Help in Troubleshooting my PC
gnosticChemist
7
24
With a help of my friend I build my PC 3 years ago, but since a couple months it started to crash, freeze and sometimes randomly crashing some apps (i.e. Discord)
The Windows blue screens keep giving different error codes ( IRQL errors are commom tho), I resintalled Windows 10 but still got this problem, and I can't recover my Linux boot because Live disks keep freezing too.
However, those crashes are fair less likely to occour when the PC is loaded, like when I'm playing game (i.e. Dead by Daylight or League of Legends).
I already run a memtest and GPU stress test with no problems, and I don't know what else should I do to try find and solve it.
The Specs are:
Motherboard: Asus Prime B450M-Gaming/BR
So other can assist let get a speccy report and some more information.
when you preformed the
How what method? Did you install the drivers in the proper order?
The Specs are:
Specs: http://speccy.piriform.com/results/UVHSSritafAgMYTKK4qEbsE
Power Supply: Corsair VS650 80Plus White 650W, CP-9020172
Publish without finishing, my bad.
I installed Windows 10 with an Live USB from my roommate.
For drivers, I download the Radeon software for the GPU and the rest I let Snappy Driver Installer handle it
However, I think it may not be a drivers problem since my Linux live USBs also freeze
Why you do not want to use third part crapware like that.
Did you make changes to the BIOS so Linux will load?
The change that are made in the BIOS will need to be changed back for Windows to work properly.
  • Love
Reactions: xrobwx71
eliminate the crapware
Download the proper drivers
Preform a System File Checker
Then install the drivers in the proper order starting with the Chipset and motherboard drivers.
If that does not work might want to look into a fresh install.
Not counting the fact that your primary drive is to small and you are quickly running out of space. Should be 250 GB to 500 GB minimal and that still depends on what the system is used for.
Partition 2
Partition ID: Disk #0, Partition #2
Disk Letter: C:
File System: NTFS
Volume Serial Number: 74D179A2
Used Space: 56 GB (50%)
Free Space: 54 GB (50%)
Way to small for windows needs.
For Windows to be able to run efficiently and to be able to update windows requires 32 GB free space on C drive available at all times, if you don`t you risk Windows becoming corrupt or not being able to update which puts you at risk of malware attack.
Then there is also reserved around 7-20 GB for future updates.
The less space you have the harder the drive and more issues you will have.
Done.
File System Check found corrupted files, log is linked (CBS.log).
Yet the crashes continues.
My friend run some Prime97 CPU stress tests and it got errors ("Prime95 rounding was 0.5 expected 0.4" with some variance on the 0.5). We searched info about it and found out "Rounding errors in Prime95 usually are caused by low CPU or RAM voltage.", so we tinkered the RAM and CPU voltages on the BIOS until we get error free on 4 consecutive tests with 10 min each.
Our ending configuration was leaving RAM voltage unchanged and increasing CPU voltage by 0.075V. It's been running for 3 hours without crashes, but I think it's too soon to call it solved.
He says maybe the problem is on the CPU and auto-overclocking, and that it shorted the CPU lifespan.
Also, I would like to ask if it would be better to put Windows on the HD with a bigger partition, is it worth since I would loss the SSD speed? Windows on SSD still felt slower than HD Linux.
Bad PSUs are a pretty common source of BSODs and power related faults, what PSU does your friend have?
What PSU does your friend have?
As he says, "Apex Gaming, 800w 80plus gold"
It didn't crash anymore, neither underloaded or overloaded.
Today I recovered my GRUB, but Ubuntu boot freezes. It happend before, I already got help on a forum sometime ago but I didn't have time to check if it's the same issue or a different problem. If anyone curious this is the thread
