Help (custom gaming pc)
Josh Martin
33
-Game max Falcon White Pc Gamimg Case with RGB fans.
-Corsair CX650M Semi-Modular ATX 80 PLUS Bronze power supply.
-Battle Hard i5-6400 CPU 4GB RAM Gold Motherboard & Processor Bundle.
-Asus GeForce GTX 1050ti ROG Strix 4GB DDR5 Graphics Card.
I cant tall if its all set up right since I don't yet have a dvi cable and the front rgb fans wont work
To ensure everything is correctly connected, would it be possible for you to get a few more picture?. Eg the front and back. The fans you need to get working. Also a more close up pic to the connections on the mobo.
Not heard back from you Josh Martin, do you still require assistance or is the issue now resolved, an update would be appreciated.
