GA - F2A88XM - D3H does not POST;PSU briefly powers on then off
  • Thread starter Thread starter R Jon
  • Start date Start date
R
R Jon
Hello PC Forum members,
I have a problem with a Gigabyte GA - F2A88XM - D3H not POSTing;PSU is new with 8 pin CPU power connector and 24 pin main power connector both snugly seated (I have a discrete gpu card installed as well as AMD A10 pu with integrated gpu)...but after checking everything (the new PSU powered another amd chipset mb with no problem mind you...)for loose connectors i powered the PSU on and pressed the pc power on switch but just got a brief flash of the PSU LED light then it would not power on!!?!!
If anyone knows how to troubleshoot the above model gigabyte MB ... please educa
te me how i may fix this issue DIY style??
Assemble the system outside of the case on a thick piece of cardboard.
Using the bare bones see if they system will finally complete power on.
If the same result, then replace the PSU.
Post complete specs makes and models are helpful to properly diagnose system issues including the PSU.
