Hello again. I use my new Dell with Windows 10 Pro for offline work only. I turned off Wi Fi but Windows still gets through. The latest was where it did a scan and indicated it had done it a total of four times.
I go online then into network settings...change adapter settings but when I double click the Wi Fi, then to properties, connect automatically when in range is unchecked. How in blazes are they getting through? How can I stop Windows from turning on my WiFi for them? Might this be a firewall issue?
Thank you.
Thank you.
