrowhead Game Studios)
Malwarebytes Anti-Malware version 2.2.1.1043 (HKLM-x32\...\Malwarebytes Anti-Malware_is1) (Version: 2.2.1.1043 - Malwarebytes)
Microsoft ASP.NET MVC 4 Runtime (HKLM-x32\...\{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50901.0 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24210 (HKLM-x32\...\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24210 (HKLM-x32\...\{23658c02-145e-483d-ba6b-1eb82c580529}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft XNA Framework Redistributable 3.1 (HKLM-x32\...\{19BFDA5D-1FE2-4F25-97F9-1A79DD04EE20}) (Version: 3.1.10527.0 - Microsoft Corporation)
Middle-earth: Shadow of Mordor (HKLM\...\Steam App 241930) (Version: - Monolith Productions, Inc.)
Might & Magic: Heroes VI (HKLM\...\Steam App 48220) (Version: - Blackhole)
Minecraft (HKLM-x32\...\{1C16BCA3-EBC1-49F6-8623-8FBFB9CCC872}) (Version: 1.0.3.0 - Mojang)
Mozilla Firefox 51.0 (x86 en-US) (HKLM-x32\...\Mozilla Firefox 51.0 (x86 en-US)) (Version: 51.0 - Mozilla)
Mozilla Maintenance Service (HKLM-x32\...\MozillaMaintenanceService) (Version: 51.0 - Mozilla)
MSI Afterburner 4.1.1 (HKLM-x32\...\Afterburner) (Version: 4.1.1 - MSI Co., LTD)
MSI Command Center (HKLM-x32\...\{85A2564E-9ED9-448A-91E4-B9211EE58A08}_is1) (Version: 2.0.0.43 - MSI)
MSI Fast Boot (HKLM-x32\...\{0F212E7A-65EB-4668-A8D7-749026A64F8E}_is1) (Version: 1.0.1.8 - MSI)
MSI Gaming APP (HKLM-x32\...\{E0229316-E73B-484B-B9E0-45098AB38D8C}}_is1) (Version: 6.0.0.30 - MSI)
MSI Gaming Lan Manager (HKLM-x32\...\{3318282C-D4D6-4B29-BBD5-95FC34B54FF0}_is1) (Version: 1.0.0.25 - MSI)
MSI Kombustor 2.5.9 (HKLM-x32\...\{0B7C79A5-5CB2-4ABD-A9C1-92A6213CE8DD}_is1) (Version: - MSI Co., LTD)
MSI Live Update 6 (HKLM-x32\...\{4F46CF54-47D2-41F4-B230-B0954C544420}}_is1) (Version: 6.2.0.06 - MSI)
MSI M-Cloud (HKLM-x32\...\{C2CA9595-A17F-4D28-BD6E-0E30447AF60B}}_is1) (Version: 1.0.0.20 - MSI)
MSI USB Speed Up (HKLM-x32\...\{79D5FA63-7003-4398-B882-C70ED18778D1}_is1) (Version: 1.0.0.09 - MSI)
Nahimic 2 (HKLM-x32\...\{05c7b70a-5d25-419a-9b71-76900393b641}) (Version: 2.3.14 - Nahimic)
Nahimic2UISetup (Version: 2.3.1401 - Nahimic) Hidden
NETGEAR Genie (HKLM-x32\...\NETGEAR Genie) (Version: 2.4.28.00 - NETGEAR Inc.)
NVIDIA GeForce Experience 3.3.0.95 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.3.0.95 - NVIDIA Corporation)
NVIDIA Graphics Driver 378.49 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 378.49 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.16.0318 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
NvNodejs (Version: 3.3.0.95 - NVIDIA Corporation) Hidden
NvTelemetry (Version: 2.3.5.0 - NVIDIA Corporation) Hidden
NvvHci (Version: 2.02.0.5 - NVIDIA Corporation) Hidden
Origin (HKLM-x32\...\Origin) (Version: 10.4.3.15631 - Electronic Arts, Inc.)
Overwatch (HKLM-x32\...\Overwatch) (Version: - Blizzard Entertainment)
Path of Exile (HKLM\...\Steam App 238960) (Version: - Grinding Gear Games)
Plague Inc: Evolved (HKLM\...\Steam App 246620) (Version: - Ndemic Creations)
Product Improvement Study for HP ENVY 4500 series (HKLM\...\{58139103-BACF-4BDC-B71C-955F9164ADA6}) (Version: 32.3.198.49673 - Hewlett-Packard Co.)
ProductDaemonSetup (Version: 2.3.1401 - Nahimic) Hidden
ProductNSConfigurator (Version: 2.3.1401 - Nahimic) Hidden
Rainmeter (HKLM-x32\...\Rainmeter) (Version: 4.0 beta r2613 - Win10 Widgets)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8010 - Realtek Semiconductor Corp.)
RivaTuner Statistics Server 6.3.0 (HKLM-x32\...\RTSS) (Version: 6.3.0 - Unwinder)
Rocket League (HKLM\...\Steam App 252950) (Version: - Psyonix, Inc.)
Rockstar Games Social Club (HKLM-x32\...\Rockstar Games Social Club) (Version: 1.2.0.5 - Rockstar Games)
SHIELD Streaming (Version: 7.1.0351 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (Version: 3.3.0.95 - NVIDIA Corporation) Hidden
Skype™ 7.29 (HKLM-x32\...\{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.29.101 - Skype Technologies S.A.)
SonicMapperConfigurator (Version: 2.3.1401 - Nahimic) Hidden
Spotify (HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\Spotify) (Version: 1.0.48.103.g15edf1ec - Spotify AB)
STAR WARS™ Jedi Knight: Jedi Academy™ (HKLM\...\Steam App 6020) (Version: - Raven Software)
Stellaris (HKLM\...\Steam App 281990) (Version: - Paradox Development Studio)
SUPERHOT (HKLM\...\Steam App 322500) (Version: - SUPERHOT Team)
Tharsis (HKLM\...\Steam App 323060) (Version: - Choice Provisions)
The Witcher 3: Wild Hunt (HKLM\...\Steam App 292030) (Version: - CD PROJEKT RED)
Titanfall™ 2 (HKLM-x32\...\{4BD80373-FEE7-45B6-8249-6E8E98717405}) (Version: 1.0.0.3 - Electronic Arts, Inc.)
Total War: SHOGUN 2 (HKLM\...\Steam App 34330) (Version: - The Creative Assembly)
TP-LINK Archer T2U_T2UH Driver (HKLM-x32\...\{F2496892-5295-4208-AB93-21F1AFD07C97}) (Version: 1.3.1 - TP-LINK)
TP-LINK Archer T6E Driver (HKLM-x32\...\{F2CF3250-3769-431E-A808-056BFA917849}) (Version: 1.3.1 - TP-LINK)
TP-LINK Wireless Configuration Utility (HKLM-x32\...\{319D91C6-3D44-436C-9F79-36C0D22372DC}) (Version: 1.3.1 - TP-LINK)
TradeSkillMaster Application version 1.0 (HKLM-x32\...\{c44da794-b956-4d50-8733-346d56ae63c7}_is1) (Version: 1.0 - TradeSkillMaster)
Ubisoft Game Launcher (HKLM-x32\...\{888F1505-C2B3-4FDE-835D-36353EBD4754}) (Version: 1.0.0.0 - UBISOFT)
UIInstallUpgrade (Version: 2.3.1401 - Nahimic) Hidden
Uplay (HKLM-x32\...\Uplay) (Version: 21.1 - Ubisoft)
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.4 - VideoLAN)
Vulkan Run Time Libraries 1.0.26.0 (HKLM\...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
Vulkan Run Time Libraries 1.0.37.0 (HKLM\...\VulkanRT1.0.37.0) (Version: 1.0.37.0 - LunarG, Inc.)
War Thunder (HKLM\...\Steam App 236390) (Version: - Gaijin Entertainment)
WD Backup (HKLM-x32\...\{a8c9535a-ecd9-4172-a330-0cb5ff9dbed9}) (Version: 1.5.5953.19614 - Western Digital Technologies, Inc.)
WD Backup (x32 Version: 1.5.5953.19614 - Western Digital Technologies, Inc) Hidden
WD Drive Utilities (HKLM-x32\...\{eab1fb93-61fb-48de-b815-b4e9b68d2ef1}) (Version: 1.3.2.2 - Western Digital Technologies, Inc.)
WD Drive Utilities (x32 Version: 1.3.2.2 - Western Digital Technologies, Inc.) Hidden
WD Quick View (HKLM-x32\...\{965D28B5-3C86-41FD-994E-D6376815C9B3}) (Version: 2.4.10.17 - Western Digital Technologies, Inc.)
WD Security (HKLM-x32\...\{249644e6-451a-4a5c-bd5c-21eeb9eec79d}) (Version: 1.3.1.2 - Western Digital Technologies, Inc.)
WD Security (x32 Version: 1.3.1.2 - Western Digital Technologies, Inc.) Hidden
WinPcap 4.1.3 (HKLM-x32\...\WinPcapInst) (Version: 4.1.0.2980 - Riverbed Technology, Inc.)
WinRAR 5.40 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
World of Warcraft (HKLM-x32\...\World of Warcraft) (Version: - Blizzard Entertainment)
CustomCLSID: HKU\S-1-5-21-697782072-1053751190-176726198-1002_Classes\CLSID\{CB492AF1-2CEF-4E58-BE47-471C77D0C8BA}\InprocServer32 -> C:\Users\Jarvis\AppData\Local\Google\Update\1.3.32.7\psuser_64.dll (Google Inc.)
CustomCLSID: HKU\S-1-5-21-697782072-1053751190-176726198-1002_Classes\CLSID\{ce5af8e4-8c03-46f3-9a02-fc33a28b74e4}\InprocServer32 -> c:\windows\system32\dfshim.dll (Microsoft Corporation)
CustomCLSID: HKU\S-1-5-21-697782072-1053751190-176726198-1002_Classes\CLSID\{E8CF3E55-F919-49D9-ABC0-948E6CB34B9F}\InprocServer32 -> C:\Users\Jarvis\AppData\Local\Google\Update\1.3.32.7\psuser_64.dll (Google Inc.)
Task: {053A9F4C-5F37-41FE-B41C-2B92659212AD} - System32\Tasks\CAM => C:\Program Files (x86)\NZXT\CAM\CAM_V3.exe [2017-01-17] ()
Task: {05FAD450-B866-442B-8933-0C174025545D} - System32\Tasks\{629FA748-A655-420C-B034-BFE42D0B39A4} => pcalua.exe -a "C:\Program Files (x86)\Pidgin\pidgin-uninst.exe"
Task: {10F2968D-F92C-4AAA-9D70-43A404CCBF02} - System32\Tasks\Intel\Intel Telemetry 2 (x86) => C:\Program Files (x86)\Intel\Telemetry 2.0\lrio.exe [2015-11-20] (Intel Corporation)
Task: {1132D714-1119-4B70-9A1E-10984BEFEA4B} - System32\Tasks\Software Update => C:\Program Files (x86)\Glarysoft\Software Update 5\Software Update.exe
Task: {39675B0C-4E03-4369-AA98-5EB8E0882499} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-06-11] (Google Inc.)
Task: {3C2DD3E3-D20E-46FA-87DD-DA53956554E1} - System32\Tasks\Nahimic2Svc64Run => C:\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2Svc64.exe [2017-01-13] ()
Task: {4D585EF2-A61E-48C5-BF0D-ED255F893AA7} - System32\Tasks\Nahimic2UILauncherRun => C:\Program Files\Nahimic\Nahimic2\UserInterface\Nahimic2UILauncher.exe [2017-01-13] ()
Task: {4DA8EB82-7D6C-4714-9963-904961B9B49C} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-697782072-1053751190-176726198-1002UA => C:\Users\Jarvis\AppData\Local\Google\Update\GoogleUpdate.exe [2017-01-28] (Google Inc.)
Task: {529005CF-4DE4-4D04-A713-972DA98AC254} - System32\Tasks\Adobe Flash Player Updater => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpdateService.exe [2017-02-06] (Adobe Systems Incorporated)
Task: {57C48B9A-5F4E-4B1A-8C5E-418EBCBBB114} - System32\Tasks\NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmMon.exe [2017-01-20] (NVIDIA Corporation)
Task: {5F990D90-226A-44D0-B25D-208862527084} - System32\Tasks\Intel PTT EK Recertification => C:\Program Files\Intel\iCLS Client\IntelPTTEKRecertification.exe [2016-07-26] (Intel(R) Corporation)
Task: {62F2FDA9-99A6-4852-BF0A-6A6EC05A82F8} - System32\Tasks\GoogleUpdateTaskUserS-1-5-21-697782072-1053751190-176726198-1002Core => C:\Users\Jarvis\AppData\Local\Google\Update\GoogleUpdate.exe [2017-01-28] (Google Inc.)
Task: {6683A52B-639D-40A9-8FD1-9FB812329EC7} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2016-12-19] (Adobe Systems Incorporated)
Task: {71529473-BA62-4436-BD78-2581C06C0B30} - System32\Tasks\IntelIOC-Upgrade-f1c8187b-2653-47cd-a9be-b554b98f68a7-Logon => C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [2016-09-29] (Intel Corporation)
Task: {73B3B14C-4E4D-4B81-AF19-69C346440BDA} - System32\Tasks\Hewlett-Packard\HP Support Assistant\HP Support Solutions Framework Report => C:\Program Files (x86)\Hewlett-Packard\HP Support Solutions\Modules\HPSFReport.exe [2016-12-21] (HP Inc.)
Task: {7DCF1B4E-2FBA-4C77-A811-152A6E7449AA} - System32\Tasks\NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2017-01-20] (NVIDIA Corporation)
Task: {83DDD57D-7106-4F30-9021-3AA52D49B3E5} - System32\Tasks\NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\NvNode\nvnodejslauncher.exe [2017-01-20] (NVIDIA Corporation)
Task: {85F678D8-0EBC-43EF-95CD-7F40A85E2C1E} - System32\Tasks\NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [2017-01-20] (NVIDIA Corporation)
Task: {908D2CB5-DDB3-42BE-ADD0-222D16EC33F4} - System32\Tasks\Nahimic2Svc32Run => C:\Program Files\Nahimic\Nahimic2\UserInterface\Nahimic2Svc32.exe [2017-01-13] ()
Task: {98B8659E-2F29-4E1E-9423-20D97B0BB12F} - System32\Tasks\HPCustParticipation HP ENVY 4500 series => C:\Program Files\HP\HP ENVY 4500 series\Bin\HPCustPartic.exe [2014-07-21] (Hewlett-Packard Development Company, LP)
Task: {A4C838AD-DC77-4C80-BD95-A88F2E8AB13F} - System32\Tasks\NahimicMSIsvc32Run => C:\Program Files\Nahimic\NahimicMSI\UserInterface\NahimicMSIsvc32.exe
Task: {AF36637E-BB3C-472A-A493-6B63FA955E5B} - System32\Tasks\DropboxUpdateTaskMachineUA => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe [2016-06-11] (Dropbox, Inc.)
Task: {B269DD9C-29C9-43AE-947C-0E088B6CA189} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2016-06-11] (Google Inc.)
Task: {B7A00EB4-DC9C-45FE-9203-214BE3D237E4} - System32\Tasks\Hewlett-Packard\HP Support Assistant\HP Support Solutions Framework Updater => C:\Program Files (x86)\Hewlett-Packard\HP Support Solutions\Modules\HPSSFUpdater.exe [2016-12-07] (HP Inc.)
Task: {C87C275C-57EB-489E-93B0-0C91224F3EFA} - System32\Tasks\NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2017-01-20] (NVIDIA Corporation)
Task: {CCA12845-9741-403B-9BC4-D280850C7F7C} - System32\Tasks\DropboxUpdateTaskMachineCore => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe [2016-06-11] (Dropbox, Inc.)
Task: {CD437205-D469-455A-AB0A-A1980CDA49DA} - System32\Tasks\NahimicMSIUILauncherRun => C:\Program Files\Nahimic\NahimicMSI\UserInterface\NahimicMSIUILauncher.exe
Task: {DE1D0724-B699-4FF3-A6F6-F419512540A1} - System32\Tasks\MSISW_Host => C:\Windows\SysWOW64\muachost.exe [2015-08-18] (MSI)
Task: {E9617400-CBF7-4D1D-B0DA-2A92D1F298B6} - System32\Tasks\Adobe Flash Player PPAPI Notifier => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashUtil32_24_0_0_194_pepper.exe [2017-01-10] (Adobe Systems Incorporated)
Task: {E9C8421B-814B-4D44-846E-1B1D31312DF6} - System32\Tasks\IntelIOC-Upgrade-f1c8187b-2653-47cd-a9be-b554b98f68a7 => C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe [2016-09-29] (Intel Corporation)
Task: {EA5A0F5B-1A4E-46C1-B5C0-BBB81069A572} - System32\Tasks\MSIOSDx86_Host => C:\Program Files (x86)\MSI\Gaming APP\OSD\x86\MsiGamingOSD_x86.exe [2016-07-28] (Micro-Star INT'L CO., LTD.)
Task: {EA8093F1-ACDD-49E8-82BA-356B740B2401} - System32\Tasks\Bitdefender Agent WatchDog_65D6944A0EF74FDAB96E31112AD39864 => C:\Program Files\Bitdefender Agent\WatchDog.exe [2016-10-21] (Bitdefender)
Task: {EBE18965-8037-4666-B4AB-A3A86BE07EFE} - System32\Tasks\NahimicMSIsvc64Run => C:\Program Files\Nahimic\NahimicMSI\UserInterface\x64\NahimicMSIsvc64.exe
Task: {ED4C07A5-2D35-45CB-BEAA-2DA87AFF9439} - System32\Tasks\NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [2017-01-20] (NVIDIA Corporation)
Task: {F183F3EA-ED9D-4A0E-BDA7-704C1E6545DE} - System32\Tasks\MSIOSDx64_Host => C:\Program Files (x86)\MSI\Gaming APP\OSD\x64\MsiGamingOSD_x64.exe [2016-07-28] (Micro-Star INT'L CO., LTD.)
Task: {F69236BD-A499-4DFF-B468-D399B5526770} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2016-12-21] (Piriform Ltd)
Task: {FA780CF2-FCB7-4105-A9E7-4C4890B19E32} - System32\Tasks\IUM-F1E24CA0-B63E-4F13-A9E3-4ADE3BFF3473 => C:\Program Files (x86)\Intel\Intel(R) Update Manager\bin\iumsvc.exe
Task: C:\WINDOWS\Tasks\Adobe Flash Player PPAPI Notifier.job => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashUtil32_24_0_0_194_pepper.exe
Task: C:\WINDOWS\Tasks\Adobe Flash Player Updater.job => C:\WINDOWS\SysWoW64\Macromed\Flash\FlashPlayerUpdateService.exe
Task: C:\WINDOWS\Tasks\DropboxUpdateTaskMachineCore.job => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
Task: C:\WINDOWS\Tasks\DropboxUpdateTaskMachineUA.job => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
Task: C:\WINDOWS\Tasks\MSISW_Host.job => C:\WINDOWS\SysWoW64\muachost.exe
==================== Shortcuts =============================
2017-01-03 11:58 - 2017-01-03 11:58 - 00027760 _____ () C:\Program Files (x86)\NZXT\CAM\Service\CAMService.exe
2016-06-03 23:19 - 2014-07-22 17:59 - 00936728 _____ () C:\Program Files (x86)\ASUS\AXSP\1.02.00\atkexComSvc.exe
2016-10-05 15:17 - 2016-10-05 15:17 - 00092472 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
2016-11-17 01:28 - 2016-11-17 01:28 - 01353528 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
2016-06-03 23:19 - 2014-07-22 17:59 - 01360016 _____ () C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.22\AsSysCtrlService.exe
2016-10-05 12:15 - 2016-10-05 12:15 - 00107752 _____ () C:\Program Files\Intel\Intel(R) Online Connect Access\libglog.dll
2016-10-05 12:15 - 2016-10-05 12:15 - 00412904 _____ () C:\Program Files\Intel\Intel(R) Online Connect Access\JsonCpp.dll
2017-01-09 01:33 - 2017-01-20 10:39 - 04489152 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\Poco.dll
2017-01-09 01:33 - 2017-01-20 10:39 - 01147328 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\libprotobuf.dll
2016-12-01 09:59 - 2016-04-16 18:07 - 00280576 _____ () C:\Program Files\Bitdefender Antivirus Free\txmlutil.dll
2017-02-08 11:17 - 2017-02-08 11:17 - 01008448 _____ () C:\Program Files\Bitdefender Antivirus Free\Signatures\OTEngines\otengines_02439_002\ashttpbr.mdl
2017-02-08 11:17 - 2017-02-08 11:17 - 00541952 _____ () C:\Program Files\Bitdefender Antivirus Free\Signatures\OTEngines\otengines_02439_002\ashttpdsp.mdl
2017-02-08 11:17 - 2017-02-08 11:17 - 03243920 _____ () C:\Program Files\Bitdefender Antivirus Free\Signatures\OTEngines\otengines_02439_002\ashttpph.mdl
2017-02-08 11:17 - 2017-02-08 11:17 - 01544568 _____ () C:\Program Files\Bitdefender Antivirus Free\Signatures\OTEngines\otengines_02439_002\ashttprbl.mdl
2016-10-04 17:09 - 2016-10-04 17:09 - 00253664 _____ () C:\Program Files\Intel\Intel(R) Online Connect\CSLibWrapper.dll
2016-07-16 03:42 - 2016-07-16 03:42 - 00231424 _____ () C:\WINDOWS\SYSTEM32\ism32k.dll
2016-12-23 18:39 - 2016-12-09 02:29 - 02681200 _____ () C:\WINDOWS\System32\CoreUIComponents.dll
2017-01-24 20:54 - 2017-01-20 07:13 - 00134712 _____ () C:\Program Files\NVIDIA Corporation\Display\NvSmartMax64.dll
2016-12-01 09:59 - 2014-08-28 13:57 - 00824376 _____ () C:\Program Files\Bitdefender Antivirus Free\bdmetrics.dll
2016-12-23 18:39 - 2016-12-09 02:29 - 02681200 _____ () C:\WINDOWS\system32\CoreUIComponents.dll
2017-01-10 21:45 - 2016-06-14 16:35 - 00187392 _____ () C:\Program Files (x86)\MSI\Gaming APP\OSD\x64\D3D11FontDraw.dll
2016-12-23 18:39 - 2016-12-09 02:29 - 02681200 _____ () C:\WINDOWS\SYSTEM32\CoreUIComponents.dll
2017-01-13 10:53 - 2017-01-13 10:53 - 00218296 _____ () C:\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2DevProps.dll
2017-01-13 10:53 - 2017-01-13 10:53 - 00289976 _____ () C:\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2OSD.dll
2016-09-13 14:36 - 2016-09-06 20:56 - 00134656 _____ () C:\Windows\ShellExperiences\Windows.UI.Shell.SharedUtilities.dll
2017-01-11 00:17 - 2016-12-20 23:09 - 00474112 _____ () C:\Windows\ShellExperiences\QuickActions.dll
2017-01-11 00:17 - 2016-12-20 22:54 - 09760768 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\CortanaApi.dll
2017-01-11 00:17 - 2016-12-20 22:48 - 01401856 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Core.dll
2017-01-11 00:17 - 2016-12-20 22:48 - 00757248 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\CSGSuggestLib.dll
2017-01-11 00:17 - 2016-12-20 22:48 - 01033216 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Actions.dll
2017-01-11 00:17 - 2016-12-20 22:48 - 02424320 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.BackgroundTask.dll
2017-01-11 00:17 - 2016-12-20 22:53 - 04853760 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\RemindersUI.dll
2017-02-05 23:55 - 2017-02-05 23:56 - 00073728 _____ () C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.11.105.0_x64__kzf8qxf38zg5c\SkypeHost.exe
2017-02-05 23:55 - 2017-02-05 23:56 - 00179712 _____ () C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.11.105.0_x64__kzf8qxf38zg5c\SkypeBackgroundTasks.dll
2017-02-05 23:55 - 2017-02-05 23:56 - 42895872 _____ () C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.11.105.0_x64__kzf8qxf38zg5c\SkyWrap.dll
2017-02-05 23:55 - 2017-02-05 23:56 - 02215424 _____ () C:\Program Files\WindowsApps\Microsoft.SkypeApp_11.11.105.0_x64__kzf8qxf38zg5c\roottools.dll
2017-01-13 10:49 - 2017-01-13 10:49 - 00705208 _____ () C:\Program Files\Nahimic\Nahimic2\UserInterface\Nahimic2UILauncher.exe
2017-01-13 10:50 - 2017-01-13 10:50 - 02054328 _____ () C:\Program Files\Nahimic\Nahimic2\UserInterface\Nahimic2svc32.exe
2017-01-13 10:54 - 2017-01-13 10:54 - 00513208 _____ () C:\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2svc64.exe
2016-07-06 19:19 - 2016-07-06 19:19 - 00098304 _____ () C:\Program Files\Rainmeter\Plugins\PerfMon.DLL
2016-07-06 19:20 - 2016-07-06 19:20 - 00339968 _____ () C:\Program Files\Rainmeter\Plugins\RunCommand.DLL
2016-07-06 19:20 - 2016-07-06 19:20 - 00133120 _____ () C:\Program Files\Rainmeter\Plugins\SysInfo.DLL
2016-07-06 19:21 - 2016-07-06 19:21 - 00022016 _____ () C:\Program Files\Rainmeter\Plugins\InputText.DLL
2017-01-17 17:49 - 2017-01-17 17:49 - 07818864 _____ () C:\Program Files (x86)\NZXT\CAM\CAM_V3.exe
2016-12-14 10:56 - 2016-12-14 10:56 - 00202352 _____ () C:\Program Files (x86)\NZXT\CAM\FPS\CAMFPS.exe
2017-01-11 00:17 - 2016-12-20 22:49 - 04046848 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Signals.dll
2016-07-16 03:42 - 2016-07-16 03:42 - 01872384 _____ () C:\Windows\System32\speech_onecore\engines\tts\MSTTSEngine_OneCore.dll
2016-06-03 23:19 - 2014-07-22 17:59 - 00104448 _____ () C:\Program Files (x86)\ASUS\AXSP\1.02.00\ATKEX.dll
2017-01-10 21:45 - 2016-04-20 14:12 - 00772608 _____ () C:\Program Files (x86)\MSI\MSI OC Kit\ActiveX_Service\Lib\USB_DLL.dll
2017-01-31 12:56 - 2005-07-18 13:43 - 00160256 _____ () C:\Program Files (x86)\MSI\Live Update\unrar.dll
2016-10-20 01:28 - 2016-10-20 01:28 - 01243936 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
2016-10-28 06:15 - 2017-02-08 23:24 - 02493440 _____ () C:\Program Files (x86)\Origin\libGLESv2.dll
2017-01-09 01:33 - 2017-01-20 10:39 - 00018880 _____ () C:\Program Files (x86)\NVIDIA Corporation\Update Core\detoured.dll
2017-01-09 01:33 - 2017-01-20 10:39 - 03774400 _____ () C:\Program Files (x86)\NVIDIA Corporation\NvContainer\Poco.dll
2017-01-09 01:33 - 2017-01-20 10:39 - 00900032 _____ () C:\Program Files (x86)\NVIDIA Corporation\NvContainer\libprotobuf.dll
2017-01-13 10:48 - 2017-01-13 10:48 - 00189112 _____ () C:\Program Files\Nahimic\Nahimic2\UserInterface\Nahimic2DevProps.dll
2017-01-13 10:46 - 2017-01-13 10:46 - 00262840 _____ () C:\Program Files\Nahimic\Nahimic2\UserInterface\Nahimic2OSD.dll
2017-01-10 21:45 - 2016-06-14 16:35 - 00163328 _____ () C:\Program Files (x86)\MSI\Gaming APP\OSD\x86\D3D11FontDraw.dll
2016-10-31 17:45 - 2016-10-31 17:45 - 00321208 _____ () C:\Program Files (x86)\Evernote\Evernote\libtidy.dll
2016-12-07 18:28 - 2016-12-07 18:28 - 00282112 _____ () C:\Program Files (x86)\NZXT\CAM\GSyncLib.dll
2017-02-05 00:23 - 2017-02-09 18:02 - 00308736 _____ () C:\Program Files (x86)\NZXT\CAM\NVAPIHelper.dll
2017-01-12 16:07 - 2017-01-12 16:07 - 00211456 _____ () C:\Program Files (x86)\Corsair\Corsair Utility Engine\quazip.dll
2017-01-12 16:07 - 2017-01-12 16:07 - 00037376 _____ () C:\Program Files (x86)\Corsair\Corsair Utility Engine\MacroRecording.dll
2017-01-12 16:06 - 2017-01-12 16:06 - 00093184 _____ () C:\Program Files (x86)\Corsair\Corsair Utility Engine\zlib.dll
2016-06-10 09:19 - 2016-06-10 09:19 - 00011264 _____ () C:\Program Files (x86)\Corsair\Corsair Utility Engine\libEGL.DLL
2016-06-10 09:19 - 2016-06-10 09:19 - 01990144 _____ () C:\Program Files (x86)\Corsair\Corsair Utility Engine\libGLESv2.dll
2016-12-07 18:28 - 2016-12-07 18:28 - 00070656 _____ () C:\Program Files (x86)\NZXT\CAM\FPS\KeyHookDLL_x86.dll
2017-01-09 01:33 - 2017-01-20 05:36 - 00338488 _____ () \\?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVAccountAPINode.node
2017-01-09 01:33 - 2017-01-20 05:36 - 00254008 _____ () \\?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\DriverInstall.node
2017-01-09 01:33 - 2017-01-20 05:36 - 02808888 _____ () \\?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\Downloader.node
2017-01-09 01:33 - 2017-01-20 05:36 - 00384568 _____ () \\?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvGameShareAPINode.node
2017-01-09 01:33 - 2017-01-20 05:36 - 00537656 _____ () \\?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvSpCapsAPINode.node
2017-01-09 01:33 - 2017-01-20 05:36 - 00468024 _____ () \\?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvGalleryAPINode.node
2017-01-09 01:33 - 2017-01-20 05:36 - 01066552 _____ () \\?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvCameraAPINode.node
2017-01-10 22:50 - 2017-01-20 05:36 - 01014840 _____ () \\?\C:\Program Files (x86)\NVIDIA Corporation\NvNode\NvSDKAPINode.node
2016-09-29 16:11 - 2016-09-29 16:11 - 00042728 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32api.pyd
2016-09-29 16:10 - 2016-09-29 16:10 - 00060648 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\pywintypes27.dll
2016-09-29 16:10 - 2016-09-29 16:10 - 00126696 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\pythoncom27.dll
2016-09-29 16:11 - 2016-09-29 16:11 - 00023272 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\_multiprocessing.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00045800 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\_ctypes.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00026856 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32service.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00023784 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\servicemanager.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00030440 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\_socket.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00444136 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\_ssl.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00287976 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\_hashlib.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00018152 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\select.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00021224 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32pipe.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00045800 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32file.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00018664 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32event.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00371432 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\_bsddb.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00025320 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32process.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00021224 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32ts.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00019688 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32profile.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00043752 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32security.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00025832 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\win32inet.pyd
2016-09-29 16:11 - 2016-09-29 16:11 - 00190696 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\unicodedata.pyd
2016-09-29 16:10 - 2016-09-29 16:10 - 00023272 _____ () C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\EnvironmentID.dll
AlternateDataStreams: C:\Users\Jarvis\Downloads\AdwCleaner.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\CAM_Installer V3.3.0.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\ComboFix.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\DDU v15.3.1.0.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\DNSBench.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\esetonlinescanner_enu.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\FRST64.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\Intel Driver Update Utility Installer.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\JRT.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\MiniToolBox.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\msert.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\namebench-1.3.1-Windows.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\NETGEARGenie-install.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\rsthosts_2.0.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\TCPOptimizer.exe:BDU [0]
AlternateDataStreams: C:\Users\Jarvis\Downloads\tdsskiller.exe:BDU [0]
==================== Hosts content: ==========================
2015-10-29 23:24 - 2017-02-04 03:56 - 00000178 _RASH C:\WINDOWS\system32\Drivers\etc\hosts
127.0.0.1 localhost
127.0.0.1 localhost
HKU\S-1-5-21-697782072-1053751190-176726198-1002\Control Panel\Desktop\\Wallpaper -> C:\Users\Jarvis\Pictures\Backgrounds\1440p\Free-HD-Images-1440p.jpg
DNS Servers: 68.105.28.11 - 68.105.29.11
Windows Firewall is enabled.
HKLM\...\StartupApproved\StartupFolder: => "SteelSeries Engine 3.lnk"
HKLM\...\StartupApproved\StartupFolder: => "TP-LINK Wireless Configuration Utility.lnk"
HKLM\...\StartupApproved\Run: => "iTunesHelper"
HKLM\...\StartupApproved\Run32: => "Dropbox"
HKLM\...\StartupApproved\Run32: => "Live Update"
HKLM\...\StartupApproved\Run32: => "MSI Gaming Lan Manager"
HKLM\...\StartupApproved\Run32: => "Command Center"
HKLM\...\StartupApproved\Run32: => "Super Charger"
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\StartupApproved\Run: => "OneDrive"
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\StartupApproved\Run: => "OpenDNS Updater"
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\StartupApproved\Run: => "BingSvc"
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\StartupApproved\Run: => "HP ENVY 4500 series (NET)"
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\StartupApproved\Run: => "Spotify Web Helper"
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\StartupApproved\Run: => "Gaijin.Net Agent"
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\StartupApproved\Run: => "Google Photos Backup"
HKU\S-1-5-21-697782072-1053751190-176726198-1002\...\StartupApproved\Run: => "My Daily Wallpaper"
FirewallRules: [{99D31BD8-7A49-4830-9F89-E4EE5A708E69}] => LPort=9143
FirewallRules: [{E6CDC0F6-6F2A-48F7-8FD7-DE4998D521A0}] => LPort=2333
FirewallRules: [TCP Query User{5FA9EB0A-76CC-45BD-9DB0-3AB626C380F8}C:\program files (x86)\google\chrome\application\chrome.exe] => C:\program files (x86)\google\chrome\application\chrome.exe
FirewallRules: [UDP Query User{2FC894D1-BF1F-4BC5-BAAB-C6C1C10EEF9E}C:\program files (x86)\google\chrome\application\chrome.exe] => C:\program files (x86)\google\chrome\application\chrome.exe
FirewallRules: [{416E918F-C4AA-4CB5-8A21-02BF5C7DBC13}] => C:\program files (x86)\google\chrome\application\chrome.exe
FirewallRules: [{B51C38F1-D805-4004-87C4-1FD0B229724E}] => C:\program files (x86)\google\chrome\application\chrome.exe
FirewallRules: [{CA456F6D-2360-48B8-B250-F832550B15E9}] => LPort=24680
FirewallRules: [TCP Query User{77E9128C-DC00-4954-A5A8-E6DCF65BFAED}C:\program files\hp\hp envy 4500 series\bin\hpnetworkcommunicatorcom.exe] => C:\program files\hp\hp envy 4500 series\bin\hpnetworkcommunicatorcom.exe
FirewallRules: [UDP Query User{429918A3-88C9-4CD9-BB34-F006ADCA1B44}C:\program files\hp\hp envy 4500 series\bin\hpnetworkcommunicatorcom.exe] => C:\program files\hp\hp envy 4500 series\bin\hpnetworkcommunicatorcom.exe
FirewallRules: [{D55D0A24-3E20-44E6-A4EE-319CECE9CFF9}] => C:\program files\hp\hp envy 4500 series\bin\hpnetworkcommunicatorcom.exe
FirewallRules: [{E83BDBDF-4EFB-45EE-802E-AB4AC6C49DAD}] => C:\program files\hp\hp envy 4500 series\bin\hpnetworkcommunicatorcom.exe
FirewallRules: [{43F4056A-F3D6-4D88-921C-536D3F5E0D68}] => C:\Program Files (x86)\Dropbox\Client\Dropbox.exe
FirewallRules: [TCP Query User{923B08C0-8842-4FB7-9766-376EB7B46C83}C:\program files (x86)\battle.net\diablo iii\diablo iii.exe] => C:\program files (x86)\battle.net\diablo iii\diablo iii.exe
FirewallRules: [UDP Query User{26CF8194-60E7-43FC-8B1A-CD9B954176BB}C:\program files (x86)\battle.net\diablo iii\diablo iii.exe] => C:\program files (x86)\battle.net\diablo iii\diablo iii.exe
FirewallRules: [{99CE2451-8DE8-44D0-8AB1-F15777A37BCB}] => C:\program files (x86)\battle.net\diablo iii\diablo iii.exe
FirewallRules: [{316CD305-7E2E-4ECF-AC77-ED2E29365F52}] => C:\program files (x86)\battle.net\diablo iii\diablo iii.exe
FirewallRules: [{C79EDBE1-CDD9-4C4F-8CBD-743C80C9A208}] => C:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{63975AB5-69DF-4C0A-9F16-44B5FC7DCC19}] => C:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{2B052AB6-0651-4D54-84F0-43989A794554}] => C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe
FirewallRules: [{505AF880-2472-4CFC-AC5A-300A2FF5A02C}] => C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe
24-01-2017 20:46:25 Installed CAM
28-01-2017 11:48:24 Removed OpenOffice 4.1.2
30-01-2017 03:20:26 Installed DirectX
31-01-2017 12:59:34 Installed Intel(R) Network Connections.
02-02-2017 01:00:16 Nahimic for MSI
05-02-2017 00:14:55 Removed CAM
05-02-2017 00:27:50 JRT Pre-Junkware Removal
08-02-2017 17:44:13 Intel® Driver Update Utility
Name: Unknown USB Device (Device Descriptor Request Failed)
Description: Unknown USB Device (Device Descriptor Request Failed)
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Manufacturer: (Standard USB Host Controller)
Service:
Problem: : Windows has stopped this device because it has reported problems. (Code 43)
Resolution: One of the drivers controlling the device notified the operating system that the device failed in some manner. For more information about how to diagnose the problem, see the hardware documentation.
Name: Standard PS/2 Keyboard
Description: Standard PS/2 Keyboard
Class Guid: {4d36e96b-e325-11ce-bfc1-08002be10318}
Manufacturer: (Standard keyboards)
Service: i8042prt
Problem: : This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)
Resolution: The device is installed incorrectly. The problem could be a hardware failure, or a new driver might be needed.
Devices stay in this state if they have been prepared for removal.
After you remove the device, this error disappears.Remove the device, and this error should be resolved.
Name: Microsoft PS/2 Mouse
Description: Microsoft PS/2 Mouse
Class Guid: {4d36e96f-e325-11ce-bfc1-08002be10318}
Manufacturer: Microsoft
Service: i8042prt
Name: High Definition Audio Controller
Description: High Definition Audio Controller
Class Guid: {4d36e97d-e325-11ce-bfc1-08002be10318}
Service: HDAudBus
Problem: : This device is disabled. (Code 22)
Resolution: In Device Manager, click "Action", and then click "Enable Device". This starts the Enable Device wizard. Follow the instructions.
Application errors:
Error: (02/09/2017 06:02:22 PM) (Source: Perflib) (EventID: 1023) (User: )
Description: Windows cannot load the extensible counter DLL rdyboost. The first four bytes (DWORD) of the Data section contains the Windows error code.
Error: (02/08/2017 11:51:09 PM) (Source: IntelDalJhi) (EventID: 4) (User: )
Description: Intel(R) Dynamic Application Loader Host Interface Service initialization failure - the spooler applet is invalid.
Error: (02/08/2017 07:26:29 PM) (Source: DbxSvc) (EventID: 320) (User: )
Description: Failed to connect to the driver: (-2147024894) The system cannot find the file specified.
Error: (02/08/2017 07:26:29 PM) (Source: DbxSvc) (EventID: 270) (User: )
Description: Filter Unload failed with: (-2145452013) The system could not find the filter specified.
Error: (02/08/2017 06:14:21 PM) (Source: DbxSvc) (EventID: 320) (User: )
Error: (02/08/2017 05:54:35 PM) (Source: Perflib) (EventID: 1008) (User: )
Description: The Open Procedure for service "BITS" in DLL "C:\Windows\System32\bitsperf.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
Error: (02/08/2017 05:54:32 PM) (Source: DbxSvc) (EventID: 320) (User: )
Error: (02/08/2017 05:53:47 PM) (Source: Microsoft-Windows-Immersive-Shell) (EventID: 5973) (User: JARVIS-PC)
Description: Activation of app Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy!App failed with error: -2144927141 See the Microsoft-Windows-TWinUI/Operational log for additional information.
System errors:
Error: (02/09/2017 06:01:49 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}
and APPID
{F72671A9-012C-4725-9D2F-2A4D32D65169}
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Error: (02/08/2017 11:51:03 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
and APPID
Error: (02/08/2017 06:15:45 PM) (Source: Service Control Manager) (EventID: 7011) (User: )
Description: A timeout (60000 milliseconds) was reached while waiting for a transaction response from the Intel(R) Online Connect Helper service.
Error: (02/08/2017 06:14:45 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}
and APPID
{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}
to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
and APPID
and APPID
Error: (02/08/2017 06:14:18 PM) (Source: Microsoft-Windows-Kernel-Processor-Power) (EventID: 35) (User: NT AUTHORITY)
Description: Performance power management features on Hyper-V logical processor 3 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Description: Performance power management features on Hyper-V logical processor 2 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Description: Performance power management features on Hyper-V logical processor 1 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Description: Performance power management features on Hyper-V logical processor 0 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
CodeIntegrity:
Date: 2017-02-08 21:15:32.744
Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume5\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2DevProps.dll that did not meet the Store signing level requirements.
Date: 2017-02-08 21:15:32.740
Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume5\Program Files\Nahimic\Nahimic2\UserInterface\x64\Nahimic2OSD.dll that did not meet the Store signing level requirements.
Date: 2017-02-08 21:15:02.069
Description: Code Integrity determined that a process (\Device\HarddiskVolume5\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume5\Windows\System32\nvspcap64.dll that did not meet the Store signing level requirements.
Date: 2017-02-08 21:15:01.957
Date: 2017-02-08 21:15:01.951
Processor: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
Percentage of memory in use: 18%
Total physical RAM: 24535.98 MB
Available physical RAM: 20104.44 MB
Total Virtual: 28119.98 MB
Available Virtual: 23181.26 MB
Drive c: (OS) (Fixed) (Total:465 GB) (Free:172.98 GB) NTFS
Drive d: (HDD ) (Fixed) (Total:1862.89 GB) (Free:1439.67 GB) NTFS
Drive e: (My Passport) (Fixed) (Total:931.48 GB) (Free:532.9 GB) NTFS
Remove the following programs.
Use Geek Uninstaller, if something will not go use Force Mode.
I'd like you to substitute BitDefender with Panda Clod Free to see if that is the issue.
  • Download CCleaner from here.
  • After install Click Options.
  • Go to monitoring.
  • Uncheck All Monitoring items.
  • Go to advanced -- Click close program after cleaning.
  • Go to settings -- click run ccleaner when the computer starts.
  • Now that you have ccleaner installed and set-up:
  • Open the program.
  • Go to Tools
  • Go to Startup
  • Now double click each item. To Disable.
  • Leave only your antivirus enabled.
  • Then disable All items in your scheduled task as well.
  • Unless they are related to windows defender.Or your antivirus.
  • Reboot the machine.
FRST Fix.
Click Here To Download Fixlist.
Download attached fixlist.txt file and save it to the Desktop. NOTE. It's important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.
Eliminate Bad Settings with this nice tool.
  • Download SupRestric.exe save to your desktop.
  • Close all running programs.
  • Temporarily disable the antivirus
  • Double click the file to launch it.
  • Windows: 7/8/10 Vista and run as administrator
  • Click Yes at any prompt.
  • The analysis takes only a few moments.
  • The report is on the desktop ( CTR.txt )
  • Copy paste report in next reply.
  • A reboot is needed to complete the repairs.
Adware Cleaner Scan.
  • Close all open programs and internet browsers.
  • Double click on adwcleaner.exe to run the tool.
  • Click on Scan button.
  • When the scan has finished click on Clean button.
  • Your computer will be rebooted automatically. A text file will open after the restart.
  • Please post the contents of that logfile with your next reply.
  • You can find the logfile at C:\AdwCleaner[S1].txt as well.
ClearLNK
Download ClearLNK save it to your desktop.
Drag the file ShortCut.txt from FRST scans made earlier.
As per picture.
A report on the work as a file ClearLNK- <date> .log
Will be produced, post that log.
Zhp Scan & Clean
2. Once you have started the program, you will need to click the scanner button.
3. Once the scan is completed, the you will want to click the Repair button.
At the end of the process you may be asked to reboot your machine. After you reboot a report will open on your desktop.
Copy and paste the report here in your next reply.
A reply from the OP Via Private Message.
So.... I actually just figured it out.
I was looking through my programs one more time and noticed a program called cFos Speed. So I looked it up and guess what... it's a ping optimizer and bandwidth traffic regulator. It must have come with the motherboard because I never installed it. Anyways do a speed test and get the same old 6Mbps/0Mbps. Then I uninstall it and bam... 170+Mbps down. I reinstalled the newer version just to make sure it wasn't the version I had and it went straight back to 6/0.
I was pulling my hair out trying to see if I had some kind of bandwidth limiting software and there it was right in front of me!
Thank you guys so much for spending the time to help me out, though! Cheers!
This issue is solved. :)
Reactions: spacedust
