Solved Galileo Pro Android 6.0 Stuck in Fastboot Mode
I tired holding the power button down but it won't power off so It like I can't do a Factory Reset. Should I just wait for the battery to run out of power then try booting it again w/ it charging?
Why not turn off the fastboot?
Go to settings, then battery. The check box for fastboot is at the bottom.
Go in to Settings
then System
then Reset
It may also be under Backup and Reset
Not to argue:) but I can't do anything until the battery dies out that includes changing settings.
I have an alarm set to go check on it @ 4:25pm since I ran into it @ 10:??am & it box says the battery lasts for 6 hours.
