Help - again
plodr
1,020
173
As I've posted quite a few times, I have lots of issues with this site. The latest, unable to upload an avatar.
Look at my screenshot. On the left, my profile here with the word avatar no where to be found. On the right my profile from MajorGeeks which uses xenForo forum software.
I was able to remove my Christmas avatar because the word appeared once. And now its gone again. Any suggestions? I switched from Palemoon to Cyberfox and it is also missing in that browser.
Here's the avatar I was using
THANKS! to whomever fixed it.
I've tried FF ESR and currently on IE and still the word avatar is missing so it isn't just a browser issue, I suspect because I've tried 4 different ones.
Hey plodr,
Sorry about the issues you've been having. I manually applied your avatar.
When you tried to change it, did you encounter any errors?
All I was able to do was remove the Christmas avatar. No errors.
But since then, I've never seen anything about uploading an avatar so I had no way to upload my old one.
