Generic PnP monitor Resolution lock
IsaGow
38
25
Using a GL2450 BenQ monitor for months now with no issues. suddenly today after doing a driver update it locked to a low resolution. I have tried rolling back restarting checking for updates and uninstalling and reinstalling PnP drivers. with other monitors, there is no issue and if I start the pc with another monitor and switch it over it works but as soon as restarted the issue happens again. any ideas on what I can do? thanks.
See if using DDU helps.
Make sure to Download the driver that was installed before the updated one that you installed.
yeah that hasnt seemed to work
What is the brand and model name or number of the PSU.
