Solved GPU with white PC build
napadaanlng
3
32
I'm looking for any white GPU with my all white PC build and I'm planning on getting KFA2 GeForce® GTX 1050 Ti EXOC White
But I dunno if this will bottleneck my system?
Anyway here are my specs.
-AMD A8-9600
-Gigabyte A320M-S2H
-T-Force Delta 8GB 2400 (white)
Thanks
PS: This is my my first build and looking to maximize the specs I have.
Hello napadaanlng,
No, its 8gb(1x)
The "KFA2 GeForce® GTX 1050 Ti EXOC White" video card that you mention would not cause a bottleneck but your single 8GB stick of RAM will, explanation, your RAM will be working in single channel mode which equates to 1200MHz at best, two Xs 4GB sticks would = 2400MHz and therefore not create a bottleneck.
The crux is, CPU and GPU are ok, single stick of RAM is not good I`m afraid, hope this helps and any questions let us know (y)
Hello napadaanlng,
Thanks!!!! Lastly, will a 8GB(x2) DDR4 2400mhz remedy that bottleneck? As also I'm trying to maximize what I have and avoid replacing parts as much as possible.
Your RAM being able to run at 2400MHz as opposed to being restricted to 1200MHz will most certainly be more efficient.
