back then i was trying to clear storage , end up i delete essential system in arch linux , when i tried to install it again it had lots of achi error ( which is common and fine to not care ) and then crash , buy new motherboard, install a windows 10 , works fine , but then i wanted linux
i tried downloading nixOS but in the middle of installing process , but it stuck on mounting tmpfs, later i found that the error "cannot find tocblock database may be corrupt" apparently is trying to delete the windows 10 disk system but it can't says on google , some people say disable the cms step in uefi but is too late
after i upgrade my hdd , but this time everything feel slow , even getting into a bios is a bit slow than regular , i tried install nixos it failed , same error , so i run my windows 10 and the loading time is very long so tried restart the computer , and then the screen is black no signal and i done
- removing and installing the graphic driver
- trying to install a window 10 using bootable usb
- removing and installing ram
- bios reset trough cmos battery
- removing disk into only ssd
- removing disk into only hdd
- removing ram
- removing GPU
- removing processor
i'm apologize if my grammar is bad , let me know if there a weird typing i will fix the best i can , and please help me im suffering , nothing work
- removing ram
- removing GPU
