Solved Headphone and PC hissing noise
Zaq
5
23
whenever I am playing minecraft my headphones and PC make this hissing noise not so much in my PC but you can kinda hear it.I can hear it quite loudly in my headphones sometimes and it's really really annoying, this has only been happing a lot when I'm playing minecraft but whenever I close the game the noise stops completely. Anyone know why this could be and how I could possibly fix it? :/
some users experience issues playing Minecraft while using a mismatched version of Java for their operating system (32 or 64 bit), while using certain versions of Java 7, or while multiple versions of Java are installed.
Check your Java version.
I have Java 8 Update 121 (64-bit) and Java SE Development Kit 8 Update 121 (64-bit) my system is 64bit
Pretty sure it's coil whine actually, I looked it up and th noise sounds exactly the same, it's only noticeable when I'm getting over 800-1000fps on minecraft I turned the fps limit down and it seems to have stopped, every other game is fine :p
Hey sorry I haven't replied, the noise isn't there much anymore, like I said the only time it makes the noise is when I put my fps on unlimited if I don't, the noise goes away. :)
