GPU help pls
Rhyve
19
so today i wanted to sell my gpu but i decided i want to sell it all together but now my gpu is out of the computer case and i have no idea how to put it back it
Ok match the gpu card with the correct slot.. Any slot that matches the gpu card copper contacts with the correct slot space ( or the cut out portion of the card) . Place card in slot and gently push down until the retainer snaps and then it is locked into place.. Make sure you align the metal part with the screw hole on the back of the pc put in screw and don't over tighten the screw and you done.
