Solved Help, black screeb
Roseanned
43
My desktop froze up on me. I forced shut off. When I turned it back on I just get a black screen. No cursor, no visuals whatsoever, no beeps...nothing... I tried the 3 start and f8 methods I read about online and no results. Any ideas on what I can do?
It could be your video card has failed.. When you are referring to those beeps,do you mean the mobo beep?
@Bruce
did the PC ever beep at startup?
if it did, it would have been one beep every time.
and when you tried the 3 reboot attempts and F8, what was the outcome? anything on the screen?
what is your OS?
So it turns out I'm a dummy and didn't check the monitor first. Unplugged the monitor, plugged it back in and it's all good now. Thanks!
